- 4 ch 2.4 reciever
- multi radio question
- Channel Grouping Question
- 2.4 parkflyer receiver
- Futaba FUTK2020 3PM 2.4GHz issue. HELP
- Use of LI-PO batteries in Futaba transmitters
- Does 10C allow modulation "shift" ?
- Futaba R617FS 2.4GHz Receiver problem
- Rudder to ailerons or ailerons to rudder question
- Futaba FP-T6VH Transmitter
- stick tension
- 12FG model transfer
- 14mz range test questions
- 9 CAP with flaperon issue
- Compatibility?
- Futaba logo on the 10c
- 10C prog mix for 2 rudder servos
- NEW 12FG QUESTION
- New FASST 14-Channel receiver
- channel grouping for 12Z or FG as well
- 10C backlight
- 2.4GHz receivers and Brushless Servos
- Questions and TEST FOR HEAT ISSUE AT R6014FS receivers
- NiMH or NiCD battery for 9C Transmitter
- 128k campac module
- 12z 8 character model naming and order
- 14mz conditions
- LiPo 11.1v battery for 9CAP Transmitter
- 7CAP 72Mhz PMIX ch4 master to ch5 slave
- Futaba R128D bands
- 9C with XPS module
- Change/turn off volume on 10C?
- 6 channel 2.4 radio pots
- Data slot on Fasst Receiver
- Futaba 12Z 2.4GHz Software...
- Futaba 3PM FASST and Novak Cut-Off problem
- 12FG ail/ail2 channel assignments
- 12FG Butterfly switch
- 12FG Butterfly differential rate
- 9CAP replacing pots
- Futaba 9c RF-module 27mhz change to 40mhz problem
- 3PKS with 2.4GHZ FASST Module
- S3115 Voltage
- FASST module and multiple planes
- 10C Trainer switch
- 9C Flaperons with VR Knob A
- 12FG 72MHz freq mod not avail separately ?
- 14MZ 60th Anniversary
- futaba 6 channel 2.4 bad pots?
- Futaba 12FGH & Spektrum DM8 Module Prob
- HD-9150 servo
- 2.4GHz system\ Signal voltage\ Servos
- Flap Trim Function 7C vs 10C - Function changed
- Older Futaba S5101 servos on 6volts ?
- 6AXS Elevon problems
- 8U Programming problem
- 12FG Pricing on Tower's website
- FUTABA SERVO BLS 452 MG DIGITAL BRUSHLESS in carden yak 89"
- Snap Programing
- T6EXH compatible with R149DP
- Futaba TM-14 Module Recall
- have logic switching
- 14MZConditions
- R617FS Amps supply?
- 12FG Programing Question
- 14MZ 2.4 file additions ?
- 10c 4 aileron servo function
- 10c throttle cut
- 12FG Programming Help
- 12FG triple rates
- 10 C Radio and JR digital servos
- 12FG 2.4 questions
- interference problem
- FASST Receiver question
- 8UAPS Warning
- 12FG Questions
- R608fs bought in US will it work in Asia?
- 12FG Switch position
- 9Z Data Transfer Question
- GY401 Sensitivity vs. Delay
- R608FS battery voltage
- 7CAF suddenly mixing rudder with throttle
- RECEIVER HEAT PROBLEMS
- How to registered for Futaba Flyers club?
- Problem with r616ffm receiver
- Repair Inspection Procedure for Testing
- 72mhz 10C
- 12FG battery drain rates
- Transferring models
- Transmiter/receiver problems or ...?
- 12FG manual
- Are 2.4Ghz Receivers region coded ?
- Futaba 6XEA Weight Specification?
- R6014 LED???
- Any issues on accidentally connect servo into Batt slot on 608FASST?
- Conquest FP-T6NPK PCM Dual Rate Switch Problem
- T4EXA transmitter pot cleaning
- 7C Idle Down
- 6EX 2.4 problem with mix ???
- Possible to Reassign Switches on T7C 2.4?
- 12FG modules question
- 12FGA modules question
- Suggested Setup 7C?
- Problem solved
- 10C PPM/PCM Module
- Please help with very strange radio problem
- radio choice
- 12z swich reposition
- Function Null with Switch Throw
- set-up futaba 7 CAP
- Question about Gimbal Springs in Futaba 10C
- 12z trim speed change
- T3PK Megatech and FASST. TX red light blinking
- Futaba 7C retracts
- Tx gimbals on 12FG and 10C question
- FUTABA 10C Trainer switch
- Futaba 6EXA Super 2.4
- Servo Pots Analogue/Digital
- Dual Servos
- Use Y connector with FASST...
- Can we expect an 8 or 9 channel 2.4 fasst??
- 9C to 10C mixes missing after conversion
- USB connection to trainer for 10c? Simulator use.
