- connector for the DX7 battery is called?
- Max Range of Radio
- I TX for all.
- Futaba 7C FASST or JR DX7 Spektrum
- JR 12X Unsigned Driver on PC Data Install
- offer FD receiver
- Futaba 2.4G receiver pricing
- JR R790UL receiver
- JR XP6102 Fuse
- AS600 Spectrem reciever
- JR X9303 Trim Following
- Airtronics servo
- Spectrum module spares........
- Maybe One Reason For 2.4 ghz Failures
- JR 9303 72 Mhz receiver compatability
- Should I get a FASST 7 chan or 6 chan for my plane?
- WHO SELLS LOST AIRPLANE ALARMS???
- Ram sound unit
- 12 channel JR Module?????
- help wiht jr 12x
- 10C FASST transmitter receiver modules
- JR DSX9 side sliders
- Help Diagnose Why Lost Plane, H9 P-47 150
- Spektrum Pricing
- Faulty equipment not my fault.
- 2.4 ghz Jammers
- 7CAF and T6EXAP crystals?
- TX & Rx Alignment Fp-7Fg
- XS3 receiver question??
- Connecting the servos via long cables OK ?
- New radio investment
- Spektrum
- Duralite Li-Ion (11.1 V) OK for DX7 ?
- graupner mc 18
- darn, futaba 6 channel 2.4ghz parkflyer only fits mini plugs
- Alpex Hobby FM
- Futaba 10c
- JR R921 Receiver Voltage
- Losi with Spektrum DSM technology vs. Spektrum DSM
- 9303 Throttle Trim & 150 ATV
- WHAT THE #$! fried my berg4L rx
- JR 2.4 upgrade
- JR 12x 2.4 gHz: Remove Xmtr back?
- JR 10x New Datatransfer Software
- Transmitter error light for Losi Sport from Mini Baja..
- Light DIgital servos for Gee BEE
- FASST antennae placement, housing, tubing, orientation etc etc???
- channel Expanders, Syncronizers, etc
- How do you program dual rate on 12FG? and what is GROUP vs SINGLE?
- Kraft Radio
- Need help with setting throttle trims
- Why not a 12 FG, 12Z and 10C website?
- this receiver? the instructions say that it should work with either brand, but I hjr rs600 to futaba
- STANDARD SERVO FOR MECHANICAL RETRACT-GOOD OR BAD IDEA????????
- Does 2.4 have shorter range than traditional 72mhz?
- Programming
- Futaba charger to charge JR radio?
- Spektrum 6x 2.4 ....what receivers?
- JR buddy box cut out and I lost my model!!!
- AR9100 Spektrum powering with Lipolies ?
- 5 amp Fuse Servo Leads to Protect Against Dead Short Melt-downs
- 12x 10x questions
- Spektrum remote led?
- Binding without a place to plug binder
- JR 10X with LiPo pack
- Futaba 8U throttle not linier
- fly sky Tx and Rx setup???
- Reassign 2nd Aileron Channel on 9ZAP?
- R156F
- Looped back antenna.
- JR 9303 2.4 Mixing
- Radio selection help please
- receiver
- will this rx work with my tx?
- JR 8611's and 8711's gittering
- Airtronics MX-3FHSS/Hitec MG65
- Help me change my mind
- Price of DX6 when it was first released
- dx7 or x2720 stick mode
- Are all servos interchangeable
- DX6I programming issue
- Need Help finding Part for JR 10x
- Extra Reciever.
- Spektrum DX5E, DX6i or DX7 for surface use?
- INFO NEEDED GOOD SERVOS
- Any known problems using Hitec Servos with Futaba 6014 Rx?
- Hitec crystal in Futaba 127 receiver
- MKII Expanded Scale Voltmeter
- Programming 2Ail 2Flap with 7ch FASST RX
- Futaba 9c- rotating the sticks
- Help with X9303, aileron set-up.
- Can I mod a tx to transmit music?
- Airtronics RD-6000 compatabilities
- Voltwatch or Voltmeter
- Sun ip receiver dual conversion or single
- Aftermarket 72 mhz synthesized futaba 9z TX modules ?
- Spektrum Bind Plug Question
- Spektrum and Deans whip
- New JR 770 gyro not compatible with Futaba?
- Spektrum 6 DXi not binding
- Help with JR 12X
- newbie questions about servos and transmitters
- Spektrum systems "jerks" when turned on
- X9303 setup for multiple servos
- JR / Spektrum rx ext's w/ disconnects
- JR DS 821 vs Hitec HS-5475 which one
- Tired of waiting on Hitec/Multiplex for 2.4GHz Module
- JR 12X in Mode 3
- Whats The Deal With Nylon Gear Servos?
- RC EBay .surprise
- AR6200 and 27% extra
- HXT hextronic servo????
- reversed radio controls
- range of 27 mhz Am radio
- AR 9100 power and swithching
- What is prefered volts for FASST RX?
- Replacement Reciever
- Question bout Flea Market FM Remote
- Futaba FP-R137GP 7Ch RX Antenna Legnth
- Jeti 2.4G System
- Mounting JR 921 rcvr on top of fuel tank
- Futaba 6014 heat failure (crash)
- Installing a Servo - Modifying the Horn? (Newbie)
- Spektrum modules
- Spektrum ar9000 vs. JR R921?
