PDA
View Full Version : Futaba Radios Direct support forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44
  1. problem with 6EX
  2. ??? Futaba GYA401 Gyro???
  3. 12Z vs 12FG
  4. R606FS replacement antenna
  5. DSC port on 6014 RX?
  6. servo list assignment on the 9z WC2
  7. R6014fs Data port
  8. MOVED: The REAL reason for the Futaba Forum.
  9. Futaba 12 channel
  10. 10C twin engine setup
  11. PCM, Single Conversion and Dual Conversion
  12. 7CHP Dual Elevator
  13. 7C 2.4 Question
  14. Question about R617FS Antenna Ends
  15. Where to fit step down?
  16. High current load receivers
  17. which receiver should I use?
  18. Digital buzzing servo and pull pull rudder
  19. 7C 2.4 with R617FS Reciever Problem
  20. 10C question
  21. GV-1 sensor housing
  22. Servos for .15 size glow
  23. R617FS max current rating
  24. Part numbers for 10c stick assemblies ?
  25. 6ex 2.4Ghz
  26. Futaba S3305 servos and battery type
  27. TM-7 R607FS Is This Normal?
  28. TM-7/8
  29. 9Cap mix
  30. Futaba T6EX stick problem
  31. flap ele mix
  32. 9Z no audible low batt warning
  33. Futaba Support Warranty
  34. Compatibility List 14channel 2.4
  35. Servos
  36. Old Futaba radio - can I use it?
  37. GV-1 and 12Z set-up question?
  38. 12fg trim steps
  39. Futaba 8UAP 50 MHz issues
  40. Futaba receiver in EFlite T-34 Mentor
  41. Twitching servos mainly rudder
  42. Was the Futaba S9204 a 4.8 volt only servo?
  43. 6xas Toggle Switch Installation
  44. radio problem
  45. Program Mix Help
  46. 12 FG system
  47. Strange problem with rudder trim in 8U with GY502
  48. control range
  49. Model Match at T10C ?
  50. BAX or KRYSTA- Question on 6EX recall and performance issue.....
  51. 9Cap Super Throttle Trim Tab
  52. 10c gimbals
  53. 10c system
  54. "Y" Connector?
  55. Where are my mixes?
  56. T9CHP Transmitter Left stick controll parts
  57. Futaba 2.4 R608FS
  58. 12 FG Question
  59. OK to use USA 2.4 gig radio in Australia
  60. FFC Locked
  61. 7C-2.4GHz
  62. 36mhz receiver
  63. FP-R148DP PCM1024 - No Power - Flakey
  64. Futaba R607FS and R617FS
  65. What Happened???????????
  66. 7UAFS Channel Mixing
  67. 1985 vintage FUTABA FP-T6FN 6 channel system :What can I use it for???
  68. Antenna plug for 10C
  69. 9CAP Tx replacement needed HELP
  70. fp r127df receiverchanging frequencies?
  71. 3-Ch. Fasst Receiver Problems
  72. R608FS HEat limit?
  73. Reversed throttle imply reversed failsafe?
  74. FP-TP-FM module on 3PK
  75. R 1410 DP Where?
  76. 9C battery
  77. 12Z Set Up for GV-1
  78. Update v. 1.6 for the 12FG
  79. 9zap wcII battery issue, too fast discharge.
  80. 3PKS LCD problem
  81. T4YF Batt. LED's are not coming on
  82. FP-R148DP Receiver question
  83. GV1 Setup in 12Z
  84. T6XAs/6XHs and GY401 don't work
  85. R5114DPS binding to 12FG
  86. 10C - Programing Flap/Elevator mix
  87. R603FS vs R603FF
  88. Futaba 3pm- R603FF Overheating????
  89. Brining back my old r/c from the dead
  90. 8UAF trim changes - strange behaviour.
  91. Servo Speed
  92. Futaba s3010 ht problems
  93. 10c crow question
  94. Compatability with JR 9303 PCM
  95. 9155 digital servo
  96. 12FG switches
  97. 7C FASST With 2048 Resolution?
  98. FASST servo compatibility
  99. 12FG UPdate
  100. 12Z
  101. 10C
  102. GYA 352 GYRO QUESTION
  103. 14MZ question for Bax
  104. 12Z encoders...
  105. 12FG failed v1.6 firmware update
  106. Mixing Question?
  107. Tell me it 'taint so - linking to 7ch & 8ch RX's
  108. 6ex manual: elevon confusion
  109. 7C tx advisory return question
  110. 10C binding
  111. FUTABA 6XAS PROGRAMMING AILERONS
  112. R156F Help
  113. Futaba Trainer cord and plane setup
  114. 4PK questions.
  115. FP-TP-FM vs. FP-Tk-FM Transmitter Modules
  116. conditions 12 FG ?
  117. T6XAs/6XHs 120 degree E-ccpm capable?
  118. can fasst be used anywhere in world?
  119. "Now Loading" problem with MZ14 Tx
  120. 3PKS connected with 2 receivers
  121. 9155 servo gears
  122. 12FG: When change tail type i loose all mixes ...
  123. GY 407 Setup with 7ch 2.4gh Transmitter
  124. 12FG, v1.6 whats new?
