- intermittent problem
- Future for fun factor
- HELP
- Roto start for Genesis
- How does 2 speed work
- ct4 engine ???????
- leaking at crankcase,front bearing
- Which is the correct belt for CT4-s
- Tmaxx wheels for my cen have arrived
- Main Drive Belt Problems
- Generation???
- Cen MT2- NT-16 to 18 conversion results
- More ATX Problems
- MT2 accelerates out of control!
- Engine replacement?
- starter probs-funfactor 2 buggy only runs with the glow stick in
- venom speed meter on ct4s
- Genesis running at high temp
- CT4-S braking.
- ct4s bad steering
- Shock replacement
- weak mt2 steering
- cen ct4-s - How should the engine sound like?
- cen funfactor problems
- New to Nitro, Mt2 with gear problems
- starting problems
- is this a fault
- is this a fault
- CEN Hi-Torque servo
- CEN MT Fun Factor 2 - Acceleration Problem
- ATX Throttle & Steering linkage
- Diff joint Cup for FUn factor
- Parts for Fun Factor in Nebraska
- When is the 3-spd transmission for the CT4 coming?
- Clutch setup questions!?
- Weight of ur funfactor?
- Better design for block movement and gear alignment GS087-90
- Come on Cen Racing lets have a reply!
- Reverse on a TR4
- CEN CT4S motor.....
- Used Cen roller worth?
- gs091
- Genesis steering capabilities (reduce turning diameter)
- FAO: CEN RACING. Centre diff for FunFactor?
- Spur gears
- 12mm hex to 17mm hex?
- better engine for cen ct4-s
- Axle Thread size on the MT2??
- Skid Plate for genesis
- Books
- Correct meshing distance(play) for gears
- Genesis glow plug selection
- Spur gears and pulleys.....
- reversing a GENESIS
- nt-16 carb loose again
- Shattered GS087, GS088, GS089. Guarantee?
- why not advertise more
- Alloy Genny Diff housing?
- cen ct4 parts enquiry!
- What make the Genesis shift
- Hit brakes and truch dies... genesis
- atx fun factor stuck in right hand doughnut
- Radio Upgrade
- Modified GS094 Brake Drive Cup?
- ATX Fuel Tank Problem
- Mounting Posts for Parma "Grave Digger" shell
- Cen Genesis So/So Dissapointment
- Winter fuel settings for genesis
- Best fuel mixture for genesis
- cen ct4 with no bottom end! help
- Cen MT2 to stadium truck?
- servo upgrade
- servo upgrade
- T MAX MANUAL
- OS or Epic .18 Engine in MT2?
- CT4-S Setup
- FAO CEN: Gear ratios
- Bearing Problem
- people of cen help please?
- lean idle
- Cen Genesis Fuel Issues
- Had it with the CEN ATX, waste of time!!
- Yet more problems with Genesis 46
- tuning and running
- body scuffs top of trucks
- CEN Funfactor ATX
- CT4S NX-15 Engine Concerns
- CEN ATX Shocks
- NT-16 Engine
- New Genesis Wont start
- New Genesis problems
- NX-76 pre-set from factory
- New Genesis will not idle, it just goes.
- Looking for aftermarket wheel Knuckles for genesis
- SOMETHIN' IS F'D!! WHAT IS IT???
- my cen ct4s wont shift into second??????
- Mt2 diff fluid
- UK genesis recall
- Is this fuel OK for my ATX?
- cen mt2 fuel
- 3rd batch
- throttle problem....maybe you know....
- Genesis pull starters
- Pipe upgrade
- Engine factory setings
- cen mt2 prob.s
- FAO CEN: Matrix 1/8 buggy?
- What are the names of these parts?
- CT4S Pull Start + Glow plug question
- CT4S Suspension
- Metal spur in fun-factor
- Pinion gear 21T ran of clutchbell
- Where are CEN???
- Which shock Oil in the Genesis?
- GEN output shafts....
- NX-15 Factory Needle Settings.
- FAO Cen racing - JT racing chassis
- ff part #
- GENESIS break adjustments?
- usinng ffs005/006
- Super Size Bodies on Funfactor?
- rebuilding cen alloy shocks
- GEnesis 3rd gear
- Who's selling the 2nd Gen. Genesis and has it in stock?
- 2nd gear keep stripping
- upgraded funfactor
- My conclusion of the GEN, aint worth reading
- shocks for mt2
- CT4S Brake Upgrade
- Whats up????
- CEN Genesis Care Packages
- difference between CEN MT and MT2?
- testing delete!
- Interference at high speeds
- Taking Pull-Start out
- CT4-S Engine Questions
- Fun Factor, whats the difference?
- CEN MT Question
- 1-888-cen-9886
- CT4S help please
- How fast is the Genesis??
- CEN question
- Genesis Fix Announced
- genesis announcement far from good
- Genesis – 3rd gear engagement settings
- CT4-S Upgrades
- Cen CT4 3 Speed
- PARTS
- Genesis Breakin
- Welcome CEN Racing!
- CEN Support Forum Guidelines
