- 6014HS
- Futaba T6XAs & Hitec Optic 6 Buddy Box Setup
- 14mz Single Transmitter case foam
- 9CAP Super channel change question
- 2.4Ghz FASST Receivers & Tuned Pipes
- 7C 2.4 Batt voltage
- 2.4 receiver 14 ch not available, WHY?
- Link software for 520 gyro
- 14MZ trainer question
- 9C Super Trim Issue
- 7C Flaps on G Switch?
- Futaba S136G retract servo
- R6014FS Question
- Futaba 9C & Hytec Eclipse 7 as trainier
- Futaba Front panel 9cap
- Futaba R6008HS 2.4GHz FASST 8-Channel Receiver
- 12FG Programming Capabilities
- Is the 12FG manual available for download
- Futaba 10CAG question
- Futaba 4EXA TX battery
- New 10C questions
- Gyro and gov. set-up on the FG?
- 10CAP servo slow
- Need part # for replacement antenna for R603FF receiver
- Question...
- 10C 2A+2F glider & throttle on a switch
- Transmitter Battery ??
- price for T9CAP TRANS.
- 12FG Linking Problem
- 12 FGA Throttle Cut increases idle
- 6008 rx Range Check
- Futaba 12FG question
- T6XA - 7CAP TX Crystal Interchangable?
- futaba 9c and retract servo
- Futaba 6exa throttle control binding
- Taking my 12FGA to Europe
- T6XA Q
- 2.4 rx battery power ignition?
- Why has the Futaba R6014 been discontunued?
- Futaba 7C throttle
- Futaba TM-8 module in a 9c
- startup delay on one channel FASST
- 7C 2.4 channel 6 & channel 7
- How to adjust throttle travel range on the 12FG
- buddy box
- Futaba 10C and Reflex XTR Simulator
- Futaba 6EX: Modify TX channel 6; Flaps
- Futaba 6EXA Stick Tension Adjustment
- Receivers
- 6014 rx being discontinued?
- 12FG throttle kill
- 12Z radio help please.
- Binding a 12FG to an R617
- New radio, older receiver and servos?
- Futaba Dsc
- Fasst TM-7 Module and R607FS any updates
- Futaba 7cap
- Futaba T7CAP to Art-Tech Typhoon help
- TM8 and 6014 reciever
- 9CHP compac used in 10CHP 2,4 Tx radio
- 2.4 tx Antenna & flight Station
- CONFIG SWASHPLATE SWH-4X IN 9C Super
- Triple rates on a 14MZ
- Do Futaba recievers save servo sub-trim information?
- Large scale Futaba servos
- New 8 ch Fasst HS6008?
- Thoughts on buying a used Futaba Tx?
- Idle Down
- 10c question
- 3PM-FM Problem
- elevator servos on 2 channels for 9C??
- Fail Safe Procedure
- 9CAP with TM8 2.4 convertion Question
- 2.4 RECOVERY TIME
- 'Advanced' Programming
- Mixture for airplane "Delta Wing"
- R617fs linking failure
- FP-8SSAP PCM
- CAP 10C problem
- Snap Roll question
- 2.4 FASST with JR Digitals
- ignition interferance with futaba 2.4
- Can a 7C tie dual rates to flight mode?
- Setting dual/triple rates on 12Z
- 12 z to 2,4
- Main control pot specification
- 6Ex discharge voltage
- 12FG Function / Channel Assignment HELP !
- Futaba 2.4ghz receiver in a fuse with carbon wing tube
- Thingy for 14Mz 2.4GHz
- 7c & New r617fs Won't bind??? Help!
- DG1 and DG2 from the training Tx
- Will we ever see a 2.4 full range 4ch RX?
- Rubber TX Grips for 10C??
- help!!! 8UH radio problem after futaba service..
- MOVED: Futaba 3PM crawler configurating
- 12FG to 12FG training cord
- R6008HS Rx question
- 12fg gimbal springs
- R6014FS - dual rx battery?
- Module Pins
- Radio System Failure
- right stick not functioning
- 12Z Throttle curve airplane
- 10C and 12FG
- My Futaba 8UAF Tx broke.
- Setting CAMBER MIX on 12Z
- 12fg 2.4ghz with aerofly pro
- Futaba 2.4 617 w/ HD 9150 servo.
- 617 with dual elevators
- gy401 with Hitec servos
- A123 Battery For FASST Receiver?
- Are the R608FS receivers polarity protected?
- GY401 won't work with anything other than Futaba servo
- Futaba S9156 Overcurrent Protection?
- 10C 2.4 module in 9 CAP
- ATV Travel or Limit?
- Servo Polarity
- 2,4 GHz Recievers EU v.s. USA
- 12fg with biplane
- 12FG single servo retracts/brakes?
