PDA
View Full Version : Futaba Radios Direct support forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44
  1. Deleted
  2. New 6 Channel Receiver Resolution
  3. 12fg stick problem
  4. What rx can I use-9CAP on 72mhz?
  5. Broken Switches need replace on 14MZ
  6. Please remove
  7. R149DP manual
  8. 9257 servo arms
  9. R617FS
  10. Need help binding a new R604FS Reciever
  11. Faast RX Install
  12. Duplicate FASST Tx ID
  13. throttle and pitch curvs on 10CG
  14. 12FG Region Coding
  15. 14 MZ GOING IN TO FAIL SAFE
  16. 12FGA - PMIX questions
  17. Use od Channel 7 on R617FS 2.4 Futaba Receiver
  18. 8U to 9C model memory transfer
  19. Info on New 6ch receivers
  20. Throtle cut question and request for actual documentation
  21. Futaba 10C - are 36mhz modules available?
  22. FM 9C converted to Fasst - should antenna be removed??
  23. Programming Smoke Pump w/9CAP Super
  24. 7C - 2.4 throttle problem
  25. dual rates and idle-up on 9chp
  26. 10CG Programmable Mix Question
  27. T4YF
  28. Futaba FP-T6VA
  29. Futaba F
  30. 7C to 10C, question about prog.
  31. Futaba Transmitter Channel Change
  32. 12FG SD Card - Copy data to PC?
  33. 12FG Dual Elevator Expo
  34. T4YC as a buddy box
  35. New S9070 Servo
  36. Dual battery setup
  37. FASST Receivers linking to Tx
  38. Twin 2.4 recievers
  39. Futaba 9c Flap Question???!!
  40. Bax, what is the dif. 10CAP vs 10CAG?
  41. Are JR servos compatible with Futaba receivers?
  42. 6004FF Receiver
  43. FASST 3PM 2.4 - 2nd motor on 3rd channel
  44. 14MZ MDL File from Germany workaround?
  45. tx battery options
  46. FF7 (T7CP) Trainer switch ?
  47. Futaba 7C 2.4Ghz and R608FS receiver
  48. Broken Throttle Detent Mount
  49. Limit vs. travel in 12FG end point setup
  50. Poor Service results in loss of business
  51. R617 Receiver Question
  52. 6014 receiver install
  53. 12FG update
  54. R617FS Power from BEC OK?
  55. Futaba servo's and A123's
  56. 7c fasst
  57. 10chp erratic behavior
  58. Interferance with wireless video transmitter
  59. Throttle mixing on 9C
  60. reciver help
  61. GY520
  62. Is the heat issue with FASST finally corrected fro car receivers?
  63. Futaba & grey imports to the United Kingdom
  64. 8U How to change the name of channel 1 to Throttle
  65. Is this normal with 9254 servo
  66. Removing clicks from throttle on Futaba 9C
  67. Futaba T12FG 35MHZ Module problem
  68. Futaba 604fs in Revo
  69. 2.4 fasst works france but not on general
  70. MOVED: Why No Choice of Receivers with 10cg???
  71. WILL THIS CAMPAC WORK WITH THE 10CG?
  72. 8U Delta Programming
  73. 12FGA 2.4 or 10CAG 2.4
  74. Futaba T7CHP - Twin elevator servos.
  75. switching on lights using a MZ14
  76. 10c issue
  77. 2.4 Set up lost communication
  78. V Tail Mixing problem??????????
  79. 12 FG Delta programming
  80. New BLS servos
  81. 12FG 2.4 Question
  82. 12FG 2.4 Question
  83. 6014 Rx
  84. 6014HS Channel Assignments
  85. Question about Futaba 4 channels radio for Tamya Tractor Trucks Scania R620!
  86. 6EX setup for Elevons
  87. 8fg? when?