- i have problem noise
- 2.4 Fasst works/and now doesn't work???
- 9CAPS Dual throttle setup fine tuning
- Lipo use as Tx Batts
- 7C Fasst flap question
- tx crystal compat?
- Lost my 600N today
- 12FG failsafe
- Most slop-free Futaba servo?
- G190 compatible with HRS?
- Significance of white dot on R608FS
- Futaba 3pk question
- TC7 Trim
- Product Advisory — R6014FS Receiver- Help on this
- 3PK and FASST question.
- Do I need to remove ferrite from my 2.4G system?
- Specification
- Attack 4WD
- S9156 1st Gear
- 6EX 2.4 & 607 came unbound
- FASST antennae placement, housing, tubing, orientation etc etc???
- Futaba R608 / HS65 swash servos "Glitches"
- MOVED: Why not a 12 FG, 12Z and 10C website?
- R148DP vs R168DP
- What is GROUP and SINGLE setting in the CONDITION?
- How do you program dual rate on 12FG?
- Timer Text Size on Radios...
- ELECTRIC TELEMETRY for the 3pm 2.4 ghz fasst???
- radio glitches
- Help with Futaba 7CH 2.4
- R156F no work
- New 3PM-2.4 lost bind
- 10C Power Down Mode, No RF Output
- R146iP damaged?
- HELP: Futaba FP-T8UP / FF8
- Dual Elevator servos
- Red Tag Crystal versus Black Tag Crystal
- Hot recievers
- TM-7 or TM-8 and TM-14 recoding
- Futaba Trainer Cord with 10C...
- 14mz data reset question
- Setting up a GY401 with a 14MZ
- Futaba 2,4
- R616 connectors
- R617FS heat issue
- 14mz 32 character model naming
- Heat Tolerance Issue
- Futaba Controller at Yard Sale
- receiver heat issue
- Futaba Micro Receivers
- Programming 2Ail 2Flap with 7ch FASST RX
- Futaba 6014 heat failure (crash)
- T7C LITTLE CONFUSION
- Is 5cell(6V) ok with FASST 6/7/8/14 RX?
- Stiffer springs for my 12FGH??
- Going from channel 21 to 46
- 7 cap
- 10 C Twin Aileron Servo Problem ?
- Turn around time
- Futaba 10C Total Height
- Mutliple Battery Inputs on 6014 receiver
- Battery Back Up
- 10C questions
- Is Tx battery needed f/long term storage ?
- WHO CAN REPAIR MY 9ZH WCII?
- Logic switches ?
- WHat is the latest updates for 12FG?
- Are they different 12FG on different region and what is Product ID?
- 10c rotary knob
- Question on my 9C using Hitec digitals and rates, etc.
- Futaba 7c mode change
- Duratrax Firehammer Radio
- 7 C FASST software update?
- Hitec analogue and digital servo ok with FASST 6/7/8ch RX?
- Which futaba 12 channel is better 12z or 12fg
- 14MZ and knife edge mixing
- 6EXHP with R127DF
- How do I tell what 12z software version I have?
- multiple servos on 1 surface?
- Throttle Trim On !0C & 12Z
- antenna orientation
- Can't change frequencies on PCM G3 RX w/12FG
- 10 C link
- Does the 12FG support MPDX-1 now?
- Model Match and Integrated 2.4 system?
- Futaba 7CAP Dual elevator set-up........
- Futaba 9CHP setup help for F15 Jet
- GYA 352 and 10C setup help required
- 2.4 Ghz rx antenna
- S9201s able to handle 6volt battery?
- Servo question
- Futaba 2.4 14 mz link question
- Broken Gimble for 9c
- 7C mixing
- Battery setup for 9156's and FASST rx's
- Nose wheel steering disconnect
- Revo Mix on 10C
- s9001 bounce
- Adjusting throttle stick friction
- 12FG Dual Rate Switch Assignment Problems
- 6EXAP Radio
- Futaba MSA-10 use with servos of other brands
- 9c problem
- 12z for dummies needed
- Twitching digital Servos test results Futaba
- 10C 2.4 and which Futaba Servos
- old futaba servos
- How to mount Fut 2.4 RX inside tight glider fuse?
- which servo?
- 12fga dual rudders
- Gimbals...
- Expo and offset
- battery heat
- Servo size
- 9C - Flaperons on a switch?
- 10CH heli curve conversion from 9C
- Flaperons
- FutabaT6XAS programing for cp heli?
- Why so few 12FG posts?
- Rates and Expo's
- Probably a dumb question
- futaba FP T6NFK receiver ?
- How do Futaba radios handle trims vs. displacement
- WHAT MODE DO I USE.
- 3pm receiver pack voltage
- S3114's stripped when powered up.
- Futaba S3152 Servo Digital Standard Hi-Torque
