- Futaba FC-28
- Maximum receiver voltage 309DPS
- Futaba Contest FP-R7L
- Why do 8UAP Neutrals Change When Switching form Low to High Rate
- Rubber Ducky Antenna?
- 9Z Failsafe
- Change servo wires to aluminum?
- 9C to ham band
- Interference problem
- Futaba 9CAF Question
- Does the 9C have a throttle curve function?
- 9c and the Timer
- Futaba 9C LCD problem
- Where to Buy toggle switch for FP-T7UAF ?
- power diode for 9Z
- 9CAP Tx Modules.
- Fp-r 138dp ?
- 4-TH & T4VF Transmitters
- Programming Futaba Super 7 with H9 Stick
- T6XA-FM and old Futaba TX - trainer
- 138DP vs 148DP
- Welcome Krista
- 3PK TX Batteries
- Futaba FP-T8SGH-P tx Revo. mix pots
- FP-T8SGH-P tx Revo.mix pots
- Quick 9C question..
- 9C Heli and Airplane Differences.
- Service Question
- PPM vs PCM
- Futaba 6XAS Programming
- engine turn off switch
- Service of non-Futaba Receivers
- Embarrising Question
- Sysnthesized Module
- Futaba 9C
- Futaba 9C
- Need Futaba Part No.
- Address for Futaba service?
- My Longitudinal & Latitudinal Range is Different ???
- 3PJS LCD screen
- NiCads for 2 channel
- S9350 Digital Servo for giant scale use?
- Futaba Super 8U question for AnnMarie
- 2 ch radio
- 9C Trim Settings Question
- Is channel 21 especially vulnerable?
- Futaba 3PK
- Futaba high/low band Receivers
- Campac 64 on 9C
- Looking to Upgrade
- Useful Age for Radio Systems/TX
- MSA-10 Grounds
- Heli Conversion
- Servo buzzing
- Help... 6XAS unusual setup ..need advices!!!
- Want information on a FP-T5LK and FP-R4F
- price to tume low band rx to high band?
- Wall battery charger question
- 9303 Servo's Gone?
- 9z shown up by a 6x?
- futaba
- FP-T7UHF Super Question
- Futaba High band Low band
- 9CAP and FP-R148DP compatibility
- What does the FP - R112JE receive?
- futaba 8uafs
- Need servo screws
- 6XA-FM and 7 ch receiver - can I add a channel to radio?
- Futaba 9CAP programming question
- Sloppy 9204 servos
- GYA 350 Power Supply?
- Would FUTABA be interchangable with IC ?
- Futaba SP-130 servo "twitch"
- 9204 servo problems
- 9ZAPs upgrades
- Mode 2 to Mode 1 on Skysport 6
- DSC cord question...
- Futaba 9Z WC2
- 9CHP and idel up 1&2
- Futaba 9ZAP Wc2
- Problem with a older SkySport 6
- throttle cut
- The R123f receiver, What is the big mystery?
- Battery drain
- Can I use 9CAP with no RF module?
- 9 CH. 149DP PCM Receiver
- Range Check
- is customer service important
- Futaba T6XA computer transmitter only
- 9C and $20 gift with Cam Pac is this a Rip Off ???
- Crystal matches????
- making a buddy box
- 9602 Servo
- Newbie Need Help Gathering Parts
- Futaba 9C Manual Now Online!
- 2nd Request - Airbrake to elevator mix question
- Msa-10
- Futaba R114F
- 9 CAP software problem ???
- Kraft servos with new Futaba set?
- R309DPS - Is there an optimum frequency?
- Busted T6XA toggle switch
- Diodes and discharging
- S3003 Servo Ball Bearing Conversion Kit
- Resetting 9CAP Timer
- how to get: Full Span Ailerons with Futaba "Complex" setup
- Looked but couldn't find it...
- crystal type?
- Help with Futaba "complex 7 or 8 servo acrobat" instructions in the FAQ's
- 9cap switch allocation
- change modes on a 7uap.
- 3103/3106 difference
- web address
- Futaba aircraft tranmitter
- Newbie... T2MR Help!!!
- Moving to europe with my 6XAS
- Crow/Full Span ailerons on US 120 & 9Z
- 9 CAP\ PCM or PPM?
