PDA
View Full Version : Futaba Radios Direct support forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44
  1. Brushless digital servos?
  2. Antenna length on 14mz RX??
  3. S 3305
  4. 9CHP + Module 36.xxx Mhz band
  5. Throttle and the buddy box
  6. new spectrum tech w/futaba
  7. Servoes under warranty
  8. Recevier FP R148DF
  9. 3PKS timer
  10. charging battery
  11. gy401 LED flashing?
  12. Transmitter voltage reg on 9C to handle 3S lipos?
  13. FUTABA 6EXH
  14. S5101 gear set
  15. I lost an inch...
  16. Mixing Rudder and Aileron with a Four Channel TX
  17. Max regulated voltage for 4.8V servos
  18. 9350 gear plastic geat instead of set?
  19. New modules & receivers that are spectrum
  20. spektrum pulls trigger
  21. MOVED: Futaba 9CAP flight pack..40 MHz
  22. 12Z/14MZ RF Modules
  23. 9cap super mixing.
  24. Futaba T7CAP & T7CP
  25. 7CAP Twin Engine Setup
  26. r5114 reciver
  27. Broken 8U gimbal
  28. 12Z Firmware Updates
  29. Futaba T8SSA-P Single Stick Tx problem (scope pics added)
  30. Elevon setup on 14 MZ
  31. 12Z Error when powering on
  32. 9c gyro remote gain knob
  33. futaba 9c
  34. PA-1
  35. 6EXAS Trainer System
  36. Info on the new Spread Spectrum??
  37. ff6
  38. Futaba 136 Retract Servo
  39. Futaba super 7
  40. Figured it out.
  41. Which ESC?
  42. CAP 7 retracts
  43. Futaba 14MZ Mode 1 to Mode 2 ?
  44. Radio Conversion: Mode 1 to Mode 2
  45. 12 Z TX charger
  46. cam pac cover
  47. Face plate peeling
  48. 9Z Throttle trim
  49. 9Z Airbrake
  50. BR-2000 Battery checker
  51. 9Z WC2 Triple Rates
  52. 14 MZ Program Mix Question
  53. 14 MZ Function Question
  54. 14MZ ATV Question
  55. 14MZ and JR recievers
  56. 6EX-PCM Futaba question "Elevon Mixing"
  57. 7CHP
  58. Futaba 12FG, Gimbals
  59. 7UAF TREV function
  60. Futaba FP 6EH
  61. R137F receiver problem
  62. 12FG
  63. 9254/9254 servos ?
  64. 14 MZ Elevon setup
  65. futaba r156F question
  66. I see lots of unanswered post here...WHY?
  67. synth. mod acting wierd?
  68. Futaba 6EXH Complete Beginner Settings
  69. 7CAP and stryker
  70. 9C channel 9 question
  71. ? about 2PH
  72. S9351 case
  73. Transmission of own data using a radio
  74. R153F voltage question.
  75. Subtrim and linearity
  76. Futaba 1024 neck strap?
  77. Cycling my T6XAS
  78. 9WC2 Problem Lit. Battery and Simulator???
  79. Lipo on TX??
  80. RX Short Crystal... will it substitute for an RX Long Crystal?
  81. 9 Caps to 12 ZAP transfer throws?
  82. 8U super Battery nicad to lipo
  83. servo wire adapter
  84. Futaba Receivers Design Voltage...
  85. rx bec ?????'s
  86. manual
  87. twin elevator servos
  88. Replacing Nicd Tx pack with alkaline
  89. 14mz triple rates on flaps
  90. Changing freq. on 8UHP
  91. 9ZHP throttle setting help please
  92. Gyro's
  93. 9255 and 5,9V regulated
  94. DEBATE
  95. What have I done wrong?
  96. 12MZ/14MZ Trims
  97. Brushless Futaba servo info?
  98. MSA-10 battery
  99. FSS capabilities of R319DPS Receiver
  100. T14MZAP Feature Request
  101. T14MZAP servo speed selection
  102. T14MZAP Offset Mix Usage
  103. T14MZAP Offset Mix Usage
  104. Servo spares part numbers.
  105. 9zhp PROBLEM! Pigments frozen? Black glob on screen.
  106. FP-R127DF Receiver Problem
  107. Spread Spectrum
  108. Support for Used 14MZ
  109. MOVED: Futaba 9255 servo problems ?
  110. 12mz\14mz versus
  111. FLIGHT PACKS
  112. Futaba 3pm cond 2?
  113. Deleted by me.
  114. FP-T6FG/k in AM. Can it be switched to FM?
  115. Futaba 12z and Customer Service Problems
  116. Winter flying with the 9C
  117. 9c/9c super campac compatability
  118. 9cap vs. 9cap super
  119. Futaba Servo Question
  120. 12Z MPDX?
