- Hello im new and ive bought a beautiful futaba fp-t4l.
- model transfer from tx mode one to tx mode 2
- Futaba T10J using sbs 02a
- Mixes and 3-Position Switches
- R617FS Recvr and Life Pack
- Futaba USA
- Receiver
- Lipo in a 18sz transmitter
- 18 SZA Screen Sensitivity
- 18MZ RST control problem
- 18SZ and Flap Speed
- New user t10j and sbus
- 14SG Problem
- Tma-1 telemetry adaptor
- S.Bus programming
- 18sz/2- rx
- Failsafe in Fut 8UAF Tx
- 18sz and T-FHSS
- 16SZ Display Configuration, Pictures?
- T16SZ change to mode 1
- Help - Programming T8J
- Unit of measure with robe F1712/18sz
- Futaba T16/18 SZ Update V 3.5
- 18MZ programming?
- Fx32 offset mix
- SBD Decoder
- Bls 173sv
- 18SZ as a master radio - trainer function
- 18MZ update failure
- 18MZH - binding new RX
- Futaba 18sz Butterfly function
- Futaba Service Announcement
- Futaba T10 CAP ERR Message
- Power supply in S.BUS 2 port
- Transfer models from 18MZ to 14MZ
- 12fg to 18sz model converter on the 18sz.
- Futaba Regulator PS-10 Mounting Instructions
- Futaba 16sz slider RS input with throttle glitch?
- Putting the throttle on a switch on Futaba 10c
- Transfer models from T8FG over 14SG to 16SZ/18SZ ?
- 18sz battery balance charging question
- Futaba 2.4 receiver antenna
- New 18MZ not WC
- T6EX As A Backup
- Servo repair
- Futaba High Torque Servos
- FUT 18MZ Antenna repair
- Futaba gps
- Linking 2 RX R2008 on MZ18
- T9 Cap
- 4PV display problem
- How can I change servo direction with a flip switch
- Set emergency motor stop with futuba and pixhawk
- Dual SBS-01RM for twin airplane, R7008SB + 18MZ
- S9551 servo question
- S3470sv
- 18SZ Telemetry display units and scale, support for more sensors, from third party
- Futaba T8SGAP
- Aurora 9 charger
- T8FG SUPER issue
- 18 MZ Timer Speech
- T9CAP Orig charger? model number?
- Airplane Rate Mode Gyro Set Up
- Futaba 14SG Charging
- Dual 2008SB Rx's
- R7014sb suitable for analog servos?
- Futaba 8JA and R2008sb
- Futaba R2008SB
- Cosmetic part for T12FG
- Futaba 14SG conditions delay issue.
- 14sg display problem
- Futaba 14mz
- Dual rates on a T7C
- 7px temperature on home screen
- 12 FGA Mixing
- 18SZ Flap system and Camber mix
- Receiver for 14mz transmitter
- Futaba 9C
- Radio Program Converter
- Repair Warranty
- Use of Heli radio
- receivers
- Hobbico and AMA East
- R6014fs
- Futaba Magnum Sport t2pc Connection Issues
- Futaba 18SZ - switch to speech timer remainder
- 18sza vs 18szh
- T7C to control Gyro(3 Axis)
- Transfer Models from 18SZ to 14SG
- 18sz Random Beeping
- 10CHG throttle ratchet
- 18SZ wont turn on
- mode
- 10C Dual Flaperons, Dual elevators with 7 channel rcvr
- 18SZ Program Mix
- Resumption of Support Thread
- 18SZ (2) RX Telemetry Question
- 18sz
- S.Bus Receiver Controlled Switch?
- Opinion please 6EX-2.4
- Futaba T6EX Dim LCD
- Binding 203GF receiver
- Futaba 6L buddy box compatibility?
- 18SZ version 3.0 software update bug
- Futaba 6EXA
- Dirt on 14SG LCD Screen
- 14sg access to DG1 and DG2 with dual 7008SB
- Futaba 18SZ Vario melody setting
- Futaba R6014HS Switch Channels
- Using both PWM ports AND S.Bus at the same time
- When are two receivers needed?
- Futaba T3PM FASST radio
- 3PM Binding- zero code issue?
- R7006SB and 3151 servo
- RSSI to the wishlist för the Futaba 18SZ
- R6014HS Replacement ?
- considering updating from my 14MZ
- 18SZ - Group Dual Rates to other conditions
- 16SZ replacing 14SG
- Multi Standard Servo End-Point Adjustments through SBD-1 Decoder
- Help! Convert 14MZ files to 18SZ
- Futaba 12fg issue
- BLS servo horn screw
- 18MZ software update version 2.7.1
- R7008sb
- CGY750 Connections
- 18MZ T-FHSS compatible?