- Futaba 10CHP - Mode 1 & Mode 2-Differences, Switches, Mixes
- JR SX600 - Need help ASAP!
- Im looking for a DX7 with microlite servos and rcvr
- 14 mz setup smoke/ choke
- specktrum -walkera set-up
- futaba 7c ...can not get my throttle to work on my parkzone trojan
- My micro servo died yesterday, maybe the BEC was the killer?
- partial rudder to throttle mix
- Advise on Futaba 10C 2.4GHz Air needed!!!
- Spektrum Module Blows 9303 TX Fuse
- digital servos , 7 CAP
- HS-65 MG screw
- Futaba 12Z/14Z
- mx3 70/30 throtle question
- JR R921 RX Battery
- How much is the R5014 Fasst RX going for now in ebay or classified?
- 10c and HS-5645
- Hitec analogue and digital servo ok with FASST 6/7/8ch RX?
- Heads-up warning: Corona 2.4GHz
- Question about speed controllers?
- Futaba 12z charge jack pinout ?
- DX6i / AR6200 / 2servos - Some questions - Need help
- Wow, Why aren't all transmitters now like this?
- Futaba S3103 and S3108 Replacement Servos
- Is this reciever compatable with analog servos?
- WHICH ONE 10C or 12FG ??
- DX3R reciver options
- How many of you find this funny?
- Bind AR6100e to DX3R?
- Question about picking the right engine, transmitter & Servos.
- JR6103 Tx and dual elevators
- Duck on a DX7
- Dual elev and ails plus flaps - DX7
- Dual elevator set up
- Servos
- swashplate movement
- Training Cord for Futaba 6EX
- Switch enabled by radio/receiver?
- Servo Reverser Harness Initial movement?
- JR X9303 Auto Land Mix Problem
- Futaba 9CH radio any salvage parts??
- JR X9303 trim lever throw values
- Fytaba rx # R136HP with a 9C Tx?
- Jr MatchBox
- parkzone radio gear
- How do you set up flaperons an the JR X9303?
- Lipo in Tranmitter and Reciever
- Programming dual elevator servos on JR XP6102
- Spectrum dx6i
- Need JR XR-3 R133 3CH receiver
- DX-7 Tx very warm ?
- New flyer info for 2.4 DSM2 Spektrum
- DX7 dual elevator and flaperons - Elevator to flaps mix?
- spectrum DX6I
- Servo Accessories
- Thinking of getting new controllers
- JR X9303 throttle servo stops working when switched to normal mode...
- JR 2.4 ghz Module
- ACT S3D is DOUBLE 2.4 ghz system
- fm or 2.4 GHz
- MOVED: fm or 2.4 GHz
- JR Sport SX600 HELP!!!!!
- can this happen
- 645mg servos not centering well.
- Warning!! Do Not Buy Futaba 3114's
- Cellshield LVC Problem
- Kid size controls
- HS 5985 MG
- Silicone Adhesives
- Futaba 9CHP Super 9C Synthesized Radio
- Servo failure help please
- 4 channel TX came with a 6 channel RX: can I use 5 and 6?
- Use of Spektrum Mz module in Fut 12FG?
- GY 501 help!
- Servo reversing on Multiplex Evo 9
- Spektrum DSM2 module
- Got my 6ex back from Futaba today
- Spektrum DX6i binding problem
- JR 7202 Timer?
- Stickly Gimbal
- peace help me with my transmitter
- Suitability of X-Bee Modules for R/C
- Spektrum DSP75 Servo Chatter
- Two Different Servo's on One Y-harness?
- Hitec Neutron 6s
- The radio used the most at large events?
- FP5UAF-setup for flaps
- Power HD 2550A Servos
- Need to replace JR r700 rx antenna
- Futaba 6EXA Elevator Gimbal Spring Failure, Almost A Disaster
- Antenna routing tips
- 1/4 scale servo size
- Transmitter / Receiver Recommendations?
- Spektrum DX7 versions
- best dsm systems?
- JR R921 Receiver Current Capability? Is a Jumper Needed?
- Odd Futaba 2.4 7c issue
- Computer Radio GENERAL Setup Tips Wanted
- 10c throttle trim button
- Noob Questions
- Spektrum DX6i Problem?
- Dual Elevator
- Why so few 12FG posts?
- Spektrum probs with Zenoah G26ei
- Kraft KPT-7CS Mk IV Manual
- Spectrum 2.4 gig worries
- super vee 27 receiver
- wrong forum
- 3pm safe receiver voltage
- dx 3.0 dsm
- Spektrum DSM2 Airmod for Futaba
- Jittery steering servo on car
- AR9100 & Different Remote Receivers
- DX6i & DX5e
- Speed controller differences, car & boat?
- battery for a futaba 12fg
- crimpper
- Futaba 3152&168DF Rx=Nervous servos
- JR DS890G Gyro Servo
- WARNING-X9303 CHAFED AILERON GIMBAL WIRING
- JR 12X MV initial evaluation
- spektrum dx2.0, aux sr3000??
- surface vs air radios
- 4+ channel surface radios and a servo question
