- Ultra Stick & 9C setup
- Futaba 6YG (Sky Sport 6)
- 9C synth module
- PA-2
- R 112 JE 2 channel receiver
- Radio Interference
- Futaba 3050 Digital
- Jumpy servos on 127df, but not 128df
- Zagi Electronics
- Futaba S3010 servo
- Antenna Down Question....
- 14MZ Questions
- 9C Flaperon percentages proper useage?
- s3151 voltage
- smoked 9206
- How many servos can one receiver drive?
- On Off Switch Harness
- 7C ELEV-FLAP Mixing
- 7C Alarm Frequency
- Question on the R319DPS receiver
- Conversion of Rx's
- 3PK HRS or PCM
- What does charger FBC-8B belong to???
- R114F Receiver and 2M Spectra Sailplane
- Futaba R149DP Receiver Problem??
- 9CHP Smooth Throttle Action
- Skysport T4YF
- 6EXA trainer cord and buddy box problems
- Turnaround Time
- R149dp RX
- Question on 9CHP TX alarm
- AFR vs ATV Futaba 9Z
- Futaba 9C
- 3PM-FS
- 9C LCD goes blank
- DisAssemble Stick Gimbal
- 3PK SYNTHESIZED MODULE-75MHz
- Partially melted case
- 14mz w/ other Futaba Receivers
- ultra stick programing
- Frequency Change Question
- 7C - can I disable ch6 VR knob?
- Futaba Skysport ..Battery
- 3305 Servo's for aircraft use?
- 9c programing ultra stick
- Futaba Frequencies
- Futaba 8UAPS FLPRON function
- a 9c bought just before the 9c super was introduced
- 14mz and Microsoft Windows questions
- 9Z condition shift
- Do Futaba S9152 and S9153's have dual ball bearings?
- Choke setup on a 9Z wc2?
- 9VAP memory battery
- FUTABA 9VAP TRANSMITTER
- Futaba 9CAP Radio Repair
- Which has better range PCM or normal FM?
- idle down & thr-cut
- 9CAP Rebates
- 14MZ delivery
- 14mz receiver
- 9C and 4 Ducted Fans
- 6 Volts
- Futaba 9caf set-up for dual rudder servos
- 9C Synth module
- 7C battery problem
- servo differences?
- Free Return Shipping in December from Futaba
- 8uaps follow-on
- S3108 servo for throtle
- FP-TL4
- Older Model Tx
- Berg Receivers & Futaba Frequency Synthesizers
- 6V on 4,8V servos
- Brand new 6exa doesnt work right I think
- CAP 9 Programming
- FP-R127DF & UPGRADE TRANSMITTERS
- Gyro for aeroplanes (X- and Y-axis)
- PPM failsafe
- 9351 servo
- Manual for 3VC
- Switch from 4.8 to 6.0V
- 9 CAP triple rates?
- Futaba 7UAF Transmitter question
- S3003 servo upgrade
- T2PH Technical info for the transmitter
- futaba 6exa
- 9C and Tx Frequency Module
- Servo tests
- 9Z's Campac Module
- 138 PCM Receiver Voltage?
- 7C Repair
- 9CAP flight time.
- R114F RANGE
- When is it time to junk a RX or send for service?
- Futaba S3101 Micro servo - power requirements
- Triton Charger mounting screw size?
- Futaba R149DP Rx Battery connection
- Looking for Futaba Rx #FP-R128DP Highband
- Help with 9C and Ultra Stick programming
- 14mz question
- 9Z and Polyswitch
- Futaba 14ch question
- unclear on charging directions need assistance
- 7C Transmitter Service Advisory
- 6V. with R138DP RECIVERS
- using while charger is plugged in
- Futaba comparison
- 149DP receiver
- aileron reflex on a dial in 9ZWCII
- jumping 3305 servo
- WHAT MAKES IT A RUDDER SERVO?
- 9CAP Super manual
- Red Streamer Flag -72 mhz Aircraft Only
- Servo's S148 ?
- Futaba 14MZAP 14-Channel PCM
- 7 cap problems
- Question on Servo repair
- 6channel battery plug (for the transmitter).
- 9zWcII vs 9c throws
- Dual Receivers
- 9Z Program storage
- 7UAFS Module still available?
- data downlink
- Frame rates
- 9Z Un-repaired?
- help with making buddy box
- 9C questions
- Electrifly reciever problems.
- 9C Synthesizer Modules
- NiCd Power for Futaba Servos??