  88. 10CAG Intergrated 2.4 & Double Aluminum Carrying Case
  89. 12FG and R6008FS or HS receiver setup
  90. R6008HS Rec and 10CAP Radio, Elevator and Aileron hook up
  91. Can't get ABRAKE to work on my Super-8U
  92. 4PK, 604FS, BEC and 3 way switch
  93. 9z question
  94. 12Z servo speed adj
  95. 14MZ MDL File on different frequency
  96. Futaba 12FGA comes with which receiver?
  97. changing crystals
  98. Max servo voltage
  99. T6XH
  100. 10c programming help please
  101. 2 rc planes on the same Futaba 6xas TX
  102. 9C to 10CG Program Mix conversion question
  103. RED & GREEN flashing lights on my 607FS Receiver
  104. failsafe on 9z question
  105. IS the 12FGA compatible with r607fs?
  106. Xmitter Case
  107. 7C 2.4 GHz TWO AILERON SERVO SETUP
  108. 10C,6008HS,Ailevator
  109. Left my 10C ON in its case for about 30 minutes ..?! bad ?
  110. how to connect twin elevators
  111. 3PM Questions
  112. R608FS vs R6008HS
  113. Rudder to Aileron mix w/elevons on
  114. 3PM 2.4GHz questions
  115. 3PM-2.4G
  116. Servo Compatibility
  117. Is the 2.7 volt issue specific to 14 channel receiver
  118. Futaba 12FG / R6014FS Rx , Y harness
  119. FASST receiver R6014HS output signal
  120. Reciever Compatibilty
  121. 9C conversion to 10CG questions
  122. High Torque EP Car Servo Question
  123. The most expensive radio doesn't have a flaperon function?
  124. 10 c throttle slow function
  125. Futaba HRS and VXL esc
  126. Futaba 6014FSReceiver Antenna
  127. TX and RX min voltages in 3PM 2.4 GHz
  128. 9Z Antenna removal
  129. 2.4Ghz in a 9c
  130. TX/RC COMBO'S
  131. Please help : 9CHP (40MHz) with Synthesize Module Having Problem
  132. 5114 in the sun
  133. 10C RAdio Antenna
  134. Fail safe problem on 3PM-2.4
  135. 2.4 ghz question
  136. lipo transmitter battery question
  137. Park flyer rec for 6EX 2.4
  138. This radio+2.4G module???
  139. fasst specs
  140. 9Z and Fasst modules and receivers
  141. Is it worth sending in 75mhz module and FPR-113ip Rx in for service?
  142. 12FG & 6014FS - compatible ??
  143. The R606FS Futaba receiver problem
  144. Futaba 7C, 2.4 ????
  145. 10 C trainer for the 14MZ?
  146. 10c throttle curve
  147. 12FG 72mhz bind issue
  148. T6EX antena fix
  149. Not lynking
  150. 12FG & 14 channel Fasst receiver
  151. 12Z problem
  152. 12 FG QUESTION
  153. New Receiver Request
  154. Digital Servo / Receiver Clash?
  155. From a 7C to a 7C 2.4 or 10C 2.4G HELP
  156. Surface Jumping With Rate Change
  157. 6014HS Channel Assignments
  158. 12FG throttle setup
  159. 12FGA switching recvrs from 6014 to 617
  160. Crystals ... beginner questions
  161. deleted
  162. Reset the 3PK to factory setting
  163. set up steering
  164. multi-prop and more on a 12FG
  165. simple help
  166. 10C
  167. 12FG: AFR EXPO1, EXPO2, POINT ???
  168. Receivers
  169. dual elevator servos
  170. exceed raptor g2 what should i set my d/r exp futaba 2.4 7c
  171. parameter setting help futaba 2.4 7c radio
  172. 3PM 2.4 EPA, EXP and D/R-ST when mixing
  173. FASST receivers
  174. 9c's and 8u's
  175. Cost To Install Heavy Springs In 14MZ
  176. 12 FG programming query
  177. servo synconizer
  178. futaba 7c switch and stick sharing problem
  179. Buddy Cord Compatibility?
  180. 9CAP trainer switch
  181. magnum 3pm 2.4g t3pm
  182. Map Transmit Channel 6 to Receive Channel 4
  183. MSA-10 programming question
  184. Futaba 12 FGA Dual Rates switch problem
  185. 9CAP 75 mhz module/reciever compability
  186. flap to elevator mix problem with 12Z
  187. Foam Wrapping a FASST Receiver
  188. 12 FG Fasst - programming an optical kill switch
  189. 6014HS Signal voltage
  190. 3pm 2.4 FAST
  191. Futaba FASST receivers
  192. help setting my throttle servo
  193. TRIPLE RATES
  194. 14MZ Transmitter Stick Springs
  195. Futaba T2PH Radio
  196. Futaba R6008HS Receiver Question
  197. 12fg Brake mix on down elevator
  198. R6014FS Receiver instructions?
  199. 7CAP Fasst - Throttle cut
  200. 6014FS - installation
  201. 14MZ Transmitter Pot Questions
  202. heli setup Set idle ups
  203. 3PM FASST Antenna
  204. Futaba FAAST receiver "beeps"
  205. 6014HS Signal Voltage
  206. R603FF Broken Antenna
  207. 14MZ Binding
  208. 10C, 4 channel receiver problems
  209. 12FG Multiengine Throttle Cut and Idle Down?
  210. General Receiver /pcm antena legnth
  211. 6014HS Channel Assignments
  212. 14MZ Transmitter Pots
  213. BRUSHLESS SERVOS VOLTAGE QUESTION
  214. 9155 servos
  215. 7 CHP Glitch
  216. hooking 6ex up to buddy box
  217. Swapping gimbles on a 12Z
  218. R617FS receiver voltage question
  219. Faast Receiver Antenna Fixture
  220. Early 6EX recall
  221. 9C P-MIX FOR THROTTLE/RUDDER ??
  222. dual conversion or single converson?
  223. 8UAF flap setup help
  224. transmitter battery discharge problem
  225. Compatibility Europe – USA 12FG (FASST 7)
  226. Futaba T4YBF
  227. just ordered the 10c
  228. Futaba 10c 2.4GHz
  229. R604FS antenna
  230. Broken Receiver Antenna
  231. R6014HS question
  232. 12 FG programing???
  233. Futaba 9Z 10 channel
  234. difference between r607fs and r617fs
  235. R603FS
  236. FASST QUESTION
  237. Voltage regulator blown on 9c Please help!!
  238. How to program 12FGH Butterfly/CROW
  239. HOW TO SET UP SMOKE ON 10C USING A TM8 receiver
  240. S9202 vs. S9001
  241. Futaba 3010 Servo ?
  242. 14MZ G3 receiver not binding or working.
  243. 9Z/TM-7 Problem
  244. 7C How to set up rudder to aileron programming
  245. Futaba 10C compared to 10CG?
  246. Futaba 14Z Upgrade to 2.4 GHZ
  247. MPDX 1 Mode.
  248. AMP Limits For 6014 Receivers
  249. futaba servos with jr/spectrum receiver
  250. MOVED: servo selection
