- Firmware update failure on futaba 18MZ
- Telemetry Log Converter FAIL
- Futaba T12FGA & 14SGA
- New radio Futaba 14 sg wish me luck
- Futaba 18MZ Talking Timer
- Futaba 14 SG door sequencing with Robart electric retracts
- 3 Position Flaps Switch with 10J
- 14SG Differential Thrust Setup
- 6014FS 14 chl receiver
- 617 high speed
- Reciver ?
- 9Z battery...
- Futaba 4PLS mixing question
- Copy 8fg files to 14sg
- Futaba 14sg flaps set up
- MPDX-1 on R6008HS
- 12fg
- BLS171 Gears
- Model Copy
- Futaba coreless servo jitter
- Futaba BLS174 gear set
- Futaba BLS155 motor
- 8FG loosing Pmix settings on 7ch only 14 ch ok soft ver 5
- 12 FG snap setting using sticks
- 5101 servos on 6 Volts
- sound switch selection
- 18MZ Throttle Cut via P-Mix--
- Replacement for BLS 155 servo
- S Bus
- Range Check
- 18MZ Switches for Purchase
- Futaba S Bus servos
- Futaba 18mz programming question
- Proper Trainer Cord Match
- Rx Won't Bind
- Latest 18MZ firmware availability in US??
- Futaba 10cag flap settings
- servos
- Countdown timer display options
- S3305's
- Futaba R6014HS binding
- T9CAP Manual?
- Could Not Deliver - Customer Not Available or Business Closed
- S-fhss and fhss
- Range check with Futaba TM-7 module
- Dual case
- 14 Mz problem
- RF Output of Futaba 18 MZ European v/s American:
- Sbus harness as Y harness?
- Two Futaba S9350 Servo's Need repair
- 14MZ Trainer/Buddy Box Setup
- Futaba 10J Programming
- 8FG trim switch problem
- Futaba 18MZ telemetry update.
- Futaba T10J transmitter batterypack / Best choice
- Futaba T10J / R3008SB/FHSS Flap setup with two servos
- 6XAs system programming question
- Xicoy Telemetry
- need help programming my Futaba 14SG for a zirolli Dauntless dive bomber
- Kudos to Hobby Services!
- buddy box for an 8u
- Trainer Buddy Box hookup
- Thanks
- Smoke on T8J
- 14SG Software Ver. 5.0 Problem installing
- 14MZ switch replacement
- Problem with futaba 8fg super
- Servos losing programming or TX wacky??
- binding used futaba fasst receiver
- 18 MZ Telemetry
- CA-RVIN-700 External Voltage Input Cable wiring
- Self centering kit
- 14SG Flight Conditions
- T8FG does not show "Format" option when a new SD card is installed
- *7008sb rx & naza-m v2*
- 7008sb rx
- FASST the Future
- What is the proper antenna setup? "Orientation"
- FASSTest-12CH vs FASSTest-14CH modes
- Hitec servos getting hot with Futaba 14SG
- Futaba 18SZ
- 14SG nimh charging
- Futaba 7c Transmitter stuck! Can't change screens or functions
- 9C super help.
- 14MZ replacement
- I need help setting up my flaperons
- Futaba System won't work with 6v
- Gyro help, lets try it again.
- Futaba 7c Radio help setting up flaperons
- Gyro set up help!
- throttle curve in the glider menu on the 9Z
- Futaba 7C 2.4 transmitter antenna
- 7 C servocoupling question
- 14sg with dual 7008sb recievers
- R7008SB receiver
- 14sg with r7008sb and r617fs receivers, analog futaba servos
- futaba range
- Rx 6208
- 10cap transmitter Problem
- futaba 14sg switch setup - flaps
- 6EXA FM slave compatibility with 6J S-FHSS as master.
- Turning off sliders on a 9Z radio
- Ultra Stick in Futaba 9Z radio ???
- Linking the 617fs receiver
- 6EX Training mode not working
- Same plane on multiple model settings
- Antenna for T10CAP transmitter and frequency change on FP-148DP & FP-149DP receivers
- SBS-01G Telemetry Speed function
- How do I copy a model from 14sg mode 2 to 14sg Mode 1 (Heli model).
- Futaba T9CP with Spektrum DM8 module & Futaba Skysport 4 trainer cord possible?
- 18MZ repeating slow mix
- 9c
- Up to date Telemetry Log-Data Converter availability??
- 14MZ won't restart after loading 18MZ model
- 18mz update getting"update not compatible with tx"
- Transmitter length antenna
- 3prk A cancel brake
- Futaba T14SG Logic Query
- BLS471SV and BLS571SV Servos
- R3008sb receiver ?
