PDA
View Full Version : Batteries & Chargers
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67
  1. LiPo Battery conversion for Double Horse Helicopter.
  2. Voltage Formula ?
  3. Voltage Question
  4. Buy Passport ,Visa,Driving License,id cards [email protected]
  5. A123 26650 battery cells
  6. Anyone know about these batteries??
  7. Best aftermarket Transmitter pack for Spectrum DX7S
  8. Watt Hours vs C rating
  9. Turnigy 4000 mah lipo tx pac
  10. iron corp extreme a123
  11. Buying balance extensions
  12. Discharge rate okay?
  13. NIMH battery help
  14. Battery Failure
  15. Blade CP Pro
  16. NIMH battery repair
  17. Do you break in your Lipos? Heres how for new pilots...
  18. Voltage reading
  19. RX Battery question
  20. LiFe pack - 1 or 2 output leads
  21. batteries and the works
  22. "Connection Break"
  23. 50 watt charger enough for 22.2 v 4000mah lipo?
  24. Electric Newcomer needs help with Lipo storage level
  25. Solar panels on RC Plane
  26. Onboard battery monitor - digital servos
  27. Charger/Discharger For NIMH Only--need recommendation
  28. 12V 12 AH field box battery and Dynatron
  29. for MVP but that's how the league works
  30. LRP VTEC LiFe batteries?
  31. Lipo low voltage cut off with out esc
  32. Charger recommendation for LiFePo4 Batteries?
  33. life batteries to good to be true???
  34. Recommended MAH
  35. Hitec X4 Eighty question
  36. Cellpro 10XP and 10s pack with JXT balance leads
  37. New guy...new charger...I'm lost!
  38. Hotec x1 servo testing
  39. Sub C pack vs. AA pack
  40. LiPo or LiFePo to power receiver????
  41. charge problems
  42. Which adapter do I need?
  43. Icharger temp problemsarge
  44. Will this charger/battery setup work?
  45. Radio Shack 7.2 pack still GP ?
  46. battery to start 60cc magneto gas engine
  47. B6AC charger: Can't save settings
  48. Quick 4.8V pack vs 6.0 pack question
  49. Newcomer Questions Re : Charger and Battery
  50. LiPo not charging
  51. Hitec X4 AC/DC Charger going into breakdown with NiMh or NiCd
  52. How many amps for 7600mah lipo?
  53. How to determine 12v resting voltage
  54. What effect will voltage difference have?
  55. Lipo To Power USB?
  56. Which charger can I use
  57. Please help to identify battery configuration
  58. Lipo Battery setup
  59. Hitec X4 AC PLus balance connector type?
  60. which battery
  61. Tork 2200 blown
  62. need a new charger
  63. Linking iPad and Laptop with charger.
  64. dynamite prophet sport plus error codes
  65. Newbe to life batteries
  66. Want to revive my NMH and Ni-Cads
  67. 3.7v 150mh 25c battery
  68. What do I need to change to LiPo, LiFe, or LiIon
  69. Hydrimax NiMH 2000 mah batteries and Triton settings
  70. Need to reduce voltage from power supply
  71. What values for charging NiCd and Nimh ?
  72. LiPO recommendation...???
  73. Trouble charging Nimh
  74. hard case req'd for lipo?
  75. Battery Low Voltage
  76. Traxxas RTR kit came with a 12 volt DC car charger. I need AC.
  77. Internal Resistance of Hydrimax NiMH ?
  78. Storage Charge Question
  79. buying a new battery and need some advice
  80. Problem charging LiFe through MPI switch
  81. New Spektrum LiFe battery packs
  82. IMAX B6 charger "over voltage" message when charging LiPo. Help?
  83. Battery / charger combo for Traxxas Stampede VXL and Redcat Rockslide
  84. Help a newbie with correct charger, identify wiring terminal?
  85. new lipo, my very first. now what???
