- Data transfer on 9ZHP WC2
- 9C with FMA M5 Rx = servo jitter
- 14MZ Frequency ?
- Futaba 9Z WC2 Can't change frequency
- Replacing 6XAS battery
- Saving Trim Settings on FF9
- 9 CAFS Radios
- 9CAP Super - Run amok?
- 7 cap
- 7 C Radios
- Futaba 7 CAP -cable to simulator
- Can all program data from 9C be transferred to 9C Super?
- 14MZ on 50mhz ?
- 14 Mz-- other Rxs.
- R127 vs Hitec digital servos
- R149DP
- 2 channels for flaps on 9c
- Range Check
- 2 stage flap programing in the 9C???
- Robbe Futaba FC-18
- Futaba 9CH Synth Module out yet?
- 9C Micro receiver for J-3 Cub
- program 9c for smoke system using chan 9
- Synthesized TX modules...unavailable???
- Servos jitter and go crazy when sitting by plane
- Futaba 7UGF
- FF6 XS unequal reaction to Elevon changes
- Futaba 6exa problem
- Frequency scanner
- 14mz Mixing error?
- Returning Receiver to be checked
- 7CAP Timer issue turn-around?
- faulty receiver or crystal?
- this forum looks dead, but what the heck,,,Help with gear set for a Futaba 9450
- Futaba 7ch Receiver broken ?
- 14mz Switch harness?
- Dropped Futaba 6EXA now no throttle control...
- S148 throttle servo+glow driver PROBLEMS""
- Super Seven Programming
- DC crystal in SC receiver?
- Bill Baxter-Follow up question to Futaba FG Gold radio gimbal replacement procedure.
- Heli Flight pack in a plane?
- 3152 geartrain vs. 3010
- ZAP and Campac questions
- 14MZ Range requirements?
- Servos dying
- 4YF crystal and antenna?
- Futaba FG Gold Series transmitter throttle stick replacement procedure.
- Shouldn't this be in the manual?
- 14MZ governor screen.
- Futaba S3050 vs S3152
- 8UAPS PCM
- 14MZ case
- 7c setup question
- Futaba Challenger 4WD AM Radio
- Change Expo loose D/R ???
- charger for futaba field force 6
- Two 9C Tranmitters not reacting the same.
- T9CAP Sub-Trim channels transposed
- Gyro applidcation confusion.
- 9Z programing problems
- 14MZ FAQ-will it ever change?
- Ultra Stick & 9C - Airbrake & Extended Ail ?
- MSA-10
- 14z timer screen loss
- MOVED: Does Any Retailer Have The 9CAF Super With Synthesized TX & RX In Stock?
- "3151 MG" servos
- Noisy S3002
- Bouncing Servo
- Dual Rates on 14 MZ
- Hi/Lo Band on Tower Hobbies System 3000 Rx?
- 9CAP Dual Elevators Ailerons - Slave Delayed
- Futaba 6XAs
- Futaba 2PL Radio-What do ya think?
- Futaba 9C synthesized
- my 3305 servos keep glitching
- Futaba 9C Synthesized
- R149DP Receivers
- Help with electronics hookup
- Interference on PCM Rx?
- 9Z WCII Broken Antenna
- 14MZ - Ultrastick Programming - when?
- 14MZ Idle down
- Anodized Gimbals/Stick ends for Futaba 9C ???
- Problem with radio system
- lighten ratchet stick on 6EXA
- Futaba T6EXA
- Aileron Trim adjustment set up backward
- 14mz channel locations on reciever
- Futaba T12Z?
- Alpha Trainer Radio Compatibility w/futaba ?
- What freqs does Futaba offer?
- This is a dual post, please DISREGARD this one
- Question regarding the cap7 transmitter
- Changing Switch
- 14 mz music playback problems
- DR on the 14MZ ??
- MOVED: Hanger 9 Super Cub Strut problems
- 9CAPS Trainer function question
- Why did the connectors get swapped???
- 14MZ - Flaperons once more
- 9C Super Dual Elevator Servo Fine Tuning ??
- 14MZ- annoying beep's
- 14 MHZ QUALITY PROBLEMS
- MORE 7 CAP PROBLEMS
- Airtronics compatible?
- Idle-Down Programming Question
- S3004 Throws
- NiMH batteries in 6EXA
- S9206 gear toubles?
- 9c upgradeable???
- 14MZ Model Name Entry Error
- 14MZ...Dual Rates and Exponential
- Buddy box
- Futaba Micro plugs
- 9CAP control assignments
- Hobbico/Futaba please respond
- FF9 Lockup/Failure
- GYA 350 gyro
- 9z and channel 9
- 14mz dual rates/expo
- R127
- 9C--Where do I plug in my servos???
