PDA
View Full Version : Futaba Radios Direct support forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44
  1. Futaba 12FGH vs. Futaba 12Z ?
  2. Futaba R5014 DPS Receiver Voltage
  3. 10c questions
  4. Futaba 12FG FASST - calbration error - on 2 units
  5. Futaba R6014FS 14Ch 2.4GHz
  6. Rudder to Elevator mix
  7. ff7: how 2 display software version number?
  8. Travel the world with a T12FG
  9. Leaving TX on for long time
  10. stick quality question (7C vs 9CAPS)
  11. R6014FS
  12. 14mz EPA question
  13. R608FS vs. R6014FS CCPM Heli Performance Differences?
  14. What recievers work with my new 6EX?
  15. which one is a beter tx
  16. 12Z
  17. TM 14 channel assignments vs G3-5014
  18. RX Max Current Rating
  19. Resetting the 606/607 and 617 recievers
  20. Intermittent behavior 9CAP
  21. Hobbico Pro HD servo wire extension
  22. Futuba R6014FS Reciver questions
  23. Can I use The R6014FS from 12 FGH to my 14MZ?
  24. Are these receivers compatible?
  25. NEW R617FS Receiver Un-Bound Q BAX
  26. 12FGA 2.4
  27. Futaba 9C - first time user in need for help.
  28. 12 G 2.4 firmware
  29. 14MZ Screen Protector??
  30. R6014FS and hitec servos. Does it work?
  31. new 2.4 ghz 7c problem
  32. 7CHP with FP-T4NBF as student not working
  33. Hitec Spectra Module in Futaba 9c Super?
  34. Transfering models from 9C to 10C
  35. Do I need a regulator with a 5 cell Rx pack?
  36. older servos question
  37. 10c latency and battery capacity?
  38. 9 cap with faast module?
  39. 10C at shows?
  40. 6EX checking station at WRAM show?
  41. Servo Voltage?
  42. ultra stick 120
  43. T6EXAP glitch
  44. New 10C Radio?
  45. 6YG...vs....6YF Systems
  46. FASST reaction speeds
  47. 14MZ frequency
  48. 12FG Trainer Cord
  49. T9ZHP Question
  50. 12FG Conditions and trims
  51. 12FG Serial Number
  52. Futaba Flyers Club
  53. 14MZ and dual rudders???
  54. Changing switches on the 12z
  55. 7C FASST Service Check Done No 'I' ?
  56. PCM receivers
  57. 3PJ 0PTION QUESTION
  58. 12Z rubber grip
  59. 8 CH Futaba 2.4 receiver.
  60. futaba 9c telebee gyro setup help
  61. 12Z 2.4 availablity
  62. Change Flapron location
  63. TM-14 /R6014 in a 14mz
  64. Futaba 9c timer
  65. Antenna orientation on the TM14
  66. Sky Sport 6H
  67. Recall of 2.4 radios by German Distributor
  68. 12FG + TM14 with 606 Rx
  69. 2.4 Buddy box
  70. Fine tuning adjustment
  71. 12z/14mz HD gimble springs
  72. 3PKS replacement part number
  73. 8U transmitter and PCM question
  74. Buddy box compatibility
  75. receiver
  76. Triming and dual rates
  77. Futaba 7FG/K FM
  78. 14MZ update troubles
  79. Futaba Power GUID Reset
  80. Futaba 2.4 Ghz 6EX looses link midflight
  81. 12Z antenna loose
  82. Futaba 6EX 2.4
  83. 14MZ pasting photos?
  84. 6exa broken gimbals !!!!
  85. FASST and Brown Outs
  86. When will 12FG Tx Only package come out?
  87. 12FGA and 149 10th channel
  88. Issues with new 12FGA/5114
  89. R606FS
  90. R606FS voltage?
  91. 12FG 2.4Ghz to 35MHz
  92. 12FG 2.4Ghz question
  93. 2PL & R142JE Question
  94. Receiver repair
  95. T8AUPS Transmitter?
  96. Futaba 7cap wall charger - Nimh??
  97. Question about new service advisory.
  98. Programming 9C
  99. 6EX-2.4 GHz with a buddy box
  100. How many servos MUST be plugged into RX
  101. 12FGA for 2.4 GHz and 72 MHz
  102. 6EX FASST + R617FS ??
  103. HOW much time
  104. 12FG with Plastic Handle???
  105. 12FG in 2.4 mode have 12+2 Chnls?
  106. servos sent for mod work
  107. 6exa & buddy box
  108. Futaba 7C 2.4ghz
  109. Futaba 3PK Screen Brightness?
  110. Problem sync 14MZ G3 frequency
  111. TM-7 and R607FS Question
  112. R607FS and R617FS 2.4 RX
  113. 12FG 2.4Ghz question
  114. 12FG 12+2 Is True?
  115. 12FGA unaffected by FASST advisory??
  116. Futaba 8UHFS channel swapping
  117. JR Digital Servo on PCM 1024
  118. hrs mode
  119. 14MZ tech questions
  120. Futaba 9C Throttle Cut For A Twin
  121. 7C flap's, What is the Easiest way to reverse one of the two flap servo's?
  122. Turn 12FG 2.4 in conventional
  123. TM14 w/6014 Rx - pre bound?
  124. How about a 9C 2.4 ?
  125. European And U.S. 2.4 Ghz sets
  126. Servo Monitor on my 14MZ
  127. 3pm range?