- ? About 9C tx case
- metal gears in 3101
- Fail Safe Feature
- 14mz on 50 Mhz
- SHIFT SELECT ON FUTABA RADIOS
- Yet another 9c programming question
- Dean's Whip Antenna
- flight modes in Futaba 9CAP?
- Trainer Box woes
- Charging/discharging xmitter batts in the xmitter......
- servos that move freely
- T6XAs Radio on Channel 12
- T2PH transmitter
- # 26 crystyl in a # 36 receiver safely???
- How to do reverse aileron differential on 9C?
- low friction servos?
- Operating transmitter with antenna down can cause damage ????
- Help!!! Radio may be possessed..
- Another 6XAS question
- Replacement for old RX
- Add trainer plug to old futaba radio
- Which Crystal for Futaba R136F72 rcvr ch47
- 9351 Servos for 29% Edge?
- 9C and flaperons
- t8uapage of transmitter
- Futaba 6XAs
- Skysport 6A - broken toggle switches
- 7CA Software bug STILL an issue.........
- Am I just being a little parinoid here.......????
- 7CA
- Busted Antenna wire on Rx....advise needed
- 3305 Batt Recommendation
- R149dp PCM RX ?
- Futaba 8UAPS converting from 72 Mhz to 35MHZ
- 7C setup for Duel Elev Servos
- Problem with 9Z left stick
- 9CAP Smoke mix question
- 7CAP NiCad vs NiMH
- 9ZAP WCZ Rudder Delay
- 3305 super porblems
- 7CAP Battery_TX&RX
- Switch Assignment
- Futaba 14 MZ Transmitter
- S3001
- futaba 7chp and 401 gyro
- 138 pcm or 148pcm receiver
- Slaving ch5 to 2??
- 9C rubber grips
- new futaba 9zap replacement
- Triple rates on 9ZII
- S134 servos
- Futaba 9C Ail-Flap mix as aileron
- 9Z and governors
- Thank you!
- 9Z Question
- FP-TQ-FM and 9CAP..
- Futaba PA-2 or GYA-350A/C
- 9C Super??
- 9CAP and Failsafe
- Futaba 3010 Servos
- 9C -throttle-needle mix to Ch 3?
- Futaba 6XAS Voltage indicator
- 9 servos, 2 batts and 1 R149DP
- Servos with G-type connector
- 138DP/148DP difference
- aerial length for a FP_R115F 36MHZ RX
- Sick of my 3004s dieing!
- Futaba 6XA Problem
- How does one reset a 6EXA to factory defaults?
- Timer/Throttle Problem with 7C........
- DIGITAL SERVO PROGRAMING
- Transmitter Battery Question
- Are Futaba consumer RC transmitters type accepted for FCC part 90 commercial use?
- 9CP/9CAP - question
- 9CAF transmitting ghost signal
- 9351 Digital Servo
- FP-R127DF worth repairing?
- 9Z Antenna
- Futaba 9C Case ????
- Futaba 9 Zap trainer function
- 9ZAWSII and battery life
- RX Hi/Lo Marking/Servo city
- Returning to Futaba servos
- Help: Programming 9C for DLG
- 9C NOT RANGE CHECKING
- S3001 Servo
- 9ZWCII Delete Model (Primary Condition)
- Safety Suggestion for 9C and possibly other Tx's
- 9Z Expo question?
- GY401 vs GYA350 for fixed wing airplane.
- transmitter crystal
- Air Brake switch assignment on 7-Cap
- 9C Ham v.s. 72
- Futaba Tx - JR Rx
- new digital servo
- HELP! Dead 8U transmitter
- Futaba FX-18 Elevator Trim Problem !!!!
- GY502 set up.
- Flaperons on 6EXA
- 9CAP Programming Problem
- Heatin' the Transmitter
- FRECUENCY MODULE
- Frequency Flag Holders
- any new plan for the successor of Futaba 9ZWCII ?
- Futaba charging question
- Power of Futaba transmitters
- 9 VDC receiver
- PCM Receiver Questions
- T6EXA on great planes viper 500 vtail
- 9C throttle curve
- 9C Flaperon and Airbrake
- 7CAP on ham channels
- MOVED: 9CAP setup for crow
- How to mix flaperons and elevator
- 9001's "wagging"
- Mode 1 to Mode 2 On Skysport 4
- Futaba 9CAP - Twin Elevator Channels
- 9C Module Problem
- MSA 10 BATTERY QUESTION
