- Flaperons on 4 ch Rx
- Dual elevator servos
- 12Z Servo Sync issue
- AM or FM ?
- noobie need a suggestion
- futaba 9cap
- 14mz fast charger
- Charging a 12FG
- Multi-Point Curve On PMIX?
- Proportional Smoke Pump Control
- flaps
- Range check with a synthesized module
- Chan 04 Crystal
- which is best for my Futaba 6chnl 2.4mhz fasst??? battery power?
- old FP-T6NFK TX, looking for compatible micro RX
- can i use Futaba 6ch fasst 2.4 mhz in a large gas plane??
- 6EX-2.4GHz channel assignments
- Can I change futaba 6 ch 2.4 mhz ????
- Center me Gimbols!
- Will a TP RF module work in the 3PK radio?
- Burn-Rate
- Option of Line-Spline and VTR Curve Mix
- 12Fg with R5114DPS
- 601 Amp backplate pn?
- How to setup T9chp with Blade CP Pro
- DSC PINOUT
- Problem with Futaba 12Z system
- Radio woes
- 2.4 14MZ antennas
- Throttle Failsafe??
- GY601 problems!
- 12Z 2.4 Module vs new 2.4 12Z System ?
- Futaba 3PM 2.4GHZ FASST radio question
- syncronizer MSA-10 question
- TM-8 module with 9zwcII ?
- Receiver for 1994 Futaba Skysport transmitter
- 7CAP mixing
- Servo specs/Old servos
- 12zhp tranny
- 6EX-2.4GHz FASST and 6 volt battery
- FAAST MODULE RE 9C
- 14 channel FASST rx
- T7CAP Odd behaviour
- Futaba 6EX European Version
- Digitals and a R127DF
- 2.4 7C
- 6EXAS? or 6EX? Help please.
- 7cap mixing problem
- 9C/9CS Synth. Transmitter and non Synth. recivers
- Is the 9C soon to be discontinued?
- 9ZAP WCII - Service menu
- Futaba trainer system question
- Differential thrust with 9CAPS & 5-Ch receiver, possible???
- How to set failsafe in HRS mode-3PM 2.4 Fasst
- 9252 Servo oscilation on UCANDO 46 Help!
- Futaba S9301 info Spec...
- 12fg from futaba
- Servo Test under Servo Monitor of 12FGH
- Futaba 3PM 2.4 FASST
- Flap --> Elev mix on 14MZ
- 12Z ugrading Software?
- 2.4 FAAST Receivers
- Futaba 7CAP battery
- Whats the difference in Limit and Travel???
- What's the difference?
- Noise Sensitivity: 1024 PCM vs G3 Mode B
- enabling all channels in chinese rf module
- R5114DPS receiver question
- 9CAP rudder and Nose servo ?
- T6EXH and R127DF
- 9C SUPER FASST?
- 9ZAP WCII - LCD screen
- Flying wing & 12z Tranny
- 12Z vs 12FG
- Cycle batteries
- R5114
- T7FASST and T12FASST Latency
- Futaba 9C super issue--Need help Bax
- 14mz Flaps. Help needed.
- 12z cant seperate ailerons and elevator
- 9ZAP WCII - RF off
- Can I use this on my Futaba R603FF receiver?
- Dual servo reverser.....
- 7C battery drain...
- Fasst Modules
- T6EX Fasst mixing for two elevator servos.
- Futaba 3PM 2.4 FASST with analog servos?
- Tacho-Sensor
- FASST MODULE SPEED & RESOLUTION
- 6EX 2.4 mixing for two elevator servos
- A few questions about 8U and spread spectrum.
- SERVO Setup
- Remove module when using the sim?
- Using a skysport as a buddy box on 6ex fasst
- stick gimbals the same on 7C as the 6EX?
- Futaba 6 Channel Repair
- DG1 and DG2? Can you explain more of what these are and what they do?
- T9CAP Dual Rate Change in Trim
- futaba 7c / ucando rudder glitch:help
- Color Stick
- 7CAP Gimbals
- SKYSPORT 4 MODE 1 OR 2 ???
- GY611
- Futaba 3PM 3-Channel 2.4GHz FASST Radio System batteries?
- 9C- Issues
- Transmitter trigger grip.
- futaba skysports 4 , broken wire
- 6 EXAS Transmitter - Model Settings
- How to program elevon on 14mz
- Futaba duel rate Transmitter usage
- T9CAP Transmitter Rear Cover
- Matching slider to servo travel
- Why no crash reports??
- Flight conditions on FF9
- Dust and Futaba receiver.
- Rudder to Throttle
- Receivers useable with 9CAPS PCM
- operating CH 9 on 12Z
- 6ch electron with 9c ?s
- 6EX fasst buddy box setup
- Futaba 4YF-FM subsequent charging time please?
- Futaba 4YF-FM Charging time please?
