View Full Version : Questions and Answers
- R/C or Aviation Stuff in the Ft. Lauderdale FL Area
- super tiger 3000 prop size????
- necessary tools for scratch building ...
- allergic to glue
- Please help identify bipe
- Anyone manufacture aftermarket carbon fiber wing tubes?
- High temp tubing/ rear exhaust motor
- latex paint
- Anyway to remove CA hinges?
- R/C Flying communities
- Crash question
- Pros or cons on inverter to run chargers.
- Quick field Charger instructions
- Painting Floats
- what kind of Table???
- Servo placement
- Hypoxy - Is there a way to make it thinner and more flowable?
- Top Flite EconoKote over SIG AeroKote ?
- Hobbico Dealer in NY City
- *New Color Scheme Needed*
- coverings...which are the easiest?
- Painting and Airbrushing?
- help with repair of wing?
- Top Flite T-34
- pilot for 28%
- Whoops...
- cut cowl with what?
- Flite Metal (Ed Clayman) Unresponsiveness
- Engine Storage
- Glow Wire Help? Please!
- Handmade/custom pilot figures
- Aluminum servo mount... anyone know where to buy this
- Fuel soaked wood, does it weaken it?
- Tip if your engine suddenly acts up
- Rear tuned pipe engines worth?
- another stupid question
- MOVED: Problem with Fuji 50 EIS
- 4.8v to 6.0v retract question
- quick field charger fuse
- Tell me what am I doing Wrong
- Accessories for Kobra RC-53
- Battery charger question
- need an on board rocket engine ingitor.
- How do I convert this logo?
- I have a Futaba 4YF 4-Channel radio that is missing one of its joystick screw on knobs.
- 4-stroke Smoke system??
- Canopy question
- How to remove Monokote
- Where's the GLUE ???????
- Dubro spinner backplate slipping
- Is rustoleum clear glow fuel proof?
- Trimming out a windshield??
- heating problems
- Fuel Proof?
- Harmon Rocket Spinner
- Prop Pitch
- Question about OS 60FP
- need help finding replacement parts for Tower Hobbies Uproar
- Problem in buying the kit from sig or any other company
- Plane builders
- Lettering on Monokote
- Rudder pull pull dimensions
- Homemade Wheelpants
- Chrome Paint?
- Hobby Shops near Disneyland?
- Help with 300 motor
- Tapping Threads for Wingbolt?
- Right Thrust for 4*??
- Handmade/Custom pilot figures
- g26 engine mounting question
- Thinning Monokote trim solvent?
- What is control surface chord and control suface length,how these are measured
- plane stand for table
- Gorilla glue
- Please help me identify this airplane
- heat gun - which one?
- Can any one tell how to take readings of Max speed of an aeroplane model,Control Surface chord
- Nylon vs wood props vs fingers??
- FutabaS-9030
- TYpe of Servos used For RC-53 Kobra abd its numbers or Product Code
- OS 60 MAX H Muffler question
- Can I spray clear ultracote over G.P. striping tape?
- rebuilding a broken leading edge
- "Dopey" question
- Covering Technique
- Silicon Cowl Bushing / Fastener where to find?
- Inexpensive Shipping Carriers for Larger planes
- need help with JR631 transmitter travel adjustments
- What would be a good second plane but still has some aerobatics into it.
- Dean's ant
- Magnum .52xls or O.S .50 ringed
- PROP TO ENGINE
- plans for a topcat
- silicone and glow fuel ?
- custom cutters
- real answers about paint
- Transparent Covering: Any visibility concerns?
- Plane Storage System
- Who sells VQ Models?
- all in one power panel by Pacific Aeromodeling: advice needed
- throttle ratchet
- Dave Patrick Ultimate Bipe??
- Monykote on compound curves
- 4-40 Pushrod Questions
- Tower Hobbies - Pattern on discounts?
- overheating a pusher?
- Frequency scanners?
- MOVED: Hobbico charger - info wanted please
- aileron/servo/receiver question
- GP RV-4 Spinner problem for FS-70
- Checker Board Techniques??
- New OS 30 FS ....and a Question
- GWS Pico RX!?
- Holy ****...any idea what the heck happened here?
- Goldberg Extra 300 Canopy
- Du-bro fuel line barbs HELP!!!!!
- Blooming Glue!!!
- CA glues is there any difference?
- K & S Coil Bender?