  86. LiPo for a Novice
  87. Do the Turnigy 1s2p hard case car batterys have balance circuitry built in?
  88. Upgrade Batts for a Skytech Gaui Hurricane M1
  89. Connecting lipos
  90. Need battery and charger help please!
  91. New to hobby with a question?????
  92. This now appears on UPS Site - New Regs for Lithium Metal Batteries
  93. How do you store your Batteries for winter
  94. Dynamite Passport Duo 400W Dual AC/DC Charger
  95. Hitec X4 AC Plus Charger Big Disappointment
  96. Lipo battery damaged in a wreck. Can I still use it?
  97. Do you lose much current with an xt160 to deans adapter then to deans on esc?
  98. Very Impressed with my new SMC Battery.
  99. Understanding Lipo chargers?
  100. USB Charging
  101. Which kind of batteries to use on a glow fuel model.
  102. ICharger 206b
  103. found my old grasshopper from the late 80's I believe, need advice on batteries.
  104. Need lipo battery and regulator for a JR DSM R922-Power Safe
  105. lipo battery in spot light
  106. Battery heating up real hot
  107. Replace alkaline cells to rechargeable battery
  108. FMACell Pro Multi 4 & A123 2500 mah Pack Charging Question
  109. Best brand of RC LIFe battery
  110. Charging a single cell 150 mah lipo battery?
  111. Charging lipo without balancing
  112. Low Voltage Cutout question
  113. Whats the possibility of two new batteries being garbage?
  114. alkaline salting
  115. question on charger/ battery
  116. I have no clue on how to select a Lipo battery for a particular setup, please help.
  117. Strong Battery That Can Survive in Back of Car For Extended Periods?
  118. NiMih Batterys Not Used
  119. battery upgrade question
  120. Losi Micro Desert Truck LiPo Conversion?
  121. A lipo charger for my simple needs
  122. At what voltage should I recharge my 3S 9.9v Life Tx battery
  123. E-flite 100mAh battery socket
  124. I need a REAL BATTERY BALANCER
  125. Recommend on battery for DJI S8000 EVO
  126. Futaba fbc 19b 4 charging time
  127. Lipo selection (specifics inside)
  128. When is a good time to retire a Lipo Battery
  129. can a 7.2 Lipo be used in a TX
  130. Quickest way to ruin a Lipo
  131. Lipo Batteries: Series / Parallel Connections
  132. Dynamite Prophet Sport Duo
  133. RC The Bandito
  134. A123 BAtteries Shelf Life/Dormancy
  135. what battery & charger
  136. Charger recommendations.
  137. SKYRC Quattro B6 4x80 320W on Ebay fake or real?
  138. 1S batery charging
  139. Triton II Charger
  140. Lipo Battery for TT-01
  141. Battery upgrade for Exceed Sunfire buggy?
  142. How To Charge Ni-MH With Common Sense RC Charger
  143. Charging 2 batteries with one charger (Noob Alert)
  144. Good receiver Pack?
  145. Lipos & water don't mix
  146. Lipo and thunder ac680
  147. Charging a LiFe battery
  148. e-flight 60 amp pro esc
  149. Charging Problem
  150. How to find Charge status
  151. Lithium ion instead of lithium polymer
  152. Cellpro 8 accessories needed to daisy chain 2 MPA boards
  153. New Hitec charger and power supply dock together
  154. Paralleling LiPos for Use Question
  155. Newbie - Battery Question Again
  156. Please Help! Servo battery dead.
  157. Another question on how to determine actual LiPo capacity
  158. Lipo cells, balancing on the typical charger, etc.
  159. Choosing a battery to power car horns?
  160. New Here, Need Some Help
  161. New Lithium battery tech developed by Colorado S.U.
  162. hard case or soft case lipo batterys
  163. Your Amazing Aerial Photography Assistant--Flypro X600 RC Hexacopter !
  164. cheapbatterypacks.com quality sucks
  165. New here need some Help with Batteries
  166. hitec X2 Ultima mutli charger 200watt X 2
  167. 4200mah 40c lipo for 90A esc? lipo 'd bebelow 6v if rc stop running any more?
