PDA
View Full Version : Futaba Radios Direct support forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44
  1. Futaba 2.4ghz FASST, is it legal to buy from USA and use in UK?
  2. Where will the new 12MZ software be posted?
  3. Major Glitch with the FASST system!
  4. TM-14, is it region locked?
  5. 7CHP display question
  6. 14 MZ 2.4 module shipping
  7. 9CAP & 9CHP Super Faceplate + stickers
  8. Hi torjue servos
  9. 12Z 2.4?
  10. Freq. Change
  11. 12FG Question??
  12. 9252 Voltage rating
  13. Silicone Tubing & 2.4 Ghz Antenna
  14. Range Problem With 6EX - 2.4 GHz
  15. 9Cs latency
  16. 6EXAS, 6EXP Difference
  17. BAX CAN YOU HELP???
  18. Futaba Flyers Club
  19. FM or PCM to 2.4GHz
  20. G3 Receiver
  21. TM-14 module shipped ...... is it going to just work....
  22. 2.4 Ghz with large radial
  23. Receiver Question
  24. Will there be a new 7 channel 72Mhz transmitter?
  25. Futaba for Tank models?
  26. Tech Questions About 2.4GHz FASST
  27. 12 FGA Manual
  28. 7C 2.4 tx antenna
  29. 14MZ, 12FG, 12Z FM Modules - why so difficult?
  30. TM-14 Module for 12Z, Any loss of features ?
  31. 9CAP upgrade
  32. Futaba 2.4 Latency on 9C conversion
  33. 14 ch 2.4
  34. No "free" Futaba stickers anymore??
  35. 2.4 GHZ rx battery
  36. t7CAP flaps and aileron set-up:how & what channels
  37. Possible TP-FSM problem
  38. 14mz and Smart-Fly Power Expander
  39. Fasst system problem
  40. Butterfly set up
  41. How can i stop the "H" futaba fasst 7c
  42. 7C 2.4GHz function assignment to switch
  43. Separate aileron servo and elevator servo
  44. 6ex battery
  45. 14MZ Reset?
  46. 6EXAP and R124F ??
  47. 3PK ABS settings
  48. 2.4GHz application issues
  49. NI-MH reciever battery?
  50. final post for 9351 servo
  51. 7C 2.4ghz and R606FS ailevator?
  52. 9CAP to 9CHP
  53. Futaba FF9 softwarw bracing...
  54. 7C on 72Mhz or 2.4Ghz?
  55. Futaba T7CAP/CHP
  56. futaba 6exap
  57. R127DF Rx
  58. High to Low band
  59. FF Club
  60. S9451 Died!
  61. Difference between 9C and 9C Super?
  62. Futaba T8UAFs and twin engine
  63. Older 9C out of storage.
  64. ACCUCYCLE
  65. FUTABA 7 CAP Tx
  66. T7C 2.4 Ghz Link Procedure
  67. TURBINE POWER JETS + FASST 2,4
  68. 14mz software
  69. 5014 ant
  70. 12Z multiple servo Q
  71. Futaba R606FS power wiring?
  72. BLS Aileron servo
  73. 14MZ Transmitter Deleted 2nd Rec ID#
  74. Stick Mode
  75. Unequal movement of same model servos.
  76. 3305 for Airplanes?
  77. 14mz replacement switch
  78. Futaba S3010 Question?
  79. 9C to give up elevator w/ L or R rudder?
  80. unique ID on 2.4 ghz or something else?
  81. Max Permissible Rx Voltage?
  82. Servicing Futaba S9252 servos
  83. FASST Micro Rx?
  84. Receiver install, Futaba FASST
  85. Interference problem. Frequency range of the FASST system
  86. 7c Fasst Manual
  87. Futaba 7C 2.4 GHz
  88. 9C Module
  89. 9ZAP Receiver question
  90. Attack 4NLB-am Tx, narrow band???
  91. 12Z Pmix feature ?
  92. R606 R(x) Discontinued
  93. 14mz - new batteries? Best place?
  94. R607FS and R617FS - What's the difference?
  95. FASST system performance in a crowd
  96. futaba t6exap help for SIM
  97. 8-channel FASST failsafe
  98. 9 CAP-Possible to program Mode 2 right stick to elev/rud ?v
  99. 7UAFS TX Battery Cycling
  100. FASST module for JR/Graupner?
  101. TM-7 Antenna Orientation
  102. No Signal from TX
  103. 14MZ Battery Question
  104. Nimh Batteries for 7C FASST System
  105. Buddy Box on 9C Radio
  106. 9c fasst system... will it be sold?
  107. 7c FASST & Dual Elev Servos
  108. FASST antenna qestion
  109. 9CHP Super Service
  110. Servo check and repair
  111. Max voltage of the 9156
  112. futuba receivers
  113. 14MZ firmware update to eliminate need to touch screen?
  114. Conditions affect which settings of a 12Z?
  115. 12FG
  116. Fast 606 RX Discontinued, Why?
  117. Shipping Damage?
  118. 6V operation
  119. complete software change on T12fg
  120. Futaba digitals with plastic gears
  121. TM-14 and R608FS
  122. TM-7 Aerial & 9C
  123. questions about using two receivers
  124. 9Z/6EXP compatibility...
  125. Definitive GY401 Mounting
  126. 14 MZ : frequencies determined by the radio or by the module ??
