- futaba 8 channel
- FG series AM 5 channel radio
- Synthesized Module
- futaba ff7 throttle travel
- 14 MZ Elevon Function
- 6EXA Programmable Mix
- High Band Crystal w/Low Band Receiver
- Futaba S3305 Servo
- Stiffer 14MZ Stick Tension Springs
- Two 7C questions
- 9ZAS WC2 Mode 1 ?
- Mixing elevator with flaps
- Triple rates on 14MZ ?
- 9206 servo amplifier
- 9C - assigning Ch 3 to a switch or slider
- 9C V-Tail software error
- servo moves when plane is turned on
- timer volume?
- 9ZAW Triple rates?
- FP-R127DF Discontinued?
- FIXED!!!! 14MZ Throttle Cut problem
- Help with hovering throttle mix
- 9C FAILURE
- 149DP with Brown colored Antenna
- 14MZ Mode 1 FIASCO
- 14 mz sticks zero servo monitor
- UltraStick 40 and Futaba 6EXA
- futaba receiver problems....strange...
- New 9c super, cant turn on
- 9C... hi vs lo channel and PCM ?'s
- Futaba 9201 servo gears
- 14MZ
- 9Z and Governor setting
- Futaba antenae break
- How to connect ailerons and elevator-9C
- T14MZ shift question
- GY 601 ACGA - rudder ctl gain
- 14MZ Battery
- MOVED: Free 14MZ soundfiles for your switches
- 9C flap switch assignment
- Flaps control on 6EXA
- 14 MZ ISSUES
- compatibility ?
- 14MZ Range check
- 14 z
- 14MZ model creation error
- 9Z WC2 Internal Memory
- Trim Button on 6EXA
- Futaba 3010 servos
- Snaproll on 9C
- 14mz throttle cut error
- pp
- Transmitter crystal changes-Why not????
- Use switch to change channels?
- 6EXA V2
- 3PK Programing
- Futaba 14 MZ Mode 2 to Mode 1
- NEW 14MZ IN TODAY .. WOW GREAT
- 14mz Throttle hold problem
- Futaba SPL receiver & Tamiya TT01 Speed control problem!!!
- cirrus and futaba
- 9C Synth Module Update Please?
- Crystal Robustness?
- 14MZ Mode 1
- Is there a Servo slow on 9C?
- Couple of Receiver Servo Questions
- Dual aileron servos with 9cap..
- Removing throtlle detent on 9CAP
- 7C and elevon problem
- 9C Charge / Discharge
- How do you tell .. Servos
- 9C setup/mix question
- 149DP 9 channel receiver
- 27mHz AM 2CH Tx and 27mHz AM 3ch Rx, will it work?
- Futaba FX 40
- Timer on 9CAP
- JR 8611 compatable with Futaba Receiver
- 8UAFS won't power up
- 9C Super/ 9ZWCII Modules
- 9CAP & 9CAPS Differences
- lithium battery question
- Futaba FP-T7UAF Super transmitter
- 401 gryo trouble
- 9CHPS processor speed
- Micro servos
- FP-T8SSA-P and FP-T8SSH-P
- 8UAP – Slaving outboard engines
- battery voltage ?
- 7CAP TX Problem
- Rudder - Tail wheel mix?
- servo reversing
- Gyro confusion..(data lacking)
- gy401 gyro with jr 8103 {gain control}
- 9ZHP WC2 question
- 9C Super flaps
- 9CAPSuper Transmitter Voltage
- glitching servos 9252's
- Completely Lost
- How to determine Futaba Tx channel?
- Max receiver current? (r149dp)
- R319-DPS
- new synthesized modules
- Is there any difference between am and fm crystals?
- 9C case
- I hate to complain but......
- 3102 case set
- 319 synthesized Rx question.
- 9CAFS and 9CAPS
- 8UAF tailerons and flaperons?
- 9C Synthesizer
- 9CHP TO 9CAP
- AC Adapter for simulator
- Metal geared servos
- Futaba Receiver crystal change
- Throttle Timer Problem Identification?
- Trainer Cord Pin Out
- 5UAP battery cycling question
- Futaba 3PK Synth question
- Receiver selection parameters and 9CS?
- What's the different between 9CAP & 9CHP ???
- Channel 5 and smoke pump
- 136HP- Crystal
- Redundant Systems
- Futaba 14MZ
- Attack 4 FM72 accept speed controller
- Saving Fail Safe On Futaba 9Cap
- Woo Hoo! 9C Synth Module Yet Again...
