- Radio interferance
- what radio is this?
- Oops/Wow/Barbeque?
- Skysport 6A--fp-t6va question
- 8U Super and US 40...
- 8UAP Super, 148DF. Noise Issue
- 4vf Radio
- Gyro GY401
- 9c trim assignment
- Dual Elevator setup on 8UAF
- Futaba 8U & futaba conquest for training
- 9c program mix question
- More Crystal Confusion
- Futaba 8uap for helicopters w/ccpm
- short circut on a FP-R148DF
- Futaba 50mhz TX Shift
- What is the Difference?
- New top of line radio coming?
- GV1 and 7 Channel receiver
- Charger for 8UAFS
- 9cap
- 9Cap question
- Futaba 9303
- Radio question
- Training cord between 9-ZAP and..
- Range of TX
- switching frequency
- 9vap modules. Tk Vs. Tp ?
- ***new Servo Data Available!!!!****
- Throttle 'Boost' Function possible?
- Need help..
- Futaba's 9ZAP WCII - Multiple Planes
- futaba 8uaf switch problem
- futaba fp-8sghp
- 9uafs compatible with r127DF
- Why choose S3001 over S3004?
- Are all 9C Tx's PCM?
- Futaba FP-T4NBL Attack-4 Question
- Futaba 9252 and 9151 Digital Servos
- 12 Channel
- Heli training box
- Newbie reciever question
- Rx antenna wire?
- Getting my 8UAFs Checked Out
- antenna length for 75mhz
- S9001 vs S9202 and Futaba specs
- Compatability Issues - Futaba and JR
- PCM verses FM
- R138DP, R148DP, and R149DP differances,
- dual rates on separate aileron servos
- 9101 servo
- Need help with a mix.
- Futaba 153bb
- Crystal confusion
- Ultra Stick 60 & Futaba's 9ZAP WCII - Crow
- specs on 9505 servos
- Ch. 5 Switch not working
- Programming flaps on a Super 8
- Futaba FP-8AP compatible RX?
- R149dp W/ 8u Super
- Hobbico Multi-Purpose Gyros ?
- need help with throttle cut on a 9chp
- Can I add dual rates? Futaba Magnum car 2 chan.
- Dual Receiver - 149dp - range
- mcr-4a recever
- futaba rec to servo conn?
- futaba rxd quit working
- 9C LED Screen going blank
- FP-R122JE Rx Question
- S9303 time for maint
- Question for A.M. Cross - G2
- Battery warranty
- Futaba and Hitec reciever
- Need Help Fast On a Futaba 6XAPS
- Comparing 9C to 9Z
- FP-T8UAF Programming problem
- question for amcross
- GY 240 gyro questions
- Any New Technologies being considered?
- 9ZAPs stick springs
- Range Test on a FF8
- Futaba 9404 servo
- 8U VS 8U Super
- 4 Aileron Servos with 9c
- Mixing Rudder with Flaperons
- How to trim dual servo control surfaces ?
- Plastic gear vs Metal gear servo for 3D
- 16K CAMPac
- Stick Tension Adjustment On 6da
- Super 8 Rates Control
- GY 401 Gyro Questions
- Campac 64K
- 9C programming
- Futaba's Number 1 servo?
- Conquest Fp-t4nbp Pcm Rx
- Trainer box hi-band or lo-band ?
- switching from a 6xa to a 9c
- crystal change
- Futaba Transmitters
- Tower system 3000
- Flap programing on T6XAS
- dual ele servo's and futaba 6xas
- 9cap and gp wagstaff arf question
- what am I doing wrong???
- S9206 on 6v?
- Futaba S9151 Digital Servo
- servo connector question
- Futaba SR-10 Dual Servo Reverser
- Futaba 9ZAP WC copy condition question
- 9c Dials
- Is FP-T5NLP PCM 1024 or 512?
- Trainer box in wrong mode
- 8UA question
- Campac
- 7UAPS Flaps programming - help
- Sync'ing multiple 9206's
- range problem c.f. fuse
- Antenna Placement
- 8u Buddy Box Problem
- 9ZAP trim issue - Help.
- Futaba 6DA...adjustments possible?