- 14MZ Team Futaba Download Files
- 7C Question
- 14mz multiple sound bytes
- 7C stick tension
- T3VCS Throttle Ratchet
- 14MZ Headphones
- S3004 abd ///////////s148 servis
- fast charging transmitter
- Upgrading from a 7UHF-S to a 9C
- MOVED: WHAT DO I LOOK FOR IN A "USED" Tx & Rx
- 9CHP short circuit
- Phase Shift
- P mixes won't work with dual elevator servos on 9C??
- MOVED: GWS Pico RX!?
- New 9CAPS out the box, servos don't move
- R319DPS Ch 00-99
- Plz Help with 6EXA and 4YF as trainer
- Futaba 9CAPS
- Lithium Battery for 9C
- 9CAP Aux' ch 9 end point adjust???
- 6xas memory
- 7CAP turn on question
- Futaba 9252 Digital servos
- Crystal Question...
- June ?????
- Futaba 7CAP CROW
- JR servos with Futaba Radios
- New 9C user - Flaperon/Elevator mixing question
- Crystal question
- 9C SYNTHESIZED MODULE (TP-FSM) 35Mhz ????
- MOVED: Re: Aerofly deluxe
- 14MZ Conditions ??
- Futaba 9ZWC2 programming issue...
- 9C 75mhz module...
- 9z wcII idle up
- 9 c question
- a different control device
- Question about 9Z battery
- Futaba S3151 Digital Servos $$$$$$ cheap
- lithium ion glitch
- 14mz range check
- Bad Servo or Bad Receiver
- 14mz sound assignments
- Xtal Holders
- s3003 in a 4 star 120?
- Crystal Confusion
- Club 14MZ and expected RX delivery
- Futaba 2PH good or bad?
- Confused about my new 9C Super
- 14MZ/CR-2500
- servo in aluminum rail?
- futaba 14mz RANGE / jet F16
- Futaba 7NFK9
- RX bad or normal
- FF6 and 6EXA set up for training
- Split elev in GLID2 on a 9C
- 9C antenna replacment
- 9C synth module
- CCPM fine tuning 9Z WC
- Skysport 6A
- What is channel 9
- 6EAX radio Replacement
- Need better 14MZ manual
- n\a
- Almost there, just a little more help
- Plastic screen covers fo FF9
- 9ZAP
- Futaba Skysport 4 and Hitec Flight Pack
- 3PK Synthesized which mod-mode
- No help from Futaba?
- 14MZ "Elevon" mix for jets
- Pictures in the 14MZ
- 6exa programming question
- Futaba 14Mz region locked
- 9C faceplate grounded ?
- Switching switches
- Futaba FF7 flip switch replacements
- 14MZ Springs
- Programming a 7UHFS on an Ultra Stick
- 14MZ backlight
- 9c and crow
- TwinStar -- separate engine throttles???
- Which 3PK?
- Help needed on choosing micro receiver for T6XHs
- Range Check with my Futaba 6EXA
- 9C Link Issue -> Bug
- 14MZ
- Crystal in the synthesized rx?
- Synth and 50mhz
- general purpose channels
- Futaba FP-T6FG/K to CSM Interface and Disable RF Output
- 14MZ instructions
- 9z wc2 question/can't figure this one out?
- 14MZ Media player
- SUPERB SERVICE!
- MOVED: Futaba 9C: A User's Guide
- 14MZ touch panel
- How to add expo??
- ACK! Bad 401???
- 14MZ on 50 MHz
- 9CAF Question
- 14MZ idle up settings
- 3002 servos / gear noise
- Futaba s3305 chatters with hitec receiver
- modeltech magic setup
- Custom Programming
- E-Flight and RFI: How Futaba copes?
- 14MZ Flyer's Club
- 9ZWC2 Synth Problems
- 7ch with g401 ?
- 14MZ Cross trims and dual elevator servos with flaperon mixing?
- 9C/8U syn module and power use
- Group to single and back
- More 9C Synthesizer module questions
- 14MZ ?
- 9C TX Frequency Synthesizer
- GV1 GOVERNOR
- MOVED: 6EXA with NiMH battery
- R5014DPS
- Will JR Servos Work in a Futaba RX ?
- 9C: butterfly or airbrake?
- GYA-350 Gyro Operation
- 14MZ pitch->rudder error #2
- 14MZ pitch->rudder mix error
- Futaba 7ch and electric setup...
- 14MZ Acceleration request
- futaba 8 channel
