PDA
View Full Version : Futaba Radios Direct support forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38 39 40 41 42 43 44
  1. Replacing TX battery with 3S Lipo: any one?
  2. 6EXA programming help
  3. New module for the 7UAPS
  4. Futaba 9Z
  5. battery lights on tx
  6. Can Servo Bearing 3003-3004 upgrade for S148
  7. 6 X A
  8. 9550 gear replacement
  9. MOVED: jitters
  10. futaba 7c mode 3 with buddy cord
  11. Radio Range Problems?
  12. 9 C Transmitter module
  13. 3PM question
  14. 9Z Tach ?
  15. Dual elevator mix
  16. Futaba 6EXA
  17. Suggestions re elevator dual-servo setup with 6EXA
  18. 9Z-WC2 - Any way to assign low end throttle trim to a slider or switch?
  19. Futaba 9451 servo set screw
  20. Futaba 9152 Digital Servo aftermarket arms
  21. Rudder/Aileron mix on the 9C
  22. 9C frequency synthesizer module Info - When?
  23. New Futaba won't work
  24. twin motor rudder mix - 9C
  25. solution to losing endpoints yet on 7CAP?
  26. 7CAP and FM (PPM) Receiver
  27. Changing Tx Freq. crystals
  28. Current carry capability 138/148 recievers
  29. T6EXA throttle stick is jamed!!!!
  30. 9C battery
  31. 9C mixing question ccpm
  32. When I order online, how can specify I want mode 1 TX
  33. 9C throtle cut is not for glider (?)
  34. Does 9Z have slider switches?
  35. 9Z mixing problem
  36. Programming 9C Snap Spoilerons
  37. 9C frequency synthesizer modules
  38. 9ZAP module
  39. Module for Futaba 9CAF
  40. 6XHS PCM
  41. 8U locked up
  42. R127DF receiver anetnna
  43. Replacing 9 Zap Gimbal Pot
  44. MOVED: Olympic games and r/c flying
  45. MOVED: 9C craps out after 12 flights
  46. Rotary Dial
  47. Need Help in programming the Super 8
  48. Futaba 7C timer question
  49. mode 3 for futaba7c
  50. Chargejack on the 6EXA
  51. Receiver Battery Port
  52. 9C Curve Programmable Mixes
  53. Inverted flight mix
  54. 9c setup for ailerons and elevator
  55. Checking battery contidion on Futaba Transmitters
  56. 9C Crow mixing
  57. Alloy servo horns
  58. computer link to 9c
  59. 9VAP battery drain
  60. Throttle Cut Alarm
  61. 9 C mixing question
  62. 9C and Campac
  63. 6X Dual Elevator Problem
  64. Futaba 12 channel transmitter?
  65. Latest 9C Frequency Synthesizer Status???
  66. Left Hand/Right Hand
  67. Setting triple D/R in 9WCII
  68. Futaba servo ?s
  69. 6XAS problem
  70. 7CAP- Need advise!
  71. change from 40 mhz to 36 mhz
  72. ATV & AFR Quest. Bax Krystal ??
  73. 9Z buddy box
  74. Futaba FF8 Problem
  75. Buddy box
  76. Futaba 7C, how to get acro?
  77. 9CAP Rudder Dual Rates
  78. 9c Slider switch and spoilerons
  79. Futaba 127 with JR 8611 guy needs helpola!
  80. can't charge the tx
  81. 7-Cap: any way to assign airbrake to a different switch?
  82. Super 8U - Flaperons and Spoilerons on switch?
  83. 9 C heli and governor switching on/off
  84. 9 Zap WC2 Modules
  85. Futaba 3102 servo arm bolt size
  86. Futaba Conquest FM fp-t4nbf
  87. RD 138 Vs RD 148
  88. need help
  89. Unanswered Question
  90. 8ua with flaperons?
  91. Futaba 7 channel receiver in GP JU-87
  92. ATV & AFR resolution question. Bax anything?
  93. Airplane radio for ground use...
  94. Futaba says NICAD ONLY with servo's???? WHY
  95. servo help please
  96. crystals
  97. 9VAP Mixing question
  98. Reverse Trims for 6XAS and 9CAP
  99. T6XA COMES OUT OF STORAGE DEAD
  100. How do you set up Dual Elevator servos with 7-CAP?
  101. Futaba7CAP
  102. Hits
  103. Switch needed for 6XA
  104. Resolved: R149DP died, then came BACK!
  105. ATV function isn't working
  106. low and high band on PCM?
  107. Re: Futaba GY502 Gyro
  108. 6EXA Question
  109. best servo!
  110. SkySport T4VF - Flutter problems - Help!
  111. Futaba S3102 / S3101 OK for 6 Volts
  112. 9C Flaperon and Airbrake
  113. any factory help here or what?
  114. reciever crystal installation question
  115. S3003 servos, are these the same?
  116. are futaba digital servos programable
  117. whats the ratings at 4.8-s3050 servo
  118. 7CAP problem
  119. 1024 Resolution
  120. Futaba Tx with Airtronics Rx?
  121. Does the 9C have the power to....
  122. 8UAPS Display
  123. Deleted
  124. RF Module
  125. Freq. Reach
  126. 3PK Radio
  127. PCM
  128. 6XA No Channel 3
  129. Futaba T6xas
  130. 6 volt on futaba receaver?
