View Full Version : Batteries & Chargers
- Charging Lead Calcium 7 AH battery
- Glow Igniter Fast Chargers, Is one better than the other?
- Blade 400 AC Charger
- Dx7 replacement battery trouble
- General question re LiPo charger/connectors
- a123 battery help
- Venom Problem
- One cell wont complete charging...
- Charging Stand
- LIPO shrink wrap?
- Blue Lipo Battery
- lower volt vs higher volt
- 0 volt cell in 2s
- "BIG" battery advise
- Lipo battery announced for public testing
- broken wire
- Would this be a good FIELD Charger??
- where to get battery shrink wrap
- 5C-8C charger batteries
- Continued Battery Life Problems
- Running two batteries to one receiver
- Correct Pinout ThunderPower 4S 6pin to Align 5pin?
- Hobbico Life Source Batteries
- loose wire somewhere in my lipo
- need charger help gt power A8 or imax b8 please help
- Lipo cell question on new (to me) batt
- Field box battery charger
- Thinking of making the move to BL and LIPO
- Will This Work?
- ran battery too low
- How to revive dead Ni-MH rc pack?
- HYPERION BATTERY
- New Turnigy 8150 Charger Comments
- Battery Not Working Right?
- SLK Elec. Inc. Good guy / Bad guy???
- HOW TO BUILD A123- LiFe batteries
- Help with original Triton
- Hyperion EOS606I trouble
- testing a niMh battery
- First charge on a new lipo mah reading??
- Duratrax Onyx 240
- Just bought a brand new charger and battery!
- A123 Packs for Rx: which connectors to use
- Using Different Capacity Batteries
- Thunder AC6 - cycle charge discharge
- 5-Cell NiMH & Piranha Charger Q
- I might have a dead cell, but not sure
- Thunder Power 1010C help needed
- Lipo Q's
- How do I know when my packs are fully charged??
- New charger for Blade 400 Helicopteer
- Charger/balancer ???
- venom reciever packs combusting?
- NIMH Batteries not charging correctly
- Dropping voltage from Acer power supply
- Puffy no more
- max of a 6v NIMH
- LiFePo4 Batteries
- e-flite male/female adaptors
- new&cheap&very powerfull but...
- Safe cheap lipos Safe cheap 10s Lipo Charger
- What battery and charger for SCX10 TR?
- Triton Jr. Question.
- Saving a Battery
- BATTERY QUESTION AND HELP
- LiFePo4 Voltages?
- ATX Power Supply Conversion
- question about my burned battery
- Why are A123 batteries not as popular as Lipo batteries??
- 2S 4600 mah A123 pack comments
- Team Great Hobbies Lipo batteries?
- did i kill a battery?
- Thunder AC6 same Turnigy Accucel 6
- About to purchase a high-end all around charger, need help.
- e-flight battery question
- HYPERION EOSO 606I CHARGER QUESTION
- Battman II Battery Manager
- RC Power BC6 Charger Power Supply
- NiMH Best Charging Practices?
- charger for sealed lead acid 6 volt
- Charge Rate on a Sealed Lead Acid Battery
- nimh batteries on nicad chargers
- Need basic help with NIMH charging/discharging rates
- A123 loose cells
- Bad news for Lipo users
- SkyCharger
- Will This Battery Fit?
- testing batteries
- charging outrage lipos
- battery pack swollen!
- Duratrax DTX 5000 exploded on first cycle
- Lipo Batteries
- Equipment needed to do a formation charge on 12V lead acid batteries
- Battery Fit
- Rustler VXL Battery Question
- graupner nimh 5 cells 2000 6v + 5645+r617fs
- Do I Need A New Charger
- FMA Multi4 Charger Error Code
- Looking for basic instruction
- Charging large mah LiPo's
- charger help please!!!!!!
- porta power industries charger old school
- Triton jr charger
- Lipo battery and charger choice
- charger for cycling for futaba 6ex
- battery choice
- Eneloop Rx Packs?
- hobbico life batteries
- how is this charger
- Should I sell or toss?
- multi bat charger
- Recommendation for charger with these in mind?
- LiFepo charging
- LiPo Storage?
- Batteries in Parallel - for use w/Jomar Twin Glow
- How long for shipping from Hobby King?
- 5000NiMh doing funky stuff any help?
- Need Help with LiPo Chargers and Batteries For Rustler VXL
- is this a good charger?
- Falcon batteries Predator Convertible
- Capacity Testing LiFe RX Batteries
- Triton2 and A123 cells
- Best Charger?
- Charger for NiCd & NiMH
- Can you run 2 8.4V Batteries in Series on the Traxxas E-Revo 1/16???
- who makes a good battery?
