View Full Version : Futaba Radios Direct support forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40 41 42 43 44
  1. 9C Trainer Setup Problem Please Help.
  2. S3103 vs S3108
  3. problem with futuba 6exa
  4. Changing Rx Freq.
  5. Buddy box control switch
  6. throttle curve
  7. TX/RX Compatibility
  8. MOVED: Futaba Servos
  9. 50 MHz synthesizer
  10. Using 9C sliders to change top end rotor pitch on heli
  11. I don't get max throw
  12. 6 EXA diode question
  13. FUTABA 12 CH. WHEN?
  14. Please Help
  15. Campac 64k
  16. Dual rates on the throttle channel
  17. 9C + Spirit 100 & 550 Can
  18. Is A Regulator Required for 6v Batteries
  19. Changing Module on 9C
  20. 9CAP PCM data transmission. *Binary codes & signal etc.*
  21. 6EXA Programing/buddy box
  22. Where are the 9351 servos?
  23. Polyswitch for 9Z?
  24. TX XTL (FUTABA FP-T4NBL
  25. Noise Traps/Chokes
  26. Futaba 6EXA "Buddy box"
  27. Adding Charging Connector to Futaba Transmitters
  28. Servo options
  29. MOVED: Webra Nano S6 Rx
  30. 9C butterfly/crow/throttle cut?
  31. MOVED: Futaba J to Airtronics Z
  32. Futaba 9C GLID2FLP v-tail bug?
  33. Servo s3050/s3151
  34. 50mhz to 72mhz conversion.
  35. Two batteries on large aircraft
  36. Idle problems
  37. fried servos
  38. DSC receiver port / Futaba R149DP PCM
  39. 9VAP question
  40. Programming an 8UAFS
  41. How to Idle up on 9C
  42. 6exa problem
  43. Spoilerons/Flaperons on switch C
  44. Extra Washer in TX?
  45. BB conversion for S-148?
  46. Mixing and Matching Radio Components
  47. Futaba T4YF Battery Meter??
  48. Stupid ? on 9C
  49. Programming 9C with antenna collapsed. Oops?
  50. RECEIVER XTL ????????
  51. Antenna length
  52. Control Horn Differences
  53. Reciver battrey pack
  54. 9ZAP WCII: Setup for CAliber 30
  55. 9ZAP WCII: change Mode from 2 to 1
  56. Futaba Rx JR Battery
  57. 9ZHP WC2 Tachometer function
  58. servo jitters
  59. 9C synth module
  60. Rudder Dual Rates with 9C and a GY401
  61. FP-8SGHP question
  62. MSA-10 endpoints vs throw adjustments
  63. Does Futaba have any plans for the future?
  64. Help futaba s9303 servos
  65. FP-R127DF Receivers
  66. Dumb question!
  67. where to buy grip rubber pads for a 3pdf
  68. Rudder to Rudder
  69. Futaba 3pk Display Problem
  70. 9C flap problem
  71. PCM with Pilot Assist 2
  72. Fut S-34 goes past neutral
  73. Single Conversion RX with 9C/9Z
  74. Futaba 9Z and Hitec Servos ???
  75. Quick 3PK question. PC-link?
  76. 6V?
  77. TX/RX & PPM/PCM
  78. Synthesized Futaba & Servo Recemondations
  79. Metalic films and Rx antenna performance
  80. Need Futaba Servo Recommendations....
  81. Unsealed screen cover on 9Z WC2
  82. CCPM Servo for fury extrem
  83. S3305 and NiMHs
  84. Can I trust my fuel soaked RX????
  85. Please explain the use of the"NORMAL" "DUAL" and "LINEAR" Gyro modes.
  86. Servo Jitters
  87. Which Gyro?
  88. Question on Futaba 149DP RX...
  89. 9Z transmit problem
  90. Futaba Super 7 Question
  91. Why is Sky Sport 6 same price as SkySport 4?
  92. T3PK FM Synthesized Receiver Modules?
  93. Problem with Futaba R149DP receiver
  94. 6XAs Battery Charging
  95. Futaba rebate
  96. ailervators to knife edge mix problem 9cap
  97. servo tray? ...I don't know
  98. Futaba S3151 Digital Sport BB MG
  99. Discharging FP-4NBF tx battery pack
  100. R138DP PCM Reciever
  101. MOVED: this could change my life if its possible !
  102. Futaba 9451 servo matching
  103. Newer 9XX TXs only have 8 channels
  104. Ailevators and 9c
  105. battery power failure to Rx and servos
  106. Magnum 2PL "Dual Rates" ?
  107. 9zap wcII Throttle Detent Replacement
  108. Two Zaps Tuning
  109. 9zap cam pak
  110. Best way to range check with 9Z
  111. FP-S134
  112. Upgrade to 9c
  113. Having trouble with Futaba 8uap
  114. Boat receiver and servo recommendation
  115. 40mhz Module?
  116. 9 C Pin?
  117. 9Z Discharge Cord
  118. Futaba Servos FP S133
  119. 9351 Availability?