  131. 9C questions
  132. IMAC programming a 9z
  133. FUTABA 7C - WHATS THE DIFFERENCE BETWEEN THE DIFFERENT MODELS?
  134. 3PJS and 50mhz TK module
  135. GY - 240 gyro ?
  136. Help!!! Electrifly 5ch ESC
  137. 6XA TMem question
  138. 9z or 9c
  139. 6XA Dual rate problem
  140. Futaba S9152 Aluminum Horns ??
  141. Mixing TX's and Rx's
  142. I need help with my T6Xas dual rates
  143. Antenna Questions 9ZAP
  144. crytsal changes
  145. Futaba 6XA Super PCM/PPM
  146. 6EXA Trainer Compatability
  147. GYA-350 A/C
  148. spoilerons on switch C?
  149. GY401 Light flickering questions
  150. Hitec Prism 7X and Futaba 9C in buddy arrangemetn
  151. 7-CAP dual Elev. and Ail. servo setup questions
  152. 7CAP flaperon mixing question
  153. Radio interference Help
  154. MSA-10 Synchronizer
  155. 9C Questions before purchase
  156. Programming FP-7UAPS
  157. Older Futaba Am narrow band radio
  158. 9CAP & Smoke Pump Mixing, Slaving...
  159. futaba attack 4 to a gws naro reicever
  160. Local club not happy with my 9C
  161. Mixing problem using the 9C, Problems mixing elev and flap together.
  162. S9351 Servo
  163. 9C Flap-Elevator mix problem
  164. Radio and Servo Setups
  165. 6XA airplane version can it do heli?
  166. FP-S133 SERVO
  167. 9zaw triple rate setup?
  168. 9C Servo Slow
  169. 6XA Dual Rates
  170. Mix problem
  171. Crystal for R138DP 8-Channel PCM Rx
  172. FP-R127DF Antenna
  173. 7CAP Setup
  174. 7CAP Throttle Cutoff
  175. Crow mix
  176. Two elevator servos mic on Futaba T8UPS
  177. Futaba 8 CH programming
  178. T9CAP 72MHz to 50MHz
  179. 9C 3-Pos Flap Issue
  180. Campac module offer...
  181. S3050
  182. 9 Zap 4 servo wing programing question
  183. Programing FP-T7UAF Super for flaps on switch
  184. JR Servos With Futaba 7CAP
  185. Futaba R149DP PCM 50MHz possible problem
  186. 7C Aribrake switch assignement
  187. Transmitter Power Output
  188. 8UAP and twin elevator servos
  189. Futaba skysport
  190. Futaba Sponsor ?
  191. help for t6npk
  192. Best servos for 74" CAP
  193. 9 CHP PROBLAM
  194. 9CAP 75 mhz to 72 mhz
  195. Mysterious 7CAP Timer
  196. 7CAP expo throttle setup
  197. Reciever match for Fatba 7aup
  198. Futaba 3305 servos / are they good for airplanes?
  199. Unusual 9CAP performance
  200. Mounting servos
  201. Futaba 9C LCD went out
  202. 6XAs and burnt circut board
  203. Help With My 7CAP
  204. Futaba 9CAP Programming
  205. krysta pleace read...7cap users
  206. 9CAP Flaperon function
  207. 3001 vs 3004
  208. Futaba 9ZWCII
  209. Futaba T9CAP
  210. Fut 9C Dual rates on more than 1 switch?
  211. 9254 servo Ni-Cd only????
  212. Shortage of 7CA Transmitter crystals?
  213. CDR 5000
  214. 9Z ??? for Krysta
  215. Replacement for discontinued Futaba servos
  216. 6XAS and Flaperons
  217. FP-T4L & FP-R4F - AM or FM and legal??
  218. 8U tailerons & flaperons?
  219. HELP NEEDED WITH A futaba FP-127DF RECIEVER
  220. Great Service!
  221. Do modules go bad?
  222. single stick controller?
  223. delete
  224. PCM Tx and Rx compatibility
  225. New Futaba Charging Rate?
  226. 7CAP Display Question
  227. Futaba...R114F
  228. Futaba trainer
  229. 9Z Expo
  230. Futaba Web Site
  231. Futaba 3010
  232. Futaba 6XAs mixing 1-4
  233. Servo arm centering
  234. Futaba 9C Dual Rates Switching?
  235. 9Z Synthesizer Problem
  236. 6XAS Tx Charging
  237. Synthesized Futaba
  238. PK-FSM75 synthesized Tx module
  239. Rx 129 PCM vs. 149 PCM
  240. 6XA antenna question?
  241. Futaba Skysport 6va tx problem
  242. Futaba 9zap W2 range check
  243. Synthesizer module for 9C
  244. Futaba 9251 as a throttle servo?
  245. tower reciever..futaba crystal?
  246. Module Temp in 7UAFS, 8UAFS
  247. 6XAS Stick ends
  248. 9CAP glitching
  249. New Receiver or what???
  250. Crystal in a 9z syn. rx ?
