- 6EX 2.4GHz throttle mix
- 7C 2.4GHz Questions
- Futaba 2.4 reciever compatibility
- 9CAPS Synt. transmitter shift?
- 14mz Sagami Toggle Switches Needed
- Futaba voltage advisory
- problems to set up a 5114 reciver on 12 Z
- R6014fs and Powerbox
- FP-R114h
- Futaba FASST Reciever 607
- 7CHP display pooped !!
- Cycling through 10 models memory.
- 4.8 volt servo rating?
- 10C mode switching
- Servos move to full throw when switch on
- T6EX Throttle cut
- ei
- Rubber Grommets on S3004 Servos
- T7CAP Usable for Heli Radio?
- Futaba FASST Product Advisory - 2.4 GHz Transmitter antennas
- R616FFM RX General Questions
- 12FG flap programming help needed
- 6EX software upgrade?
- Wrong RX descriptions?
- tm8 and transmitter tray FF-9
- 72MHz Module for 12FGA
- Futaba 12FGA vs 12Z
- 9ZWC2 display voltage doesn't match actual pack voltage
- A123 Batteries and Futaba Servos/Receiver
- 9c Super User's Guide
- Futaba 2.4 and Carbon Fiber models
- 12FGA & 10C Questions
- Mode one
- realistic date for the 10C?
- 12Z updated with 2.4 Ghz problem settings
- TM-10 module
- 9CAP FAAST 2.4 Module and 2.4 Receivers
- 14MZ-What to buy
- 10 C
- Futaba S9101 Servo Replacement
- FAAST 9CAP Module vs 10C 2.4 TX
- 12Z CF Card
- April Fool
- Programing a Futaba 7C on an Ultra Stick
- TM-8 Module Error
- Reversing a Servo
- 9 CAPS Elevator Trim Question
- 4PK features
- Antenna dimensions
- Futaba or Specktum help!!!
- T12FG Mix Programming Help
- faast module
- 3PM Battery Question!!!!???
- is there a 10 CH Rx in the works?
- FC 28 and 9ZWCII 2,4 GHz able?
- R608FS receiver
- Futaba FP-T7UAF 7
- 9C - Build Flaps - messed up?
- BLS-251 Brushless Servo Ad
- Boot-Up EX6 2.4
- Modulation setting for TM14
- 607 or 617 Receiver ?
- New 10C - Question
- LiPo in 9C transmitter.
- Futaba 6EX FAAST Compatibility Questions
- TOLEDO!!
- 3PM / 3PKS & Electric Motor
- Futaba Flyers Club
- 14MZ and DSC cord usage
- 3PM-2.4G Battery pack?
- 7CAP and 7CHP ATV GLITCH!
- 14MZ/12Z and 12FG updates available at Toledo
- Synthesizer for 9CAP
- R149dp voltage
- R607 Vs. R617 Rx
- What 2.4 recievers compatible with TM-8 or TM-7
- 6EX signal loss fail safe.
- 9c - Can you swap Fasst in&out?
- FASST Question
- 3pk speed controller compatibility
- Frustrated trying to get Futaba parts!!!!!!!!!!!
- T7CAP Programming Glitch?
- FAAST v SPECTRUM
- 9C FM - When is the battery charged ?
- Delete
- Experience returning TM-7 to Futaba Service Center
- 14mz updates
- Two ele servos with 14MZ
- battery door/cover for a 8UAF
- futaba 12 zap
- MOVED: HPI Radios who makes them?
- Set up Ailer. Fut T6EX 2.4???
- 7 C FAST Switch's
- Are the 2.4GHz 12FG and 6EX buddy lead compatible?
- Question about mixes
- More Service Complaints
- Programing a slave servo, Futaba 6EX-2.4MHz
- What is the Data Port for on the R608FS FASST Receiver
- FAAST and Hitec servos
- MOVED: Futaba Attack and Conquest radio
- Older Futaba radio
- Futaba 6EXAS self centering failure
- Charge 6v Rcvr Battery with Futaba Charger?
- servo coding chart
- ultra stick
- 10C question
- 2 receivers
- Strange Futaba 9C aileron glitch
- How do you assign switches to the Digital channels??
- 6ex 2.4ghz FASST transmitter
- 5014 reciever
- Security code and the user's name.
- Servo current draw
- Flaps and 14 MZ
- Am 72mhz
- Water on Fasst
- Futaba replacement Gimbal Knob thread
- Flap travel adjustment
- 6exhp transmitter batteries?
- R607FS and R617FS...what are the differences?
- TM-14 and receiver pre-bound?
