- Flaps
- Futaba 12FG - Rudder stick off center.....
- RCU Review: Futaba TM7/R607 2.4GHz combo
- 9C flap to elevator mix
- Latency of the Fasst Module system
- 12Z and MPDX-1
- Channel 10 on 9CHP
- FUtaba 2 DR range
- No dual elevators for 7c???
- Futaba S9350
- FPS131s servos
- 12 Volts on a 6EX
- futaba 9 channel 2.4 radio
- flaps down ailerons up
- Question about TM-7 frequency hopping
- 9C FASST
- 14mz problem
- 14MZ Stylus
- 4channels radio
- Futaba 9C - Map CH 7 to CH5?
- Installation protocol
- Question re-TM14 module and 6,7,8 ch rx
- single & dual conversion & 7 CAP TX
- Question of Charge and Discharge of NiMh inside 12FG Transmitter
- How do I use all 9 channels of my reciever?
- 12FG SD card compatibility issue?
- Changing 7C channel
- Please update: Futaba FASST System Deliveries - 6/21/2007 5:00:59 PM
- Bax.. please verify or correct if nesessary
- 12Z and "LOGIC" Help!!
- comparison chart
- differences in buying options.
- Futaba MPDX-1 Multi-Proportional Decoder 8-Channel
- 8EX 2.4 GHz TX GUID
- wht trainer cord=???
- 14MZ Battery Removal
- 9 CAFS to 12FG
- Futaba 6EX to 9Z buddy lead connection
- Need some help with a 14mz
- Futaba 9C
- 7C questions
- 12z pcm1024 question
- 7 uap super ?
- Question about 7CAP battery
- 14 mz battery replacement
- Futaba FASST inter-module compatibility
- 9C upgrade path
- F7CAP aileron+flaps
- 14MZ on 1024 PCM question.
- buddy box for futaba 2.4 6EX
- futaba 2.4 6EX
- 12FG Variable Resistor Mode Change
- 2.4ghz recievers
- 2.4Ghz modules
- A real challenge for my F/18 please help :)
- 5114DPS Recommended Range Check Procedure
- 14 MZ looses frequency
- 9C programming
- Krysta, Bax help me - 9Z Flaperon and 3 pos switch
- 12Z Vanishing Model Memory - HELP!
- Dual 2.4 Ghz Receivers on one transmitter?
- Are 2.4 gig Futuba radios functional in cold weather?
- fastest latency of 6ex fasst or 12 fg fasst?
- FASST 2.4 GHZ STICKER
- Skysport T4YF Buddy Box
- R5114DPS
- Fasst 9 ch
- Trainer switch delay
- Futaba 9125 slop
- 9125 digital servo and slop
- Another 9CAP buddy box question
- FASST RX antenna placement
- Futaba Heavy Duty Gimbal Springs for 14MZ
- Tailerons setup with 14mz. Help Please.
- 6EX Settings for Blade CP Pro
- 6EX 2.4 & 607 Rx's
- 6EX 2.4Ghz with R603FS Receiver?
- Heavy duty Springs for the sticks 6 EX 2.4G
- 6EX Fast Trainer compatibility
- 3PM 2.4ghz Model Select
- On Board Rx Performance Monitoring?
- modules speed how come as fast as not module?
- Changing chanels on a transmitter
- R168DP compared to the R138DP and R148DP
- Fasst's FHSS specifications.
- FASST 7+ channel failsafe options
- FASST 7 Channel Module IN 9C
- 35mhz and module or native 2.4???
- FUTABA FP-TK vs FP-TP Tx Modules - HELP!
- G3 RX 5014dps?
- FP-R129DP Crystal
- R148DP 8-Ch 72MHz PCM 1024 Dual Conversion Micro Receiver
- Servo Suitability.
- MOVED: Futaba 9CAP + Spektrum or FAAST
- 6EX Fasst & 7-8ch RX??
- FASST System Deliveries?
- TM-7 FASST Module
- 2.4 FASST receiver installation
- 8UAPS DUAL RATES
- Futaba GY401 question
- "Match Box" Functions on the 14MZ
- 12Z and 12FG questions?
- My Radio causing glitch
- Is this a sign of stripped servo gear?
- IMAC Plane Setup
- Low range problems
- 2.4 GHz dedicated radio systems and receiver compatibility
- Aluminum arms
- New S9156
- Master Reset for 9Z?
- 14MZ Butterfly Settings
- 12z 12FG +- Modulation
- FASST Modules
- When to expect 2.4GHz 7C delivery
- Fasst compatability
- Brushless Servo Question
- Help with 6XA!!
- Programming 9C for dual ail/flp
- Frustrated by Futaba and the 14mz
- 9Z switches
- FAAST, 9C & compatability
- 1 Airplane - 2 Radios?
- How old is this TX?