- engine mount for funtana 90
- Fly RC magazine
- NICD/NIMAH Charger advice
- Aileron movement
- Trim painting blisters on a Waco cowl help
- Trans-Atlantic record fuel
- Engine starting without spinner
- Sealing Trim
- V tail direction of travel????
- Glues?
- Lancair Onboard Glow Driver for my Saito 100?
- GWS servos (too much play)
- what size fuel tubing for .40-1.10 engines
- Help Needed With HAL Autopilot
- Watt-Age Mad Dog powerplant
- Retract clip
- 25-10 3 Blade prop?
- Pneumatic Retracts
- Lubricating Pushrods?
- 9c and 9z futaba
- Extra vs Edge,,, the why and what's ????
- Good Hobby Shops in Manhattan, NY
- Hobby Shops in LA?
- rx and tx repair in Sydney Australia
- Uproar Kit vs ARF differences.
- Robart Problem
- Sanding Drum
- Needle settings for Thunder Tiger Pro .46
- Makinig Your Own Cabane Struts?
- Real-Flight G3 simulator multiplayer question
- Shop in Osaka, Japan?
- OS 120 surpass and non surpass difference
- Anyone know what kind of .061 this is?
- 1930 Fleet Biplane dummy cylinders
- Magazine
- what engine for tower Hobbies Uproar?
- Pitts S-2A .10 Need more info on this plane? Pics
- funtana 90 w/saito 1.20 engine mounts
- lithium Ion radio glitch
- Midwest Aero-Star 40
- Sophisticated Lady
- longitutde + latitude....of field and home
- Flying in Southern Illinois
- Lustrekote primer peels right off
- Weak landing gear on my sukhoi
- OS 60 questions
- unknown pattern plane
- 4C engine install on J-3
- Should I take a "step back"??
- Saito website?
- Thinning white latex??
- Need help with plane racks for trailer
- Where should I exit my annteanae?
- Project for a Saito 1.20?
- Expanded scale voltmeter question
- Pollution regulations in California???
- How to balance a 3 blade prop?
- prop?
- Seagull PC9 40
- I want a Stagger Bee!
- With What Can Fuel Proofer Be Used?
- Spinner sizes?
- Tinting the canopy
- Servo "Jitter" interferance
- I miss my old heat gun?
- what size spinner for a 16x6 and where?
- CHIEF AIRCRAFT, INC.?? Futaba 9C super
- SHOULDI APPLY LITE COAT OF EPOXY ON S. DECATHLON FRAME????????
- Nose steering for my jet?
- what type of paint to use on monocote?
- 1/5 Piper J-3 Cub Landing Gear Replacement
- Balsa Sealant for Painting
- Balancing the plane
- what size prop for my twist 3d
- Problem with trainer cord
- Magnets???
- Find a previous post
- Floquil jar and Iwata compatibility?
- servo glitching problems
- EPOXY THINNED WITH ALCH. KINDA RUBBERY WHY????
- help engine/feul problem sig something extra
- covering wing slots
- quick fueler question
- Do I really need a Tailwheel?
- First Manufacturer- Fibreglass & Foam kit
- Safety fence
- Servo Jitter
- Keep it simple stupid!!!!!!!!!!!, I'm trying
- Removing old silk and dope covering
- Flight characteristics... Trainer
- Haze on covering left by CA???
- monokote question
- Covering Wingtips?
- Help..need servo .. advice
- CA Shelf Life
- Polks Hobby Tracker Radio
- Saturday Night And...
- High rates or Low rate
- flexing control rods in a goldberg model 12pitts
- why no space shuttle rc ?
- Towerkote
- Easiest/best hinge repair?
- Sig coverall
- Help with Spring Air air control valve .
- Flying Fees
- Reedy Quasar # 610 AC/DC Charger
- Ultracote or Fabric?? ARGH!
- Cline Fuel System
- need to level horizontal fin...how?
- interference......metal brackets
- Sanding sealer and Prestain conditioner
- Changing from a regular servo to a mini servo
- Help!!How do you fly a Canard????
- Thinning CA
- Triming using Ultra-Coat
- Poltergiest???
- balsa grain?
- Just joined the forum
- Where to fly near San Francisco?
- 35mhz, which band?
- 51" wingspan and engines
- setting up the fuel pump?????
- Paint the inside or outside of canopy?
- Antenna Question
- where can i find TOC videos
- pica 1/5 scale cessna 182
- Glow Drivers............. Best value
- WEBRA Speed .91 muffler
- Monokote instead of paint on a car?
- Hitec Servo Arms