- Old PCM Receiver
- Airbrakes mixed w/elevator question
- 9ZWC2 quad flap programming for US
- Help with problem for newbie
- Super 7 questions re: modules and modes
- ATV for ch9 on 9Z WC2
- Is 6 volts okay with digital servos?
- S9302 Servo Oscillates
- Futaba GYA350 Gyro
- Futaba 6xas and realflight
- 9z ATV and Subtrim Interaction???
- Is the 9C supposed to say "mix" when you're using flap to elevator mix?
- Futaba Skysport 4 VF question.
- Brand newbie
- 9CAP Radio
- How old is my FP-T8UAF?
- Newbie to Radios & RC
- Full span ailerons & airbrake w/ 8uafs?
- Loose Leaf 9C manual
- Elevator stick futaba 8u
- Crystals For Futaba 3PJFS Equipment (27 MHz fm).
- Service Not Available
- Is there something wrong with this servo?
- Exponential on 8U
- Futaba 6vh
- Some problem about WCII use
- Futaba 8U program screen
- Ground to Air switch
- 6v
- 9C Manual Update Download
- Futaba Synchronizer
- Replacing the antenna with "Rubber"
- Futaba Modules- 9C & 8UAF
- Futaba--Your final answer?
- Direct Servo Control
- S9304 servos
- 9C throttle curve
- Screw for 9Z
- Switch Reversing???
- 9 z Trim
- Max charge/discharge rate through the 9cap
- 9C Storage Case
- Ailevator and Flaperon question
- 8UAFS airbrake problem
- 9c and dual elevator servos
- What are the correct torque ratings for 9202 and 9304
- MSA-10 10SX Synchronizer
- 9c swash setting on r30
- Futaba Slave Xmitter
- aileron 2 flaps
- 9Z synthesized module issues
- New Shipping Address For Futaba Service
- 8UAS Case
- am cross
- Tx Rx matching
- Why not?
- compac
- Gv-1 ??
- Super 8 Question
- t9chp,holy confusion....
- S9151 Digital Servo ????
- Hey Bax, Please read from post #6 on....
- Range Check Problems
- 9c Premix - Can't Figure Out Why
- 9402 Servo Jitter
- Hrs?
- 9C Transmitter Module
- 9206 servos still around?
- Trim Memory T6XAS
- No RC dealers in India !
- Futaba Ball Bearing Servos
- throttle trim not working
- 9C programming questions
- futaba fp-t7fgh
- 4VF differences
- 6X with dual elevator
- Servo conversion question...
- 8UA Case
- Auto responder
- 9C TX & R138DP with dual elevator servos
- Fraperons & aileron diff. in the new 9C
- Trim Change on D/R switch
- Feature request
- heavy duty springs for 9C
- 3Pk - Throttle Neutral 5:5 7:3 setting - where did it go???
- broken switches-- T8UAPS
- What could it be?
- Campac interchangability??
- 9CAP Programming
- AMC on vacation! :-)
- 8U Super Case
- How often to service radio?
- tention on throttle
- Service Turn Around Time ???
- Question for A.M....
- Scary radio glitch!
- 9VAP Tx
- Help with 9ZAP WCII
- TX 6XA Memory Upgrade Available?
- Rx and Tx Compatibility
- Futaba 9cap
- Endpoint or Subtrim on 9C
- S9202 Where's the Beef?
- 9zap wc2 question
- Futaba Receiver Question
- Futaba 9150 Servos
- Questions about 3PK
- Question for A.M.
- New 9CA Radio
- Beeper Volume on 9ZAx/WCxx
- R309DPS vs. R149DP
- 9202 Torque
- Throttle Stick Ratchet on 9ZA Can I change it?
- FF9CHP ultra stick 60 setup?
- Futaba 9Z WC2 Transmitter with JR Matchbox
- Futaba 9202 Servos
- is there a manual available...?
- Dual Rate Switch Problem
- Help with 9c programming please
- Need Help Programming a Futaba 6XAs for a Zagi with a Cirrus 4 channel Rx
- 9chp and 9cap Differences
- batteries
- Question on Reciever
- Module Switch
- Flap on switch
- Eclipse 7 with Futaba GY401/9253
- AM recievers
- 9C 3-Position Flap Switch
- service
- What's the difference?
- 4 or 6 channel