- Help programming a mix in a 7C
- TM-8 module with 7&8 ch rcvr
- R608FS Servo Signal Voltage
- TM-8 Failsafe Question.
- TM-8 Failsafe Question?
- 6EX 2.4 GHz fix
- 8 CHANNEL TO 2.4GHZ?
- 9C Dual Rates to Single Switch?
- using y-harness
- Futaba FASST Receiver Antenna Replacement/FIX
- Elevators and Ailerons 7C 2.4ghz
- 8 Channel Fasst Receiver with 7C Transmitter
- R606 FS receiver
- FASST 8Ch Module delivery
- T14MZ bought in Europe + USA 2.4 module
- dual elevator servos w/7C 2.4 Ghz
- 2.4 Receiver Resolution
- 14 MZ 2.4 With Two Receivers
- 14 MZ Mixing
- Futaba Flyers Club Membership
- range check 14mz 2.4
- 6EX 2.4 GHz FASST query
- MSA-10 Multi Servo Adjuster
- 6014 signal voltage
- 6EX dual elavator trim?
- 9c to 12z change in software???
- 7C/ 6C 2.4 recall: Will You Be at the Toledo Show?
- Futaba in Australia
- 14 mz easy link
- 12Z Guide
- Futaba 12
- Servos Won't Center
- 7C fASST UPDATE ON RETURNED SYSTEM
- 12Z Switch Swapping Dilema
- 12FG timer question
- Which radio's have pc connection?
- 12Z 8ch to 12ch. How to do it????
- 12fg 1024/2048
- Micro plugs
- BLS251 and voltage
- 6ex and 7c hardware/software update
- what size (mA/Hour) battery in 6V system
- 7C 2.4 Question
- T14 Travel and Limit
- 12FGH 8 Channels only ???
- Futaba 4PK 2.4 GHz
- Delta Wing programming using MZ14 & FASST
- 9c frequency
- Futaba Tx will not charge with Smart Charger
- Fasst reciever voltage
- 12z 2.4 conflict with HT5595
- 14MZ regional code change service from Futaba USA?
- FASST range check timeout and turbine jets
- 12FG range check with a turbine Jet
- 9cap programming for robot use
- Dual 2.4 Ghz Futaba Receivers
- 14 MZ programming
- 127 receiver
- Crystals and radio range
- 12z channel assignments
- Futaba receiver battery help
- 7c fasst mixes
- Using the T9CHP with the Horsefly
- R617FS receiver
- 7c faast ssytem crow mix?
- Futaba Club (I think) question
- help plz
- 14mz trainer mode
- wondering if Futaba will match the "giveaway"
- 7 CAP Timer
- How do I get the authorization for return of my 6EX
- 7c software updated on returned system
- FP-T7UAF SUPER
- TM7 binding
- TM-14 2.4G
- How do I send my 6EX in for update?
- 12Z?
- Servo voltage.
- Mode II Config?
- batteries
- Exchanging models between 14-MZ and 12-FG ?
- 2.4 Question
- R608FS RX
- Need Help with 12FG
- Help w/ choosing 3PK
- T6EXA Stick Fell Out.
- Receiver 6014FS Futaba
- T6EXHP signal lost
- FASST Test Station checkout procedure
- TM7 Problem?
- FUTABA 9ZH WC2 Module help
- fast fasst repair
- 7C FASST 2.4 firmware upgrade
- Sliders on a 12Z? 12FG looks to have them
- 12z and 14mz 2.4 configuration?
- R6014FS Battery Connection
- R617 resolution
- 14MZ Serial #
- 2 engines with 12FG
- Balancer for the 14mz
- TM-7 Question
- R617FS Question
- 14 mz mixing variable rates
- The R6014FS 2.4 combo just kicked over another month
- Another 12Z question
- MOVED: Which Futaba to buy, non 2.4
- MOVED: New T6XA in the box just opened !!!
- 7C FASST firmware update
- RF strength?
- Futaba 10C
- 2.4 for 9C
- Difference - Futaba R607FS and R617FS Rxs.
- futaba fasst
- 9C Complex mix (Mini Ultrastick) - problem :(
- BLS Servo resolution
- will a trainer cord work between a 7UAF and a FP-T4NBF?
- R122JE Rx signal problems
- 7C FASST and Simulator
- S148 servo's
- Futaba Module for 9CAP
- Futaba 12Z
- Futaba 7C 2.4 GHz model match
- futaba 12fg - trainer system - FF8 as student transmitter
- Revolutionary Radio Idea
- TM 8 compatibility
