PDA
View Full Version : Futaba Radios Direct support forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36 37 38 39 40 41 42 43 44
  1. Wrong Name & email Bouncing
  2. PCM Radio won't rangecheck...
  3. 9Z WCII battery holder
  4. Futaba 9C 3-Position Switch Locations
  5. 3101 servo?
  6. FP-113iP
  7. What G2 Interface cable do I need?
  8. GYA350 Gyro Recommended Servo?
  9. Digital Servo power needs
  10. 14MZ Elevon setup
  11. Futaba GY401
  12. Retracts on Ch4 with 7C
  13. General question re:Futaba airborn
  14. Futaba 9 Cap
  15. modules
  16. Need a little info
  17. slight problem
  18. General Futaba Flight Pack Question
  19. R146iP on 75MHz needed
  20. MOVED: 9C vs. 9Z
  21. Servo Bench Check
  22. 9z and 16k campac
  23. Checking Battery condition Conquest FM
  24. Dual aileron setup for Futaba 8UAFS
  25. Using 4 servos Ail and flaps with 9Z
  26. Stalled servo?
  27. r156f receiver not working
  28. Servo reverser
  29. Buy a Futaba 3PK???
  30. S3050 slop...
  31. Ground and transmitter don't mix
  32. Flaps and flaperons?
  33. R319DPS Receiver and dual batteries problem
  34. Any way to get variable airbrake/crow in Acro mode?
  35. 9C Flap / Spoiler mix help
  36. **** POSTING IN THIS FORUM ****
  37. Throttle Conversion?
  38. Futaba 9CAF ? on Spoilerons & Flaperons
  39. MOVED: Voltage regulator
  40. 14MZ: Flying wing 2 aileron programming question
  41. 9Z not talking to FMA M5
  42. programing 9C for nose wheel steering
  43. How to set a dial to Throttle EPA with 3PK?
  44. 6EXA Mixing question
  45. Futaba 9CAP and Pmix
  46. 6EXAS voltage reading incorrect
  47. 7c throttle spring
  48. I'm concerned about my receiver
  49. Krysta, are you there?
  50. 3pk display problem
  51. 14mz won't recognize my R149DP
  52. jr and futaba
  53. More Indepth Manual for 14MZ
  54. Switching rx. from low to high band?
  55. 7 Cap flap/elevator mix on G switch
  56. Programming Help - 9C
  57. can 9C synthsized module install on 9Z
  58. Can 9Z use FP-TP-FM Tx module?
  59. ff9 spoilerons & flaperons
  60. 7C crow and servo position
  61. Futaba 9CAP simulator use
  62. 9C Flaperons
  63. Futaba FP-T6NFK trainer switch
  64. Specs for a S9201
  65. 14MZ software update and new manual ... WHEN?
  66. MOVED: Glitch problem, need help
  67. 9C crow mode
  68. How to replace 9Z built in lithium battery
  69. Futaba T7-UPS Problem
  70. Futaba 9CAP - GY401 Gyro
  71. Antenna
  72. Back order status at Tower.
  73. 6YG Spring Return on Both Sticks?
  74. adjust the EXAP
  75. 9C carries some mixes while training, 9Z absolutely nothing?
  76. 14MZ on Ham band
  77. Futaba 8 ch Receivers - 138DP vs 148DP
  78. Is futaba working on spread spectrum?
  79. 9C range Problem
  80. Transmitter RF Module
  81. Super Seven elevator mixing.
  82. 9C: gimbals material?
  83. Futaba 9cap manual
  84. PCM problems?
  85. 9zhp wc2 idle down settings?
  86. 9C display question
  87. 8 Super Radio Rudder problem
  88. help me please
  89. MOVED: 8103 flaperon setting flaps
  90. Ailevator question
  91. 9C setup
  92. 9CAF Trainer Function
  93. Custom Futaba request? 14MZ electronics in FX-40 case?
  94. Flap servo reversing
  95. digital trims
  96. 9chps Module.
  97. 9C End point adjustment problem...
  98. Futaba 3PK question
  99. 9Z dual rates problem
  100. Wet servo's & Gyro ??
  101. S143 S133??
  102. price for a futaba 3pm receiver
  103. broken switches
  104. 9Z WC2 "on air" display
  105. 9C synth module and receiver power consumption
  106. Help with FP-S143
  107. 9C reset to factory defaults
  108. Radio 7CAF
  109. Fail Safe not functioning correctly?
  110. 14MZ on 50 MHz
  111. PMIX or COndition select with dials/sliders
  112. 6AXs to Skysport 4 channel radio trainer cord does not work
  113. Futaba TX RF failure?
  114. Futaba Flyers Club
  115. 9C Frequency bleed problem
  116. S3010 Servo Horn Screw
  117. Futaba 8UAPS and 9C Sythesized TX Module
  118. 14 MZ back up battery
  119. Replacing transmitter xtals
  120. 9C Servo Reverse
  121. Futaba High or Low Band?????
  122. Choke servo setup on Futaba 9cap
  123. Futaba R5014DPS rx
  124. s9254
  125. 40Mhz module
  126. T14-Receiver power...
  127. Settings When Upgrading from 9C to 9Z
  128. s3010 servos question
  129. 14 MZ Tacho ?
