- Question about 9C radios
- Setting up On-Board Glow Driver
- T6XAS,assigning flaps to a switch
- Creating proportional Airbrake on 9Z
- Must Read!!! Really!
- Odd problem with my T9ZHP
- Current 9C
- Lost Flap Elevator Mix
- 9C Throttle response
- Battery Charging
- Campac
- Turning Off A Knob In an 8U
- 6XAPS and R127 reciever
- Switching crystals on FP-R148DF
- Futaba 10ch?
- What the &%$#&%$ happened???????
- Can I assign a VR knob to CH9 on a 9CAP?
- Battery Fail Safe on the 9c
- 9Z trim positions
- 8 servo complex aerobatic model setup.
- Programming help needed
- freq. questions -- air radios for ground, ham, etc....
- Hobbico AccuCycle Plus Schematic
- 9c program mix 6 & 7
- 8UAFS Switch C Sticky
- 8u/9c avoiding overcamming thr servo with ail/ele to thr mixes in helis
- New 9C
- Rubber Transmitter Grips
- 9C Display question
- antenna for FPT2NCS
- Ultra Stick with 9C
- Still Needing Old Futaba Stuff!
- Connecting a 6DA to a PC..possible?
- gy401 voltage
- GV-1 sensor mount for 50
- Change to ham band??
- How do I setup mix for using flaps?
- Elevon set up on a Futaba Super 7
- futaba gv1 governor
- Control Flaperons on a Futaba 8uafs from switch "c" ??
- servo selections
- 6DA problem
- Can I Use Futaba's Fail Safe Unit with a NIMH RX Pack
- Flap knob changing
- what receiver can I use?
- Well, FedEx has really done me over this time...
- 9250 gears
- 8UAFS ch 6 control
- Can I
- 8UAPS that constantly sounds alarm.
- Clarification
- Need an old AM radio checked
- 9z Dr
- Futaba FP-T5LK ???
- 9CAF vs. 9CAP
- Dual Elevator servos with a 9C
- Slider On 9C
- Trim Memory
- Can I assign "Throttle cut" to a knob instead of a switch on a 9C?
- Comparing current air/heli radios to older Futaba models
- Where to buy
- Tighter Springs?
- 9Z WC2 Question
- Left Ail on 9C is on C7 if using Ail diff; C6 if using Flaperon
- Vol****ch
- 9C Trainer Switch
- Silly Question - 9C
- Cost of repair
- Charger Cycling
- basics of NiCDs - charging/cycling/discharging
- 9204???
- Need help programming elevons on Futuba 8UAF Radio
- 9Z vs 10X
- T6XA Got WET
- 9CAP TX - Help!
- 9Z WC2 Back from warranty fix - new problem
- Futaba TK-FSS Synthesized Module?
- futaba s9252
- Metal Vs Nylon
- Buddy cord Compatibilty
- Need advice on GV-1 settings
- Battery failsafe! Help AMC
- Am I out of capability on my T6XAS?
- Battery and DSC Port ?
- 8UAFS elevator d/r switch
- I need clarification about flat rate sevice charges
- Changing Modles
- New Flat Rate Services at Futaba Service Center!
- Schort antenna for the 9C
- 6xas crash question
- FUTABA T6XA conversion???
- Basics on the GV1 governor
- 6X trainer system -- special things to know...
- ATV AFR D/R EPA AST TRIPLE RATES...huh?
- Synthesized module on 8U?
- manual for the FF-9 9C
- fp-8uhp & gy-401
- AM to newer FM transmitter Module swap
- range - air vs. ground
- servo torque
- FUTABA 8-UAF Flap Setup Question, Help Please
- Thr-cut 9CAP
- 6XAS LCD turning dark
- 6XAS Battery Cover
- Fast charging a transmitter
- Futaba FP-T7FGH Gold case radio set
- Digital Servo Questions
- re: broke Rx antenna
- Setting up a mix for an Expert Glow Driver
- twin futaba recievers?
- Correct Crystal Set for R127DF-FM50 Receiver?
- 6X and 8U Tx meter readings
- 9Z program mix overdriving the throttle sevo
- 8UHFS vs. 8UHPS...Any difference?
- Futaba R122JE Rx
- 9CA Dual Elev. Servo ?
- 8UAFS Range Problem
- futaba super 8 tx problem
- Programming question Futaba 8U
- 9Z WC2 Poor Range Check
- 9C timer - unusual glitch when counting DOWN from 0.