- Futaba 12z/14mz and TM14/R6014FS
- Burned Futaba 3004 servos
- FP-T7UAP transmitter with FP-R127 DF receiver
- "Throttle Cut Warning" Lock-up on 9Cap
- Limiting Elevon Travel with 7CAP TX
- 12Z question
- 9Z WCII Synthesizer Module
- Trainer Cable
- 3PK-PCM servo glitching
- Futaba 9ZHP PCM 1024
- Thottle kill switch
- 9Z WC1 setup for dual elevator and aileron servos Krysta, Bax anybody
- S 3305 Metal Gear Servo
- Servo Recommendation Please
- BAse loaded antenna on g3?
- Servo speed
- AM 29Mhz R112JE reciever antenna length
- MOVED: Throttle arming switch
- 9C 2.4 module & r606fs receiver
- flaperon on 9c
- 2.4 on dual receivers.
- 12Z Programming question
- Bent FASST receiver antenna.
- Futaba FASST System Deliveries
- 12zh dual rates
- Warranty Question
- 8UAPS
- 8UAP-S and e-ccpm
- MZ-12 lock out issue
- S9254 Servos are **failing inflight**
- 9CS Throttle Programming Question
- burnt resistor in my charger
- Futaba 6EXHP model settings?
- 6EXA Range Problem need Futaba HELP
- A quick question about the range test.
- T14MZ Dual Elevator question.
- EXAS and EXAP
- 14mz auto crash damage.
- 9303 futaba servo
- 12zh ffc?
- 7C 2.4GHz on Towers site
- Futaba 2.4Ghz modules question
- 7CAP no display
- 3PK UPGRADE: FUTABA 2.4 FASST MODULES
- Futaba R319DPS 9-Channel PCM Receiver Synthesized
- Problem with FP-6NFK
- R319DPS Receiver
- help!!!!!!!!!
- When will the 12FG be available?
- Servo numbering
- Futaba Digital RX: Why "Ni-Cads Only?"
- need to know the difference between these receivers
- 12z reciever
- FUTABA 7 CAP 2.4
- T7CAP Dial Button INOP
- S9451 Digital Servo Questions
- Reciever and battery redundancy
- Charging the 6 channel 2.4 Fasst transmitter?
- can the rx battery plug into any channel?
- Grips for 12ZAP?
- HELP!!!!!!!12Z LED BLINKING, NO GREEN
- 12MZ AFR mode selection question
- Upgrade software 14mz
- 9CHPS & Removing RF Module?
- FX-40 updating software question
- 9C airbrake problem
- Futaba 9zap
- 6EX 2.4
- That Infamous Ceramic Filter
- Futaba T7CAP
- 12Z Multi-Engine Mixing
- 9C Elevator-Flap mix
- Did I just destroy my FASST receiver?
- 7C Service Problem - FUTABA PLEASE HELP!
- Futaba 2.4 GHZ Brochure
- 9CAPS Twin Throttle Control
- 6EX2.4 program mix firmware?
- R149DP 9 CHANNEL RECEIVER
- 9257 Tail Rotor Servo
- R606FS 2.4 GHZ Receivers
- 7CHP and pitch curve range
- Gold Sticker Question
- old futaba receivers
- MPDX channel expander
- Question regarding the MPDX1
- 14Z on 2.4
- Crystal color codes??
- 12Z and 2.4 FASST module
- 12Z Temperature Related Screen Problem
- Fasst TM-8 module in Tower Hobbies
- Futaba 12FG vs. 12Z
- 12FG 2.4 radio features and manual
- gear set for the 9001's?....per Tower?
- Confusing Instructions
- Mysterious PCM Reset on T7CAP
- 9254 servo temperature
- Servo slowdown on 12Z
- T6EX transmitter battery voltage display
- 3PK Super, manual error?
- Possible to use a 6 channles RX for F3F glider?
- Futaba 6XA dual elevator servo mixing
- Availability of Futaba 7 ch. 2.4 GHZ
- Current carrying capacity of a 149DP reciever
- RX ?
- SPLIT ELEVATOR SERVOS ON MY GP RYAN STA
- Futaba 3PM-FS HRS
- R5014DPS Lost ID #
- Futaba Micro Servo?
- compatability
- Availability?
- NiMH Batteries
- Intermittant problem for T7CAP
- MSA-10 connected to 4 ail servos
- only 8 channels using a 149DP anfd the 12Z?????
- R319DPS receiver and 9CAP Super
- Equivalent of Futaba 8UAF system
- 2.4GHz Fail Safe
- 149DP PCM Receiver
- 6EX-2.4 Programming Question
- Delta Wing Mixing??
- 7 Channel 2.4 GHZ Air Radio
- 14MZ won't change Freq. in the plane
- Charging Batteries in Receiver
- Futaba 9CAP Throttle Lock for Electrics
- warranty
- Teather balance point
