PDA
View Full Version : Futaba Radios Direct support forum
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44
  1. Slave channel has no trim function..??!!
  2. Futaba 16SZ Throttle
  3. T14SG Flaparon Programming
  4. 12FG Question
  5. FUTABA T10J output fail
  6. help on futuba t9chp radio
  7. R3008SB HV receiver output voltage
  8. 16IZ Reciever Linking
  9. 16IZ Antenna Orientation
  10. Futaba attack-4 radio charging question
  11. Futaba 12FG Limited Elevator Travel
  12. CIRRUS vs FUTABA
  13. Setting via Futaba 14SG
  14. Can’t find the SWT controls on FP-9ZAP
  15. Futaba 14 MZ help
  16. Futaba 16SZ vs 16IZ
  17. Futaba 16sz Rx compatibility
  18. 12 fg gear door sequencing
  19. Futaba 16IZ facilities
  20. Plug Battery into S.BUS2port
  21. Range Checking
  22. Futaba 10cag receiver availability
  23. Futaba 12Z throttle travel programming ???
  24. Compatibility of new 16IZ with18SZ/16SZ
  25. T14SG switch repair
  26. 12FG triple rates switching
  27. Radio Terminology
  28. Futaba 16sz dual rates
  29. 4PL issue
  30. R7008SB Channel Modes
  31. Inhibiting a switch or surface when another switch is in a certain position? (18SZ)
  32. Futaba Air RX with ground TX binding?
  33. 16/18sz Flaperon Programming
  34. Futaba 10CG
  35. Futaba SBus2 Auto Pilot Interface?
  36. 32mz inspection
  37. 16SZ Program Mix
  38. Futaba 18 SZ to power box professional
  39. Futaba 16sz
  40. 32MZ Inspection Notice
  41. R6014FS Recivers &n RCexceell kill switch
  42. Futaba Receiver Battery Redundancy
  43. Username on Futaba 18MZ
  44. Futaba T2PH one servo not working
  45. Fasst and Fasstest
  46. Futaba T16SZ Channel Crosstalk
  47. LiFe Battery for T7C Transmiter
  48. FASST receiver with 8J or 10J tx
  49. 18MZ slow boot
  50. Futaba T12FGA 72mhz module
  51. Futaba 12FG to 16SZ memory transfer question
  52. T6K tx telemetry issue
  53. Elevator trim for airbrakes
  54. Futaba 12z module issues
  55. T7C Transmitter will not link or bind to R617FS Receiver
  56. 16Sz/18Sz 3.9 Upgrade
  57. Robbe/Futaba F1712 Vario and 18sz
  58. futaba 4pk
  59. Help troubleshooting
  60. Sbus hub - green or orange connector?
  61. Model ID for 18MZ
  62. Futaba Receivers and Carbon Structures
  63. T18SZ SD Card Problem
  64. Receiver compatibility with 12FG
  65. T6J with Trainer Cable
  66. 32MZ and flaps
  67. 32MZ Throttle Stick Friction Brake
  68. 16z airplane throttle hold
  69. 18MZ updates
  70. R7008sb signal loss (interference ???)
  71. Upgrade R6308SBT to R7008sb?
  72. Power supply to most Futaba receivers
  73. R6014hs
  74. 18sz Right Slider not centering
  75. Queseion
  76. S-BUS2 Filter
  77. Futaba T14SG HELP
  78. t18s1i 3.9e update
  79. Futaba SBS-01C Sensor
  80. 18 SZA Transmitter Antenna Orientation
  81. Very old system
  82. Futaba 10J buddy ?
  83. Futaba Radio Service
  84. Loud puzzling noise when power on
  85. Throttle on a 18MZH
  86. Programing dual elevators servos on a Futaba T6J radio
  87. Futaba 8UAF - Programming the 'G' switch
  88. Wing and Tail Type Futaba 16SZ with more servos
  89. Futaba Model ID Information
  90. T16SZ/T18SZ Version 3.9E Available Now
  91. Futaba 18MZ to Futaba 14MZ
  92. 12 FGA Expo values and how to set expo
  93. Sound File Update on a Futaba 14SG
  94. T18SZ Update 3.9 - Model ID
  95. T10J and flaps
  96. T18SZ motor kill switch in glider model type
  97. 32mz rx voltage
  98. 16 sz
  99. Elevons
  100. External voltage on 7003SB
  101. Futaba voice announce transmitters
  102. T18 T16 3.8update
  103. update 3.8 18sz1/16sz1
  104. T18SZ and R617 Rx
  105. Futaba 9 Cap radio
  106. So confused
  107. 2.4 Receiver Volltage requirements
  108. 16sz
  109. T18MZ and SBS-01C
  110. T16SZ SD card
  111. Futaba 6L Sport
  112. 18MZH to 16SZ
  113. Futaba 16SZ won’t link at all.
  114. 14SG mixing rudder/aileron and rudder/elevator
  115. Futaba 14SG "Japan" , US software update ?
  116. 32mz availability
  117. 12Z Loose Antenna
  118. 12FG battery replacement advice required
  119. Downloading Model file onto SD car
  120. Futaba 32 MZ sofware update
  121. Electronics for Piper Cub
  122. Futaba T18SZ update v 3.8 unzipped
  123. futaba t8j
  124. 18MZH Dual/Expo
  125. Futaba T10J Radio Jack Size???
  126. Need Gyro Setup Help on 9C Super
  127. Futaba 10CG lost control. I need some answers please..
  128. Looking for service manual for 36MHz T7CAP
  129. futaba t8j
  130. 14sg servo reverse
  131. LiPo on BLS 153
  132. Need Futaba receiver and receiver switch
  133. 14SG End Point submenu: how exactly do Travel and Limit settings interoperate?
