PDA
View Full Version : Futaba Radios Direct support forum
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44
  1. Set fixed output on channel 7
  2. Futaba 10CG LCD replace
  3. Using trainer just for channels 7 and 8
  4. GY-401 going bad?
  5. Futaba T8FG 2.4
  6. Replacement Switch for 14MZ TX
  7. 12FG Model Recovery Software - what is it
  8. Futaba T7C. Size of Coaxial DC charger plug?
  9. T8FG V4.0/1 software update. Battery alarm clarification please
  10. Timer set up on FUTABA 10c
  11. R6106HFC won't link to 8FG
  12. Futaba R2004GF 2.4GHz FHSS Range
  13. 7C 2.4 MHz Flap set-up help needed...
  14. R617FS made in China
  15. 10C question
  16. 8fg Throttle cut... solved
  17. want flaps on 3 pos switch: 10cag radio
  18. S3306 application guidelines
  19. T12fg dual rate and expo
  20. EUROPEAN & US SBUS SYSTEM COMPATIBILITY
  21. 8SSAP for 2.4GHz?
  22. y harness on 7c 2.4 for gas plane
  23. TM-8 Range check question
  24. 8FG wandering center w/ elevator dual rates
  25. T12FGA Firmware update to 3.0 has weird problem for Range Check
  26. Futaba T7C Transmitter Reverse
  27. Setup Endpoint
  28. FG8 setup flaperon/dual elevator
  29. S Bus with Y-lead
  30. 4 Aileron servos
  31. 8U with low reading volt meter
  32. R6008 receiver question
  33. Using HH only
  34. Rapid green light blinking on TM-7 module
  35. replacement t/x case required
  36. 8FGA Firmware Upgrade for S-FHSS ?
  37. Trainer control from 6EX-2.4 to 7CAP-72
  38. Faast: 2 planes, 2 Rx, 1 Tx, same problem
  39. CIU-2 Help
  40. Two Aileron servos on a Y-harness
  41. gy 701 prob
  42. 12fg software
  43. Where Are The 10CAG
  44. MOVED: 14mz Touch Screen Replaced...new pots....
  45. 8FG Super Question!
  46. Futaba Trade Up Promotion
  47. MOVED: 4PKS upgrade
  48. powerbox or not to powerbox!
  49. if I use elevator-aileron mix?
  50. GY520 Gyro
  51. T9CAP stick broken
  52. FF T10CG and R6014HS binding problem
  53. Help regarding T1o CAP
  54. 8fgs 3 pos switch question
  55. 5114 rx lost channel
  56. New 12z user
  57. Futaba 3010 Servos
  58. Just bought 10CG & 7C 2.4 FASST systems
  59. 10c flap/elevator mix
  60. Futaba 8FG super -servo speed adjustment?
  61. SETTING UP 7C2.4 FOR 30CC
  62. Manual of 7C a disaster
  63. Radio placement with gas engines
  64. Differential thrust for seaplane, Futaba T7C
  65. PMix help
  66. BLS451 Gear Damage
  67. Futaba TX abd Park zone T-28 PNP
  68. Futaba S3003 Servos
  69. charge jack
  70. New to Futaba
  71. Trainer switch
  72. futaba receiver question please?
  73. Why cant I get a straight answer out of Futaba service???
  74. Fubaba BLS153 servo - two broken shafts.
  75. variable dual rate
  76. Reversed power on Futaba R6014HS Rx
  77. 9C 2.4 ghz module and R2006GS S-FHSS
  78. R603FS receivers...
  79. Trying to activate THR>RUD mix in my 8UAF
  80. Trim mix T9ZHP
  81. TX 9ZHP - THR left to right
  82. futaba 6ex 2.4gig
  83. T12Fg with R5014DPS
  84. S.BUS System
  85. help regarding futaba t9cp
  86. aileron servos and Berg receiver
  87. Futaba BLS153 servo - any metal gears for replacement?
  88. Futaba 3PM 2.4ghz Fasst controller fell and snapped antenna cable... Help?
  89. Flaps on 3-pos switch - Stumped.
  90. fasst vs. fhss
  91. 12Z Timer Questions
  92. 9ZAP not working with TM8 2.4 module
  93. sequencer and 14mz
  94. 14MZ - use of the rotary key
  95. Help! Mixing elevator with flap - 8U
  96. 8U WONT KEEP SETTINGS
  97. 3PM FASST Plastic Housting
  98. 12FG Trainer Cord
  99. Help setting up T8FG for use with xaircraft x450
  100. Synthesized Module
  101. Setting throttle curve in 7C
  102. Futaba Trade-Up Program
  103. MOVED: FUTABA TELEMETRY
  104. More 6008HS - Problem found!!!
  105. 10C radio having binding issues
  106. Going from 4.8 volts to 6.0 volts
  107. LiFe in 7CAP 72 Mhz Transmitter
  108. 40.695-41.150 frequency image?
  109. T8UAPS - intermittent
  110. Is there a proposed date for the 18MZ?
  111. T8FG Throttle Cut
  112. 7C Lost Its GUID
  113. Linkage-induced differential
  114. New 2.4 Radio: 8 ch. with S Bus capability or 10 ch. CAG?
  115. Gasser Set Up question
  116. Using ch1 & ch 7 for dual aileron servos
  117. 6J System?
