- 9c w/airtronics
- Radio Tune Up?
- Receiver Crystal Question
- 9z memory capacity
- DUAL CONTROL FOR FUTABA FF7 Super
- trainer between a mode 1 and mode 2 radio
- FP-T6FG/K w/FP-TF-FM = FM = Legal?
- Futaba 8UAPS to 9CAP memory transfer
- 7UAP Question...
- Triton charger memory question
- Futaba FM Rx Glitch
- 8uhp
- Any Futaba equivalent to CS10BB servo ?
- servo wire damage
- Fut 9c
- 6EXA on 27 or 75Mhz?
- Thanks for the service
- 9CAP, R129DP and crystal swap
- S9351 sero...WHEN?
- 9206 gear sets
- 9C rudder and nose wheel servos, Throttle ?
- 3 Channels???
- GP Patty Wagstaff with DA50- Futaba S3305 Servos Ok
- Sending back a 9253 for check up after a crash?
- Rudder and nose wheel mixing T6XA
- how can i set my 8UAPS with my plane?
- Trying to use HiTEC Neon as trainer with Fut6EXA
- JUST GOT muah 9CAP and need some help
- flaperons I need help
- 3 Position flaps on Ch 6 using switch G on 9CAP
- Crystals online ??
- WEAK TX Springs
- Hsp7850
- Poor Quality Futaba Switches
- Futaba Receivers/Crystals- Question
- Are these receivers Wide band?
- Dual ESC/motor mixing on 9C
- 6X gear up switch different
- 9151 Servo Failure
- Can two batteries be the cause of my problem?
- Futaba service
- FP-T7UHF AND FP-T7UAF rf module swap
- Krystal,please help,high or low band?
- Throttle ratchet for 9ZHP WC2
- Parts for Super 8
- Changing Crystals
- 9CAP Flaperon VS AIL DIFF wing mix
- I have a Radio question
- 6exa sticks
- 127 DF Receivers
- 9550 servo
- Bax: Please clarify previous post.
- is it okay?
- Batteries for old Futaba FP-T5FG Tx
- Fp-t6va 6m
- T6EXA Elevon Problem
- Futaba Timer
- Futaba 9CAP- throttle setting
- 9c pmix
- 3PK Antenna Warning
- Futaba FP-T5NLH
- Gy-351
- swash plate set up on a 9Z
- Channel 36 or 37
- 9Z Mixing question - can this be done?
- servo oscillation
- Dual elevator receiver requirement
- Trainer Connection
- Lost All Control
- 9CAP Needs warranty work??? (Is it damaged??)
- 512 / 1024?
- Airbrake and Flaperon on Switch C ?
- 9z replacement
- Gear Set for S9202
- 6EXA Memory
- futaba 9252 4.8 volt what about 6.0 volt
- 9CA charger??
- JR servos with Futaba
- Gy-351 ???
- Problem with Futaba 9CA Transmitter.........
- 9602 & 9650 Servos
- on-board glow programming
- 9202 Jitters at Center
- charging transmitter
- s9251 servo
- 9C Servo Test
- Weird 9C dual aileron problem
- Any plans for a new 9C?
- Futaba 8UA three position flaps
- Hey Futaba, would you please consider making.......
- transmitter problem
- Futaba Failsafe?
- 512 to 1024 conversion
- Mounting the servos
- 9CHF Tx & FP-R127DF Rx
- Cell Phones & R/C TX
- Futaba FP-7FG/K
- 5uap and 7uaps
- Batteries
- s3305 servo
- Possible Damage
- Setting Dual Rates on 9CAP
- changing crystals
- Futaba Transmitter to be used as buddy box
- Timer on 8UAFS
- Changing servo gears
- Scanner says radio is on two frequencys???
- 8UAP rcvrs.
- 9451 Voltage
- 9206 on 6V
- T6XA Futaba
- servo arm attachment?
- 5 cell or 6V?
- 8U Question about beeper
- programming problem with 8U Super
- Skysport 4 potentiometers
- 9C compatible with Hitec 8ch FM rx and crystal?
- Flap setup for 8UAP transmitter
- 6XA 40Mhz - Can I change to other band?
- Range check
- Low band-Hi band ?
- futaba S3305 servo
- Error on the Futaba info page GRRRR
- 9C 3 position flaps
- 9z or 9c module
- 9201 Servos ok for use with 6volt batteries?