- Futaba FP-T8JN Info
- 9206 servo
- RX bus and pulses
- 9C and adjusting the idle
- Crystal "type" confusion
- what receivers?
- Kill switch channel assignment on 9Z
- 9Z switch replacement, do I need to back up memory?
- Question about 6XAs
- Amcross
- PLL error on 9Z
- 9C programing
- 9vap module
- Receiver range New receivers
- 9C Programming Flaw???
- Big Bird Questions
- Radio Features Requests
- 8u service help!!!
- 9ca
- T8UAF throttle tension
- Free Compac w/9c & 9z ? When Did we Need To Buy?
- Futaba Receivers
- Outstanding service.
- Trainer box compatibility
- New Futaba digi servo?
- Synthesized TX Module
- New 3PK and HRS modulation receivers ROCK Chicago show
- 9C Servo Slow
- Realflight controller as 9C buddy box
- Synthesized module
- another question for ANN MARIE
- GYA 350 problem
- 8UAP range check
- Random glitches perhaps not TX/RX related but worrysome
- Futaba receiver question
- Futaba 6xas
- 9z - Mix Types
- Does the Futaba 6XAPS have Digital trims?
- Futaba 9z
- S-148 servo question...
- Futaba 8UAF Fail Safe
- 9 Channel Futaba Mixing - With Manouveres.
- Where Can I Get The Futaba 9 C Us Version Manual
- 6XA strange behavior
- 9C questions
- 4-servos 4 ailerons
- 8U spoileron programming question
- Buddy Box Compatibility
- 9zap lithium batery
- Transmitter - multi outputs?
- R 149 DP problem
- Old Futaba Manuals Needed, Please Read
- R309DPS rumor
- gyro manual needed: G134 or G154 please?!
- Mrs. Anna Marie Cross I need your help.
- Gy-501
- 9C Timers
- 8 Uafs
- 9ZAP Gear travel adjustment
- Battery for 9C
- 9Z, turbine, elevator to brake and gear to brake mixes
- 9001 up/down play in output shaft
- 9C Knobs came loose
- 9CHP pics
- 9C-Heading Hold
- 9C and Butterfly
- Now I am confused!
- Is this really true?
- Battery Cycling 9ZA WCII
- 8UAPS D/R Switch Mystery
- Another 5 cell question...
- 9Z WC II battery case
- 5 cell receiver pack
- 6xhs
- 9Z ATV Function
- 8 UHP Elevator to Flap Mixing
- Radio Hit, from different channels?
- 9C - UltraStick 60 - Crow and Full Span Ailerons - I’m confused.
- 9Z Flaperon Function
- 9252 voltage tolerances
- Another HI-LOW Band Question
- Flaps On Throttle Stick With 9C?
- 9C instructions not in a 3-ring binder, blemishes in transmitter
- Moving Condition Select from switch C ( 9Z)
- 2-servo Elevator
- More servo recs
- 9Z and Ultrastick
- Low end servo recommendation
- Futaba 9CAF Super?
- Cutted off receiver antena
- AnnMarie
- Futaba Xtal confusion. FUTL58 vs. FUTL85
- 9ZWCII trim memory
- S9550 mounting depth
- 9c Addendum 2 Printing
- Futaba 5050 digital servos
- Direct Servo Lead For 9c And Please Check Radio Section For Msg To You About Your Web
- Help with 9Z and FMA Reciever?
- Skysport/Conquest "Ghost" Aileron Channel
- servo reversing
- Futuba 8U Questions
- R148DP Regulator
- Polyswitch Question
- 9 ZAP question
- Futaba TX6A
- How RC electronics work question
- Full span ailerons 9C
- 9C And Peak chargers
- Range Check on 9C
- Synthesized vs Crystal ?
- 6AXS throttle mixing for a twin??
- T9vhp
- resetting 9C's system timer
- 9c timer
- S9202 servo failure
- Aileron differential an Slider on 9C
- RF Tx with module on 9C
- Moving to Florida - will my receivers work
- 114 Receiver
- How long will my 9Z be gone?
- QUestion about 9C programming
- best 6 chanel radio?
- 9C manual
- Accu-Cycle Plus PC Interface
- comment on futuba vr4 4channal
- gyro servo
- 9C transmitter grips now available!
- Question about 9C radios
