- 18 MZ and Elevon
- Sbus servos won't power on
- BLS 172SV gear type "hybrid gear"
- 7008 receiver compatibility with 12 FG transmitter
- Tx suggestions for my son..........
- Lower end FASST radio's
- Futaba s.Bus config
- Programmable mixer question on my 18MZ.
- 18sz linking to r617fs rx
- 14 SG Trainer Function Not Working
- 18MZ and S-Bus
- Futaba T6J Transmitter & Receiver batteries?
- DG1/2 (Channel 13/14) via Trainer Cord with 14SG
- SBD-1 decoder with R2008SB receiver
- 14SG battery - whats the safe voltage point
- 8 Channel telemetry receivers and digital servos?
- 14sg electric engine cut off
- 18MZ Winter Storage
- What's the future for Futaba's production of 72MHz equipment?
- 8FG to 18SZ
- Futaba 12FG to 14SG
- Setting up Futaba 12Z for Aerobatic flying!.
- Minejack
- R7018SB Reciver
- 14MZ pieces and repairs
- 18sz -- 3 position gear switch?
- 18MZ volume
- R7008SB receiver
- Curve setting operation with 18SZ
- Futaba 14SG Corrupted Model Memory?
- connect the motor battery Before turning on the receiver
- 14SG / R7008SB link problems
- 12z to 18sz?
- Manual Switches MZ18
- Gya430/431 vs. Gya440/441
- Transmitter service life
- MZ 14 Back Up Battery
- Is it the only way
- Sbs-01g, r7008sb, 14 sg
- Couple of 18MZ questions
- Futaba 14mz to 18sz model transfer
- What is the best position for the TX antenna on a 18MZ?
- Futaba 3PV tx binding with Kyosho KR-200 rx
- Futaba 14 sg A C T fuzzy gyro
- S bus servo not being read by Tx on setup
- SBS-01C and 14sg
- Futaba S3470 servo
- Problems with telemetry on new 18sz
- Futaba 3PM-FS (Continuous Bleep from Transmitter)
- 18MZ Throttle Stick Travel
- 14sg CMBFLP to ELE motion with "slow" flaps
- RX remote link question
- Channel mixing help futaba 3pk and kyosho blizzard
- 7c 2.4 radio flap switch?
- Link Issue on Futaba 18SZ
- Continuous beeping from futaba r2008sb, s-fhss receiver
- How do you get 18MZ DG1 and DG2 from R7008SB in Mode B?
- futaba 9C + digital servos
- Butterfly and elevator comp; on 12 FG
- Futaba 431
- S3151 Voltage Rating
- Futaba 18MZ - any way to Hold the throttle stick in a airplane configuration
- Futaba 10c spoileron and flaperon setup
- Futaba 12 Zap and TM 14 Fasst Modules
- Futaba's answer
- New Corsair Setup with SBus and Conventional
- Is there any FASST rx that I can change the PWM channels
- Two Cell LiFe Receiver Battery Pack
- 10 C Futaba Transmitter and the R6008HS receiver
- 18SZ Switch Change
- 18mza vs. 18mzh
- 10cap dual elevator servos/crow
- R2006GS installation
- Safe operating limits
- Futaba 18MZ - can't update
- 12Z Timer
- Programming 7c 2.4 for warbird with 2 elevator servos
- Futaba 14MZ "Backup error" - should I be worried?
- Receiver swap 6008HS to 6014HS
- 14SGH Trasmitter - Memory Card
- Using Futaba 12Z with Aerofly simulator
- 18SZ Not showing receiver voltage
- Extra voltage connector type on Futaba R7008SB Receiver?
- Use R6303SB and R7008SB with 18SZ ?
- Bad Throttle Trim Switch
- Use of Dual Receivers using 14SG
- 14 MZ- 6014 HS Range?
- Futaba 18SZ: Easy to delete your model by mistake
- 14 MZ back up error
- main difference Between the 18MZ and the 18MZ WC
- Setting up flaps on 12fg
- 18MZ case foam
- 14 sg dual rates
- FUTABA Support
- Display Flash
- Telemetry data
- Tx 8J with Tx 8UAP as trainer
- touch sensor on T14SG
- Operating S bus 2 with dual receivers
- 18SZ warning voltage
- Using a mouse to navigate on 14mz
- Operating Canopy suggestions on a 18MZ
- 6014HS unlink
- futaba 6ex 2.4
- 14Z HV Rx
- Bag/case to carry T8J
- 14mz touch pad differences ?
- Noob question - Futaba 8JA Tx/R2106GF Rx question - sailplane setup
- 18SZ SD Card
- Latest 14SG updates
- 14 sg
- Features missing from 18SZ that are on the 14SG
- 18SZ Start Select
- Futaba T10 CAP trainer compatibility with T6ex
- R7008SB and 18sz questions
- F/S problems
- What hardware interface do I need to run jetCat version 10 ECU
- 14sg rudder/aileron mix
- R200GS doesn't bind to 14SG Tx
- Differences between 18MZ and 18MZ-WC and 4XP and 4XP-R
- 18mza upgradable to use T-FHSS?
