PDA
View Full Version : Classic RC Pattern Flying
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18
  1. UGLY STIK TIME CAPSULE
  2. What is it?
  3. Received ST G60 ABC Bluehead's Today
  4. My Carolina Aircraft T2A MKII arrived
  5. What is the typical Right and Down engine thrust for pattern planes?
  6. NOS Super M's
  7. Old enough to remember Pro-Line Radios ?
  8. Help? I need plans!
  9. Knoxville TN Pattern Meet
  10. No School Like Old School....
  11. Power choice question, which 60/61 for UFO?
  12. Great Planes Tiporare
  13. Engine Expert's - Need Opinion
  14. Bob Reuther-Tom Moore/Vertigo II SPA legal?
  15. Classic Pattern Kit Needed
  16. Why wont my Kaos spin right
  17. Who's The Best Kit Cutter for Classic Pattern Planes?
  18. what happened at the southern In. spa event
  19. MK Aurora 90
  20. Does the SPA need another class?
  21. King Kobra's CG
  22. Vertigo II Build Thread
  23. D'Best Photo Page...
  24. Rhett Miller Compensator
  25. Is Huntsville BPA still on?
  26. YS 1.40'S
  27. Peppermint Pattie ?
  28. dual elevator pushrod setup
  29. Diagram of SPA maneuvers
  30. Kato Model Aircraft
  31. ops speed 60
  32. ABC or ringed?
  33. EU1A
  34. Tiger Tail build thread
  35. Finish the Phoenix
  36. Curare Ready, Throws?
  37. What engine and CG for Atlas?
  38. Which Kaos is this?
  39. Name the Plane
  40. Classic Pattern Event comes to Midwest
  41. Picco .60
  42. Triton
  43. Carolina Aircraft
  44. HYDE MOUNT DIMENSIONS
  45. Javelin II
  46. Beechcomber
  47. Know These Guy's ?
  48. Bridi Deception
  49. Canopy ID ...
  50. Class II airplanes
  51. Thinking about pattern flying
  52. Minare - German Translation Please
  53. Looking for old pictures
  54. EPA or Dual Rates which is better for set ups:
  55. Start to Finish Phoenix VI
  56. question about CG and using weight
  57. Anyone on here coming to the Vintage contest in Nov?
  58. Atlanta 60 Instructions (PDF)..
  59. Early R/C Nutcracker
  60. C.G for Atlanta 60
  61. Does anybody kn ow the e-mail of the Phoenix 8 designer "Don Lowe"?
  62. Argentinian Pilot of f3a "Daniel Falco"
  63. I need a YS120 Exhaust Pipe Nut
  64. HANNO SPECIAL ENGINE
  65. prop size differences
  66. Webra "F" Series .61 Is this a long stroke?
  67. Thunder Panzer
  68. how do you feel about the maneuvers for next year novice?
  69. PHOENIX 8 PLAN
  70. Aztec Air Summit III and LA-1..
  71. New Planes Available Curare II Ect.......
  72. Does anyone know Ugly stick what ones legal?
  73. RCM pattern plans
  74. Peppermint Pattie build
  75. Tower Hobbys Kaos ARF help
  76. MK Retracts
  77. Ed Kazmirski's Taurus
  78. Webra ID
  79. name the plane
  80. Negative diehdral stabilizer
  81. Hanno Special info required
  82. Fuel Fed Problem
  83. SPA
  84. Power of SPA legal engines 2Cycle
  85. Well got my first pattern Plane
  86. Name this airplane Please
  87. What IS or SHOULD BE "Classic Pattern"?
  88. Revenger flight after 30 years
  89. atlanta 60
  90. Revenger
  91. SPA Planes
  92. Super Kaos and OS 55ax??
  93. Southern R/C Alley Cat HELP
  94. What all pattern planes are Kitted out there?
  95. if you own, or have owned a utter kaos read please
  96. ASHEVILLE SPA CONTEST
  97. Meridian restoration
  98. When was this PLANE MADE?????
  99. Rossi 60 ABC in Phoenix VI
  100. MK Arrow
  101. Phoenix VIII
  102. Phoenix VIII
  103. Just wanted to say hello
  104. Before the Brushfire there was...
  105. What ever happened to pica?
  106. Rossi Phoenix
  107. My New Curare
  108. Question about propellers
  109. Sig Kobra
  110. Picco 80
  111. Putting together Classic Pattern Plane list
  112. WM Intruder 90 prop?
  113. burning plane....
  114. Misbehavin'
  115. Need Help w/ Miss Norway
  116. Bridi UFO conversion to tri-gear
  117. Name the plane
  118. Will O.S. 1.60 handle it?
  119. Where to find Tiporare plans?
  120. Troubelmaker
  121. Ideas for a new project
  122. What is this?
  123. O.S. .61 SF ABC info
  124. Knoxville SPA pattern results
  125. ys 91 4 stroke for an LA-1?
