- 6EX-2.4GHz Transmitter Un-Links
- 9C Throttle Hold Problem
- FASST module for Field Force 3 (FP-T3UCP) Radio
- 14 MZ Mixer adjustments
- Question about STICK SETTING
- 7C FASST Flapperons
- 9ZHP WC2 + TM7 or 7C ?
- Campac Data Transfer......
- Software upgrades 12fg
- li-po tx
- Latest 14MZ Software Updates
- Trainer Cord Question
- 12FGA with twins
- 14MZ switch channel assignment
- T12FGA 2.4Ghz programming help
- 12 FG Gyro Setup
- R6004FF and current draw
- 12FG Offset programming explanation.
- 8UAFS -TM8 vs 7C FASST
- Futaba T7Cap Mixing
- 14MZ FASST channel grouping??
- Futaba receiver
- RX 6014, ESC and UBEC
- about the TM-14 issue
- FASST 6-Ch Rx with standard servo connectors?
- Question on a 12FGA vs a 12FGH switches
- 9Cap-TM7 2.4 gig Question
- 10C, 12FG, 12Z, stick/gimbals?
- Futaba FF7 Programming Problem
- Futaba T9CHP Super just died.
- 10C 2.4GHz CCPM questions?
- 12FG offset programing
- R145iP antenna length
- FP-R127DF
- 4pk antenna
- Futaba 12Z reciever question
- radio frequencys for uk and usa
- 9C low rate to high rate - servo centers moving
- Futaba CB12Z versus T12Z
- receiver antenna ok with multimeter?
- Two Simple Questions
- End Point question
- 6004 servo selection??
- Confirming MPDX-1 modulation schemes in 12FG
- What is DSC on my Rx?
- Bubbles on 9C Faceplate
- 12FG programing question
- 12FG 2.4GHz Trainer with 9Csuper
- Two r5114s have the IDs swapped
- r5114 receiver ID
- Help with 12FG and SD card
- 6XAS Channel change
- Dual Channel Support for 4PK
- Futaba RF608 and hitec 5475 ylead servos
- Futaba Servo Battery Compatibility Data
- 14MZ Encoder
- Thread Deleted/
- DG1 and DG2 plugs on R6014 Rx
- Futaba FASST Receivers with Dots
- 12Z Setup for a TREX 450
- 12FG Questions From New Owner
- Throttle Cut on 9C
- 9C 72mhz antenna with 12FG
- what is the DATA conection use for?
- Futaba 14TM Module US vs Asia
- Futaba 10c 2.4 throttle curve (heli)
- 9ZAP Setting a Gryo
- 12FGA and 617FS Failsafe
- R149DP Lo<>Hi
- 3PM-FS+R203HF+2 Digi Buzzing Servos?
- 6014 - weak servi pulse?
- TM-14 module recall
- How to setup Multiple receivers
- REVISED: Bax & Krysta please read this as well!
- Burst amp in R608FS
- 12fg programing question
- Programing questiona
- Carrying Case for 12FG
- Dots on 617 RX's
- 14mz Transmitter case
- Resolution question
- Futaba 6XA Mixing ? ? ?
- Crystal set change for 9C Super
- 12Z switches replaceable by us or send in?
- Heat Failure Testing at Hobby Services??
- MOVED: Ultrastick and Futaba 7CAP Help Please
- Futaba 7C 2.4?
- R617FS Receiver heat issue
- receiver crystal question
- ESC and Rx Location
- Futaba servo's & A123 batteries
- Trainer switch problem on 10c
- 10c antenna
- Receiver Heat Issue Testing Video
- Servos for big stik 60
- Need a FP-T7UHPS manual,please help.
- Futaba RF modules for FF7(FP-TP-FM) and FF9C super(TP-FSM) interchangable?
- reprogramming a Futaba display & 2.4ghz antenna
- Futaba 617 FS RX
- MOVED: Radio Data Sheets
- Setup changes between R6014fs and r607fs
- ERP on FASST
- MOVED: Futaba 12FG compatible SD Cards
- 9C
- What are "Virtual Channels" used for in the 12FG?
- Mode settings
- MOVED: Display protector
- 12FG: different servo speed in each direction ?
- Dots on returned or new 2.4 RXs
- 10 c programming without module??
- 12FGA Flap-Elev Mix
- Dots
- 12 FG 2.4 Snap Roll Function
- 9C mixing question
- 7 channel 2.4
- Here's one to pick your brain. Glitching issue...
- 10C changing modules
- futaba servo s3152
- Can't arm speed controller with 6EX
- 10C ailevator function and 12FG mode changing
- 12Z inflight mixture
- 10c separate trims on different conditions?
- Using 12FGA with R617FS
- Dual Rx`s
- 6EX 2.4 Ratchet Plate-part number?