- Changing Crystals
- Futaba Flight Checker FP-FC1
- 9Z: MSTR Mix mode
- 9Z Expo
- Radio training ??
- 9150 servo arms
- 9250 gears
- Servo backlash
- Another TX module question ( AM to FM swap)
- diffrent flap movement
- Futaba 9204 Gears
- 148df problem
- SERVO SPEC DISCREPANCY
- ZAP Mixing issue.
- AnnMarie ... Converting an 8UAPS from Mode 1 to Mode 2?
- 9C manual online?
- R114f
- Ot: Gp 1/3 Pitts Arf Tech Notice
- T6xhs
- Txs A vs H F vs P
- I'm confused
- 9c and Ultra Stick 40
- 9CAP W/Heli
- Poliswitch
- Synthesized Tx
- Timer volumne
- Seperate Crystals
- Tip of the week -- what receivers can i use?
- Futaba Servos strong enough?
- twin rudders as airbrakes
- 72meg to 50?
- 6XA Mixers Question
- Futaba 127 Low/Hi Band?
- GV-1 and 9Z Radio
- A.M. - Will my T6XAS be enough radio for ...
- 9C Trainer Cord Pinout
- 8U Super Trainer function
- A.M. My 9Z sticks are not calibrated@!!!
- bypassing the diode NOT ITS PROTECTION
- 9Z power off delay
- Question for Ms. Cross
- when can i use 6 volts?
- Case of 8UAF
- Futaba 9C Frequency Module
- Vee tail set up
- 6XAS Problem
- Futaba servos
- AM Cross - Split Elevator Servo ???
- 9c and RF G2
- Hitec synthesizer
- Getting problems fixed at the factory level
- Futaba radio puzzle
- Futaba Servo Torque
- MCR-4A
- New Futaba Users email list created!
- AnnMarie, please respond to another thread
- The Real Benefit of PCM over PPM
- Users: You may only start a new thread or reply to your own here!
- Futaba 148 rx problem
- seperate airbrake and flap swithes?
- 9-C Diode
- Switching to 9CHP
- T6X more memorys?
- Servo mounting
- Mounting hardward for micro servos
- Out Of Town Notice
- topic of the week - GV1 governor
- Where to repair Futaba Super 7 ?
- Can a T6XA be set-up for Heli's
- Tower Hobbies Radio Questions...
- 9CAP Link settings in the 5-point curves
- Ann Marie Cross,Parts for the 8 series Futaba Xmtrs??
- US 40 and Futaba 6XAS
- 9C, program w/o RF; use DSC?
- Futaba Receiver,Change72 to 40
- 6V on PCM Rx bad idea?
- 9C Transmitter Modules
- 9c faq site
- 9C contrast adjust ?
- futaba mini digi's???
- receiver antennae replacement
- lost dial on the 9c
- 9cap @ 129dp rx
- 9C LCD so dim
- 8UAP mixing for the UltraStick
- Futaba 9 CAP Trainer Cord Set Up
- need help with T6XH
- Set up on a 9 CAP
- Spread Spectrum
- Hello All
- 9Z Battery Failsafe (BFS)
- Univ of Futaba tuition
- 9c ?
- AM.... a thought on 9C and Realflight
- AM G@ USB controller reabte for older interfaces?
- AM, did you get my radio?
- No sticker on futaba receiver, how do I tell if it is for hi or low freq's?
- 9C and Butterfly
- Skysport 6H trim switch centering
- JR -Futaba
- 9C recall?
- AM, Question on new G2 USB Controller
- 8UAF Super Transmitter Module
- Converting a WC2 to heli
- T6XAS timer?
- The Module Pins, Should I be concearned?
- 9Z Upgrades??????
- Changing the Channel Assignments on a T9CAP
- helpful tip of the week
- Repair time Question for AnnMarie Cross?
- transmitter crystal changes
- too old?
- Eutaba Rx
- Still no TRIM FOLLOW on 5 point mixing with 9C
- 9403 servo
- 9C Mix to sound alarm on high rate
- swap out a crystal module from a super 8 to a 9C?
- did you know? ......
- Futaba Industrial RC
- Futaba 9CA Template
- Futaba uap8 Spolerons
- Futaba 9CA Trim reset
- nose wheel steering on a V-tail setup?
- How Can I Cycle my 6xa Super Tx Battery
- 9CAF Questions
- IMPORTANT! READ THIS! Dedicated Futaba Support Forum
- (Ask Me Too!) Futaba V1.0