  126. RCM Xpert
  127. FK SBA 60 Speeda - Build
  128. li'l honcho
  129. MK SkyMaster 60..
  130. RCM - February 1985 Issue...
  131. pattern/pylon
  132. Classic pattern for .20 cu.in
  133. What is it?
  134. Good modern 60 side exhaust for Dirty Birdy?
  135. Ideas for an inverted engine Kaos 60
  136. An incredible discovery of new Rossi .61, Rhom and Pro-line retracts and parts...
  137. WM intruder questions/problems.
  138. What year was the Dirti Birdi designed?
  139. TH KAOS MOD'S
  140. Virginia SPA Contest Question
  141. Finishing a Cajun R/C Tiger Tail IV
  142. Phantom 1 plans?
  143. Phoenix V FYI
  144. In-Flight Mixture Control
  145. Woohoo! $84 YS-61 AR with pipe and header.
  146. Super tuning??
  147. New to pattern, is SPA the only Classic pattern event?
  148. S&W Carbon Fiber Tuned Pipes ... Any Interest??
  149. Bobcat Plans from AMA?
  150. Auction Finds
  151. painting canopies
  152. Gator Tiger Tail 4S
  153. Looking for Tatone mount
  154. Andrew MiniMaster Plans
  155. Electric Kaos
  156. Hammer
  157. Curare 20
  158. ARROW FLAPS & SPOILERS
  159. novarossi 60
  160. Returning to RC after 30 years
  161. '65 Worlds
  162. MK Topstar, covering question
  163. Alabama SPA ??? How'd it go??
  164. Super Curare vs. Curare
  165. SPA/BPA Contest in Miami
  166. Taking Orders For **YS-AR** Piston and Liners
  167. Help with ID Please...
  168. Ultrasport 60
  169. YS 60
  170. Guess The Plane!
  171. El Camino Vs Kaos
  172. SUMMIT III Need the CG Location !
  173. Marabu
  174. Spring air retracts
  175. What is this Plane?
  176. SUPER kAOS mAIDEN
  177. Banshee power plant
  178. some old pictures
  179. MK NOSE STEERING CONTROL ARM-WHERE TO GET ONE???
  180. ATLANTA 60's FIRST FLIGHT IN YEARS
  181. What have I done.
  182. have plans can you help with article
  183. Citation .60??? .60...really?
  184. Crankpin's Intruder's Finished X 2
  185. ???Bootlegger???
  186. Intruder Plans ?
  187. SOUTHEAST FLORIDA SPA CONTEST ???
  188. Help cleaning a OS-61 RF-P
  189. Foam Core Wing Question
  190. Crankpin's Twin Intruder's, Almost
  191. hanno motor
  192. Calypso Build
  193. Perry Pumps
  194. My Latest Find
  195. Graupner Kwik Fli MKIII
  196. hours of fun!
  197. A Blast from the past
  198. Alabaster R/C SPA Contest Results
  199. Alabaster RC SPA pics!!
  200. A Discussion on Servo Usage
  201. Hatori pipe identification
  202. Mach 1 , Does it need right thrust?
  203. What is this Plane? Consensus says it is a Deception w/ Mods.
  204. TigerTail
  205. '80s Mallory Models 1/4 scale Laser 200 wings
  206. prather panther
  207. Older Rossi engine parts...?
  208. Fliteglas Pagan MK II
  209. Is the Typhoon 900 a BP plane?
  210. Here's another Airplane that needs a name
  211. Fort Worth Vintage Pattern contest
  212. Bluejay XLT question
  213. SPA my way - Kaos
  214. Miss Norway
  215. Help Identifying this Older RC Airplane
  216. FLORIDA Vintage Pattern Association
  217. Peppermint Pattie for SPA / BPA
  218. Need better weather
  219. Electric SPA plane
  220. Taking Orders For Hanno Piston/Liner Sets
  221. OS 61RF-P and Hanno Piston & Liners
  222. Another Tipo
  223. Pictures: Bob Violett-Dubb Jett
  224. Original King Altair ?
  225. Question......How many sevros you use
  226. The Bridi XLT kits are in stock at Bluejay!
  227. Tower Servos?
  228. My DEPS Solution...
  229. Foam core ?s
  230. New build, Bridi Utter Kaos 60 size w/ retracts
  231. Maiden Flight of my 21 Year Old Tiporare
  232. Blue Angel 2 Build
  233. cg on a dirty birdy
  234. After Run Oil For 2 & 4 cycles
  235. XLT
  236. Omega 60/Zigsaw/Golden Gate Hobbies
  237. DO YOU KNOW THIS MOTOR MOUNT????
  238. Thinking about returning to Pattern
  239. my old glass fuse
  240. Name the Plane
  241. MK Beetle offered to me
  242. Peppermint Pattie 25 yrs later
  243. Dream 50 pattern plane
  244. Dead Aurora....
  245. 1975 Pattern World Champs - video
  246. fiberglass fillet question
  247. Tiporare LG Question
  248. Name That Plane (Fuse)
  249. HELP? EPOXY OR FIBERGLASS RESIN TO ATTACH SERVO MOUNT
  250. Help identifying old plastic pattern plane
