- Post-Crash Checkout
- Futaba S Bus system configuration
- 18 MZ Switch Position Warning
- 18mz/7008sb RX telemetry issue
- Continuing 12Z woes...
- Two aileron Servos on R2106 receiver?
- 8 FGS Function Channel Replacement
- Buddy cord between 14mz and 18mz
- Futaba 14SG Setting flightmodes for Flaps
- 10 cg interferences
- Hacker X-70-SB -Pro and Futaba SB rx
- Futaba 8JA questions
- 14 SG power outputs
- 10C TX in Glider Mode - Throttle on Ch3?
- Getting new radio
- receiver range
- Max voltage for 10 c rx and Futaba digital servos?
- 8fg super and naza
- Servo moving without input
- 9C Super with TM8 module, whats the most channel rcvr available?
- R3008SB 2.4GHz FHSS Telemetry Receiver
- LD Dial Polarity on 8FGS
- Futaba 14SGA and MPDX-1
- 8fg super expo?????
- 18MZ LST RST LS RS Friction Adjustment
- upgrading and copying models from 9c to 10c
- Replacement antennae for 7 channel CAP radio
- Switch position on my T7C
- T8J, R2008SB glitching on startup
- 14SG switch to operate Aerotow Autowinder.
- 14SG and R2006GS
- R6108SB receiver
- T8fg super and non super
- Futaba T10J Problem
- RonaldMotrich
- 10JA or 14SJA radio?
- Futaba Rec. R617FS Damaged Antenna
- Slaving channels on a Futaba 7C
- 10J and R2006GS
- R6008HS Rx Problem
- 14SG - 7008SB config
- 9C will not let me buddy box
- Futaba 10 CAP stick centering problem
- sg14 dual rate question
- Sbs-01g
- R6014FS - vs - R6014HS
- Tower and Futaba
- Futaba 9C Trans Repair
- Ail to Rud on 14 MZ
- 6EXA stick modes changed?
- programing the new super 8
- Servo IDs when all connected to the BUS
- what do i do help please
- futaba 7c/2.4
- 12FG. Warnings
- Futaba 14SG SA & SD switch have "out of limit" values
- Can you program a SBD-1 directly from the 18MZ?
- 14SG SBUS setup
- Futaba 2PL Question
- Futaba T8FG super display screen has gone!
- Power consumption of my Fut Tx.
- Range for R6106HF
- 14 mz settings are mysteriously changing
- 9C Trim Tab for Actual Elevator Trim Tab Control?
- ST1 and ST2 timer speech on 14SG
- Turbine brake programing question on 18MZ Futaba....
- Which channels to use for dual elevators (ailevator function) ? (Fut. 7C)
- Upgrading my TX's
- 18mz manual link error
- decals
- Futaba T18MZ Teacher (Master) vs. T10 Student
- Elevator to Flapperon mix on 6J
- Flaperons on 14SG?
- Replacement battery for 14SG
- Dual aileron channels with FP-T7UAP?
- futaba 7c 2.4 binding with 617s rx
- SBD-1 Question
- Copying Models from Futaba 12FG to Futaba 14SG
- gya431 and gya430 set up help needed
- S bus questions
- 14 sg duel rates on twin servos
- Stick centering Problem on Futaba 8FG Super
- Butterfly Offset setting on 12fg
- Futaba T6XA radio
- 14 sg
- Futabe TX T14SG and RX 6017HS
- 18MZ Question
- Futaba 14sg
- The perfect SBUS setup...
- Futaba proto
- Futaba 8FG Super is being discontinued?
- Futaba trainer cord compatability
- T8FG Super Trainer Mode
- Throttle cut 12FG
- 18MZ Door Sequencing
- Request for Futaba Part No's
- Noobie receiver power question
- Need 12FG replacement part number
- 12fg Motor/Elevator mix
- Futaba 14 SG
- T8fg to t14sg model transfer
- Model Data Recording Sheet for 8FG?
- Gear door sequencing using radio.
- Throttle position indicator is reversed
- 12 fg conditions/ non default alarm
- Gya 351 gyro atv
- Futaba servos and voltage
- Telemetry Log Data Conversion Tool v1.0
- Invoice for 12FGA serial number
- 12FGA battery re-form?
- 14 MZ issue.
- 14MZ, R6208SB, and 18 channels possible?
- 2.4 RX Antenna extension to avoid carbon shielding
- 12FG region code
- Tx and Rx compatibility
- 9074 discontinued, say it aint so!
- Trainer Cord
- 14SG and ultra mini stick flaps and ailerons
- Found some old Ripmax Futaba Digimax 4 equipment and could use some help!
- 12fg updates
- dual receiver+dual batterys opinions
- Futaba 3115 servo usage
- Futaba fix for 14SG Labeling wearing off of front panel?
