- Futaba equivilent to a DX7
- NEED HELP PLEASE
- Which receiver for T9CAP?
- 12Z throttle brake
- 9C nose wheel servo trim on knob
- 12Z and 14MZ switch assignment logic??
- Futaba 9ZAW PCM
- FP-T4NBF Manufacture Date
- Futaba Brushless digitals ?
- 14MZ Mixing Flaps and Elevator problem
- Futaba Flap Knob - Direction?
- tx crystal change
- 2.4 ghz module
- 9C/138DP Huge Problems
- RX 6V battery availability?
- 12Z Condition Delay screen?
- Sailplane mixing on the 6EXA
- 9cs and throttle hold
- trainer cord question
- crystals
- Using crow with Futaba super 7
- Frequency Change on FP-TF-AM/FM transmitter modules.
- Which Servos for 9CASP for US40?
- DG1 and DG2 on R5014DPS
- Flaps on Ultra Stick 40
- Modulation Compatabilty
- Futaba 3FR Question!!
- After crash checkout
- Help! Can't connect 14MZHP w/ R5014DPS
- Throttle Cut and optical cutoff on same switch
- Futaba S9255 on 6V
- Adjusting a Futaba MC111B Speed Controller ???
- dead battery voltage
- 14MZ Screen replacement cost.
- Futaba S3151 servo on 6V??
- 7cap and UltraStick
- 14MZ vs FX40 or Z ???
- Two batteries, one Rx
- MSA-10 Question
- Crow setting on 7CAP
- T9CP Charger
- Touch screen no longer "touching"
- When to recharge my 9C Super. and whats jitter
- Any chance of a new Radio to fill the gap?
- MOVED: 9C - Anyone else seeing these problems?
- Freq of the beeper
- upgrading to 9ch super
- Servo life
- R143F w/esc????
- t9 zhp lcd
- Problem with R138DP on 6v
- FUTABA RCU CHRISTMAS ADS
- Failsafe question
- Replacing S9206 metal gears with nylon?
- FP-T8SGAP modulation selection
- Lubricating antenna?
- Jittery S3101 servo
- R5014DPS Filter
- T8UAF Throttle trim not working?
- 9C Aileron offset
- Help with T9z delta programing
- diff bet 9cap vs 9cap super?
- 6EXA programming for dual aileron servos
- 9cap, long beep before rf light comes on
- Dual rudder in 12MZ
- S3106 Servo Horns
- New 5114 Receiver
- FUTABA 9C switch to mode 2
- Spoilerons on 9C
- Turned off 9caf channel 3 how do I get it back on?
- 7CAP Flap Glitch?
- 9C and R319 dpc mix problems
- 7CAP elevator channel problem
- Futaba 9C Super vr(b) for throttle trim....HOW???
- 129DP rx issue
- Futaba Computer interface
- Idle up throttle/pitch curve
- Buddy Box 9c and 6exa
- futaba and hitec trans and rx
- 6EXAP Transmitter Problem
- crash damage assessment
- 12Z Flyers Form
- Possible to use 3pk's 3rd channel as an on/off switch?
- What is difference between 9C and 9C super
- 2.4mhz for 14mz?????
- 12Z Dual Rates & Flapperons
- Pulse Width 12Z
- S3151 Servo for YAK 54 ARF 67
- 6exas flap dial specs
- Transmitter Selection with mixing
- Manual for the Futaba FP-T7UAF 7 channel radio
- Help setting 9ZA on a Raptor 50!!!
- 12Z Flyers Club
- T7CP setting up heli expo question
- 12MZ Question
- 10 channels out of a 129DP or 149DP
- FPT7UAV vs FPT7UAF Super
- 7 CAP Throttle trim not working
- Changing Bands
- Matching instructor- trainee transmitters
- Any plans to compete with the Hitec Fusion?
- elevon programming 14mz
- Need Help Setting Up Futaba 9CAP for Dual Throttle Servos
- Gyro-trim problem
- How do you get into idle 1 and idle 2 menus on a 14mz
- FUTABA 9C SUPER
- 9CAP module in 9ZAP
- Flapperons
- tx antenna
- servo pots
- 9zap issue
- T12Z TX buying without RX?
- What's a S9155?
- sticky joy stick 12z
- Trim change when changing between conditions
- Futaba R133F 3-Channel FM Micro receiver
- radio repair
- What is a left Hander suppose to do?
- 12 Z Screen concern
- Compac Flash Card for 12Z
- 14 MZ Glitching
- 12Z Conditional Condition
- Super 9C Sounds Volume
- 14MZ and compact card issue
- T7CAP Set Up for Warbird
- never been used 6XAs question #2
- Futaba 8U Super, Question?