- Interoperability of receivers
- 9z Tx
- MOVED: Airplane rudder gyro
- Elevator problem
- Aileron setup
- 2.4 Ghz module for 9Z radio
- Lipo Battery for 9ZA WC2 transmitter
- Regulated power for 9150 servos.
- Futaba GV1 Setup
- 14mz update problems
- futaba fasst
- 6EX-2.4GHz Stick Tension
- Futaba 7CAP Fail Safe
- fast charging tx on super 6 EX
- Futaba 6EX-2.4 Ghz FAAST R606FS Receiver Antenna
- Registration for 14MZ Download Community?
- Futaba servo substitution
- Futabe2.4 gig FASST and jet issues
- Receiver problems?
- New 14 MZ V2 ???
- 14 MZ FASST Modules
- New (older) 14mz Receiver.
- 12FG FASST
- Futaba 9C Need Help/Ideas
- 9CAP Super issue
- servo info please
- 9C Super Campac memory transfer.
- Futuba Plugs / Connectors
- Trouble setting up GY-401 and s9254 tail servo
- Transmitter Balance
- S-148 Servo gears and grease
- 7CAP and Crow problems, please help!
- 12FG Special Software
- 3114 BIG disappointment
- 9Z WCII - Condition help!!
- How Do I Set Up a Multi-Point PMIX?
- 9c Subtrim setting changed by EPA setting
- Range problem
- Faast module speed for 9C
- 3PM overseas?
- In What Country Are Futaba Radios Manufactured?
- NiMH and Futaba Servos
- 6EX FAAST
- Futaba 14MZ and Jet issues!!
- Futaba Super 7 UAP programming
- Futaba Servo voltage question
- 12 FG 2.4 antenna
- 9Z WCII - Help 9Z owners - LCD Screen
- Ground use systems
- BAX,.....is my 9Z WC2 "non serviceable???""
- I have a new
- 9Z synthesized module abuse
- Can the DSC port on a 319 DPS reciever be used for power?
- 6C FASST 2.4gig Jet questions
- 8uap with broken gear switch
- 9CAP: trainer switch defauls to OFF
- 7C PACKAGE
- 1/4 scale vs standard size servo amp draw?
- 9CAP Programming question
- R153F receiver question
- 9CA buddy box problems
- 9C
- Flaperons on 4 ch Rx
- Dual elevator servos
- 12Z Servo Sync issue
- AM or FM ?
- noobie need a suggestion
- futaba 9cap
- 14mz fast charger
- Charging a 12FG
- Multi-Point Curve On PMIX?
- Proportional Smoke Pump Control
- flaps
- Range check with a synthesized module
- Chan 04 Crystal
- which is best for my Futaba 6chnl 2.4mhz fasst??? battery power?
- old FP-T6NFK TX, looking for compatible micro RX
- can i use Futaba 6ch fasst 2.4 mhz in a large gas plane??
- 6EX-2.4GHz channel assignments
- Can I change futaba 6 ch 2.4 mhz ????
- Center me Gimbols!
- Will a TP RF module work in the 3PK radio?
- Burn-Rate
- Option of Line-Spline and VTR Curve Mix
- 12Fg with R5114DPS
- 601 Amp backplate pn?
- How to setup T9chp with Blade CP Pro
- DSC PINOUT
- Problem with Futaba 12Z system
- Radio woes
- 2.4 14MZ antennas
- Throttle Failsafe??
- GY601 problems!
- 12Z 2.4 Module vs new 2.4 12Z System ?
- Futaba 3PM 2.4GHZ FASST radio question
- syncronizer MSA-10 question
- TM-8 module with 9zwcII ?
- Receiver for 1994 Futaba Skysport transmitter
- 7CAP mixing
- Servo specs/Old servos
- 12zhp tranny
- 6EX-2.4GHz FASST and 6 volt battery
- FAAST MODULE RE 9C
- 14 channel FASST rx
- T7CAP Odd behaviour
- Futaba 6EX European Version
- Digitals and a R127DF
- 2.4 7C
- 6EXAS? or 6EX? Help please.
- 7cap mixing problem
- 9C/9CS Synth. Transmitter and non Synth. recivers
- Is the 9C soon to be discontinued?
- 9ZAP WCII - Service menu
- Futaba trainer system question
- Differential thrust with 9CAPS & 5-Ch receiver, possible???
- How to set failsafe in HRS mode-3PM 2.4 Fasst
- 9252 Servo oscilation on UCANDO 46 Help!
- Futaba S9301 info Spec...
- 12fg from futaba
- Servo Test under Servo Monitor of 12FGH
- Futaba 3PM 2.4 FASST
- Flap --> Elev mix on 14MZ
- 12Z ugrading Software?
- 2.4 FAAST Receivers
- Futaba 7CAP battery
- Whats the difference in Limit and Travel???
