PDA
View Full Version : Futaba Radios Direct support forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44
  1. 12FG and GY401's on pitch and yaw
  2. Programming 10CHP
  3. MOVED: Why servos dont work y connection..on Futaba 2.4 10c
  4. "7-channel" vs. "multi" modes
  5. Default switch position alarm
  6. Futaba MZ14 Coversion to 2.4
  7. TM 7 and TM 8 Module question
  8. PCLink Software
  9. R617FS not functioning.
  10. programming super 7(uafs) for heli question
  11. Futaba R6008HS and S9157 system
  12. Futaba and Telemetry
  13. New Trasnmitter battery for 7 channel CAp
  14. 8UAP transmittertoggle switches
  15. 10CAG Compatible Receivers
  16. Futaba I need a few info about the BUG
  17. 8FG Flap>Ele Mix
  18. 9C to 10C model memory
  19. T6EXAP Flight Sim cables?
  20. Radio help please
  21. Futaba 10C increase low voltage alarm.
  22. Model Data Converter support for 8FG?
  23. 8FG Trainer
  24. 8FG SD card use
  25. R319 DPS Receiver Issue
  26. futaba 10c module antenna
  27. 9C super
  28. 14MZ Range Check Question
  29. Can the 10CG do 4 aileron servos on a Bipe
  30. Futaba - 10C airbrakes??
  31. 8fg mixing a slider and switch combination
  32. In flight adjustment using VR knobs
  33. Futaba 7CA 3-position switch mode change
  34. FF9s aileron problem?
  35. T8FG warning beeper
  36. Need Help with Flap - Elevator Mixing 12FG
  37. R617FS Overvoltage Issues?
  38. 14mz changing modes
  39. Futaba 8fg mode switching
  40. 14MZ Servo Centering, EPA & Grouping Q's
  41. BLS 352/351 or 551
  42. Futaba S3114 & Servo City
  43. R617FS Works with 10CG?
  44. Question RE Futaba 9157
  45. 9C LCD replacement
  46. 12FG/12Z/14MZ possible software bug
  47. Unregulated Futaba 9252 & 9256 servos?
  48. 8FG flap/elevator mixing question
  49. Twin elevators trimming
  50. 10CHP and 10CHG campac compatability
  51. Futaba T4YBF GWS Slow Stick Setup
  52. S133 servos for ailerons on electric 40 size plane?
  53. 8FG Screw Driver
  54. Futaba 75MHz 2PL FM R153F Receiver Question
  55. futaba 4pk
  56. 10 CA
  57. 10 CA
  58. 14MZ alt function
  59. 3pm fasst broken steering shaft...
  60. Charging 8FG Help
  61. New Gyro
  62. srevo failure question
  63. Futaba 10c. Differences between separate module / integrated module
  64. futaba t8fg
  65. 14MZ: How to properly delete a model / picture
  66. New Futaba Technology????
  67. 6EX aileron mixing
  68. Multiple power sources for R6014HS
  69. Programming 'crow' in 10C transmitter acro mode
  70. Futaba T8FG
  71. Elevator offset trim from throttle stick
  72. Futaba 7CHP aileron issue
  73. Coupling
  74. T10c
  75. Futaba 10CHG Mode1 to mode2 conversion
  76. Replacement 2.4GHz 7C transmitter antenna
  77. Defective receiver?!
  78. 12FG Throttle Curve for Gasoline Engine
  79. Telemetry
  80. Using WTR-7 to connect T6ex and T12Za
  81. 10C Hover Throttle and Hover Pitch
  82. FASST International Compatibility
  83. Broken 14MZ switch harness
  84. Transmitter trim problem
  85. TX stick extensions
  86. BLS153 v BLS 651
  87. R6008HS
  88. 12z 2.4 ghz Sync with R617fs reciever
  89. 4PK & servo response mode
  90. Make 14MZ Throttle Lever Beep Question
  91. 12FG: Does TX battery voltage affect Servo Monitor?
  92. R6014FS Reciever and 14MZ TX
  93. R6106HFC lipo battery
  94. Futaba in bejing
  95. 6EX Throttle Cut Off
  96. Futaba R6108SB 8-Channel 2.4GHz FASST Serial Bus Rx
  97. 12FG Charger - Does it trickel charge
  98. PDF file for 14MZ Software Ver 1.39 update
  99. Futaba 12fg problem and crash
  100. Hook !!
  101. 6ex sticks
  102. FASST Receivers and Brushless Motors
  103. 12Z 2.4 Dual Rates on Bipe
  104. BATTERIES
  105. can you do this
  106. Futaba FP-TP-FM 35MHz Module - Help
  107. dual elevator servos?
  108. 14MZ Four Aileron channel assignment
  109. R6106 Receivers
  110. Futaba 7CAP/CHP Programming
  111. 8FG Throttle Curve (Air)
  112. 12fg transmitter problem
  113. FASST Receiver Mounting
  114. R6004FF not binding to TM-8 in 9C
  115. I have a question on the R6106HFC Receiver
  116. 10C programing help
  117. Question for Bax about 9C super tx problem
  118. 9CAP Voltage Increasing
  119. 8fg flight modes
  120. BLS-154
  121. Setting up Expo
  122. Futaba 7c 2.4g throttle curve help
  123. 8FG - How to setup a Throttle Hold Switch for AirPlane modeL?