  134. T8j
  135. 18mz lifespan
  136. futaba t6 ex trasmitter
  137. Paper copy
  138. Trouble linking Futaba transmitter to receiver
  139. Futaba T16SC stuck on first base!
  140. Multiple protocols
  141. 14 sg
  142. Futaba R3206SBM error in user manual
  143. 32MZ and F173 temp sensors..
  144. fried training port
  145. schematics for FP-T6VA
  146. T6J to Failsafe
  147. Setting up non Sbus servos on a Futaba RX
  148. 32 MZ charging problem
  149. SBD-1 problem maybe
  150. 32 Channels via powerbox
  151. Several Futaba 16sz Technical Questions Need Answered ?
  152. Futaba 4YWD vrs 4VWD
  153. Telemetry Logic 18mz
  154. Futaba 4PM trigger adjustment screw
  155. 18 SZ gimbles sticks to left .
  156. 7c failsafe
  157. New to Futaba 8FG Super - Flaperons Help Please
  158. Futaba Frame Error Rate
  159. FUTABA T14SG has Futaba gone backwards or am i the noob? Endpoint, Expo, D/R
  160. T12FG Camber Flap/Elevator Mix
  161. 8uaps buddybox problems
  162. FUTABA 9C Super battery drain
  163. 18mz V tail mixing
  164. T18SZ Mysterious Mystery
  165. Speed Control starts to run in reverse
  166. V Tail trim
  167. Futaba 7C programmable mix problem.
  168. Futaba Flap Set Up
  169. 18 MZ telemetry
  170. 10Cap/Skyport body boxing?
  171. 14sg to 14mz data transfer
  172. Help problem T18 MZ
  173. T16SZ Snap Conditions
  174. converting futaba 12z H for airplane use
  175. Futaba Service Turn Around
  176. 16SZ life battery
  177. Linking 10J controller with R200SB receiver.
  178. Having difficulty reversing dual aileron servos with my 8UAF Tx.
  179. Repair Center
  180. Futaba Training Mode
  181. T18SZ Reflecting Sunlight into your face
  182. Setting snap condition on 9 ZAWS
  183. T9zap
  184. Compatibility
  185. Idle Switch
  186. 16 sz switch programming
  187. Receiver R3008SB Channel mode
  188. S.Bus and Telemetry
  189. 10J receiver voltage display
  190. Y harness
  191. T16SZ S3072HV The connected servo is not ready
  192. R7006sb
  193. Futaba radio T4YWD-2.4
  194. T18SZ programming a servo delay.
  195. Can a Futaba R608FS run on 6 volts?
  196. T8J rudder control oddity
  197. 16sz Linking issues
  198. futaba t6j
  199. Futaba t-18mz battery charging
  200. Pulse width, how do I know?
  201. Advice for Elevon mix with Futaba 8J
  202. futaba 6ja verses 8ja
  203. Channel 12 problem on 7014SB
  204. t8fg
  205. Transferring data on my 12z to my 18 mz
  206. Futaba 16SZ Programmable Mixing selection
  207. 18mz touch screen
  208. 18MZ battery alarm
  209. R6014FS with 14MZ and RCEXL kill switch
  210. 18SZ Speech Function
  211. R7014SB receiver
  212. Servo Gear replacement BLS173sv
  213. Help with Futaba Channel assignments
  214. 18sz sound problem.
  215. Futaba T18 MZ RF Module Internal Memory Error
  216. dead band setting
  217. How do you link up a 3008sb rx to a 18 mz?
  218. 18mz T-fhss question
  219. Futaba 7C FASST 2.4GHz radio system
  220. Sbs-01tas
  221. Wiring of Futaba FP-R138DP receiver
  222. setup for 18MZ F16 skymaster tail-wing switch
  223. 18MZ Update
  224. 18sz instructor tx 14sg student tx
  225. Twin Engine setup on a 16sz
  226. Stutus of old "New" System
  227. Futaba 18sz and futaba micro reciever
  228. Screen for Futaba 12z
  229. 10 CAP fail safe
  230. Simulator for a Futaba 6Ja transmitter and Apple Computer
  231. Futaba 6K Radio
  232. Futaba 10J flap servo travel speed setup
  233. R7014SB and 18MZ
  234. Futaba 18SZ system freeze
  235. Futaba T8J turns off on C Switch
  236. Spoilers
  237. Futaba FPT-8SSAP manual and replacement switches
  238. 18/18sz SD Card File System
  239. 14MZ touch screen
  240. futaba 14sg voice
  241. Modify Switch Function - 14SGA
  242. Futaba 6K Radio
  243. Futaba 72 mhtz RX for LiPo batteries?
  244. 18MZ variometer melody range, offset and deadband setting resolution
  245. T7C buddy box leads
  246. 14 SG Range Check
  247. New 14SG Backup error
  248. 18MZ with Kingtech telemetry module
  249. Futaba and lead free solder.
  250. T14SG to R617FS Aileron Differential