  121. R136HF
  122. 7CP flaps to switch
  123. Old servo specs
  124. RAdio 8uHP - Inhibit switch when mixing chanels
  125. Gy401 w/s3154 digital servo issue
  126. Multi Decoder Switch + Prop 12 + 2 No. 8370
  127. Changing to a 9CAP , only half of my Aileron working
  128. Programming 9Caf
  129. Complicated flaps
  130. 9C not centering elevator servo
  131. 9C and buddy box question
  132. installing crystal
  133. F utaba for FMS Simulator
  134. Futaba 9CAP and H9 Ultra Stick 60 Programming?
  135. Joy Stick to Radio Control
  136. Switch Assignments for 12Z
  137. futaba 8uafs
  138. max current through 8ch pcm rx
  139. Futaba 7CAP channel 6
  140. Servo buzz.
  141. V-TAIL with differential with FF9
  142. 9CH super programming
  143. T6XA throttle trim problem
  144. Futaba Christmas rebate
  145. 9ZAP programing problems
  146. programmable mixes
  147. 14mz/12mz
  148. Simple question?
  149. Futaba FP-R112JE AM29 2CH Reciever - battery connection?
  150. futaba 6exh
  151. Cirrus Rcv and Xmtr with Spectra compatability
  152. MOVED: Futaba vs JR
  153. transmitter annual retune needed?
  154. How to update 9C to 9C super
  155. Futaba servos for 4,8V on 5,6V regulator?
  156. Delete
  157. PCM vs. PPM Rx Current Drain?
  158. Serial number
  159. futaba servos
  160. Futaba FP R112JE Rx
  161. need help with my 9c
  162. G3 and 9CAP
  163. MOVED: R5014 antenna cut to 4"?
  164. R 146iP range.....
  165. Spoilerons w/ 9CAPS
  166. Throttle cut problem with Futaba T7CAP
  167. changing from ch#28 to ch#41
  168. 9C Programming
  169. throttle cut help
  170. 6EXA Throttle Stick Suddenly Centers
  171. Futaba 300+oz servo ?
  172. Futaba 3pm fs
  173. Futaba FG series transmitter
  174. S9351 conversion to S9155
  175. 6exas to 9C super
  176. 9c super - serious pcm trouble
  177. rx & crystal
  178. How to install a Polyswitch?
  179. Mode Question
  180. Fail safe
  181. Trainer Cord Question
  182. .
  183. Upgrading from a 6EXAS to a 9C
  184. 7C Battery
  185. Throttle Hold on indoor model
  186. MSA-10
  187. Can I used futaba #6exap-fm to control nitro-gas helicopter?
  188. R149dp DSC port
  189. Nose Wheel with Rudder mix using 9C
  190. r149dp?
  191. 14MZ Charging cable
  192. 14MZ Conditions select
  193. Thanks for all your help!
  194. Latest S/W Version
  195. S3305 not for Airplanes???
  196. Red LED on 7C TX??
  197. servo chatter
  198. 12Z flight conditions and Pmixes?
  199. Futaba 9Z parts
  200. FP-R168DP
  201. 14MZ Transmitter Battery Question
  202. Split elevator glitch.
  203. 14Mz Not holding Trim setting after setting up Airbrakes
  204. 3pm-fm for t-maxx set up
  205. Futaba Flyers Club
  206. 12Z function question
  207. S3155 Dimensions
  208. Mz12 in a twin
  209. Whats wrong with these servos?
  210. Cost of changing a transmitter channel xtal?
  211. Futaba transmitter with changable channels?
  212. S9550 in glow aircraft?
  213. 7C with an Ultra Stick
  214. Repair Costs - Do you charge bythe hour?
  215. 4YBF TX
  216. Rubber duck antenna installation
  217. 9CAF for heli?
  218. D/R's on one switch with 8AUF?
  219. TX RX compatability
  220. 14MZ touch screen help
  221. 12mz question
  222. SUB-TRIM QUESTION
  223. 14MZ Field Charger
  224. Airbrake on a 7CHP
  225. TP-FSM powerup procedure
  226. Futaba 9c mixing?
  227. Futaba 12z and throttle expo (airplane)
  228. R149DP and 14 MZ
  229. GSR Pylon Racing On-Board Equipment
  230. 6 meters and the 12Z
  231. Should I Shorten My R5014 Antenna?
  232. Training system setup - cords and stuff
  233. Info on old pattern type Futaba Single Stick
  234. Simulator
  235. Twin Throttle Question
  236. SUB TRIM QUESTION
  237. Setting Twin elevator servos using 9CAP
  238. very dissapointed, Futaba can't fix my 9zapWC1
  239. T12MZ Futaba receiver compatibility
  240. Throttle setup on Futaba 9CAP
  241. PCM Encoder idnetity
  242. R127DP dual PCM compatibility
  243. S9351 for use in aircraft
  244. T3PDF --which receivers.
  245. ??Futaba TP-FSM Synthesized RF Module??
  246. Multi servo control surfaces
  247. Interference/glitching with Futaba R168DF receiver
  248. 14MZ integrating a JR500A gyro
  249. R149DP ans Align ESC cutout problem.
  250. Futaba equivilent to a DX7