- 12 FG programming -dual rates
- Data warning after selecting model
- Futaba 18SZ Telemetry Info when signal is no longer received
- Charge cords
- Futaba 9670 Servo
- 14SG Model data on SE Card & Futaba FFS Software
- maufacture date ?
- Sd card
- 'Advanced' master/slave buddy box question
- 14SG beeper volume
- Servo arms for BLS154
- PDF doc locked for printing, Please unlock!
- T10CAG to T8FGS Transition - 3 position switch
- Castle Creations/18SZ Software Update
- 14 SG Why don't values on gyro page exactly match servo page
- 18 SZ Telemetry
- 18MZ battery
- S9070SB servo
- Cant link my 7C to my R6014FS receivers
- R2006GS receiver
- Futaba 14SG Setup Help
- GYA 431 Gyro for Delta wing
- 14SG slow flap deployment with MOTOR function to get proper Flap to Elev mix
- T18sz r7008sb no RX voltage on screen
- Futaba T8J connecting to Hobbyeagle A3SUPERII issue
- T14SG Transmitter with R2008SB receiver
- Norton Anti-virus deletes T14SGupgrade.exe file
- swapping sticks
- Futaba 14SG free mix programing
- cmbflp with the 14 SG transmitter
- Can 2 6208 receivers accomodate more than 8 channels without using sbus
- Futaba 14SG Sound Function and Software V6.0?
- Can I download My Model Configurations froma 14SGH transmitter to a Futaba 18SZh
- Receiver packs
- 14sg gyro function assignment questoin
- S9405 Servo
- Transmitter trainer compatibility?
- Futaba 14SG version 5 sound
- Is 6014 FS without a dot safe to use
- 12FG programing for 2 rudder servos
- Futaba T 10 J swashplate mixing problem
- Adapting the Futaba MZ14 (36Mhz) to FASST 2.4 Ghz and using Sbus Receivers
- SBS-01G Altitude
- voice alerts
- 18sz screen
- 18SZA Programming
- Futaba S3010 problems
- CAP10C Replacement Case
- 18SZ Telemetry Display Questions
- Futaba File Utility ver 4
- Is something different with the sBus output between FASST & FASSTest receivers?
- 10CG case
- Futaba 12z with Powerbox Competition
- Throttle cut 14SG
- Futaba R6014HS Power Through S-BUS Port?
- Futaba Sbus questions on TF Giant P40 setup
- Twin i/c engine setup on 8FG
- 18MZ files to 18SZ
- *Futaba R2008SB S.Bus 8-Channel S-FHSS Receiver*
- How would you program your 18SZH to do this?
- Futaba 10j radio
- 18MZ trainer port question - Dragon Link UHF install
- Dual receiver setup with telemetry
- Futaba T8J linking
- Sbus cords
- Futaba T6XAS servo mixing programming
- Futaba 6 EXA design change request
- Jumping Servos
- Futaba 4pl trade up?
- Servo Ch setting Sbus
- Buddy Box trainer chord
- T14SG update
- Futaba 12FG
- Help ! delay throttle bout' 10 second
- changing from 12 ch to 18 ch
- throttle delay Futaba T10CP
- SBUS RPM sensor
- Digital Throttle Servo
- R7018sb
- Futaba telemetry
- how to set up timer on 10j
- Setting D/R and expo in 18sz Transmitter.
- T12FG dead after battery polarity inversion
- HV servos and Powerbox HV digiswitch
- Dual Futaba 617FS rx's with 7C Transmitter??
- Failsafe and kill switch
- 9 CAP & 9 CHP LCD screens gone black
- Availability of the 18sz radio
- Linking Fut 617 rec to Fut SG 14 transmitr
- Futaba FX-32 mdl file
- SD Card
- SBS-01G Speed
- Sbus and power boxes/expanders
- ETSI EN 300 328 V1.8.1 for EU.
- 4pk steering signal problem by throtle trigger.
- Program dual elevators
- 18MZ to 18SZ Data transfer and Vice Versa
- 18mz
- 10J timer
- 7008 battery input
- Need a second transmitter / Pupil to be used with a Futaba T10J
- R148DP PCM receiver frequency question
- Tx model transfer from 14sg to 18 sz
- T18SZ / R7008SB Receiver EXT.battery Screen
- Copy models from 12Z to 18SZ
- Proper Flap Setup on an 18SZ
- LiFE Battery Charger
- Are there new mid priced FASST radios coming?
- t6ex
- Offset Mixing
- r 607 fs
- Frequency modules for 8U
- Futaba MSA-10 Servo Adjuster
- futaba t8uap
- 14SG throttle cut
- Futaba radio repair
- Data transfer from T14MZ/T18MZ to T18SZ
- Futaba 7C
- 18SZ Switch change
- Ailevator: aileron and elevator trims don't work
- What transmitter do I buy now????????
- Black out display in 12Z
- futaba 2.4 7 channel transmitter battery options?
- Futaba GYA-460 question
- Smoke on 14sg help
- FP 7UAP Super PCM 1024
- Disappearing mixes
- Firmware update failure on futaba 18MZ
- Telemetry Log Converter FAIL