- Merry Christmas
- New 6014
- Information on new 9157 servo
- GV-1 Sensor Case
- Futaba tc10 halp!!...
- 14MZ-FASST Use With MPDX-1(s)
- 12FGA TM-14/R-6014 Linking Question
- Futaba R617FS How to mix Battery and servo plugs
- throttle cut \idle down stuck on
- 12fg question
- Futaba 6 Channel 2.4 Ghz problem
- R607FS vs R617FS
- 12FGA R6014FS combo
- Futaba Buddy Box Help Please
- MOVED: spektrum receiver antennas
- T9ZHP power up...
- 12 FG MANUAL FOR 2.4 VERSION
- Blown fasst receiver
- 12ZAP Updates
- 12FG: Dual rates and conditions - Followup question
- PCM FP T5NLP Rec. compatibility
- Futaba FUTK6901 and FUTK6902
- changing modules from 72 mhz to 2.4
- Futaba 12-fg
- neumatic landing gear (servo operated)Landing gear and gear door mixing
- 12z 2.4 ghz
- 6004 receiver current drain ?
- New TM-8
- 12FG vs 12Z
- T6EX mixing
- Using the 72 module from a 9c on the 12 fga 2.4 radio
- 6EXHP question
- 12FG ?
- 3PM-2.4G help
- Futaba 2.4 10 channel receiver question
- 12FG RADIATED POWER QUESTION
- Futaba 12FG
- 12Z Range Test Question
- Dunked R606FS
- Re-confirm FUTL15** modules for 12FG?
- 6004 receiver range?
- Futaba FP-T4L 75mhz Transmitter Question
- 9C
- R6014FS receiver failure
- Futaba 12Z - Flaps
- Futaba 12FG 2.4
- Futaba 12FG transmitting Wattage
- Futaba 7 UAP TX
- new Futaba FASSTâ„¢ R6004FF
- R617FS Questions
- FUTABA 12FG TROUBLE
- Duel battery connection question?
- 14mz steering wheel trim
- 12z
- 2.4 Latency
- 12Z SET UP
- Futaba 12FGA 2.4 operating on 72mhz
- Radio
- Radio/reciever compatible
- Futaba FASST R603FS Receiver Antenna Replacement/FIX
- 12Z Help with set up
- Frustrated after a 14mz purchase (Futaba Flyers Club)
- PLL error with 9ZAP transmitter
- Using the R616FFM receiver with standard size servo connectors
- A Hearty Thank You To Futaba USA (and a small question)
- Futaba S9156 gear problem
- Dual Rate with the 10C...
- MPDX Pulses
- Neck strap attachment points for 2.4 Txs.
- FASST Receiver voltage output
- WHY THE FIRESALE ON THE 12FG 2.4
- FF9 flight mode
- T8UAF reciever compatability?
- Bax or Krysta need not respond please others what are your results using TX li-po's ??
- Thanks for the new 14MZ update and a Suggestion
- Power-Down Refinement: TM-14 Transmitter Module
- Fasst Rx compatibility
- 7c problems
- futaba 3pm help.
- Software Uptdate for 14MZ and FX-40 Transmitters
- CAMPAC MODIFICATION POSSIBILITY
- Futaba 10fg or 12fg
- FUTABA VIDEO INSTRUCTIONS
- 12Z Alarm warning??
- Transmitter Lipo?
- MOVED: Airtonics M11
- 2048 resolution
- Unwanted Mixes by 12FGH
- 12Z vs. 12FG
- 12Z Trim Adjustments
- 4pk (only 3 push bottom)
- Futaba 9c servo
- 9C ailevator problems
- 7C, 2.4 GHz Program Mix help
- 12z/14mz programming for all channels?
- 3pdf question
- R603FF and FS Rx with TM-7 Tx module?
- 8uaps throttle cut issue
- skysports 6 D/R switch problem
- Futaba 8SGAP remote
- Futaba T7C 2.4GHz Mix Programming
- 14mz Blade 400 ccpm?
- New FASST R6004FF receiver
- Futaba Flyers Fourm?
- 12Z Programming Question
- 9VAP ON 2.4?
- Transform a Futaba FM to 2.4
- 8 Ch. Fasst Rx voltage
- 4pk and Lipo
- Flaperons on 3 position switch
- Compatibility
- Antenna mouting on CF fuse
- Interference with 2.4GHz?
- FASST Receivers
- GY401 Gyro w/S9254 combo
- New Futaba FASST Parkflyer receiver
- SYSTEM MENU - STICK SETTING ??
- 6014FS with Power Expander
- BLS 351 servo fluttering problems
- RC Robot Using Futaba Speed Controls
- 12Z ELEVON TRIMS??
- Futaba 3151 ?'s
- R608FS
- BR 2000 battery checker issues
- 9CAP Data Reset?