  118. 12 fg programming question
  119. BLS 651 GEAR
  120. programming help with my 12 fg
  121. FUTABA 4YBF
  122. T10 CAG Throttle cut
  123. Making a 3 channel respond like 4 channel
  124. need new stick asm.
  125. error404.
  126. Strange behavior - Rx 6008HS
  127. 9C mistake
  128. 14mz LD/RD ?
  129. MOVED: R617FS Fail Safe and Rx question.
  130. FUTABA 6EXA 72mhz screen.
  131. Futaba 8FG physically change from Model 1 to 2
  132. Futaba radio sistem question please.
  133. 9VAP and TM-8 work?
  134. 6203SB not working with SK720 on SBUS
  135. Floating Aileron Servo's
  136. Linkage-induced differential
  137. Having trouble with the 8FG update.
  138. Broken antenna base
  139. help with stick priority with 10cg / 401 gryo
  140. throttle working wrong way round
  141. .
  142. Saftey Switch for Electric Motor on 8FG
  143. MOVED: FASST BNF compatibility?
  144. can I mix ch5 and 6 on my T7C transmitter?
  145. What is a J-Series Dual Sx (W) Extension Cord?
  146. 8FG Super & 6014HS
  147. Backup for my 14MZ
  148. Futaba S9156
  149. 10C vs 8FG dual rates
  150. Futaba 7C setup with Hobby Lobby's F/A 18E
  151. Can I use a field charger with my 8FG?
  152. Futaba TM 8 Module
  153. 7C ch6 to be controled with switch "E"
  154. Difference between AIR and HELI. Just curious
  155. 1
  156. Need help with Futaba 8FG
  157. Binding R617FS
  158. Futaba 7C Vector Thrust Setup
  159. can bax test the cgy750 for firmware bug
  160. Futaba R6203 Sbus only 8channels??
  161. Futaba 8FG Super
  162. R6014 HS link problems
  163. FG8 - is it CE everywhere
  164. Vinatge 1978 ID needed
  165. problem with cgy750 swash mix
  166. Crow on a 9Z with throttle curve?
  167. 8UAP problem
  168. Connecting a old FP-7FGk as buddy to newer T6XA
  169. My Radio channels got mixed up
  170. Battery for FP-T7UAP PCM1024
  171. Fasst rx comparison chart
  172. Help programming T8FGS
  173. Good place to get a UltraPac?
  174. Having trouble with TM7 Module
  175. Throttle Position to set dual rates on a 10C
  176. 8fg..will it support FHSS with a software upgrade?
  177. twin elevator set up for 7c 2.4
  178. 8fg charge plug size?
  179. Getting a Futaba 8UAP Tx out of the 'H' HELI mode in the model naming menu
  180. After Market FASST Receiver Antennas
  181. 12Z Sliders.
  182. A couple of questions for Bax
  183. Trainer Box Capability 10CAG and 9C
  184. Futaba and carbon fiber!?
  185. Throttle stick on 8FGH?
  186. 8FG can do this?
  187. Trading models setup on 8FG
  188. t8fg flaps ,gear speed ?
  189. futaba t8fg next update
  190. Is this mix possible?
  191. 6014HS and Power Box RRS
  192. dual throttles
  193. 6EXA Question
  194. 10 cag flap adjustment issue
  195. New 8FG won't bind.
  196. NEED COMPLETE BUDDY BOX MATRIX
  197. New Futaba radio
  198. neck strap holder loose on my12Z
  199. 9CA TX with SPECTRUM
  200. cui-2 what does it work with?
  201. futaba 12fg tx/rx linking trouble
  202. 10CAG F/S not working on throttle
  203. conflicting reciever information
  204. Configuring heli retracts with 12FG
  205. FP-R127DF Receiver Crystal
  206. 12FG - gyro sensitivity - servo monitor display
  207. R6208SB Setup
  208. Can The GY401 Be Used Without The Remote Gain?
  209. servo hum
  210. futaba 7c /flaps
  211. 6014HS Rx battery inputs
  212. 14MZ - Backup battery?
  213. S.Bus questions
  214. Radio from Hong Kong...?
  215. R6203SB Programming?
  216. t7cap program to t7c
  217. Charging the 8FG with Accucycle Elite
  218. programing question
  219. 8FG mixing
  220. 6EX-2.4GHz Channel 2 and 3 Reversed
  221. Fg8 mixing problem
  222. 7CAP Throttle Exponential ???
  223. Radio storing question please.
  224. 12Z flap to elevator mix
  225. Receiver comparison
  226. DG1 and DG2 outputs on R6108SB
  227. Buddy box question for 6EX and a 7C
  228. Powerbox ???when and why
  229. Futaba Gyro Voltage
  230. 10C and ailevator
  231. flap control for 6exa tx
  232. Futaba 520 Gyro voltage
  233. 3PKS Won't Bind with R603FS
  234. Difference between R6014HS & R6014 FS
  235. 12C Crow Mix
  236. Default Futaba support - does it exist?
  237. Futaba 8 Channel Receiver Question
  238. futaba stick calibration with new software
  239. 8 Channel FASST Rx
  240. 12FG and BLS 152 issue
  241. 12FG Twin throttle - rudder coupling mix question
  242. GY-701 question
  243. Will new (longer) lever arms on 8FG Super fit older 8FG radios?
  244. Trainer 12z
  245. Futaba charging
  246. futaba 7c 2.4
  247. R6203SB reciever
  248. T12FG update change docs
  249. Futaba t6ex Short Cut!
  250. 8FG dual elevator programming
