View Full Version : CEN Racing
Pages :
1
2
3
4
5]
6
7
8
9
10
11
12
- STILL HAVING TROUBLE STARTING
- gst glow plug
- bust a nut....
- Genesis Question
- what's better CEN GST 7.7 or Nemesis 7.7
- nemesis shock oil weight
- one way bearing
- roto starter for gst 7.7
- Is the TR. 28 one way bearing faulty?
- roto starter
- face book cen group
- CEN GST 7.7 Wheelie bar?
- charging glow plug
- Matrix tr arena owb
- GST 7.7 bashing VIDEO! Check it out
- Varius question about Nemesis
- GST 3 speed to 2 speed keep reverse
- Another broken shift lever
- Broke another rear diff bevel gear shaft
- Other CEN GST tires/rims??
- GST7.7 need help making a spare parts list
- gst 7.7 why is it so hard to start
- looking to buy a new car
- GST 29cc gas powered conversion
- installing nemesis diffs in a GST
- GST 2-3rd gear shift fix
- Has cen started shipping the arena with the NX-26???
- GST 7.7 pipe mod
- GST 7.7 engine stops !!!!!!
- broken shift lever for gst
- GST revs but BARELY moves? HELP!
- Broken Pull Starter
- Manifold FF Rally
- Genesis turns hard left with more then a little throttle
- Does The CEN Magnum NX go backwards?
- SO..My GST is alive again!
- rapid fire in cen pajero
- cen nemesis shocks
- ST2 spur gear pitch
- Cheap place that sells the ARR Matrix?
- CEN fuel tank help
- ct5 body question
- replacement antenna
- CEN NT 16 Pajero
- Engine assembly questions.
- Matrix / Genesis tyres
- ultimatehobbies question
- Best receiver pack for the GST 7.7
- 2 speed
- MT2 Grub screw
- AHHHH I completely submerged my GST in WATER :( HELP ME!
- CEN Pajero NT 16 help
- what do you guys recommend
- Nem,Gen,GST Hardened Steel Pinion Here??
- pull start for mt2
- mt2 mudding
- will this work?
- i need help
- Stock Mini Madness ESC motor limit
- Anyone ever broke their pull starter? I did and can't seem to find the way to fix it?
- roto start question
- Heavy duty CVS?
- GST 7.7 clutchbell thread type and pinions
- GST 7.7 vs. FG MT (Comparison pictures)
- diff oil weight for matrix truggy & locking center diff?
- street tires
- GST SETTINGS
- top end needle on matrix truggy @ 1 1/4 turns ok?
- make a ct4s race worthy????
- cleaning out the diff grease on cen gst???
- Gear mesh on Nemesis
- CEN Racing Results
- gst still having issues!!!
- The true Cen bashing video (it works now)
- Magnum, MT Spec, Talon, & Fun Factor owners
- glow plugs
- My GST Just wouldn't go!
- Best Carb tunning for GST
- Didn't hear any gear change on my GST
- good baseline tune after run-in for matrix tr arena?
- adding diff oil to matrix arena tr improves power?
- CEN CT5 Parts Question ..
- engine run-in fuel settings for matrix tr arena?
- my nemesis weight
- 1st race this weekend
- Are The CEN Red Clutch Shoes Any Good???
- gst 7.7 tuning
- Pro's and Con's of locking the front Differential?
- Thanks CEN, my truck is an animal
- GST 7.7 Mods?
- 7.7
- Quick Question
- Camber setting
- Cen Spurs?
- Skyion Radio Battery Charger?
- GST Working Fine, Now it wont go anywhere
- Airtronics
- O.S. .18 CV-RX mounting
- body trimming
- GST 7.7 Quick question
- Concrete wall 1 GST 0
- Cross and What
- Servos.......
- CEN bouble post sorry
- CEN CUSTERMER SERVICE
- new enegine/ ideas or opinions welcome!!
- Hitec 5955 and 5995 differences
- not staying running
- Wierd Carb Action
- One Way Bearing Replacement On The Cheap!!!
- cool video
- Matrix Arena TR Air Filter, what are people using
- Need help with my CT-4S
- Matrix Arena RTR Carb Settings.
- Matrix TR Arena Shock Spring's
- Fuel & Glow Plugs for Matrix TR?
- Anyone ported and flowed an NX76 engine?
- Side, Rear, CV , CV-RX?
- Matrix TR Arena - 3 New Body Colors!
- MT-spec 3.0 or Premier 4 or Magnum NX?
- hi all... would like some info please..
- CEN Matrix Arena TR hard to start when hot!
