PDA
View Full Version : Futaba Radios Direct support forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44
  1. 9ZW11 Conversion
  2. Changing channel
  3. Futaba T6XH Shading around computer display
  4. Cycling 6x battery
  5. Futaba 6YG can it take a 48 crystal set
  6. Can i use Airtronics "z" wiht futaba "j" connectors?
  7. FP-7/8UAP antenna?
  8. 9253 not working when brand new???
  9. 9001 gear set
  10. Does Crystal have to be a matched set
  11. How do I setup my Twin using 2 Throttle servo's?
  12. 8U Module?
  13. Futaba T6XH Transmitter batt upgrade?
  14. Broken Switches
  15. Futaba SkySport 4 Help!
  16. Futaba 9C, Mix6 and Mix7 questions...
  17. Futaba 127 DF RX problem
  18. Part numbers for broken switch
  19. Futaba 9C Stick Tension Adjustment
  20. 9z question
  21. Quick Question on Futaba Rx
  22. 9CAF Thottle DR Need your Black Magic
  23. futaba radio question
  24. Is Futaba going to replace the 9zw2
  25. question about programable mixes.
  26. Elevons with 4 servos on 9cap How to ?
  27. 9CAF Is it safe to use while on charger?
  28. Low Band and High Band
  29. Questions about multiple servos and batteries
  30. mixing on the 9Z
  31. 9CAF Elev-FLAP mix instructs yeilded Elev-AILERON mix?
  32. 6XAS Trans./Battery & Memory loss
  33. Futaba 8UAF Super TX help please
  34. Sticky Sticks on my TX
  35. 9CAF adjust center on VR SW?
  36. 9C servo will not return to nuetral
  37. 9C possible applications of blank channel 5
  38. GV1 Hidden params
  39. Replacement Potentiometers for Futaba Servos
  40. GV-1 govenor use on a Gas X-Cell via flywheel magnet coupling
  41. futaba fp-r127df rx problum
  42. futaba 9252 flutter
  43. tf8uaf vs tf8uafs
  44. Snap Roll switch for 7UAFS
  45. Basic 9c question
  46. 6xh transmitter
  47. Problems with new 9z
  48. Futaba 3PDF Magnum radio reset???
  49. 9CHP to 9CHP Buddy setup with Futaba Cord Problem
  50. 9CAF antenna position for ground testing
  51. Compatibility question
  52. Is their a difference between GY-401 and 502?
  53. 9c airbrake question
  54. 6XASP and Buddy Box Setup
  55. 6XAS Discontinued
  56. Please read before posting....
  57. 9cap Question- I Need Help!!
  58. How-to sensitize the throttle around hover seting for a plane with a Futaba 8U TX
  59. 9C Synthesized Module
  60. Range Check question
  61. older r127
  62. 9caf campac
  63. 9C and a "full house" glider
  64. Futaba 9405 servo
  65. is this a obscure (older futaba)? Tri Seven X
  66. GYA 350 gyro in a heli?
  67. Futaba 9C Lock out
  68. 6vh trainer setup?
  69. Futaba Micro flight pack
  70. 9Z with flaperons and spoilers?
  71. 6xas gear set up
  72. 9Z - twin RUD servos on seperate channels?
  73. One from FP-R129DP receivers
  74. 9Z mixing question
  75. Fp-t5uap Pcm1024 Rx
  76. Futaba 9ZAP WC2 Question?
  77. new 6exa radio
  78. high band / low band
  79. Re: 6XAS radio...awkward programming
  80. 9ZAPWC2 Module
  81. 8UHP lcd contrast
  82. ew futaba 6exa 6 channel computer radio?
  83. Bring back rudder dual rates
  84. T6XA - Master/Slave - Ch 5/6
  85. shaken all over
  86. Narrow or Wide band?
  87. Buzzing Servo
  88. Info on sending items for service, rates, time frame, etc.
  89. futaba 6xas transmitter programming problem
  90. Having problems getting a loose leaf 9C manual from Futaba Service
  91. 9Z synthesiser module
  92. V-tail programming problem
  93. 9ZAP tx Module
  94. Futaba 9Z - Alarm Light
  95. Is the Robbe FS 500 servo made by Futaba?
  96. T6XAS question
  97. Futaba S3004 Dimensions?
  98. 9z current draw?
  99. Mixing on FP-T7UAF SUPER
  100. servo chart
  101. 9c charging question
  102. Antenna conduit help.
  103. 8u Fm51
  104. S9351 Hi Torque Servo
  105. FP-R114H Rx. use w/ BEC?
  106. multi engine throttle servos
  107. flaperons/spoilerons/mixing in acro mode on 9c
  108. crystals
  109. 8UAF Memory Battery?
  110. Charging Transmitter Batteries
  111. 9CHP with G2 ??
  112. Futaba 9 CAP Update???
  113. When to re-calibrate
  114. Futaba 3001 Sevo~
  115. Programing 8U for retracts,flaps etc
  116. 9C--how to activate idle ups?
