- 149DP on 29 MHz
- re: the R146iP
- Elevator deflection
- R146iP on a T Rex
- 9Z WCII Question
- 6EXA mixing question
- dual aileron servos w/ 5 channel rx
- is there an upgrade from4ex to 6ex
- FP-R127DF Jitters
- 8UAPS transmitter
- Wc2 tranny and a 3d Plane - config
- "twitchy" servos when TX in PCM mode
- 9 vap
- Flaperon trims, 6XAS,7C,9C?
- 9Z WC2 and dual Rates
- Futaba 7CAP
- 3PK Brake Balance vs. Rate - Confused
- 8u works and 9z doesn't
- Reciever questions
- FUTABA 9C Super
- 7CAP 5chan RX Flaps?
- 9CAP super and 9CHP super.....
- Hi/Low Pitch on 9chp
- can I buy components from futaba for my conquest 6?
- can 7C use synthesized module??
- Futaba 12ZAP Anounced in Tower Hobbies
- 7CAP Broken "B" Switch...Warranty??
- Rx. battery Voltage
- Flaps on Sw G on a 9C
- What's different about the T9CP??
- FP-TF-AM Module... Narrowband???
- Transmiter vs Receiver (PCM 1024)
- rx @ channel 37 verses tx @channel 42 need help
- how to transfer models from WC II to 14MZ
- Is Futaba TX compatible with JR RX
- servo eyelets
- Micro Receiver ???
- FF9
- Skysport 4 modification
- dsc and pc serial connection
- 7CAP Snap Function Inhibited
- Trainer cord?
- 9C Super PCM Mode
- 6EXA CHANNELS MIXED UP...
- Super 7
- Servo question
- troubleshooting radio/receiver prob (1990's futaba)
- Cross mode teacher student link on 14 MZ
- 8UAPS
- Can you use a 6.0V receiver battery w/s3151
- Mode 1 and Mode 2
- type 72-7 & 72-9 crystal application?
- 9Z WC II triple rates and internal battery?
- Futaba fp-t5uap transmitttor mode change
- NiCad Only for S9351??
- 9C super programing question
- Trainer/student with different modes. Possible?
- 3pk wierd problem Pls help
- Sent in receiver for service....
- i think i just blew the mothafukin speed control out!
- Diode in 8UAF Super
- DISPLAY SCREEN T9CHP
- GY401?
- 9ca to 9ch conversion
- Larger Campac Memory available ?
- 72MHz Synthesized Transmitter Module
- Futaba 9ZAP
- AM Futaba T4NL ch 50 legal in U.S.
- 7 CAP
- 6EXA...Flaperon
- 6exas
- Futaba 7CAF transmitter help.
- Waterproof
- 14mz virtual chanels
- 7C and flaps/crow strange behavior
- 9C/9CS Synthesized Transmitter Module 72MHz Question
- Receiver I.F. crystal?
- Futaba 9C failsafe
- Will a JR RS300/310 Rx work with the 9CAP? (Tx and Rx = 75MHz)
- Synthesised TPFSM module in a 9ZAP
- Futaba Spread Spectrum Module?
- 14MZ receiver fix
- Futaba 114F receiver
- R5014
- Difference between R309DPS & R319DPS
- 14mz spektrum??
- Set-up advice for Dual Receivers
- T12MZ
- 9CAPS
- Using data from 9C in a 9CS
- 7CAP Screen going out for second time
- MOVED: 14mz new radio case
- 8UAP dual aileron servo setup question
- R5014 DPS Receiver - Unacceptable
- 9Z WC2 Discontinued?
- 14MZ 50MHz Mode 2 USA Availability?
- 127DF range problems
- S9451 NYLON 1ST GEAR
- 14 mhz mode 2 to mode 1
- 14 mhz
- Transmitter Identification
- FG Series
- 7cap
- PCM will it help
- 9Z - Flaps / Spoilers
- PCM
- 2PL range problems
- Range check problem
- 9CHP Bands
- 9C timer
- 6exa vs. 6exaS
- 9Z - Setting up Conditions
- futaba fg series , module question.
- 9CH Super Questions
- 9 WC2 Questions
- Futaba 6XA programming mode problem
- servo repair
- FM or PCM?
- 9C global throttle reverse - how?
- Flaps/Spoilerons
- Futaba HD Switch
- HD Switch for Digital Servo's?
- fubata receiver 6 v?
