- 8FGA RF Off
- Should I send my 10C to Futaba for checkup & updates?
- Futaba 6 EX ..Servo direction problem????
- Governer setting on 12Z
- 10 Channel Choices
- GY520 w BLS251 or bls 254?
- futaba 10C and two servo for each ail...
- 8FG - Mixing 2 ESC's
- Lost Link with Receivers
- channel question
- Charging batt. TX:7C and 8FG
- 6014 Receiver Problem
- FUTM5549 Transmitter Extension Hook
- Mode 1 & Mode 2
- T8FGA / T8FGH / T8FG - what's the difference?
- european radio
- Transferring Airplane data from 8FG to memory card
- Odd mixing issue
- Batt connection
- Gyro recommendation
- Very strange Futaba 10C problem
- T8FG Airbrake/Flaperon setting
- Telemetry
- 14MZ update not installing
- 10c trim switch circuit board
- Can I use this setup without issues?
- receiver
- 8FG Condition renaming
- File System Error
- GY 401 Gyro
- Futaba 27 mhz module compatible with Futaba 3VC
- Need some Help Programming a Delta
- A Book 14Z for dummies
- Problem with Futaba R617FS Receiver
- Flyers Club
- Question on FPT8SGA=P
- Servo connections
- Futaba MG servo for nose wheel
- R6014HS 14-Channel Receiver
- How to set a T10CAP for 4 ailerons biplane?
- Futaba Gyro
- trainer cord 12fg to 8fg
- 8FG throttle cut problem
- sub trim
- Flap setting ?
- 7C 2.4 Display
- 7C : down trim with flaps
- 10CHG Mode Change?
- Futaba S3151 6V compatible?
- Futaba Fliers club
- Futaba 8U glitching
- 12FG Springs
- Whats the difference between the Futaba 12FG and the 12FGA?
- 8fg elevons
- 12FG dual rudder servo, high rate link issue
- 8UHP age?
- 10 Cap Failsafe
- DISCONTINUED SERVO GEARS?
- MOVED: 12z - Simple Question
- 12Z update, 1.6.0 or 1.6.1 ?
- Damaged R603FS receiver
- T8FG from Europe
- 14Mzh 4 position flaps
- 12Z Switch Replacement
- Model Data Convertor
- 14MZ AIL Differential
- FASST RF Module for JR
- s buss decoder cable length
- How Many Times Per Second Does FASST Switch Frequencies?
- programming paraglider setup. Servo movement from top-center-down with stick movement center down?
- 12FG Out of Calibration after Update
- Difference FUTK62** and FUTK63**
- Fasst 7c throttle lock out
- T8FG and 4 servos in the wing
- 9257 voltage
- 12FG how to reverse elevator trim?
- FAAST-Binding to 2+ Transmitters?
- 8fg and telemetry
- 8FG Self Centering?
- MPDX-1 and 2.4 6014FS
- T6XA
- 12fg models to 8fg models.
- Beginner again! Servo help
- R617FS / R6008HS
- Futaba dropping all NiCads?
- Dual Throttle Transmitters
- 8FG - Throttle Lock?
- Servo S3004 replacement metal gear set?
- Bind and Fly from Horizon-Work with 14MZ Futaba Module?
- Radio conversion
- 14MZ Eratic Pitch Movement
- Need HELP! R617FS for Gas Engine?
- 2.4 FASST Modulation - PPM??
- R603FS Receiver w/ 4PK(S)?
- Need tips on setting up Throttle on Switch(F5B)
- 10CAG memory settings erased
- Channel assignments question
- 3050 servo gear set??
- Futaba 12FGA and Sullivan smoke pump setup
- No steering with gear up
- 9ZAP
- Can T6EX fly a warbird?
- FASST Failsafe options
- 12FG Condition Switch question
- Receiver at 7,4v
- converting t6exa to t6exh
- 8U Inverted function question
- 12FG Switch Logic Question
- Futaba Flaps and Crow braking set up on 10CG or 9Z
- Intermitent lost of signal on R603FS Reciever!?
- 12 Fga as Teacher
- PCM Receiver Antennae Length
- Futaba Servos
- T8FG 8+2 channels.....???HUH
- Servo arms for 9154 servo
- Camber mix on 8FGA
- Mixing and batteries
- 8FG Throttle Kill Switch
- 9001 servo problem
- Futaba receivers and 2 battery packs; whats the best connection?