  127. Servo grouping on 12FGA
  128. Voltage limitations and recommendations?
  129. FASST w/ Large Fuel Tanks ?
  130. tx cases
  131. MPDX-1
  132. Lithium Polymer Battery Pack for 9CAP
  133. Futaba micro reciever
  134. So, I have a 9c and....
  135. 12Z vs 12FG
  136. 3PKS Fasst Servo Issue
  137. Futaba Service Manuals
  138. Tx Modules
  139. Futaba 7CAP Up and Died ????
  140. 12FG TRANSFER
  141. 6EXAP RF out transistor
  142. Futaba 6EX-2.4Ghz controller
  143. Losing mixingfunctions after update 14MZ
  144. Futaba 6EX modification
  145. Difference between 3110 & 3114 ?
  146. 9155 Question
  147. Fut R133F 75Mhz FM receiver with JRXS3 Tx
  148. 12z question???
  149. 12Z channels
  150. FASST/PCMG3 inherent flaw?
  151. 9C 3 position flaps
  152. 7 CAP HELP 90 DEGREE SWASH PLATE CONFIG
  153. 6EXAS upgraded to 6EXP?
  154. 12Z mixing for flying wings ??
  155. Support email doesn't work, need warranty claim
  156. Newbie needs advice!!!!
  157. Moving a switch
  158. Servo Signal Futaba FASST
  159. S9451/ S9452
  160. Futaba 12FG Swicht SD, SA Problem
  161. 8uaf parts
  162. FASST antenna mounting. Plane of 90 degree matter?
  163. 12FG 2.4
  164. 12Z VC1-4 ?
  165. Programming switch "C" on a 9C ?
  166. 6EX 2.4 Ghz Flapperon programming.
  167. Futaba 3PK
  168. Futaba T7CHP Dail Problem
  169. Faster FASST?
  170. Failsafe with FASST 607 and 617
  171. 14MZ "super" version
  172. No signal to servo-7 ch FASST rx.
  173. New 12 Ch 2.4 FAAAST Transmitter
  174. Futaba Help
  175. S9451 Trouble
  176. 3305s for Airplanes?
  177. Are there switch use conventions?
  178. upgrade 9c to 2.4ghz
  179. 7CAF & 7c model and Two servos for elevator
  180. 12Z aileron2 (ch5) setup
  181. Elevons for 12FG w/4 channel Berg radio
  182. 3050 servo jitters
  183. Will a Futaba 2.4ghz work w/Specktrum Recv
  184. Futaba 12FG Problem
  185. Which servo's for large scale
  186. T9CAP problems?
  187. BLS251 Clarification
  188. Discontinued the 606 Spread Spectrum Receiver?
  189. Short antenna for 14MZ
  190. Bax, I need your help!
  191. 12FG questions
  192. Futaba 14MZ went crazy
  193. Flaps best practise?
  194. Need to set up a throttle/elevator mix on the 9Z
  195. futaba 9 mixes
  196. Question on 9C's actual trim range
  197. transmitter shift
  198. FASST and CE-label
  199. 12s & 12fg current draw
  200. Futaba 7CAP Airbrake Function
  201. Futaba 7CAP Airbrake function
  202. Bad R149DP Rx ??
  203. need help
  204. Faceplate bubbling up on 9CAP and my 9CAPS
  205. 2.4 Fasst module for Futuba FP-T8UAP
  206. 12FG and MPDX-1 ?
  207. Question about channels
  208. FASST questions - Inquiring minds want to know
  209. 2048 Receivers
  210. 12FG
  211. Servos, s9550, s9551.
  212. Futaba 9ZAP programming question
  213. Futaba 12 FG adjuster?
  214. Should it be charged
  215. 9ZHP WC2 CHROME FRONT COVER
  216. What is the power output (in mW) of the 3PM 2.4GHz
  217. 2,4GHz FASST and C/F - Metal interferences
  218. Stupid questions
  219. 6EX 2.4G, setting ch 6 trim
  220. 9cap repair question
  221. 12FG software updates?
  222. 14MZ 2.4GHz
  223. 2.4 Ghz System Battery Charger
  224. 6ex mixing question
  225. WHICH 12FG??
  226. 9 Z AP programing manual
  227. FP-9VAP - switch mode 1 to mode 2.
  228. Futaba 9c Display
  229. FUTABA 2.4 GHZ transmitter with 7 or 8 channels?
  230. Current software version for 12FG?
  231. MOVED: T6EX 2.4 GHz System
  232. 2.4 antenna and the $2000 14mz?
  233. Throttle kill switch
  234. Futaba BLS451 servo
  235. Futaba Charger Question
  236. 2.4 Ghz and dates?
  237. 9C Set-Up Question real easy
  238. 50 size heli servos
  239. 8UAF-- can I disable a switch?
  240. 9CA vs 9CA Super
  241. Dual rate crow?
  242. Failsafe for 14MZ with FASST Module
  243. 8UAF question on mixing
  244. Futaba 6YG FM / Skysport 6 / flapron setup?
  245. S3153 and GY401
  246. FASST system for JR?
  247. Disconnect Throttle Rachet on 9C?
  248. Reversing flaperons, ch 6, 8UAF?
  249. Detached T6EX 2.4 GHz Antenna
  250. Futaba 8UA w/Spetra Module