- EDF battery telemetry
- T6k and R2006GS Binding
- T14SG Range Check Mode
- T14SG and phoenix sim issues
- SBUS Question
- 16SZ Questions
- futaba 18 sz lock out
- T18MZ Flap setting problem
- Futaba 12FG can it transmit as fast as a 14sg
- R7003SB Channel Mode setup
- R7008SB Receivers
- Futaba 14SG: Setting a Governor
- Setup duel R7008sb
- 18sz Servo Delay Question
- 14mz start up
- 14 sg lcd fail
- Futaba 18MZ - Is the 18SZ model compatible
- Logic Switch Setup
- 18SZ/14SG/8FG Trim Switches
- Set up a P38
- 8fg useage
- Elevator comp on Butterfly Mix - 18SZ
- This fell out of my 18mz when I was putting it back together. Please help
- Futaba 18sz model photos
- SBS-01C current sensor
- Futaba 8J Flap elevator mix
- Info for 9C converted to 2.4
- Futaba 7c master with T6EXAP slave problem
- Trainer
- Program Mixes
- Loose buddy box connector on t7c
- Futaba 4GRS
- Four indépendant Dual Rates on 14SG
- End Point adjustment on Futaba 10C
- Throttle position warning
- Sbus-2
- Futaba 10C Flap Setup Help
- Can receiver signal quality be viewed on 18sz?
- 18SZ gear door programming
- Futaba 18mz airspeed problem
- 7 C question
- Vpp 1
- Futaba 14MZ - sound beep for mid stick position.
- Linking GYA351 to 14SG
- linking r6014hs to my 14sg
- R7008SB Sbus 2 HV Receiver voltage output
- T6J transmitter
- A wierd one
- 18MZ Display Lock & Throttle Cut Functions
- Which Charger?
- using 7008sb receiver with 7c 2.4ghz transmitter?
- throttle question
- Using an EU transmitter in N. America
- T6J Binding problem with R2006GS
- futaba interferences problems
- 9CAP Super question
- Cgy750
- 18mz sliders
- Is Futaba 14SG being replaced?
- transmitting sign is blinking
- Setting Switch Endpoints
- Jetcat V10 sensor alarm question
- Transfer of models from 12fg to 18sz
- Trainer function 7CH
- 14SG and SBus
- Futaba 14SG / Futaba R7018SB
- PS10 Voltage Regulator Mounting
- S9001 servos
- Futaba 6008HS RX
- What Futaba Fasst test telemetry Rx for the 18sz?
- R7008 No Telemetry
- R7018sb
- 18WC audible alarm when RSSI smaller or disappears
- Trim Levers
- How to understand Futaba TX names & functions
- T14SG mixing help
- 12FG updating
- Futaba 18SZ Error Message
- 18SZ Region Code.
- Futaba 18 SZ reboots when I try to set dual rate function name on DR 1,4,5 or 6
- Removing a mix on Futaba 7c transmitter
- Futaba S3150 Extension . . .
- CUi-2 or 3
- T18MZ and Prog. Mixes features
- Futaba 7008SB 8 CHANNELS POWER INPUT
- R7008SB anolog servor compatable issue
- R2006 reliability after crash
- ANY ONE USEING FUTABA R7018SB receiver with capacitor
- Futaba 7C Switch disable
- R6008HS receiver with a 14SGA radio won't work?
- Throttle
- Dual elevator Servos one Trim?
- Mix on throttle for a multi motor airplane
- 18MZ and 18MZ WC firmware update?
- 18 SZ telemetry sound quality
- T18SZ & 7008sb setup question?
- Probably User Error - but need Help
- hearing issue
- Throttle
- Futaba GY611 gyro - display problem
- Futaba SZ18 questions
- T6k transmitter alarms
- Is there and easy way to transfer all models from 8FG Super to 14SG?
- update 18Mz
- Futaba 18MZ question about servo speed and conditions.
- 18sz model copy to sd card
- Mix and switch verification
- Trainer system supports Mode change 18MZ?
- Just a note on my service experience
- 7C not powering up at times
- Futaba 6K receiver compat.
- mixing Elevator and flaps
- 8FG tx handle
- Fast verses Fastest
- Futaba 18SZ software bug in latesy update
- Tailless Wing on a 12Z
- 18Mzh kill switch
- 8FG switch part number(s)
- Speed voice not operating
- 18SZ/R617FS and Bavarian Demon 3SX connection. Helicopter set up.
- 18sz Rudder to elevator mix
- Help need a throttle ratchet plate
- 18 MZ and Elevon