- Servo Current Draw ratings
- Futaba 6 channel
- FP-T6VA range ??
- reciever question
- Cycler for 9Zap
- 6XA and a buddy box
- Tuning receivers/need info
- Can I use 9350 and 9451 on a airplane?
- Futaba 9Z - 1024 resolution and ATV/AFR settings
- help setting up 6Vh radio
- Older rcvr, module and servos with 9ch
- Service Turnaround Time
- Smoking Throttle Servo
- 9c and offset settings
- Futaba 8uap servo reversing
- My Radio Jitters When I drop the battery???
- Getting back in the game
- Throttle Ratchet Help Wanted
- 6 digitals and 2 analogs on a DP 149
- 9 zap charger question
- FP-T3PG questions
- Futaba 7UHF Manual
- 9C powered by lithium
- R127DF Rx compatability with Ni-MH
- one piece wire connecters
- Help!!!! Very strange behavior.
- Rudder Servo Zero
- Futaba Receiver Problem
- R148DP Frequency Change
- Trainer cord
- T6Xs, flaperon and v-tail mixing?
- Replacement for Charger..
- AM Frequency module use in 8U Super
- transfer data from 8 UA to 9C
- V-tail setup W/ 9c
- 7 uap duel rudder and elv servo
- 8UAP manual
- Jumping diode on 6xas
- rx compatability
- 9z and flap switch
- S3010
- 4 servo elevon trim problems
- Buddy Box and Dual rates
- crow with 9C TX and 7 Ch RX
- PPM to PCM interference
- Futaba 9251 Gearset replacement
- 8uaps case
- FP-S108 Servo Gear Set
- Almost Shot Down
- Futaba 9CAP PCM transmitter left on for 3 hours with Antenna Down?
- 9C Firmware Issue ?
- Futuba 9 C Questions
- GYA 352 Gyro
- what different between low band and high band of receiver?
- 9ZAP Question
- FUTABA RX, servo & gyro
- 9Z Screen Flickering
- 7uaf--Broken Mixing switch
- Attn: Someone who knows more than I
- Futaba skysport 6a died on FMS cable
- 8U Super HELP
- How long am antenna wire on my Futaba Rx?
- 9C-How to program flapperons...........
- Hi Band/Low Band. How important is it?
- Heli
- 3305 & 3310 sevo info?
- 8UAFS will not power up
- GVof on my GV1
- Transmit module or FP-T7FG/K
- Alarms on the 9ZAP
- Replacement Springs for 9ZAP
- Moderator needed for this one!
- Tx Battery Adapter ?
- how to control my RC model from my computer?
- 6EXA Expo on Rudder???
- 8 Uap Shoftware Lock
- Using 8th channel on RF-P148DF Receiver?
- 9C Same Strange Behavior
- 8UAF/8UAF-SUPER CAMPac Problem
- 9chp end points not working.
- S3010 4.8VSpecs
- Minimal distance between pilot boxes?
- Hit while taxiing?
- 9C Strange behaviour
- 9C trainer setup
- Futaba 9CAP Changing Modes
- Older PCM transmitter question
- Futaba FP-7FGK
- 9151 Digital Servos
- Full span ailerons - US60
- what am I missing??
- 9Z WC II module on 35 mhz
- 6EXA Trims Question
- GY-401 Question
- 9za Wc2
- Futaba Radio
- Receiver Case Part Number
- Repair Question
- 9c module
- Futaba 7UAP 6 cell receiver battery
- 9C Timer reset
- Can A FP-R6L Reciever be used with a new Futaba transmitter
- Will this work in my boat?
- Digital Servos
- Hobby Services Warranty Work
- 8u heli radio need flap switch
- Where can I buy arms for your micro-mimi servos?
- Futaba Super 8 Series Help!!
- 9cap can ch9 have end points adjusted
- 9z battery
- Is there a typo in the 6xhs manual?
- Futaba Gv1
- 7 UAP Super MIX error on power on
- bad futaba rx
- Futaba 9c measurements
- 9C question
- 401 gyro/servo question
- Hi Band And Low Band Compatability
- 401/ 9253 Gyro Drift
- model memory
- Cycling
- Futaba 9V questions
- Futaba T6XH radio - controlls mixed up
- 9ZW11 Conversion
