- FLAPERON mode on DX6
- Futaba 8UAF timer buzzer not working
- DX7 users...
- Futaba 12 FGA VS. JR X9303
- Frequency question
- X9303 NEED AILERON SETUP HELP
- dual servos on aileron help
- I need to know....
- JR261
- RE: PowerBox Digi Switch & DSC??
- 2.4 GHz lots of questions
- flash 5 glitch
- servo power draw question
- Futaba 9zap or new 12fg
- Noise Traps/Ferrite Rings Needed with 2.4 ?
- Light Flite RC Rx's
- Hitec and 2.4GHz
- Traxxas TQ or Cen DSX
- JR X9303 2.4
- 129DP vs 149DP
- GY401 Problems with BCPP (updated with video)
- Futaba, Spektrum, Modules, oh my!
- With all of this talk of 2.4 ss... !!!!!!
- mx3 vs. xs3
- DX7 and DX6i, can they both support dual elevator servos?
- difference in an radios and recievers
- Mode change on Futaba 6EX 2.4Ghz
- Need help with Futaba 3pk
- Futaba 5014 or 5114?
- T6EX 2.4 GHz System
- Futaba 7C 2.4ghz, WHEN WILL IT COME?!!!!!!!
- another servo question
- Throttle kill switch on 9C
- 27mhz Vs. 75mhz Surface Frequencies
- Hyperion Servo's
- A CLARIFYING QUESTION JR/SPECKTRUM BINDING
- Hitec HFP-20
- Hanger 9 P-47 recomended retact servo problem
- Spread spectrum radio suggestions
- wireless reciever
- Dual elevator servos and dual Aileron servos with a 9C and 7ch reiever
- LOOSE CAPACITOR ISSUE--AR7000 OR R921????
- My horror Story DX7
- Futaba 127DF reciever and Hitec Digitals...A BAD combination
- Futaba 6EX or Spectrum DX6
- Color-coded servo extensions?
- Which servo should I buy?
- servo question
- Channel mixing my 9C
- Help Reseting an Airtronics Radiant 6/H
- Anybody "USED" any of the cheap Hong Kong servos
- Spektrum and JR RF Link Performance Telemetry from Eagle Tree!
- Advanced radio setup help
- Optic 6 and trainer cord
- 2.4GHz RC Car controller
- Futaba Tx, Late 1970s Vintage - Photos
- heli cannibalism???
- New 7C
- Kraft servo torque
- What do old timers think about 2.4Ghz?
- Radio, heli or airplane version
- Spektrum Receivers
- Rubber transmitter stick ends
- JR servo compatability with Hitec Rx
- RCD platinum for airtronics but using jr servos??
- Why buy Futaba?
- Voltage flickering on 6EX Futaba Radio
- Servos, servos, servos - - does it really matter for basic day-to-day flying?
- tryin to run 2 ele servos with a sx600 rad
- Spektrum DX7 Lockout
- TX adjustment?
- Should PCM be twitching like crazy?
- Metal geared servos and metal control arms
- voltage from ESC into receiver
- 7UAP elevon programming
- dx7 failsafe settings
- Expo on Throttle, Futaba 8U & 9C
- HELP" "Throttle Cut" Lockout on Fut 8UAP
- JR DS821 Servos
- Hitec Eclipse PCM module with arbitrary PCM receiver?
- conversion
- Futaba 6EXP Transmitter Setup
- Futaba 9C w/Spektrum wiring modification
- Airtronics M11
- servo linked to its own rx pack, any one know how to?
- What does the "B" mean on feigao 6ch RX?
- Lithium Battery for 9c Radio
- Why spektrum rx batt has 3 wires?
- Gyro Switch unit
- Who makes the Crystals?
- Futaba R5014 DPS Power Rating
- Lipos and Transmitters
- Futaba Skysport 6 model T6YG Mode change
- Need help choosing Radio's
- Mode 1 & Mode 2? 2.4 fasst
- Spontaneous aileron offset (discussion)
- Futaba 9Z and Fasst module
- Spektrum DX7 Neck Strap Warning
- Airtronics 94141Z servos..
- Servo size for 1/4 sclae (dynaflite super decathlon)
- HELP! futaba 4ex receiver discontinued
- Graupner MC-18 & MC-24 Spekrtum Module Installation Mod
- 6 channel Futaba
- Time for a new radio...what to get?
- DX7 Does it again
- JR Nes 606
- Multiplex Royal Evo
- can I use my 4 cell rx nicad packs with the AR9000
- Matchbox - stepped controls with retract servos?
- Is 72 Mhz Dead???
- why the rediculous delivery times for 12FG
- Castle Creations Thunderbird 36
- Question about JR radios
- Received My X9303 - 2.4 GHZ Radio
- Servo Question
- Servos
- Ignorant receiver ?
- I just want a standard receiver
- Futtaba 9chps + dsm2 spectrum module
- Expos on JR vs. Futaba
- JR 9303 - 2.4 GHZ Radio's on E-Bay
- ESC timing-mode setting.....
