View Full Version : Batteries & Chargers
- any difference in TX packs and flight packs ?
- Battery Voltage Differences
- Sanyo 2100mah AA NI-MH Batteries???
- What Battery charger & Cycler???
- lightest battery pack
- 3000 ni mh
- AMA Mag Battery Artical
- Where can I get a power supply repaired?
- ?? On Power Supply
- Charger and cycler
- battery pack problem, need help!!!
- Changing battery pack configuration
- Futaba 9c and supernova
- I am no "whiz kid" at electronics!! Please help!
- triton charger question
- need high output lead acid or gel cell
- battery/charger plugs
- hitec transmitter battery pack
- Best DC charger for RC Car + Accessories
- Car Chargers
- need help with Triton charger
- Sanyo N600SC batteries
- Charge Rate Limitations??
- 12v Starter Battery
- initial charge on 6v nicad???
- Red's Battery Tester down & dirty, take 2
- Question about charging tx battery pack while in tx.
- how to use super nova on the AC (240v) ???
- Power Panels
- How long charge 7 amp Gell Cell?
- Starter Battery
- Charging 300 mah 7 cell 8.4 volt
- Supernova 3000
- charger for fieldbox battery?
- Ground wire turning black
- I need a new charger!
- Why do RC batteries require so much care?
- question on charging multiplex radio
- Charging Rate
- Is this battery still OK
- Glow Plug Charactistics
- Will this work ?
- batteries
- What does "C/10" mean?
- Triton charger
- Cheap easy twist on Reds Battery Tester
- Charge Rate for Small NiMH (300mA)?
- 18650 Cells
- Battery go boom
- How many amps = mAh ?
- Multi charger/cycler
- Where to buy battery packs?
- NiCad NiMh charger
- Charging For Dummies
- PC Power supply ATX shutdown on load applied
- Duralite plus tx batteries
- Kokam and triton behaviour
- Ace ChargeMaster
- New Charger choice
- Triton and Home Charging
- what to do with 5 x 3.6v (3cell) 300mAh
- Triton Charger Temp. Display
- Hobbico Accu Cycle
- home built quick field charger??
- voltage vs mah?
- battery packs
- NimH & Hobbico MKII Problem, HELP
- leakage on nimh on superbrain
- Triton, how does it know # of cells!?
- Charging Reassurance Needed
- Best Field/Home Charger for Nicad and NiMH batteries?
- Another Triton/Power Supply Question
- futaba wall charger
- Hobbico 905 Ac/dc Multi Charger For Sale
- Battery connector
- Fried battery...
- Does anyone have a users manual for a Model Craft MFG. Pro-Tech Autopeak AC/DC 707
- soldering on leads
- Field charging with superbrain
- Triton and NiMH question
- 4n600 upgrade
- left my transmiter on all day, are batteries damaged?
- 4.8 in avistar need some input!!
- 6V vs 4.8V on your servos and receivers
- SR Batteries worth more than 2X Radical R/C?
- Powerflite Packs
- NiMh charge voltage question
- New Battery Pack
- How to wrap a home made battery pack?
- How to measure capacity reliably?
- Disposing of damaged or depleted RC packs
- Ammeter reading vs Battery requirements
- receiver batteries
- how long should the radio receiver battery last on full charge
- nimh charging ?
- new to rc (nicad question)
- Triton - Reliability ?
- Is this right ?
- 45mA charger & new 1100ma Rx nicad?
- In-home power supply for Triton
- NiMh initial charge?
- Nimh Probs
- MkII max amps
- Help needed in charging/discharging
- what i need to know to get started?
- Li-poly questions...
- Are these Toast ??
- What is delta peak
- can a charger fry nicads
- cycling nicads
- Source for a TAM connector to use with Superbrain
- new NiCads
- Charging the NiMH with the Trinity charger.
- Ni-MH problems?
- charge rate for two cell 300mah battery?
- Lithium Poly initial charge
- build a charger for mini3
- Triton charger memory question
- What charger for Li Cell phone Cells?
- Wall wart charge indicator
- Xmtr battery voltage
- Different capacity Wall Wart chargers?
- Quick Question on Charging
- Where can I find a 8.4V 1000 mah battery? I cannot find anywhere!
- my battery only lasts three flights
- Sirius charger on JR transmitter
- RED- You are the Triton man! Help!
