- strange problem using wireless trainer system
- Futaba 12FG transmitter and R6014HS reciever stops activating servos after short time
- Trainer Box
- Better range over water.
- Programming for a twin engine with the 8FG
- Alternative for S3051HV ?
- Connecting Sbus to 3gx, Tarot GS, DJI Naza
- R2106gf
- servo setup
- 14SG rcvr setup help
- Futaba 9C conversion
- compatibility
- Programming 7C for quad servo wing configuration
- Sticky Stick
- 72mhz buddy box question
- Throw Differnce
- Futaba 14 channel rx quirey
- T14sg updates question
- 8FGA/14SGA to mode 1?
- 18MZ power on/off audio
- 6004FF reciever won't link
- T8FG update
- Need Help P mix T8FUFG
- Futaba 12FG Problem
- 7008 dilemma
- 18mz battery draw with Transmitter off
- 14 channel
- Assigning a Different Funtion to 'SWITCH B'
- 14sg v2.0.1 speech update, why not on futaba website
- Servo arm screws
- Subs and a power panel
- Condition delay on 18MZ
- 6J Trainer
- Servo "flutter"
- 18MZA software update 2.4 fails
- Vectored thrust set up on 18mz
- BLS172HV servos and Powerbox Competition
- R617FS and Litium Ion
- T8FGsuper and Sullivan Skywriter smoke
- Futaba T6J with HK 6S receiver...
- R617FS Receiver ruined???
- R6303SB and FailSafe
- Volume Control
- 8FG Antenna hinge
- Futaba 12z and R6014FS Binding problem
- 12FG and dual throttle Servos
- T8J Voltage Reading Low
- SLT Rx compatibility
- 8 channel fASST module failsafe
- Question on 18MZ stick springs
- Futaba 8 FG teething problems :-(
- retract servo
- 18mz Telemetry Data Logging download?
- Futaba 18MZ and R7008SB :(
- Ailevator with 6008HS
- Difference between T10C with module and Integrated T10 Futaba Xtr?
- R2004GF binding problem
- 18MZ and Trainer Box compatibility?
- 18MZ Condition Hold for Fixed Wing?
- Futaba r6004ff - connecting a BEC and an ESC
- 18MZ to 12FG model data conversion?
- elevator launtch set up mz12
- T7C programing
- Flap to Elev mixing on T8FGsuper
- servos
- FUTM4376 Trainer Throttle Reversed
- Throttle Ratchet
- 12FG Failsafe settings with R617FS
- telemetry record log
- T14 SG lost it's data!
- T18MZ GEAR DOORS SEQUENCER
- Futaba FP-R7F and FP-MC4-P10 Wiring?
- 14SGA Endpoints vs. travel
- Futaba Gimbal Replacement
- Flap on VR-D to Elevator Mix on 9C
- SWITCH ASSIGNMENT
- CONDITIONS 4, 5, 6, ETC For 14Mz
- 14SG telemetry alert question
- 8J programming dual Elev & Aileron servos
- Futaba R7008 External voltage
- 2.4 conversion
- T9CAP Chrome flaking on front cover
- How to install 2 R7008SB receivers?
- Futaba 6ex
- hes-1188
- 2.4 Conversion
- SBS-01V Voltage Sensor problem
- S Bus/ S Bus 2 probably dumb question!!!
- Which is Correct. One Last time for an answer, please
- Futaba 14SG RX-Voltage Uncertainty
- Which Futaba 2.4 Receiver to use?
- R5114DPS and LiFe
- T14SG + FX32 and Captouch, what were they thinking.
- Explain: Which is correct?
- GY430a gyro
- Throttle cut
- R617FS voltage?
- 7c 2.4 throttle timer at low throttle?
- R617FS-10 servos?
- Futaba Flyers Club
- futaba 7c/2.4
- Non default condition
- 12ZH part# for SH switch
- 12z Flaps
- Futaba T6YG Sim Cable help
- part number for fut 617 antennas
- How do I do this?
- MOVED: Futaba T7C neck strap balance
- 14SG and DG1/DG2
- FHSS Module for 3PK
- New RX / TX = Servos dont respond anymore
- 14SG Variometer (Melody)
- Setting aileron differential with a 7C 2.4 transmitter
- Elevator off set
- Throttle to elevator mix
- T18MZ Gas engine kill switch
- MOVED: Futaba S-Bus
- 14MZ software update for Asian version
- 7C 2.4 GHz Throttle Ratchet
- S3171 servo
- GY 401 in flight gain adjustment?
- 10C Programming - Can't get CH7 activated
- 18MZ Trim levers
- 10CG and trainer
- SG 14 Telemetry Problems
- 12fg setup for delta wing
- 18 MZ
- dual servo extension leads and digital servos ?