- S3003 / S3004
- X9303 Shipping Estimates
- -- reposted to JR forum, pls ignore -- JR/Spektrum 2.4GHz receivers and rx antennas
- Spektrum DX7 Ratings from flyers who have used it
- Futaba mc1128 help
- AM recievers - AM/FM conversions
- Castle Creations Berg 7p receiver question
- re-binding receiver to X mitter
- Airtronics M11 - 2, 3, or 4 channel?
- What is this ?
- 2.4GHZ RECEIVERS USED IN CRAMPED SPACES???
- HOBBICO CS170 ULTRA TORQUE SERVO??
- AX700 scanner use?
- Spektrum stuff
- Time for an Upgrade
- Profi mc4000 module available from XPS
- 4 functions from an Airtronics M8 3 channel?
- DX7 receivers 6000 vs 6100
- Negative or positive shift?
- Servo & Battery Wires
- Mapping AUX to elevator on DX7?
- Make your own servo extensions?
- RECIEVER WENT KABOOM!!!
- End point Adj.on retract servo
- Newbie here with a ?
- So would you trust a $10,000 plane to a DX7?
- Rcvr Jitters
- 60s gear
- Battery Charger/Discharger
- Horizon Support sucks
- Coiled Antenna
- JR and Spektrum
- Antennas breaking off the Spectrum small receivers
- Future Pricing on Futaba 2.4
- Compatability
- What kills my servos?
- Hitec HS55's with Airtronics Rx.?
- ALERT! Issue with "Air Alert"
- Why plane finders don't work with FASST R606FS?
- JR and Spektrum connectors?
- xtal falling out and causing crash
- Gyro question
- Dropped my Spektrum DX7
- controller advice
- Futaba T6EXAP NiCad voltage after 2 week storage
- How to extend Tower Hobby TS-80 servo?
- Jato controller
- Power output of JR 9303 2.4Ghz??
- ESKY receiver with 9CAP
- GWS Crystals
- JR 9303 available now?
- BD-5B and jr digital servo DS285
- Why don't manufacturers support 4 servo wings etc?
- xtremelink - smartfly
- Futaba 7C intermitten problem???
- Returning R/Cer Question
- Old Futaba Servos
- Has anyone ever mated a commercial joystick with an RC Transmitter?
- Spektrum install pics wanted
- POLYSWITCH ANYONE?
- FUTABA 12Z "Logic" HELP
- Futaba 9C + Spektrum AR9000 System
- XTREME LINK 2.4 MODULES FUTABA 9C
- Spektrum DX-7 help
- Can you use JR Rcvr with Airt TX 75 mhz?
- Difference between 4 5 6 and 7 channel heli radios?
- REDUNDANT POWER-SERVO ISOLATION
- Multiplex Royal Evo - Good News!
- Extreme Link 2.4Ghz System Question
- Hitec servos
- 14MZ Transmitter Pack - Cycle Results
- futaba 9c super synthesized transmitter
- High to Low freq receivers, FP-R127DF
- HAHA LOOK WHAT SERVO CITY SENT ME!!
- Servo Voltage
- 9303 flight mode ?
- dx7.. 1024 or 2048 resolution?
- glitching dx3.0
- Spektrum DX7 Transmitter case
- Berg 7p poor range check
- 2.4 9303 or 12FG 2.4 Going to 2.4 Soon
- Hitec Reciever, Battery/Switch into Channel 5?
- Futaba/JR Combination
- 9CAP Parts
- Torque on JR NES-L501 servos??
- Is there anyone use JR10X heli version with Reflex simulator?
- 8711 gears
- Flying wires causing glitches
- Do I have a faulty servo?
- Model Memory Vanished! Futaba 12Z
- good RX for Alfa mig15
- Glitch Busting Help
- Hitec programmer RC Mall Ebay
- 7c module Fasst system report
- Spektrum DX-7
- PCM Lockout?
- y
- What Work's Best?
- Loss of frequence on 14 mz
- Anybody own a Futaba FP-T2P
- what servo arms fit jr other than jr
- Futaba 2.4ghz compatability??
- general electronic q
- Kraft radio users
- Servo S3305 Futaba or ... ?
- need and want Radio, but which one?
- A question from a newbie
- Servos - Why or what makes them do this?
- XP9303 With Select Scan
- AR 9000 failures - service bulleting
- 2.4GHz Radios - enquiries.
- SOURCE FOR SERVO CONNECTORS AND CRIMPING TOOL
- APEX tranmitter
- HiTec Black Servo Arm Limits
- DX-7 Rx reset - possible cause
- Futaba 12Z or 12FG???
- Power System for a 28% Edge
- Futaba 6EX 2.4 Ghz lost ID Code
- Making my own PC data cable?
- Another Futaba 9CAPs/US40 Question
- 9303 2.4 Is out
- JR XP662 and aileron programming
- Futaba antenna for a JR Tx?
- help!Walkera 5G6 technical support
- Help!
- transmitter/reciever compatability
- Futaba 9CAP + Spektrum or FAAST