- Good Source for Batteries?????
- Rx Battery Replacement
- simultaneous charging
- Best Voltmeter?
- non chargeable battery question
- Einstein XL hits the wall...
- Storage
- Sanyo's with REVERSE POLARITY!!??
- Sirius Pro Charger
- charging a lithium-ion battery
- I need help to lower discharge rate Duratrax Digital Charger
- Triton cylcing "feature"
- been reading - still don't know which charger to buy
- Lithium battery pack process!
- Where to get cheap Zagi Batteries?
- Source for Sanyo 3300 nimh cells?
- Poll - Cycler/Chargers
- discharging single batteries
- What are the chances....
- Triton Buttons
- Second battery for retracts
- Alkaline batteries for GWS receiver/servos?
- AC to DC power supply from an energizer NImH charger
- Dual Charger/Cycler
- Best/good lithium Poly charger
- Parallel Rx batteries?
- want to get a 969 superbrain pro
- Charging large NiMH packs with 50mah charger
- 220 Vac???
- Battery Discharger Plans
- Battery for Cirrus radio
- Futaba Tx Battery extension -
- Einstein XL
- Red - Peak Sensitivity/Threshold ???
- Triton input error message
- Schulze & Orbit chargers
- Battery Cycling -Flase discharge reading
- found this
- Heat shrink battery covering?
- 2/6 amp 12 vt car charger
- Transmitter battery
- Good lithium bats/where to buy them?
- Help with switching Battery from Fut to JR
- Futabe Attack Charge/Discharge
- What happens if battery gets discharged below 5.6?
- plugged bat into receiver wrong
- Alpha 4 problems?
- Alpha 4 Payment
- Dual batteries for redundancy
- What is wrong with my battery?
- PF Transmitter pack
- Making charge leads....
- Hitec 5945 digital servo
- Triton: green dot/yellow dot!!!
- Smoke from Super Brain 959
- Double lead on receiver battery
- Super Nova in Pb to charge Li-Poly - How does the 250s work in Pb Mode?
- SuperBrain 969 Pro---Help!!
- VoltWatch/Hobbico MK III?? Who to trust
- ION Batt/ What is the danger in them?
- Please help! - Question on NiMh Batteries
- I can't get my Lipo 402 charger to charge my Kokam 1200's!? Please help!!
- Problems! Help me Red!
- Info
- NiMH Failure ?
- NiMh bettery pack testing?
- Kokam 1200
- Triton charger advise!!!
- Do the CellTek Chargers Actually work?
- 4.8 VS 6.0 volt
- battery tech. specs.
- Glow starter battery capacity?
- Best price on a Triton Charger?
- Schulze leads
- Battery Pack Building Guide/FAQ/Tutorial
- Please help me find a manufacturer that can buy this battery from!
- Test LiPoly
- gas electric hybird
- Charger or Converter for LI Cells
- 100 mah wallwart, 700 mah battery, first charge, how long?
- Standard Charger and Charge Time.....
- Supernova 250s/Triton charger/discharger advise!!!
- 5 cell 720 sanyo rx pack
- Alpha 4 question
- Building my own nicad chargers.
- Reverse polarity
- Wall warts and Ni-mh
- Charging Nicad Battery
- Roasted Battery Usefull?
- Digipeak Charger
- wingo battery
- Comparing battery packs
- Conditioning Nimh ?????????
- field battery charge
- TX/RX cycler
- Hitec Tx Battery connector - where?
- Tekin Bc870
- SuperNova & SuperTurbo ????
- *** VOLTWATCH in nimh useless ??? ***
- HELP!! I'm a first-timer!
- Triton – Liar???
- Anyone no the name of these Chargers from Germany???
- DELETE
- discharge/charge battery, need help!!!
- NiCd or NiMH
- 33% battery
- Power Panel Chargers?
- Fuses popping on charger
- 12V Field Battery Chargin
- Frustrated Triton Owner
- Setting up NiMh pack on SUpernova
- Power source for supernova charger
- Alpha 4 question
- Another source for Triton Power supply ?
- Question about charging??
- ni mh batteries
- Super Cycle -- Electrostar Systems, Inc
- Ok let me refrase it, would Duralite be against
- 6v 1650mA NiMH w/ WallWart? (NiMH charging formulas)
- Wall wart chargers
- How old are my batteries?