  120. Question for Bill Baxter...
  121. Futaba T3PK - HRS Mode Information
  122. change from 75mhz to 72 mhz
  123. Does AM module may plug in my 9c?
  124. RX aerial length
  125. Futaba 149DP Antenna replacement or repair
  126. Tower System 3000 Rx antenna cut in half
  127. RX crystal question
  128. New pot for a Zap
  129. 9C Programming Question for Turbine ECU
  130. 9C Programming for 8 servo Operation
  131. PPM control system info needed
  132. Problems with flaps in Flaperon on Futaba 9CAP
  133. Urgent 9Z question
  134. Futaba ofst, what is it? Manual puts me to sleep
  135. Synth module for 9C
  136. Which Modual for 9C. Confused
  137. Buddy box setup, T6XA and Conquest
  138. Stick Tension on an old Attack-4TNBL
  139. reversed polarity to tx?
  140. 9303 gears
  141. AM futaba problem
  142. Radio tuned for channel 38
  143. can't find the s9351
  144. intermitant throttle with 3PK
  145. Reversed polarity?
  146. crystal installation question
  147. Checking Voltage on 4VF
  148. New 6xas help
  149. Futuba T3PDF - 3 Channels
  150. Problem FF6 xs
  151. 9Z ATV Limit on CH5-8
  152. 401 gyro
  153. FM Reciever
  154. 3pk question
  155. Peso
  156. FP-T6FG/K AGAIN
  157. Tune up on 6xas in Canada
  158. Fautaba trainer switch
  159. 8UAFS 120 CCPM mixing?????
  160. battery
  161. Programming 6 servo plane with 9C
  162. With a Buddy box, what powers what?
  163. Futaba skyport 4 (old style) battery connector
  164. Futaba 3pjs pcm 75mhz - crystals?
  165. Futaba 9CAP in Europe
  166. Older radio compliance?
  167. S3010 Servos, only 6.0V??
  168. Flaperon on T6XS
  169. 9cap battery
  170. 8UAF glitch/malfuntion?
  171. GYA352 Question
  172. Futaba 9ZAP Wc2
  173. Buddy Box/Dual Rates/Expo
  174. 148 DF Question
  175. 9C to 6XAS training setup
  176. 9CHP Question?
  177. SkySport 4VF trainer switch?
  178. Change from negative or positive shift to the other??
  179. Antenna Length and guage Futaba 72mhz?
  180. Trainer Cord Compatibility
  181. Futaba 6EXA
  182. Futaba digitals
  183. Futaba Snap roll switch programming
  184. Did I hurt my radio gear?
  185. Flap programing on the 9c
  186. How to set up push-pull rudder servos...
  187. 8UAP Flap Programming
  188. futaba fp-r102gr
  189. 3pk help
  190. Futaba Recievers
  191. 9Z parts
  192. Servo Oscillation
  193. Ultra Stick - Quad Flaps with 6XAS
  194. Square plug trainer plug question
  195. Futaba 7UAF Transmitter Fuse
  196. Mode change on stick is it costly???
  197. 9C - Timer Question
  198. 9C Manual Online - Not online?
  199. About this Forum
  200. How to return for repair service
  201. 9CAP Hand Grips
  202. Replacement rubber backs for 9ZAP.
  203. 9CAP_Glitch
  204. Futaba 3010 Servos--How much play is too much?
  205. R148DP Question
  206. 6XAS Flaperon Question
  207. Futaba 9C
  208. 9202 Servo - How much torque and speed, really?
  209. Futaba Customer Service
  210. Receiver repair and servo connectors
  211. Newbie Mixing Question
  212. 6xas mix??????
  213. 9ZWCII stick question...
  214. 6XAS transmitter
  215. Futaba FP-R148DP rx question...
  216. Futaba 9C & Slimline "Showtime" Smoke pump
  217. Info on Battery Eliminator Circuitry RX.
  218. futba attack fp
  219. US 72 Mhz to Australian 36 Mhz
  220. Futaba R127DF FM 72MHz Low
  221. 9Z - Ail Diff and Flaperon
  222. Skysport 4 Nicads
  223. 9C: Setting spoiler/flap to kick in @ 3/4 elevator throw?
  224. Transferring models from 8 series to 9 series and 10x v. 9Z
  225. futaba glitch
  226. Mixing a 9CA while flying
  227. Reversing a servo internally for dual elevator application
  228. 8 Super TX with Multiplex Brick RX
  229. Need both nylon gears for S9206 servos
  230. 9z Wc2 Problem
  231. How to mix dual elevator servos on 6XAS
  232. tx frequency change
  233. Real Flight G2 TX Interface Cable as buddy cord?
  234. Mixing elevator to flaps with the 9C
  235. Futaba 6EXA flaperons? Help...
  236. Futaba FF9 - what have I done?
  237. Standard switch current capacity?
  238. fast peak charging a Futaba 6DA
  239. FP-T7UAF SUPER with CCPM
  240. 9C Case Cleaning
  241. Zap conditions
  242. futaba 3010 bearings
  243. Servo "bounce"
  244. transmitters receivers and crystals
  245. 6XAS - gear and elevator
  246. Setting up a 6XAS for dual elevator servos
  247. Attention Bill Baxter
  248. TX output
  249. FP-R127DF receiver battery reversed!?
  250. Bad Solder Joints??