- Futaba FASSTest R7003SB Receiver and Mini V-Bar w/ Telemetry....problem?
- 14SG transmitter battery options
- 14SGA programming help needed
- Telemetry
- R7003SB Sbus does not work with Bavarian Demon
- T6exhp 35mhz
- 14sg & t-fhss
- R6008HS Receiver Case
- R617FS Receivers will not bind
- BLS172SV servos
- 9551 for dual elevators on a 30cc plane?
- Flaps Programming FUTABA
- DG1 and DG2 14SG and R7008SB in Mode D and sbus1
- AnyLink & 8fg
- Mode 3 for 18 MZ
- Futaba 14SG transmitters Switch A labeling is wearing off!
- 18MZ binding
- 4PLS - charging
- TX battery and charger for 8J
- Futaba programing
- 14sgh updating from v2.0 to v3.0
- Futaba 14SG telemetry
- GYA430 and GYA431 Gyros
- 18MZ sound files
- 12FG radio not working with PCM G3 receiver.
- THANK YOU! Futaba and Great Planes customer service
- Antennas exposed lengths differ!
- 18 MZ Telemetry setup
- R7008sb & flightmetal
- Programming Futaba 12Z for Behotec retract/brake valve?
- Max voltage limit for Fut SBD-1 S-Bus decoder?
- 2 aileron, 2 elevator servos on T10CAP with 7 channel receiver
- 14SG Flying Wing Programming
- Moving switches 12FG
- Software Update Question
- Buddy Box
- 12 FG problem elevator-rudder
- Battery size
- 12FG to 14SG data transfer
- t8fg restart ?
- 14SG switch question?
- cgy 750
- gang servo
- New 14SG Rx Voltage Telemetry warning not working
- T8J I'm a little confused
- Bax,should I be concerned about reception/interference?
- 14 SG with R6014hs
- Wrinkled T9CAP
- Futaba 14 SG
- cgy750
- 14sg sound volume
- T8FG Model select
- Futaba Transmitter service in Australia
- 14sg Updates
- 14sg update
- T18 and programmable mixes for DG1/DG2 channels
- 18MZ telemetry with CC ESC ?
- 8FG SD card
- Futaba 14SG LED Questions
- Futaba R6008hs on 7.4V
- Futaba 4vf-fm problem
- futaba 6x 2.4
- 14SG with 7008 rx operating DG1 and DG2
- Futaba Trainer Box FM/PPM/2.4GHz (FUTM4376)
- Futaba 9Z
- S-Bus newbie question
- 8j throttle cuts to off regardless of throttle position
- 18MZ Flyer's Club?
- Futaba 18MZ warnings
- 18MZ data to 12FG
- Questions about 18MZ
- FHSS vs FASST
- FP-T8UAF can I use throttle cut to operate dle gas engine kill switch?
- T14sg external volt and rx question
- Futaba 9C elevator setup
- Will the 18MX work with the Futaba Trainer Box FM/PPM/2.4GHz Properly?
- Programming 18MZ
- Futaba programming page? Maybe?
- T8FG Upgrade download
- T8FG Bind same RX to different models?
- New R617FS
- 12Z Throttle cut
- Configuring the telemetry display on the T14SG
- Gimbal switch control
- trainer options for a t8fg super
- Can Someone Get Futaba to Fix the 14SG Variometer?
- Signal wire load
- TM-14 Module Link mode
- New Futaba Servcie Center Email address!
- 8FGS 2 levels of airbrake
- Converting a 14SG to mode 1
- T14SG having trouble with updates
- Date of manufacture?
- Trainer question
- FASST 7C no longer links to receivers
- R7008SB Frame Losses Or Lost of Signal while using PowerBox Or Smart-Fly
- gyro
- Dead-band
- please some help bls 251
- 14mz eurofighter programming
- 14SG touch pad won't respond
- 18mz How to switch vector thrust on/off
- Futaba R6014FS - Older unit stops working shortly after starts
- Need help programming 10c
- Using MIX on 6EX transmiter
- S/bus receiver question
- reciever ports
- R6208SB vs R7008SB
- BLS153 replacement?
- 14SG and Flaperons
- Futaba 9C with AnyLink Module NEED to remove RF module too?
- Bls173sv
- 9ZAP battery
- SR10 reverser and digital servos
- 4PLS and Team associated rc8.2e
- 8FGS switch problem.
- 9CAP issue when altering EPA
- Hadron Thrust vectoring question?
- T8J with R2006GS 6-channel receiver
- Lost the bind and crashed
- 8FGS power down/shut-down
- Wireless trainer system and T18
- BLS 156/ 157 HV replacement
- Installing ratchet and not returning-to-center on left stick
- Trouble adjusting servo level/signal
- Futaba 4PLS Throttle cut off when turning left or right
- S.Bus 2 & HV