- Never been used 6XAs computer radio
- 8UAF Capable of flying CCPM Heli's?
- 7CAP with no display?
- Futaba BR-2000 Battery tester
- yET ANOTHER 12Z PROGRAMMING QUESTION
- 12MZ compatible with the MPDX-1
- Setting up dual-elevator servos 7CAP!
- S9351 Digital Servo vvviiiibbbrrraaatttiiinngg
- T14MZ vs Butterfly
- Programming 9C
- cplr servo choice
- Changing from 72MHz to 35MHz and back
- New improved G3-receiver: Rumor or fact?
- need help!! T7UAF Super setup for blade cp
- 2048 receivers
- R146iP Rx in 6 channel application
- Servo torque
- 9c snap roll not working?
- 12Z Stick springs
- 14MZ forgotten password...
- Problem with S9202 servos
- Dual Elevator Setup? T9CAP
- CAMPAC
- duplicate post - delete please
- Futaba HD switch and charge mount
- Futaba radios???
- HELP - Switch assignment on 8UHPS for TH-Hold
- 9C supper throtle and elevator mix ?
- J connectors
- Minimum Battery Requirements
- Need Help with Switch Selection on 14MZ
- FP-T8UAF & TP-FSM?
- 12MZ question
- Plane Converting from 9Z to 14MZ
- servos ratchet effect
- 12Z in PPM mode question
- SERVO DIFFERENCE
- loss of signal from close range
- Throttle-Cut on a twin
- help with 14MZ spoilerons...
- MOVED: where is futaba factory?
- 149dp + FF9s --> 2 channel gas
- 9C Super - any come with the synthisized mod?
- MOVED: on board engine starter
- what is the expected current drain of the GY401 gyro?
- Frequency Question 12Z
- Integrated CH1->CH8 and CH2->Ch8 mixing problem
- Servo ocsillating at home position
- FF9s trim
- CDR5000 Evolution2
- 7UAFS Flap->Elevator mixing
- PLL warning on 9Z
- servo problems
- RX antenna length
- Super 7 with 401 gyro
- Broken Futaba crystal?
- Futaba FX-40 raido?
- futaba parts.
- twin engine setups
- 9C programming question
- Futaba FF8 LCD Display
- 9 cap the screen dissapear
- Futaba receiver range
- Overcharged Transmitter battery 6 XAS
- futaba 9zhp mixes
- 9CAP mixing
- HELP WITH 14MZ SITE
- What is Futaba's take on the 2.4Ghz XtremeLink module?
- GV-1 sensor prob
- 12Z Range Check Questions
- 9CHPS Modes??
- 14 MZ Reciever can it work w/ base loaded antenne
- Futaba 9CAP with 9 ch RX with 9 Servo set up/programming
- 6EXAP Buddy box problem
- 7CAP changing frequencies
- Futaba information
- Bizzar glitching
- Lost my memory
- 'Jumpy' fast servos
- 7C setup for 6 servos
- S3101 on a DPM Ultimate?
- 14MZ AFR set up.
- How I clean this??
- rate switch replacement
- resolution question
- 9CHP How to use Flap in FLAPERON
- Futaba 7caf question.
- Futaba FP-8UHP/8UHF
- R127DF / R148DP / Medusa 2A BEC / CC25 ESC
- Futaba 3CVS
- Aerofly Professional Deluxe - Tx problem
- Power to the DSC port on a R149P
- 9C super broken display:where can I find it?
- 7TCP trainer switch relocation
- Once again, setting up 4 servo wing.....
- Torque
- 12z can't select EXP1
- R136HP Receiver specs?
- Servo noise question
- Fast Charger Question
- Mixing Rudder to Nose Gear 9C
- 9ZAHWCII elevator gimball problem
- 35Mhz 5014DP Receiver not for electric helicopters?
- 6EXH vs 7C (for heli)
- 12Z model copy question
- What model of radio
- 14 MZ Transmitter Battery
- 14MZ Throttle Trim has stopped working
- trim tabs reversing on Futaba super seven
- Futaba flyers club
- 12Z using 149dp question
- Range test with syth module
- Ultrastick 40 setup problem
- light on tx.
- Receiver min safe working voltage
- Need help! 9CSuper: making flaps work
- Skysport 6 broken trim
- Troubleshooting boat receiver problem
- futaba pcm and hitec fm
- 7CHP/what is this?
- 14 mz battery
- SERVO VOLTAGE
