PDA
View Full Version : Futaba Radios Direct support forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44
  1. Programming conditions for 8FG
  2. Futaba 4YF transmitter voltage
  3. 3 cell LiPo in 9C
  4. Help with 10C airbrake/butterfly in acro
  5. R6106HF bind trouble
  6. Futaba Fasst information wanted
  7. 7C and proportional steering
  8. HRS mode performance
  9. Program the VR control - 10C (or 9C)
  10. type 72-7, 75.490
  11. s9002 and s9602, s9650 questions
  12. Transmitter connected to simulator
  13. R6008HS Antenna length
  14. How to program 10C for Motor Cut Off
  15. How do you use digital channels?
  16. Hitec to Futaba Compatibility
  17. 12Z & 4 Aileron Servos & 2 Elevator Servos
  18. Rx compatibility with 8UAF Tx.
  19. 6 EX Pitch ?
  20. Need JR to Futaba servo cross referance
  21. Futaba TM 10 Fasst Module
  22. Can the 66014HS handle high current servos?
  23. A123 batts for futaba rx's
  24. Help needed setting up bi-plane with Futaba 14MZ
  25. thank you futaba service
  26. FP-T7FGH radio need help
  27. Running Two Fasst Systems in same plane?
  28. 7c Fasst and 8FG Fasst
  29. BLS257 and GY611
  30. 12FG alarm volume
  31. Range checking with a Futaba 8UAF system
  32. Antenna Question
  33. PCM and 9CAP
  34. 14 MZ service maintance
  35. 2.4 gig and Fut SR10 Servo rev Compatability?
  36. FASST Rx does not link with Tx
  37. Antenna extender or splitter for Faast TM-8 2.4GHZ?
  38. 8FG Questions?
  39. Which Futaba Receiver
  40. R617fs Repairs
  41. 128K CAMPacs
  42. 9C and Realflight
  43. Futaba 12FG Mixing Question
  44. How/where to purchase 14MZ switches
  45. How do you set up Triple Rate's on a 8FG?
  46. 9252 running on 6 volts
  47. 8FG and conditions
  48. 617 FS question
  49. Linking WTR-7 to Futaba 6EX or 7C Transmitter
  50. 12fg setup for twin!
  51. 2.4 RX antennas
  52. WTR-7 Wireless Training System on 9Z
  53. 12FG trainer with 9C
  54. 14MZ switch changing
  55. Futaba 9C TX faceplate Delamination
  56. 8FG flaperons?
  57. Futaba 2PH 2-Channel AM
  58. Radio check up
  59. Two Switch Operation
  60. Futaba 12FG native 2.4
  61. 14 MZ, need help.
  62. Futaba 7C setup help
  63. where to get 2.4 spare antenas
  64. Futaba 10C
  65. 12Z slowing electric motor start?
  66. R603-FF input voltage
  67. Futaba 12FG - How do I set Dual Rate for RUDDER2?
  68. R6008HS Rx on High Speed Mode
  69. Futaba CIU-2 and windows 7
  70. 7C 2.4GHz Throttle Stick Not Working
  71. 9cap aileron throws
  72. Question about Robbe/Futaba F-14 & F-16 Radios
  73. 10CAG w/ R6106HF, R616FFM or R6004FF
  74. BLS 651 vs BLS 153
  75. 12FG - Using switch to disable mix
  76. Are Hitech servos problematical with Futaba 2.4Ghz
  77. 8.4V for 6014RX
  78. CAMPac for 9ZAP
  79. Flaperon and Elevator Mixing 8UHPS
  80. Ailevator trimup
  81. T4YF radio system
  82. New Futaba radios and old servos.
  83. Brushless servos for F3A
  84. Futaba 6008 fasst recevierhow do I get ch 8 to work
  85. T14mz Change Mode
  86. 10chp and 4 aileron servos "no go"
  87. Preferred RX - PCM or 2.4 with high power electric?
  88. T12 FGA and cyclic settings!!
  89. 6014 HS receiver and non Futaba servos
  90. Futaba 6008 fasst recevier install
  91. TM-10 module in 9C
  92. new sport R2004GF rx
  93. 6EX fault
  94. 12FG and Flaps Function
  95. S3801 servo
  96. Futaba T10CG Problems (Crash)
  97. Automatic rudder dual rate on the 10C ?
  98. mixing program on T14mz
  99. Futaba 10CGA Problems
  100. R604FS-E ??
  101. wireless trainer system
  102. 9ZHP Tach
  103. 14MZ Virtual/DG question
  104. Battery F/S voltage cut-off
  105. Thread size on T7C toggle switches?
  106. T9CHP SUPER programming issue
  107. 7c won't turn on
  108. Y Harness needed???
  109. Problems with something? Help please
  110. futaba 3PM 2.4ghz FASST Problem
  111. 2.4ghz Micro Reciver
  112. S9002 for small gas OK?
  113. Planing to Buy Futaba 4PK But Scared :(
  114. Planing to Buy Futaba 4PK But Scared :(
  115. Futaba T7c Throttle Cut
  116. 10CAG Timer Switch
  117. 2.4 Glitching on Futaba 10 C with 14 ch. Rx
  118. FUTABA T6XAS Throttle Ratchet
  119. Futaba 9303
  120. 14MZ switching to 2.4G
  121. 12Z Range Check Power
  122. 12Z mixing qustion
  123. 2.4 receiver antenna
  124. 8FG configurations
  125. Y connector voltage question.
  126. Older Receivers.
  127. 6EX joysticks for 7U?