- NEED HELP!
- Is the T8FG compatible with the R6008 recievers?
- Futaba 14SG ~ Receiver Installation
- Futaba 12FG RD volume swtich
- S.bus servo Programing on 18MX
- FLAP DELAY on 8FG SUPER
- Futaba 10C 3 position switch C
- Beep when Throttle Stick is in Mid Position 18MZ
- 8FG won't power up
- 2S 7.4v LiPo OK For RX and Digital Servos?
- 14MZ display BACK LIGHT
- Futaba 6EX
- 14MZ - Warning when turn on TX about Throttle position.
- 14SG mechanical problem with RD
- Futaba 8FG questions
- 14 SG switch assignment
- 12FG to 14SG
- 12 FG Flap enabled by low throttle
- 10CG sliders
- 9C question
- S Bus receivers and Fail Safe
- Futaba 9C with AnyLink module
- 18 mz programmable mix lockup event
- S148 servos powered by A123 battery
- R6014HS w/A123 batteries
- Futaba s9157 @7.4v?
- Unable to link new 8FG to R6208 receiver
- How to copy 14mz into the 18mz
- Calibration problem / loose Pot in new Futaba 14 SG
- Seperate telemetry device or upgarde to new tx
- BUDDY BOX
- T8J Flap programming
- 10 CHG TRANSMITTER
- 14SG and 18MZ Model compatibility?
- 8FG resetting
- Linking 7008 rec to 14SG
- Does anybody recognize these futaba servo gears?
- 9203 servo
- FF9 and heli gyro setip
- MOVED: 1700mAh t8fg super problem ?
- Charge 14SG
- DJI NAZA - R7008SB S.Bus connection
- 12fga not binding to r6014hs rx
- Futaba S9071SB Mini Servo
- MOVED: Servo Extensions
- 7008SB Battery connection
- Got 8J to finally mix ch1 to Aux1
- T10CAP Failsafe on Ch 9 & 10
- Futuba 8J slave ch7 to ch1 not working
- Hi Bax.
- Futaba 9z battery needed
- 12z elevator to low idle mix
- need info on sbus2 vs sbus
- 14sg telemetry save to sd
- VR (D) and timers on 10cag
- Futaba 14SG and GY520
- Configuring non-SBus servos with the SBD link software
- 14sg bugs and suggestions
- 18MZ feature request
- 12FG & Governor
- 14SG Fuel mixing for twins
- BLS172HV replacement
- using one radio with 2 reciver in the same time
- sbus hub
- Hooking up a gyro
- Futaba compatibility with ebar flybarless
- Throttle Failsafe, 2.4GHz with turbine power
- any good instructional videos for the super 8fg?
- Dual receivers setup?
- Futaba PCM FP-T8SGA-P Radio
- When will the SBS-01V Voltage Sensor come to market?
- Futaba BR-2000 battery checker
- Futaba servos and six volts
- Assigning elevator trim in butterfly 12ZAP
- Flap to Elevator mix T18MZ
- Setting up twin?
- Futaba FP-T8UAP Transmitter
- futaba 18mz transmitter
- S bus setup for a large jet using 12 FG TX
- S-FHSS ranges?
- Futaba new feature requests?
- Futaba 14sg FCC Certification???
- 9Z and 2.4
- Futaba 6008-hs ok to use 7.4 unregulated
- Setting up Switchglo Pro to throttle
- Futaba 9ZAP battery
- I give up...
- Will 12 .mdl program work in the 18mz?
- Futaba skysport 6a HELP
- 12FG trainer port
- 9VAP Rudder Dual Rate Switch Change!
- R2006GS with HV Servos
- Multi-Mode vs 7ch Mode
- Mixing twin elevator servos on T7CAP
- Running a 100cc Yak on a 8J?
- 14SG Telemetry
- T9CAP lcd
- 12ZAP 2 Ail 2 FLP with 7 channel receiver
- Charging 8FG battery
- Futaba T7C
- Futaba T7C Programming Question
- 6 EXP problem
- Set up for FBL Helicopter with CGY 750 and 14Z
- Simple seven
- 12FG Flapperons How To?
- MOVED: help! which radio to buy? 8fg or 8j.
- Futaba 10 CAG
- Question on channel assignments
- Futaba FP-7FGK neutral positions skewed
- 14mz models to 14SG?
- 14SG New model receiver linking
- 12z stick tension
- 18MZ and Cold Weather
- Futaba 8FGS pdf is not searchable
- Futaba T10CAP 2.4 Ghz Antenna repair
- Futaba T10cap Parts
- 14SG 7-Channel System Type
- 14SG and S.BUS