- Where to get parts for .12 onrd nitro 4wd older car?
- Crap Engine?
- CEN CT5 question
- Is my engine junk???
- Turnbuckles hitting shocks on Nemesis
- Magnum NX will not idle (Revs like crazy)
- front dogbones keep poping out
- .12 tuning help, recommended needle settings.
- Matrix Arena Truggy Body?
- help with shocks
- Cen RC Car Swap Question.
- Not Moving?
- help
- front wheels
- gearing with brushless
- How fast does CustomRCCars usually ship
- what 0/0 nitro 20 0/0 30 0/0
- Matrix Arena Pro Questions
- Ignore
- hardened steel gears Done
- Help with Genesis shifting (into neutral?)
- best way to break in rtr matrix tr engine
- Why You Choose a GST 7.7
- Any upgrades for GST's telescopic shaft?
- Centre Diff
- Cen Matrix
- Upgrade Magnum Clutch shoes?
- The Free Mini Madness
- matrix and matrix tr hop ups factory???
- CT5 steering servo
- Need to know how to put diff oil in GST
- Check List for GST 7.7
- steering servo
- break in issues
- CEN's forum/customer service
- Genesis servos
- What is this stuff that came with my car? (plus pics of my new GST)
- matrix tr arena roto tech starter
- Cen's website down?
- My fingers are blistered lol
- Genesis/Nemesis GST Clutchbell Tool??
- brek in not going so well
- Removing Nemesis Diffs...
- PICTURES of my GST 7.7 W/F-650 body!
- CT5
- Mini Madness Wheelie bar?
- CEN CT5 or Traxxas 4-tec 3.3
- clutch shoes
- BREAK IN QUESTION
- How to remove flywheel from GST
- Breaks Not Stopping
- Where to find parts
- tr problems
- motor swap for genesis
- anybody have this problem-mt 3.0
- Nemesis tires Gst rims
- cen ct-5 wont steer
- New Hardened Steel Clutch Bell Pinion Gears - CEN Gen, Nem, GST
- matrix arena diff. problems.
- 1st ANNUAL CEN NITRO INVASION MAY 25-27
- Genesis alloy Clutch Engagment?
- Cen Genesis LE just bought!
- PIXXXXXXX
- Question about the Matrix TR Arena
- Venom 6cell batt pack
- Genesis/Nemesis & GST blocks all the same?
- .15 Engine choking? need help
- skyion tx battery pack
- The cure for Genesis center link slop!!!
- Slow Servo Response GST
- My Wifes Got The Bug!!!!
- O.S. .18 CV-RX w/11J Rotary Carb vs. Nx18
- NEMESIS OUTDRIVES ISSUE
- Matrix is finally running
- genesis wheel foams
- LSM fighting with HSM
- Cen Pajero....
- Matrix reciever battery
- Schumacher or CEN or Mugen?!?!?!
- need new motor mount for genesis
- CEN Matrix TR video question
- Fun Factor Racing
- Matrix TR RTR Questions
- GST & Roto start
- Clutch Shoes, What's the proper tension?
- If my engine is (looser than a sidewalk crawler)
- gst 2nd gears steers left
- Difference between CT4-S and CT-5?
- NX-15 head stripped
- More Matrix problems
- GST 7.7 Bumpy Ride
- Priming problems Genesis
- Gensis suspension adjustments?
- GST 7.7 exhaust
- MT2 Problem
- GST 7.7
- GST 7.7 Cold Engine
- GST 7.7 Diff grease & Shock oil
- GST 7.7 Question
- Tuning a CT5
- NX-15 Exhaust leak
- gst 7.7 center diff lock
- Wheel Shaft wobble CT5
- GST 7.7 Reliability
- Genesis front/rear bulkhead assembles.
- Cen Matrix TR Arena
- cen ct4s trouble again...
- free mini madness
- gst 7.7 clutch bell
- Cen GST 7.7 gear adjustment help
- NT 16
- Sending my Matrix engine to Cen
- Need help with starter box - engine - CEN MATRIX
- Manifold and Seal problem
- Metal Spur Gears Eat Clutch Bell Gears
- carb needles
- I love my new Matrix!
- MY latest mod for nemesis
- CEN RACING SUPPORT click here
- Cold Starting My Cen MT2, Help
- FF Differential Parts
- GST 7.7 Stuttering
- Premier 4
- How do I post a pic?
- Help with Matrix RTR
- Clutch bell and pinion gears
- Cen GST 7.7 3rd gear
- Genesis GST 7.7 (My first day at a track)