- T12Z- On/Off power to a Rx port ?
- High speed 6014 Rx
- Camber Mix 12Z
- FASST Dot significance??
- S9304 & S9303 vs 6.0v
- Rudder to Aileron P-Mix on 7C
- 14mz 72mhz module
- "Futaba FASST Product Advisory - R6014FS Receiver": More Details?
- Antennae on Futaba 7-CAP
- R6004FF receiver
- transmitter tray for fc28
- Replacement body/casing for 14MZ
- R603FS
- Confused on Fail Safe 9C
- Futaba FP-T7UAF FM Additional Receiver
- close thread
- TM14 module
- Futaba R149DP How to tell the Difference in a High and a low R149DP
- 14 mz and jr reciever
- after market charges and my 10C
- 10 C resolution
- Fasst RX Mounting HELP
- Futaba R149DP Hoe to tell the Difference in a High and a low R149DP
- 9C Super 2.4 conversion
- MOVED: AquaCraft's Reef Racer 2 transmitter/receiver
- R616FFM
- Futaba MEGATECH Receiver question.
- G3 Receiver R5014
- Anyone knows what the ReefRacer2 or MiniRio's transmitter ?
- how mach the R6014FS can handle?
- Futaba 10c current drain
- 10c developements
- FG 12 Ch. setup for flaperons and spoilerons
- 12FG Battery
- 12z stick setting
- 6 Channel FASST Receivers
- Y harness servo problem with a 617 rx
- Rx R617FS
- Throttle stick travel limiters on the 10C
- Futaba 7C back green led problem
- 9C Flap Ailerons setup on a Chipmunk
- How to setup a opto-kill switch?
- Reading actual trim values on 8UAFs
- Receiver Power??
- format of model data on SD card
- BLS351 Servo centering problem
- 5014 Antenna Length
- Another Snap Roll Switch Question
- Fasst TM-7 module
- 14MZ New Model Question
- MOVED: BACK TO BASICS
- Futaba 7C ~ R606FS
- Battery for Futaba Gold Xmitter
- Transmitter with Helicopter mode?... or airplane mode?
- servo twitch
- R6004FF
- 3111 arm set?
- !4 Channel Synth Receiver will not hold frequency
- trim lever question
- 12FG left stick problem
- synthesized Tx?
- Futaba S9155. Which power suply?
- 2.4 FUTABA
- 14MZ Snap Roll Function
- Futaba GY401
- 4ybf scheme
- Replacemnt Switch Assembly for 9CAP
- Futaba 7C throttle trim
- 14MZ quirk
- What is the frequency range that FASST operates within?
- Futaba/Spectrum
- 7C questions
- 6014FS Receiver antenna replacement
- FASST mounting question
- Limk Failure: 6EX and R617FS
- R129DP Operational Test / Compatibility?
- R6004FF link with T10CAP with TM-10
- Futaba T7CHP sailplane mixing ability?
- Flap delay, Futaba 12Z
- nevermind
- failed trying to register for Futab Flyer's Club forum
- Couldn't register for Futaba Flyers Club Forum
- What does water protected mean?
- 9C Twin engine control
- 8UA/S Programming Question
- 12FG Glider settings
- Understanding throttle hold on the 12FG
- 9cap vs 12fga
- GY520 availability
- Futaba 7C-2.4 antenna installation in plane
- 12z Electric Glider Motor Control
- 12FG Elevator trim in multi conditions
- 3PKS Steering not working.
- Antenna for 9z wc2
- Futaba 7C and R617Fs channel 1 dead?
- Futaba T6EX Binding
- Signal voltage gold-dotted 6014FS
- 14 Channel 2.4 Gig Receiver
- PK4 Second condition Issue
- 9C fail safe
- R603FS/R604FS Rx Input voltage
- Futaba 9157 Servo
- 10C Resolution?
- Torque Rating Question
- LiIon battey charge for 12Z and 14MZ
- MOVED: 12FGA - Recap of functions organized in an easy to read form
- AFR question 12FG
- Skysport 6A and Futaba R156F Micro
- 12 FG origin
- 12FG
- 12z and 7 channel receiver - channel order?
- More FASST rx choices
- 14MZ loose neckstrap loop
- Futaba 6EXHP
- Foam Around The 2.4 Gig Receivers
- MOVED: Getting Students involved in flying
- Re Link R617FS?
- Sub-Trims are Unstable
- New 10C 2.4
- FUTABA RX QUESTION
- Converting a 2pos switch to a 3pos switch
- Servo to Receiver Wiring
- 2.4 receiver 2048?
- Interference glitches from other channel, is it possible?
- Crow brake, elevator volume control? 12Z
- 12Z switch location
- 6EX-2.4GHz Transmitter Un-Links