- 6EX doesn't bind to newer RS617
- fx30 (T12fg) - butterfly
- 6108SB Receiver and The S Bus System
- Futaba T6ex problems
- inflight uncommanded control input
- R6108 Questions
- Futaba Trans/Rec problem
- T6XAS Master and Slave Trim Set UP
- Spectrum mod 8uap
- ModelDataConverter doesn't work for me
- FASST vs FHSS
- 10C ailevator not working with mix
- Futaba R604FS and 6 volt servo
- Fasst Receiver R617fS ch 7 problem
- Lost swing arm - where to get parts?
- 10 CAG 2.4 flap adjustments
- 12Z update file missing from V.1.6.1 zip file
- 12FG questions
- s9156 Output Screw Size?
- Amperage
- Futaba flyers club
- 12z programming
- New futaba, battery ok to work
- Extending a FASST tx antenna?
- Spoiler mix help!
- Battery Low Cut off Voltage
- Binding Question R6008HS 8-Channel Receiver
- 8FG to 6EX instructor/student information needed
- T7C 2.4 charge question
- Connect a Futaba 6004FF
- slave to master
- 12FG and assignment of airbrake
- 12 fg- What switches do you use for controls?
- using easy link on R617FS with my 10C
- 12fg 2.1 firmware update problems
- Broken switch - where to get parts?????
- 12 FG Step by step - Nose to rudder mix?
- 12FG timer setting problem
- 12FG - Switch Assignment
- 8FGh aux channel and governor questions
- FUTABA ATTACK R FP-T2NBR
- Programming shutter release in Pmix on a T8UAF
- 12FG Stick problem
- Multi Engines 12Z
- Must a throttle curve be assigned to a switch?
- Futaba Flyers Forum Registration
- new 12fg software
- Futaba non reversible software upgrade
- 12FG upgrade
- T6XA Futaba student/instrutor button mod
- R6108SB
- Dual rate neutral position setting on 8FG
- 6EX mixing
- Is V2.1 a one way upgrade?
- Futaba R127DF -72
- Fasst System servo incompatapility
- Optical Kill Switch On 12FG
- MOVED: FAST lock out issues
- antenna orientation
- 6EX 2.4
- T9ZAP
- Need S3050 Gear set or option...
- 12FG V2.0 update problem
- Rudder -to- Elev mix help needed
- need help for t7c
- v 2.1 firmware release for 12FG and others
- 8FG - Copying models on SD card to PC
- New futaba radios in development
- programing nose gear, retract servo and rudder with 12z
- 12Z 2.4 receivers
- 5 cell NiMH with 6 volt systems
- Delta mix with T8FG-help needed.
- R3110DPS Rx and DSC
- 7c 2.4 ELEVATOR TO FLAP MIX
- Latest 14MZ update/manual
- R6008HS vs R6108SB and best TX antenna position
- 8U Throttle for Electric
- <<<<i need help to link two ruuder servos
- Firmware updates for 14MZ, 12Z, 12FG, 8FG!
- T8FG Software Upgrade - when?
- Initialize Campac
- 6EX 2.4
- Connecting 617 rx to 12FG, problems
- FUTABA SERVICE CENTER
- 12Z and lost model settings
- Servo jitter with ch.6 Futaba 9C 127DF receiver
- Futaba 6xas
- Electric motor goes on when Tx shut off
- Futaba R6008HS 2.4GHz Battery ?
- 14 channel r/x fail
- Cost effective to fix a 3PK?
- MOVED: 8FG
- 10CH radio, 10 PPM channels?
- Beginner Radio
- setup help 9chp on 4 aileron bipe and twin elevator servos
- MY T12FG DEAD DURING UPGRADE
- 8UAFS and 9CAPS memory
- FF-7: Difference Full Radiation to Reduced Power?
- futaba 2.4 temperature
- FALSE LOW BATT ALARM ON MY FUTABA 8UAPS
- Fasst receiver voltage requirements
- Intermittent Aileron problem on 9c
- FP S128 Voltage Limit
- Old Futaba 10 pin-pinout?
- 12FGA major problems
- Futaba 8FG Throttle Cut Question
- esc plug in on reciever
- 8FG dual aileron question
- 7c Conquest
- Trainer cord question
- TRAINER CORDS FOR 8FG AND 12FG
- 10 CHP Model programming
- 12FG CHANNELS PROBLEM
- Wireless Trainer
- Just looking for some input and or help..
- 12FG - using LD and RD to control rates
- 7chp 140 ccpm support
- S9602's OK for??
- new 7C Programming questions
- R6008HS RX & Hobbico JM912 FASST Module
- 2.4 extended antennas
- Futaba 10CAG D/R and Flight Modes
- 12fg programing
- Futaba 12 FG and LiPo battery
- 7C opening Transmitter Screen
- Can It Be Converted
- 3PJ pilot light blinking
- 8fg and ailevator help please
- MOVED: reuse of reciever after crash