  128. Glitching Problem!!
  129. Futuba Transmitter and 27MHhz Reciever
  130. 9c super buddy up question
  131. 9CHPS Not Transmitting.
  132. Failsafe question about TM-8
  133. LIPO for 7C transmitter
  134. Discussion - 6EX TX battery
  135. 12Z's shipment??
  136. 12FG absolute limit, end point limit/travel question
  137. 2.4 FASST parkflyer 6 channel
  138. T12ZH Cursor switch
  139. Battery for 9ZHP WC2
  140. 6EX usb sim cable help for NOOB
  141. 14mz throttle stick movement range
  142. 9CAP Module change
  143. 14mz software update
  144. Sticks Futaba 12Z(14MZ), 12FG
  145. harphunt on "Lack of Communication"
  146. PCM Module for 12FG?
  147. 12fg will not format card
  148. 3PM 2.4 Ghz FASST Please HELP
  149. 7C channel change
  150. Confuse with these batteries (NiMH, NiCD,LiPO)
  151. Futaba FP-T7UHP Super - XCELL 60
  152. TM-14 Module and RX set Factory linking?
  153. TM7- module
  154. Futaba's BIG Glitch & Lack of Communication
  155. ID code
  156. uneven CCPM servo movement
  157. 14MZ 14ch 2.4Ghz RX question
  158. Fast 2.4 system failsafe
  159. 12Z and servo travel limits???
  160. 2.4 check at local hobby shop?
  161. MZ14 Compatability
  162. Krysta/Bax - would this make FASST safer?
  163. Futaba T8SSA-P Question
  164. Is this a design fault?
  165. Switching 12Z from 72 to 50mzh and back??
  166. 9CAPS throttle trim
  167. Futaba 6EX, 7C and TM-7 Serivce Advisory
  168. 3PKS battery question
  169. 9C 2.4 availability?
  170. Futaba 6EX and 7C Service Advisory-UPDATED 04/17/08
  171. Programming question 9CAP
  172. Lack of communication
  173. Native 2.4GHZ 9 channel system
  174. FX-40 antenna
  175. 12FG deltawing setup question
  176. 12Z vs 12FG
  177. LESS LATENCY?
  178. modeltransfer from 14MZ to 12FG ???
  179. t7CAP programing
  180. Performance Claims need to be addressed
  181. wrong transmiter???
  182. Same D/R-Settings in different conditions. How ?
  183. MPDX1 Multi Proportional System & 12FG
  184. Heavy Duty Springs for 12z
  185. TM-14 and Hitec servos
  186. Heavy Duty Springs
  187. 12Z. why is ch. 1 defaulted to Elev?
  188. 2.4 Gig Shootdowns?
  189. 12 FGA Program Glitches
  190. 12FG FASST manual cmplaints
  191. 2.4mhz 9 channel recievers and moduals
  192. G3 Performance with TM-14???? please explain
  193. 12FG Channel Assignments
  194. TM-14 Fit
  195. complaint
  196. 12Z Jan 7 update
  197. 3pm question
  198. I am trying to set up a 12FG and a 14MZ as a teacher and trainer unit.. The only thing I can get to
  199. 7Cap problems
  200. 12ZAP vs 12ZHP
  201. FASST Channel grouping?? 14ch
  202. 2.4 FASST module TM-7
  203. Import Receiver and support
  204. 7C 2.4 mixing
  205. Futaba's big glitch
  206. 12FGA Handle
  207. Futaba/ JR compatability
  208. 12z How to copy Models???
  209. Attack 4 Compatability
  210. Buddy Box peculiarities...
  211. 12FG 2.4GHz Tx Case
  212. Futaba 6EXH Idle-Up not working?
  213. 2.4 rx's
  214. 12FG won't bind to rx
  215. 12Z updating
  216. Futaba 12FGA 2.4GHz: How to setup for Multi Engine?
  217. Futaba battery capacity
  218. T12 FG + TM-14 Compatibilty problem
  219. Latest 14MZ update
  220. Change of address stuff
  221. How do I register on The futaba Flyers Club?
  222. 14Z reciever hook up
  223. Krysta please read and advize
  224. TM-14 ANTENNA
  225. T12FGH 2.4Ghz SD card problem
  226. 12Z Mode 1 / mode 2
  227. 12FG Dual Rate Switches
  228. 6xas
  229. Region Code Change
  230. Swash Ring problem - 12FGH 2.4
  231. 9 C MIXING Elevators ???
  232. Futaba FASST(PK-FSM2.4G) problem
  233. MOVED: Servo Lead position on Servos
  234. Futaba 12FG
  235. 14 MZ dual elevator
  236. 12FGH 2.4 and 617 receiver problem
  237. Futaba T7C 2.4 GHz Issue
  238. Receiver unique id numbers
  239. antannae length
  240. 12FG-12Z
  241. Futaba FASST R607FS RX Question
  242. Note to Krysta
  243. 2.4GHZ UPDATES NOW AVAILABLE
  244. Futaba 12FGH Comments
  245. Max R617FS voltage - strange warning in manual
  246. TM-14 FASST MULT and R608FS
  247. TM-7 2.4Gig Module Area Select
  248. FASST Resolution
  249. Update for 14MZ 2.4 Module
  250. R6014FS RX questions