  125. Servo connection by model type
  126. changing model on Futaba 3pm 2.4ghz
  127. 14Mz Tx
  128. Servo Gittering
  129. how mach models with 16K CAMPac??????
  130. S9351 new servo problems
  131. 10c and "glitch"?
  132. Install A123 Battery 3 cell in 10C?
  133. 10C heli flight mode setup
  134. 10c and sim
  135. 12fga & 6ex buddybox
  136. Sailplane motor control
  137. 10C Locked out
  138. 10c module?
  139. Battery failsafe??
  140. T12Z to T12FG Model transfer
  141. 10C compatibility with a TX tray?
  142. Max apm draw for 9252
  143. Carrying Case for the 10C
  144. dual servos on aileron for T7C
  145. 9C CAMPAC conversion 10c
  146. Futaba 12Z 2.4 Set up as "Teacher" w/9C "Student"
  147. 12 FGA stick problems
  148. 9C CAMPAC IMPORT
  149. 6ex 2.4
  150. Signal amplifiers on the 14mz?
  151. R616FFM 2.4GHz FASST Rx
  152. S3150 current draw + BEC
  153. Can I power my 10C with a 3 cell Lipo?
  154. Receiver antenna
  155. 3156 over centering #2
  156. End Point Adjustment Vs. Limiting the Percentage in the Dual Rates - Set up
  157. 12z programming
  158. 3 Rates for 10C?
  159. S9101 & S5101 Servo 2.4 GHz compatibility
  160. 3PKS + FAAST binding issues.
  161. HRS vs. PPM?
  162. Mixing-problems
  163. 14mz music problems
  164. Futaba 10CAP Throttle Lock?
  165. 6ex to 4exa buddy system
  166. possible 607 issue or what else?
  167. Futaba TP_FSM synth module Glitched on Ch60
  168. diode that prevents cycling
  169. 10CAP Reverse Elev servo using mixing
  170. Problem with T8UAP Probramming
  171. msa-10 equal travel??????
  172. 10C ailevator on 7-channel receiver
  173. 3PM FASST receiver "R603FF"
  174. 12FG
  175. New Rx Pricing Current??
  176. 10C countdown/timers
  177. can I change the light in the 10C???
  178. 9c conversion
  179. FASST Receivers
  180. Signal loss in a brand new 14 ch. rx!
  181. R616FFM Receiver servo adapters?
  182. Did I blink and miss the 10C release?
  183. Overheating of FASST RX
  184. 2.4 fasst european module
  185. FASST confusion
  186. TM-8/TM-7 module + Futaba 9Z
  187. BLS251 compatibility
  188. 9C Super face plate
  189. MSA-10 plus MPDX-1 and 2.4
  190. 9CAPS 2.4Ghz Module "lag time"?
  191. FASST install on helis
  192. 2.4 only
  193. Futaba 8UAF radio set battery power.
  194. fasst receiver
  195. Crossed trims
  196. Compact Flash Discontinued?
  197. 12Z E glider
  198. Urgent Help required T12FGH+Calibration !!
  199. Wich reciever?
  200. 10C with FP-TP-FM
  201. DG1 and 2
  202. Multipel receviers
  203. Futaba 10C with PCM
  204. re; parkflyer receiver
  205. FASST antenna mounting
  206. S9254 Tail Servo on a Gasser Heli
  207. Product Advisory on the R6014FS
  208. Buddy Box for 10C
  209. FASST reciever...heat problem???
  210. 10c fail safe funtion with 608 receiver
  211. Throttle stick travel problem with 12fgh
  212. Futaba Flyers Club
  213. GY611 Servos
  214. Composit Extra with R617 Fs receiver?
  215. 10C ailevator function
  216. Futaba BLS251 brushless servo
  217. How many can fly at the same time with FASST?
  218. 6EX FASST loses GUID, resets to "error" ID
  219. Why were my posts removed?
  220. MOVED: 3PM-FM settings for RC Electric Drag Racing
  221. Diode on R5114DPS?
  222. How far for FASST range check?
  223. 12 FGh
  224. Dedicated FAAST 10C
  225. receiver voltage of 2.4 fasst.
  226. 10C compatibility with R606FS RX?
  227. 6014 with Powerbox Royale.
  228. radio interference
  229. 36 mhz
  230. Futaba 7c 2.4 FAAST
  231. signal loss
  232. How to reset the FASST unique id code in one easy lesson!
  233. Futaba Faast buddy cord 7Cap
  234. Antenna & Receiver placement R617FS
  235. New 14MZ Firmware, v1.3.1?
  236. number of mixes in 9C Super
  237. R608FS output voltage
  238. Fail safe question for 10C
  239. Module and 10c
  240. GY 401 with 2 servos
  241. 6014 Heat issue #5/ Rx installation bulletin
  242. Are the TM7 and TM8 modules the same?
  243. Futaba 10C diff btw Europe vs US?
  244. 10C Release date
  245. end points not absolute
  246. FASST receivers
  247. FASST Receiver Installation Guidelines
  248. R 6014FS Signal output
  249. 12zheli of 12z plane.
  250. TM-8 module: What are the power, range, and antenna ratings?