  117. Bax RX case
  118. Futaba 6AXAS
  119. Mode 3 for a newbie heli pilot
  120. Futaba Gyro 350
  121. Am Vs. Fm
  122. 9C user channel assignment
  123. Fiutab 9ZAP
  124. Futaba S9204 gearset replacement?
  125. Crystals and mod.
  126. Power supply to Rx from ESC ok?
  127. Reseting A Zap Radio
  128. How to flap elev mix?
  129. 6XAS and voltmeter
  130. Terminology: Servo throw and %
  131. S28's and 48's ?
  132. Zap with 16K campaq
  133. RX Case
  134. 9C Trim Question - Flight Mode(s) ?
  135. Reseting the User Name Registration On ZAP
  136. black wire disease?
  137. (C diode
  138. Futaba Super 8
  139. setting up Giant Extra
  140. Reveiver Wire
  141. Futuba 6XHS Worth the money
  142. Need charger help for Conquest Tx.
  143. servo bounce skysport 6a
  144. radio
  145. NEED HELP FAst
  146. One more dumb dumb question.
  147. Futaba 3fr Fm Radio
  148. Did I mess up in ordering a 9CAF?
  149. Service Price Question
  150. S136G retract servo
  151. 8UAF w/148 RX - flaperons disables ch.5!?
  152. flaperons with a 6XAS
  153. Quick Futaba Digitals Question
  154. crappy transmitter help
  155. 9c/dsc
  156. 6Xas and PA1
  157. 6XAS and PA1 pilot assist compatability
  158. FUTABA GYA352 GYRO Assistance please
  159. Help with making a THR to ELEV mix, 9C
  160. Fut 9151
  161. Futaba 9CA Programming
  162. Altitude Indicator
  163. Futaba 4VF and Aerofly simulator
  164. R127DF High/Low Band Identity?
  165. Futaba "J Series" radios
  166. Futaba-FG Series radio
  167. 8uhp ccpm mixing
  168. T8UAP and fp-r127df gone crazy
  169. 9Z module swap?
  170. What to use for servo grease?
  171. 6XAS and a PA1 assist hookup & program?
  172. 9 C trim
  173. dual rate to three position?
  174. Disable CH7 Knob on 8uaps?
  175. Why my digital servos chatter?
  176. whats the difference in pcm recievers?
  177. Safe to use a 6v battery with G154 Gyro?
  178. 9Z Trims (C vs M)
  179. Servo for elevon
  180. futaba receiver
  181. Got my FP-T4NBF (Conquest)... Now what?
  182. Trainer chord for older FG to Skysport 4?
  183. Futaba Super 8 TX
  184. G153BB gyro question
  185. Possible 9C manual error re snap roll
  186. 9CH CCPM question
  187. TX Batt
  188. Frequency Module in Futaba Radio
  189. 9ch and module question
  190. Old Futaba reverse servo
  191. 6 volt system
  192. How do I check for 9C module damage?
  193. Can one stick nob control two servos?
  194. 9ZAP not working w/ R309DPS
  195. Futaba PCM 1024 / R149DP question
  196. 6XAS exponential
  197. Futaba S9302
  198. Futaba 9001 servo's
  199. 3PJ Module question
  200. 3PK modules
  201. Retaining tabs on RF module
  202. Need Help With My Motor!!!Expert Needed!!!
  203. Futaba 9C fast charging
  204. AnnMarie or Bax, Please help
  205. Bad Rudy - Need New 8UAF-TX
  206. T5NLP Tx Trim problem
  207. Futaba Conquest info needed
  208. Is this a problem
  209. am rec question
  210. Futaba 3PJS Frequency query
  211. Fp-t5uaf
  212. Crystal Type 72-7
  213. Servo speed
  214. Module
  215. Use with Simulators
  216. Evaluating used servos
  217. Output shaft
  218. 9CAP,can't get aileron to work,HELP!!!
  219. where to get servo gears
  220. older futaba servo's
  221. 9C EPA on Ch9
  222. Switch Harness Question
  223. Fut. Analog servo dead band
  224. charger included with 9CAP
  225. 9CAP Dual Rate Trim
  226. 9ZWC question
  227. Futaba Servos
  228. Mode 1 9C
  229. 9CAF Help
  230. change am tx to fm
  231. Futaba S5101 servos
  232. Elevon Function with 9cap
  233. master the 9zap
  234. charging 8U tx
  235. T8uaps Programming Setup Help
  236. Skysport 6H twitch with movement of Tx
  237. S9206-Use Duralite package?
  238. R148PCM OK for 9Z Synth
  239. Throttle cut on 9Z
  240. FG Compatable Rx
  241. futaba t6xas question
  242. Question about full span ail. on US40 and 9C
  243. Throttle kill switch
  244. 309DPS question
  245. 9C dual throttle mix
  246. servo chatter y
  247. 6v with 350 gyro?
  248. 9zap power indicator
  249. 9CAP and Airbrake function
  250. Futaba FC-28