- 7CAP Question
- Need some answers
- 9CAP Programming
- How do you disable Ch 7 knob on my Futaba 8UAF
- Can my 9CHP take the Synthesized Module?
- 3PK troubles & questions
- 7 CAP G Switch Crow & Flaps
- Can I run my R319DPS on a 6V batt?
- Ailvator
- how do i join the futaba flyers club
- nine channel use on 14 mz
- 9Z you CAN change modes in FLIGHT!!!
- Poor Futaba support??????????
- R149DP...self regulated?
- 7C display Problem
- Reverse differential with a 9C
- Ailerons elevators mixing
- S3017 Long Servo Arms?
- Transferring 14 models from 9C to 9CS
- Flaps to G switch on T7CAP
- 75mhz Module for the 9C
- Dual Rate Trim Zeroing Error - Futaba 8UHP
- PCM TRANSMISSION INTERFERENCE
- 7c Dual Elevators not trimming togeather??
- 7CAP & Airbrake/Flap Function
- 14MZ 50 MHZ Mode 1
- T7CAP & 7 Servos
- Synthesized RF Module For T3PK
- Link Function
- NEW RADIO -BAD RECEIVER-Stutter-Issues
- 35Mhz R5014
- FF-9 Super: Motor on Switch?
- NYLON 1ST GEAR FOR S9451 AND S9152
- Futaba 3001 Servo Feedback Pot Replacement
- 14MZ and variable pitch setup?`
- 9c
- 14MZ new functions
- 14z with cracked screen
- 9c Super Crash
- 7C and Airbrake
- 9253 servo on 5 cell NiMH??
- 14MZ recent update - new functions
- R146iP burnt out?
- elevator to flap mix
- 6 EXA Flaperons
- What to do with older AM set-up?
- 3110 servo horns
- Juggernaut ESC or Radio/Receiver problems
- Throttle PCM Failsafe
- R149DP and dual power supply?
- Weird channel 1 (ailerons) interference
- 14MZ AFR (D/R) question ???
- gyro setting question
- Module Crystal Change
- 50Mhz Band and Antenna on 9C
- Programming the 9c
- Futaba 7CAf questions!!!
- 9C or ?
- TreX CCPM setup on 5 ch Rx?
- 4 channel or 7 channel
- Set up guestions on a 6EXHP/R146iP
- S9351 servo' at 4.8V.....
- will this module work!!
- 7 cap or 7chp?
- R113iP 75 mhz PCM
- 350 gyro and 6xa operation question
- SkySport 6
- 50 band to 72 Mhz band
- Radio Feature Suggestion
- receiver antenna help
- futaba 39351 probs
- 7CAP model memory slot 1 elevator problem
- 512 receivers
- 4EX-FM batteries
- Help with 9c super spoilerons
- 14MZ help; actually R5014DPS
- Music files in the WMA folder doesn't show.
- 14MZ touch screen
- Proper set up of the GY 190 gyro
- TX output questions...
- 9C not working anymore...RF module?
- 128DP Rx Compatability
- FX-14/18
- 2.4 GHZ module for Futaba 9C
- Range Check for limited range receivers
- reverse Servo in Helimix mode?
- 9Z WCII Lithium Battery
- R149DF Question
- channel 5 as elevator servo
- 9Z Synth and 50MHZ
- Any servo suggestions
- Charging Ni-Mh pack in 3PJ Radio.
- What is the difference between the futaba 3004 & 3001 servo?
- Single conversion crystal
- Q? re the new (improved) Futaba R149 PCM Rx
- Futaba 9351digital servos/6 volts?
- Digital/Coreless Servo's
- 9C trim graduations
- 14 Mz on 6 meters
- Ultra Stick/Futaba 9C Problem
- 14MZ Battery Life
- Need help
- Charger/cycler
- 351 gyro
- Mixing to Elevon
- 6EXAP Programing issues.
- 14MZ, flap setup problem.
- FUTABA Servo S9550
- 9Z - Twin Elevator Problem
- Help is all of this stuff compatable
- Futaba R128DP
- dual conversion
- HIGH BAND AND LOW BAND
- Lithium memory battery?
- DSC capable receivers
- 8U -- Twin engine throttle control
- 9z WC2 clock/timer sound alarm
- max safe amp setting via charger port?
- 35MHz Transmitter
- WC2 display problem
- 7cap and dual elevator servos
- FUTABA T8UHPS
- Thanks for the service
- Does Futaba offer a Rx with Auto-Tune?
- 72 mhz radio in uk