  130. S3151 question
  131. 9Z WC2
  132. Varying trim adjustments
  133. Futaba 7C, Dual Elev Question
  134. 14MZ synchronizing
  135. S3001 servo oscillating
  136. Shift Selectable Futaba TXMTR?
  137. Futaba transmitters won't charge with Astroflight 112D charger
  138. 7 CAP Engine Kill Adjustment
  139. Max Voltage on Receiver Bat and Servo's
  140. copying models from one 9c or another
  141. Slop in S3151...
  142. BATTERY VOLTAGE IN 9C
  143. Futaba 14MZ won't go "on air"!
  144. 9C Synth Module - Reliablity?
  145. glitches
  146. 7C neckstrap issue
  147. .
  148. 9 Channel reciever
  149. Range test glitches - Futaba TX & RX
  150. Transmitter 7cap/chp & Receiver 138dp 72mhz
  151. 14MZ BATTERY CHARGER
  152. Problems During Range Check
  153. Charging 7CAP Transmitter
  154. Futaba 9 CAPS launch, camber, reflex presets with trim
  155. 9Z WCII FLAP PROGRAMMING
  156. Voltage for futaba servos
  157. Futaba Single Stick Woes. HELP!!!
  158. Blue Gimbals on the 14MZ ??
  159. Futaba Rec/Xmitter Question
  160. 3151's at 6v??
  161. WC2 neck strap
  162. 6EXA charge question
  163. MOVED: Futaba 5UAF....Opinions?
  164. PA2 location
  165. Help Futaba PCM Rx
  166. 9CHPSwith synthesized receiver
  167. 14MZ Support?????
  168. throttle to smoke mix
  169. 9 C Super with Giant U-Can-Do
  170. 9Z spoilerons
  171. usb cable
  172. S9351 digital servo lock-up
  173. Does antenna wire gauge matter?
  174. 14MZ Flyers Club
  175. 8U and 6AX training setup
  176. servo question
  177. Gold series 7 Ch wideband to narrow
  178. 9CAPS Throttle Curve
  179. Bubbles under the screen
  180. MOVED: Single stick radio
  181. 9CAP upgrade
  182. 14MZ Neutral test
  183. 6EXAP repost from 7/6 come on Futaba aswer my question
  184. 9Z WCII Questions
  185. 8SGA-P
  186. Who has a 6XAs for sale?
  187. 7UAF elevon setup ?
  188. Servo Slow down with 9C
  189. air brake programming
  190. Buddy box and PCM
  191. 14MZ throttle cut problem
  192. cracked display screen
  193. 6EXAP
  194. Futaba GY611
  195. 14MZ triple rates?...
  196. 14MZ trim resets.. help
  197. Buddy boxes and functions.
  198. Are there any plans for a 35Mhz (UK) Tx synth module for the 9C (FF9)?
  199. 7CAP
  200. 9C throttle stick and switch on E-F mix
  201. 6exap
  202. Another 9CAP Flaperon question
  203. Trainer: T14MZ and FC-28...
  204. 14MZ Twin elevator travel not equal
  205. 14MZ Model name error??
  206. 9CAP Rotary Dial button Replacement
  207. 7Cap Question
  208. GWS DC Crystal in a Futaba DC Rx?
  209. Assigning preset Flap amount to any switch? (9C)
  210. Idle up setings on a FF9 Futaba
  211. S3152 digital servo application
  212. Throttle Exponential on 9CAP
  213. MOVED: C 25 speed control
  214. 7-UGF
  215. 9CAPS throttle timer trigger
  216. Changing Radio Channels
  217. Ultra Stick Program
  218. 14MZ Flaps
  219. 9C Voltage Readout
  220. speed control
  221. fp-r127df rx for electric airplane
  222. Futaba 6exa
  223. converting a 9451 to 9351????
  224. servos jiddering (SHAKING)
  225. Futoba Recievers & Switches to trigger 35mm camera??
  226. 14 MZ trim reset
  227. 7C used with Quad Flaps (Ultra Stick) Limitations ???
  228. 9 cap expo question
  229. Recenter screen trim bars
  230. throttle elevator mix 9C futaba?
  231. 9CAP HELP
  232. Old FP-R129DP RX
  233. 9ZA WCII Power Indicator Light
  234. Futuba S3010 Replacement Gears
  235. glitches (again)
  236. R149DP Receiver Problem
  237. 149DP hi/lo
  238. Will a 4VF Antenna work on a 7CAP
  239. futaba 3010 servo
  240. 14MZ Trouble
  241. Problem with 3FR 3 channel FM transmitter
  242. servo application guidelines
  243. Futaba 149DP PCM RX & 9CAP servo check?
  244. Radio request possibility
  245. Dual elevator set-up 7CAP
  246. Is it safe to fly below 4.8 volts??
  247. Hardwire Servo Reverse Possible?
  248. 3pk hrs vs pcm
  249. Synthesized Transmitter
  250. servo using standard with digital