- 18MZ plus SBD-1
- 14MZ and throttle curve
- Digital vs Non-Digital Servos
- futaba r5114DPS battery connection
- 14sg updates
- R7008 will not Link to 14SG
- Futaba 10ja air radio question
- 18mz to 14mz buddy boxing, model program not loading
- set flaperons and tripple rates on futaba 12z
- crack in left gimbal
- 12Z Flash card issue
- Reversed the polarity on my Futaba R617FS RX, repair cost?
- 6ex low voltage display
- 14sga with power box
- How to link 12 Z to R6008HS receiver
- Futaba 18MZ mode 1to mode 2
- 10cga
- Futaba 14SG Program Mix Question. ***Need Help****
- Futaba 14sg Programming Help
- 18MZ Update 2.5
- Communication
- 12Z programming question...
- Futaba 8U - Trainer Function Doesn't work
- 10J charge lead
- loose tm-14 module antenna
- TM14 antenna rubber grommet?
- 7C multi use of channel
- Futaba T14SG and Hobby Eagle A3 Super II - Configuration
- Futaba airial problem
- 14mz will not turn off?
- T10CAP linking problem
- Futaba 10J update version 1.0.4 and 1.0.7
- voice recording 18 MZ
- Campac
- 14SG Antenna mount broken
- R617FS Location
- R 6014 on 2 cell LiPo's
- 14-MZ SPANISH language
- Heat shrink tube seen on the antenna cables on a new Futaba 617fs receiver
- GYA430 Gyro and Sensitivity Switch Assignment
- Telemetry and Failsafe activation
- Futaba telemetry, Powerbox ect.
- Wrong receiver?
- Futaba t3pm 2.4 ghz mx
- New 14MZ software update - 14MZ Software Update Ver. 1.7.3
- 9Z FUTABA kill throttle switch Q.
- Sbus servo programming
- 18MZ v2.50 JetCat telemetry
- High voltage servo Rx and servos
- Rutabaga 12FGA to 18MZ
- Bax/ Parts 9ZA WC2
- Futaba R6014RC in my Phantom 2 Quadcopter. HELP!
- Roxxy (also known as ESC on 14SG) sensor support broken on 18MZ
- Telemetry Log Converter not working with 2.5.0 SW on 18MZ??
- 10J receivers
- Trim lever problem
- servo compatibility
- 9 Super with campac question
- How to link 18MZ to 6014 rx
- GY520 voltage
- BLS153 replacement
- T10cap
- Fasst protocol in UK
- 14sg
- Futaba made in China
- Using a futaba super 8u with a spektrum module.
- Need help setting up temp sensors on 18mz
- servo flutter
- 18MZ Sounds not playing consistently
- Toggle switches
- Slave chl ( gear ) used as second elev doesn't move when Crow is activated
- 14MZH Losing Plane Data
- rudder servo 50cc extra s9157
- Pattern Biplane setup
- S3114 Neutral Position
- Futaba am 72,160mhz
- Multiple Recievers
- Futaba T10J programming for 4 wing servos.
- Battey size
- Fasst TX
- Transmitter switch going bad
- Futaba receiver in a Spektrum setup
- 12FG Data Reset
- Crystals?
- Servo arms
- R7008sb
- Trainer cord for 14SG
- Confused ... Again!!! 10 CAG - 14 SGA
- 8J specs conflicts within Futaba literature
- GY401 Gyro - can it start burning out servos after a crash
- Futaba S3170G retract servo question
- Futaba T10J Helicopter Failsafe and Gyro setup for Phantom 2
- 14sg and # of telemetry units
- BLS173SV and BLS173SVi differences?
- 8J Trainer question
- Robbe Tbox with USA 18mz
- Throttle Cut for Twins on 18 MZ
- Virtual channels on 18MZ?
- 14SG Telemetry Logging Question
- How to disable the RF on a Futaba TX 6XAS
- Program twin engine
- Futaba 14sg signal blackout
- location of miracle heavy duty switches
- Using 2 R617FS Receivers
- 9Z Tx battery replacement
- 7FGK switch
- how do you program twin elevators on super 8fg help!
- 14SG Telementary not working
- 9CAP SUPER Need help with flaps setup on slider "VR E"
- 12FG Flap/Elevator Mix Issues
- dual switches for redundant battery packs?
- 14sg - analog servo
- 12 fg switches
- Discontinued Servos S9202 and S9204
- R6008hs on 7 volts
- Futaba 14sg crow. Which channels to use?
- Dual Elevator & Flap Servos
- Gyro questions with S Bus
- R7008 channel assignment question
- R617FS Receiver Question
- Troubling linking issue with R6008HS and 14SG transmitter
- Futaba T10J and NAZA M V2
- gas kill switch issues with 18mz SB2
- Futaba 8 FG Super high voltage setting
- Futaba 7C throttle cut at high stick???
- 12FG Trainer Cord Confusion
- redundant systems using super 8 rx.futaba
- which is which??
- Using a 14SG with 6014 HS
- Futaba 14 SG question om model change