  124. 6V Receiver Battery Charger
  125. Elevon Settings 9CHP
  126. Need some help With 8FG and Saiplane programming.
  127. 12fg lock
  128. 14 MZ cold start
  129. R617FS Rx problem with server extensions
  130. Which trainer cord? 12FG to 6XA
  131. twin engine electrics
  132. Help with Futaba FP-T7UAF
  133. data transfer 9C to 10C
  134. mode 1 12z Tx to ? as buddy box
  135. Servos efficiency.
  136. WTR-7 issue
  137. 8U vs 7C help
  138. Older Futaba radio
  139. 14MZ charging
  140. 5v Regulator
  141. A nice gift.
  142. 8FG Different version ???
  143. 14MZ FASST Remap
  144. 14MZ Function Changes
  145. PLease Help!! Need 14MZ Throttle Hold Advice
  146. T7CAP 75Mhz need micro receiver!
  147. twin thottle set up 3pjs, 3pks
  148. 9CAP
  149. 14MZ PMIX
  150. T7C Switch Assignments
  151. 14 MZ battery life
  152. WTR-7 reversing issue
  153. 12Z case
  154. WTR-7 in use
  155. 14MZ & 9 WCII compatibility
  156. 10C 2.4 Programming Help
  157. blank screen
  158. 12Z setup (crow/Aileron to flap/Elevator to flap)
  159. Problem with Easy Link(ID-Set) for T7C - R617FS receiver
  160. 8FG andR6106HFC
  161. battery replacement transmitter
  162. 7C - SubTrim Issue
  163. 6EX 2.4 Servo Hunting
  164. Neck Strap Attachment
  165. Receiver or transmitter issue?
  166. 4.8v with 6014HS
  167. 8FG Range Test
  168. Futaba Transmitter 12FGA 2.4 Ghz
  169. Pitch & Throttle Curve, What Does This Setting Do?
  170. 2.4 Module Initial Use
  171. 8FG longer sticks?
  172. T6EX BATTERY LIFE
  173. Delta Wing conventional Rudder on a 14 MZ
  174. 10C Throttle Delay
  175. Can I change the Futaba 8FGA from Mode 2 to Mode 1?
  176. 10C Ratchet?
  177. Futaba PCM receivers, 138DP, 148DP, 168DP
  178. receiver range
  179. WRT-7 and T8FG compatibilty
  180. 12FGA Files Transfer
  181. 14MZ Trim Step Question
  182. 8FG joystick / trim question
  183. 12FG Software Compatibility
  184. Recall on Early 2.4 Radios
  185. Dual Rx's on 2.4
  186. HFM12-MX+R6014FS ON MX-22
  187. PC Based Model Programming
  188. 2nd battery location?
  189. 6EX 2.4 zero guid question.
  190. Trainer Cord for T8FG (instructor) and T7C 2.4 (student)?
  191. Futaba BEC capable receivers
  192. Curiosity: Why Different Region Codes?
  193. 2.4 receivers antennas
  194. 12fg and proper flap setup
  195. BLS-154
  196. Using a 7C-2.4 TX with a simulator?
  197. crystal for r153f
  198. Minimum operating temperature?
  199. BLS-451 Usage in jets
  200. converting a 9C tx to 2.4
  201. Trainer Box Capability
  202. 12Z and R617FS channel 7 issue
  203. 10CAG back cover
  204. 14mz question regarding sharing sd card/model memory
  205. 10C electric plane on glider program?
  206. 10CAG/10CHG/10CG- 2.4GHz
  207. futaba 3pks 2.4ghz setup, please help!
  208. Shortest Control Stick for T7C ?
  209. running 2 600mah 6v packs?
  210. 10CAG 'HS' Elevator programming
  211. A big thankyou to Futaba Service (Ripmax) U.K.
  212. 12FG Switched flap settings
  213. Need Help! Strange T12FGH problem!
  214. how many rx's
  215. how many rx's
  216. r603ff Problem
  217. is nicd 1400 6v enough??
  218. Help! 14MZ and 4 ailerons!?
  219. Voltage regulator for BLS451...
  220. Futaba/Hobbico LifeSource LiFe Receiver Pack Compatibility?
  221. R6008HS rx
  222. 14 MZ Discontinued??
  223. Futaba Flayers Club. . . The Saga continues
  224. Flying data From Futaba 12Z to 14MZ
  225. Elevon - Ailervator?
  226. 10c 2.4 broken switch
  227. 7c Dual elavator trim
  228. Futaba 8FGA Question?
  229. How to assign ailevator to a switch on 12fg
  230. FUTABA 10CHG
  231. 12FG stick calibration
  232. MOVED: futaba2.4 or keep my DX7 brownout specialty
  233. Flyers Club login issue
  234. 14mz screen acting up
  235. Futaba FG radio & 2.4 ?
  236. 9C TxTM-7 Mod606FS Rec
  237. 12Z neck strap screw has fallen out
  238. 12z Backup data
  239. 14 MZ TX Spare parts
  240. MOVED: micro servo connectors
  241. 14MZ On-Board Battery Life Expectancy?
  242. Futaba Flyers Club
  243. T6XA EXP
  244. Futaba 4pk - throttle glitch
  245. 401 Gyro "Glitch"
  246. metal gear set for futaba 9151 servo
  247. 3-rd flight timer for 12Z
  248. TM-14 module and software update
  249. T6xa battery not holding charge
  250. New 2.4GHz FHSS Futaba 4YF