- 4S and 6S to make 10S or do they have to be equal
- Eneloop Batteries & Chargers
- What gives with these lipos just bursting into flames..
- Is anyone using the Imax B8 Pro Charger?
- Charging LiFe through switch
- LIPO balance lead extension
- General Battery Discussion
- need quick form charging answer
- Is this brand new Venom 3S 2100 bad ?
- Really Need Help With Charger Selection Please
- bad lipo????!?!?!?!
- ATX power supply for Turnigy Accucel-6
- Turnigy Accucel-6 NiCd question
- Who else sells Turnigy Accucel -6 chargers
- BATTERY CHARGER X2 LIPO'S???
- charging 2 batts thru 2 switches to 1 Rx
- 7.4 lipo vs. 8.4 nimh....
- how to form charge with a intellipeak digital pulse charger
- discharging lipos
- LIPO hitting 50% output Traxxas Rustler VXL
- li -fe batterys now avail at walmart.
- GOOD 6cell Battery 7.2 V for 1/10 scale buggy
- What is the lifespan of regular NiCd Rx and Tx packs?
- hobbico charger question
- understanding charging and discharging lipos
- USB Software for the Supermate DC6
- form charge question
- Lipo Voltage Drop
- Rhino 6s 3700 question
- Charging a Hobbico Hot Shot 2 glow plug ignitor.
- Need a diode for A123 100 on ign.
- What are you running?
- Cycling Batteries
- Bulb discharge with LiPo's?
- Accucel-8 balance plug
- 12Z battery charge problem
- lipo charging/storage
- Accucel-8 Where's the Lipo mode??!!
- what is 3s and 6s stand for in lipos??
- where can i find one of these cheap???
- how much capacity do i need?
- TX/RX charging question
- A123/Lipo Balancer???
- Dead RX pack...Kicking myself
- What could it be?
- Lipo charge & discharge?
- Charging 1s, 150mah LiPo
- Lipo won't charge fully
- 2/3A discharge rate?
- Lipo Battery Parallel noob question
- another dumb question, 20c vs 25c
- New Charger From FMA
- smaller voltage for larger voltage
- Anyway to save a cell that's reversed pol.?
- Monitor for A123 cells?
- venom 1800 question
- Amps in ballancing leads?
- turnigy lipo battery
- How to read and charg li-po batteries
- what is cycle a lipo battery, and why is it important?
- asize of cells
- Lamp timer for charging
- LIFEPO4 9.9v or 14v as fast as 11.1 lipo???
- More voltage or current?
- Battery help
- Field Cahrging Stations
- Reciever battery NO NO!!
- I am looking for a good charger
- need to buy charger
- Traxxas 1/16 Mini Revo Slash Supercharge 1300 Stick Pack NiMH 8.4v???
- Charger Recommendation
- A123 construction wire size question & more
- Killed my JR Receiver ???
- NiMh Rx battery charge ?
- Poly RC Lipo BLOWOUT!!!!!!SALE!!!!!! All Models need to go
- charger's
- How big deep cycle battery to charge 5amp lipos at the field?
- Lipo wiring parallel vs. series
- Supermate?
- ni cad rx pack 5 cells equals "6 volt" pack?? Correct??
- Charging AA's with Triton2 EQ
- esky battery wont charge please help.
- What size RX pack?
- HOME MADE GLOW DRIVER.
- battery temps
- Good Discharge rate for testing RX packs
- Battery wires made contact, battery ruined or damaged?
- Batteries up front?
- 6v ni packs more like closer to 7v ?
- Onyx 230 vs Triton
- Battery pack wires
- Using a wall charger to charge my RC submarine?
- BATTERY HELP
- Battery Charger
- Charging Lipo, blinking lights.
- Charging NIMH WITH GT POWER A6-10 No cell number to enter? CONFUSED
- newbie charger question, charger for 6S or 2-3S
- 20-24'extentions ?
- Correct charger for lithium ion 7.4v 2600mah battery
- NiMH max charge rate
- lipo extentions
- Trion 2 "Open circuit" Error.
- Death by storage
- accucel-6 and NIMH
- lipo charging question
- Sj Propo Absolute 3014 dual charger, - Where?
- Power supply?
- Three wires?
- How to charge batteries?
- Pro Peak Prodigy back screens ?
- bought 2 atx 400 watt to do a psu for my chargers
- NiMH Receiver Pack Minimum Voltage When New?????
- Charging Losi Lipos
- Accucel 6
- accucell connectors
- which battery is suitable use on Trex helicopter?
- accucel 6 charger question
- Checking a new A123 pack
- Battery brand question?
- Power supply problem
- AA NiMH's with ICE charger
- need to figure out load on battery ?
- Regulated Switch vs Switch + Regulator