  128. Old Flap Problem Revisited
  129. Futaba 8FG
  130. Futaba T7C 2.4GHz - Jittery Rudder Control
  131. 8FG Question
  132. Possible Virus On CF Card
  133. Channel assignments f/R6014FS on a 60 Stick
  134. Is the 9ZAP WC2 transmitter ratcheting tention adjustable?
  135. Plastic display cover scratched
  136. Throttle Hold switch assignment for a Futaba T7C?
  137. futaba
  138. Software switch problem
  139. T8FG SD memory power usage
  140. servos
  141. Cannot find the "Ail to BRAKEFLP" mix on my 12ZA
  142. 12Z 2.4 aerial
  143. 12FGA with light gimbal springs?
  144. 12FG Servo Reversed Itself
  145. Wireless Trainer System
  146. something not so funny..12z
  147. 12FG trainer switch heli vs. airplane
  148. 6ex 2.4Ghz
  149. Battery Sharing with RX Channel
  150. AFR dual rate set up help needed.
  151. buddy with 2.4 and 35mhz
  152. Futaba Short Crystals?
  153. 12Z strange thing happened.
  154. Setting a deadzone at end of travel
  155. Converting 14MZ to 2.4MHZ
  156. 10C flight conditions
  157. 14mz software version query
  158. 8c
  159. Need help setting 12FG TH -> EL mix
  160. Futaba S9551 Low Profile Digital High Speed/Torq Servo Question
  161. Futaba 9ZHP
  162. Range and -
  163. T7CAP/GWS R-6NIIF GLITCHING PROBLEM
  164. R6014FS
  165. 6014HS Question
  166. 12 FGA Mode Change
  167. metal servo horn machine screw
  168. New antenna TM-14
  169. mode 1 and trainer cord
  170. 12fg multi prop mix
  171. Using Futaba 6EX as a buddy box to a 12Z
  172. any new full range 2.4 receivers coming
  173. Gimbals
  174. futaba R6106FHC range ?
  175. R6014FS
  176. Enough battery power?
  177. Flap ontrol 7c 2.4
  178. FASST on 4.8V
  179. 12FGH throttle stick change??
  180. 12Z and 12FGA F5B motor switch glitching
  181. 5014 Rx Question
  182. Bax throttle servo speed help
  183. T9C to T9C Super
  184. 12Z & 12FG Questions
  185. Futaba 10C
  186. how to set the T12FG 3-position switch? Help
  187. futaba AM transmitter use-able with any futaba receiver?
  188. Futaba PK-FSM FSS question
  189. overseas purchases and warrenty
  190. Futaba 10CG Logic
  191. CAMPac initialization.
  192. Futaba t6ex won't start
  193. 12FG Erratic Servo Functions
  194. 12FG Sub Trim
  195. 6016 Rx Problem
  196. futaba t6exa radio
  197. 9201 servo on 6 volts????
  198. 9Z 2.4 module vs. new radio
  199. 14MZ: Need to disable a switch at certain throttle position
  200. Is it safe with the 6014HS?
  201. How do I setup my FF8 to use 2 retract servos?
  202. Programming snaps with 14 MZ
  203. BLS253 vs BLS451
  204. More 12FG spring tension
  205. does Hobbico still exist?
  206. Futaba 7C radio 2.4
  207. 14MZ Prog mix
  208. 12FGA mode change
  209. Charging Futaba 4pk
  210. 12Z Compatibility with other TM for training
  211. 14mz mix question
  212. 12 FGA Transmitter charge plug
  213. Programming Dual Elevators
  214. ff9 ????
  215. 9cap programing ailerons
  216. 10CG STICK ASSEMBLY PROBLEM
  217. Region Coding question
  218. R127DF and Hitec servos
  219. futaba 3pm steering potentiometer
  220. 12Z continuous beep on some programming setting
  221. programme a 14 mz
  222. R617FS Receiver power
  223. HELP! 14MZ custom program mix for heli gear & doors
  224. SOLVED 10C and R6014FS How do I set up 4 aileron servos?
  225. R617FS Receiver Won't Bind
  226. R6014FS Trouble
  227. T6XAS with aileron throw problem
  228. Futaba 7c 2.4
  229. Does anyone know the specs on a Futaba Receiver R136 F
  230. R617fs receiver
  231. FP R 102GF rx. ?
  232. 12FG Exponential Setting Question
  233. 6ex dont link easy
  234. FG nomenclature
  235. Where does the battery go on R6106HFC 6-Channel 2.4GHz FASST Mid Range Rx
  236. Receivers - Whats the difference?
  237. fUT 3305 SURFACE USE ONLY?
  238. 6ex problems
  239. What does Diversity mean on the FASST receivers?
  240. Futaba 7CAP - trim
  241. 6 EX won't link up
  242. Futaba T6XA manual
  243. transfer data from 10c to 12fg?
  244. how to setup a front weel movement and rudder on futaba 12 FG
  245. MOVED: dsm2 module for futaba 10chp
  246. 9402
  247. Problem with Futaba 2.4G T7C Transmitter
  248. 10CA/HP vs 10CG
  249. Futaba 7C 2.4
  250. 6V usage for S9150 Servo