- 9C Super knife edge mixing
- 9CS question
- help with my 3pj
- help with 3pj and hi tech
- Futaba 7cap reciever???
- 6XAs Mixing Problems
- Quick Question About 9CAPS
- R127DF to use with 9C Super
- 9CHP questions
- Help! Ailevator question
- 9CAP to 9CAPS Model transfer?
- Solved t6exa flapperons problem.
- Tower comes thru!
- Futaba Rx crystal 'type' query
- CHANGING CRYSTALS
- DIRECT ME TO BUY TX
- Computer 6EXA
- Does Futaba sell replacement shell for the 9C?
- WC2 with Jeti RX question
- 7C and crow?
- Posted in Error
- 7CAP vs. 9CAP
- Dual ail servos w/7C
- Any Futaba Computer radios with TIMERS?
- 9254 Noise question
- Down Line Mix
- Futaba R114F Rx (29Mhz) with JR Tx ??
- flaperons on 9c's
- Futaba width of negative shift.
- Futaba Gold Series FP-6FG/K FM 6 Channel & rudder/throttle stick replacement.
- Futaba Trainier box questions
- No crystal
- futaba 9chp super or 9chps synthesized
- 14 MZ release date delayed?
- snap roll futaba 7cap
- 9Z Voltage specifications
- Futaba 9C Super PCM chrage rate
- 9C Synth Module Delayed Again?
- Futaba FP-R127DF
- Futaba FP-T6NFK
- 9C Servo Test Function
- AMPS ??
- Silver coating on the 9C TX
- Buy 7C or 6EXA
- futaba 7c confused
- 7C dual elevator trim question
- 3PK,PK-FSM,R203HF,S9451
- Futaba Hitec trainer cord compatible?
- help plz. t6axs
- Receiver interference - 6V battery
- el from oneTransfering from one 9C to another?
- T6XA help pls!!
- 2 Futaba radios get damage using simulator
- 127DF problem
- 7CAPs with the throttle trigger timer problem
- 9 SUPER C SYN.SERVICE REQUIREMENTS
- S3010 and NimH
- This really stinks Futaba 2PL!!!!!!!!!!
- QUESTIONS REGARDING 14MZ
- 7C snap spoilerons?
- Older Futaba 9zap trim questions
- 9C Dual Rate Setup
- Need Help Mixing throttle to elevator in 9C
- What happend to the 9C Synth Module???
- programming a 7 channel vs. an 8 channel
- Futaba 601 Gyro question about voltage
- Data transmission rate for 9CAP.
- Compatability??
- Futaba Repair Service
- Why only 6V on 9152
- 9 C receivers
- designated channel FPT6VA
- 6YF vs 6YG
- Change Frequency .
- r319 dps question
- Futaba/Cirrus
- channel determination
- Change stick mode on a Futaba Skysport T4YF
- servo speed
- RF module compatibility
- What campac will fit my 8uap
- Input Voltage Range for Futaba 9C
- SkySport Glitch
- futaba receivers
- Replacement transmitter battery
- 9C with 4 aileron servos & Flaps?
- 9C help!!
- 9Z Manual
- 7C/ buddy system
- 9CAP Throtlle setup
- 9 CAP programming Help.
- Hitec 7 for Heli's
- 6XA series...special memory battery?
- 9Z SCREEN
- 8UHF-S Mixing Question
- Transmitter modules
- M14 Questions
- Old Radio - Is it still legal?
- 6XAs Futaba (sudden reversal)
- 2 futaba s3305's not same speed.
- FP-R148DF problems
- R114F with Synth. module
- 9C finish
- Futaba R-127DP PCM Receiver
- 7CAP 75mhz-72mhz conversion
- Happy Birthday Kyrsta
- futaba s3151 digital servos???
- Futaba Junk
- 3004 Servo grommets
- How to reduce rotation of gear servo on Fut. Super 8
- R-149DP reciever
- Battery Charge question on 7C Radio
- Servo packages say "Ni-Cad only" Why?
- Many Thanks
- 9Z battery questions
- 7C Throttle Curve for Aero?
- throttle on trainer switch, spoilerons on stick, 5 channel RX, Futaba 9CAS super
- Problems with 3PK / ESC combo
- Help progaming SUPER 8, please
- Gyro Setup On Nose Wheel
- 7CAF timer
- Ball Bearing Servos