  168. Help charging my lipos
  169. Possible change in LiPo construction
  170. Looking for a decent smaller charger for 1, 2 and 3 cell lipos
  171. JST Balancing/Charging Leads
  172. Why is the iCharger 306B 1000W and not 756W ???
  173. Help - Trying to charge glow igniter with Accu-Cycle Elite
  174. How long does it take to charge a LiFe battery?
  175. Got my hands on 2 used turnigy lipos they look slightly puffed....
  176. 7.2v 260 mah nimh help
  177. Parallel Charging Individual Cells - Balancing, What mAh?
  178. Triton EQ
  179. Turnigy 11.1 Volt 2200 MAH Lipo's
  180. This is a really good little charger.
  181. Turnigy Accucell 8150 charger backlight not working.
  182. LiPo batteries swelling not while but after charging them?
  183. Vista Quad Charger Q6320 AC Help
  184. Rechargeable Batteries Charging Time
  185. Any of you had this happen?
  186. been out of hobby a while, some questions
  187. Hobbico Life Packs
  188. Turnigy LI-po need some help choosing
  189. What kind of battery for my boat...
  190. FMA PL8 and 7.4 2cell charge?
  191. "Puffed" Batteries
  192. What do you guys use to charge your Lipos?
  193. Balance harness HP 8 pin to XH (battery side)
  194. Bulkhead balance port for field box
  195. nimh???
  196. JST-XH bulkhead connector?
  197. will old charger work with NiMH
  198. How to charge my new Lipo Battery + IMAX B6AC Charger
  199. 25% off all 5500mAh Revolectrix HV LiPos
  200. NiMH battery not fully charging?
  201. NIMH charging to over the rated capacity?
  202. Admiral Lipo Batteries - Any Good?
  203. Battery Connectors
  204. LiPo Charger question
  205. Reducing wire guage...looking for an elegant/solid solution
  206. How connect Turnigy Lipo to eflite esc
  207. Lipo fire!
  208. Four button charger - Thunder AC6.
  209. Battery Question
  210. really cool sales going now!!!
  211. battery help please
  212. Puffed up LiPo
  213. EC-5 Connector Variants
  214. SkyRC e6 ACinput charger is giving me fits!!!!
  215. Looking for a cellpro 4s
  216. A123 Dual switch set-up question
  217. Duralite Plus A123- Can I use my Cellpro Multi-4 charger???
  218. What am I doing wrong need help
  219. Replace Alkalines
  220. Battery Discharge Rates
  221. Charger Won't Charge!
  222. Duralite Plus A123 4600 battery-Dual switch setup ???
  223. DYI Voltage Regulator
  224. Saddle bag lipo suggestion for Team Durango buggy. What do you run?
  225. Best charger for my application
  226. Please set my mind at ease
  227. switched to deans plugs chargers not charging very little or non at all HELP
  228. please help with ripmax propeak prodigy II identify chip
  229. Power supply and charger question
  230. Where are the CellPro Multi 4 chargers
  231. disposal of LiPo
  232. G Force 3S 1800mA Life Tx battery
  233. New Accucell 8150 charger fan and screen back light not working.
  234. Transmitter Battery convert to Lipo
  235. Buyer Be Ware
  236. Use Lipo Bags and a Metal Box to Charge your LiPos!
  237. NimH Battery Cycling
  238. Recommendation for Aligh 100 battery
  239. how t make a car bub lipo discharge the right way or not
  240. A123 2300- On board balancer or not???
  241. 7 V+2.5A Charge,am i right ?
  242. Chargers Balancer for Lipo
  243. trouble ordering batteries today
  244. Can the onyx 210 charge AA's?
  245. Double Horse 9053 helicopter charger box problem (I think)
  246. A few basic LIPO questions
  247. Lipo Discharging
  248. Is there one charger that will do all I need?
  249. cant adjust the turnygi 420 charger with this video
  250. Jan hermkens B-17 build, batteries and servo connection
