- Where to get Red Anodized stick ends for Futaba Radios?
- Airtronics MX 3, Ko Propo EX 1, JR Racing XS 3 or Futaba 3 PDF-X
- Trouble programing 8U with Futaba Gyros
- Intresting Fact about the 9C
- S3010 doesn't work with NiMH? Nope.
- redundant radio systems
- extensions on rx battery pack
- Glitch counters and PCM
- 2 Aileron servos without MATCHBOX?
- XP642 BROKEN THROTTLE STICK
- Need 'stuff'
- Futaba DSC Compatability
- Programming rd8000
- Futaba 9C batteries
- Reversing an S130
- JR 8103 gimbal stick tension
- differential thrust
- Hitec HS 225 question
- Rado setup for Extra 330L
- Receiver shootout (part 1)
- Futaba 8u problems with Hitec Frequency module HELP!
- 10X vs 9Z
- NEW 9C synth
- Projeti cut my Antenna
- Futaba 8U question
- throttle ratchet
- Jr 4000 Servos
- what is the best servo for my application
- Jr 8411's buzzing
- ACE Silver Seven Receivers
- multiplex
- multiplex
- Maxx Products New LED Switch Harness
- Bad servo glitching question
- R700 CH 36 ???
- JR servo ,L501,L4001 How much are they worth and there Torque?
- What is your stupid radio story?
- Futaba 7CAF ..placing order monday morning...read...
- Just upgrading to digitals?????
- JR 8103 Timer?
- Futaba 8uaps
- Throttel cutoff in Royal evo
- Help with 8UAF auxilary channel set up please
- Airtronics Freq swap
- Futaba 6EXA / Saito 30 throttle-cut switch setup?
- Cheap Micro Servos - Dragonfly - Any Good?
- Reversing S9402 servo
- RD-8000 with Ultrastick-60 -- HELP!
- 18 AWG extensions
- JR RADIO
- How many radio do you all have?
- How does it work?
- Good first computer radio?
- Dula Rates on Throttle
- which is the best radio of these 2
- Hitec 625mg's
- 4 Segment wings and the Futaba 9C
- XP 8103 VS PCM 9X
- JR PCM 9X
- Servo extention question!
- receiver question
- FUTABA SERVO QUESTION
- 9CAP 4 servo aileron programing
- Futaba Radio Question !!!!!!!!
- Frequency "bleed"
- What gives?
- Older recivers compatibility
- 9Z newbie question--first of many, I'm sure...
- 9 CAP programming book..the one for "Dummies"
- emcotec
- Futaba 9 vap - Please post.
- PREFERRED CHANNEL ON PICCOBOARD PLUS
- I.D. Transmitter 2
- I.D. Tranmitter
- futaba 9c question(set up trick)
- fail safe receiver switch?
- Can old FP-7FGK be narrow banded?
- Futaba Reciever problem
- T6xa elevator trim problem
- 9CAP Throttle Mix
- BERG STAMP RX with PICOBOARD
- Futaba 9CAF ok for heli?
- 56mhz?
- Antenna for micro flight
- Where can I buy a stripped HITEC FLASH 5 Radio?
- Multiplex charging
- JR 8103 Promo servo Flutter
- kopropo EX-10 HElios help?
- battery in backwards on Futaba 127DF
- Servo synchronizer or Servo reverser?
- 1oz low voltage, 4 standards
- My Take On The Futaba 7CAP
- Futaba Crystal Experiment...FMA Crystal
- 4 Channel Radio/5channel receiver??????
- Receiver Problem
- TX with 5th Proportional Channel
- RADIO FOR PICCOLO
- Futaba FP-T8SGH-P question
- Left handed mode 1 on hitec flash 5 ?
- Who's using FMA Servos?
- UNI Vs MPX in MUltiplex RXs
- How do I program 9CAP so throttle is less sensitive?
- Radio Crystal question
- FMA Direct Fortress == Futaba???
- old airtronics servo connectors...
- Airtronics VG6000
- servo plugs
- futaba 6xas
- Higher frequencys better ...?
- Antenna must be full out
- MicroStar 2000 parts
- New JR 10X Air
- Charger voltage for RD6000 TX
- JR XP6102
- FF9 throttle setting?
- High voltage affect on servos
- Using Eclipse 7 w/other brands ie airtronics
- Flutter on the ground!!!
- FMA co-pilot 8chanel
- Beta test my JR XP8103 Data Sheet
- Volz Servos
- Computer radio question
- ServerCity combos
- ultra stick servo
- DAD Pro+ servo gears?
- Futaba S9153 and S9152 Digital Servos
- Sweeper for Interference
- Hitec Supreme 8 with Futaba Crystal?
- JR radio compatability
- Airtronics Help
- Futaba FP-8SSAP
- Good & Bad News at Horizon
- Beware of low priced computer radios.
- Good Deal on JR 8611 Servos
- Looking for servos in Montreal (Canada)
- does torque increase proportionally with weight?
- What does the speed of a servo mean??
- Futaba 8AU with Hitec 72 Mhz module?
- 7CAP/Ultra Stick
- Servo Selections
- Regulator needed for Hitec digitals?
- Buddy box, need help!
- NEW RADIOS
- Hitec 555 in a 40 size nitro plane?
- Airtronics PCM RX problem
- Airtronics Infinity 600a?
- Futaba PCM with Hitec digitals?
- Crystal failure
- ? Changing frequencies
- Power output of different brands
- increase range (power output) of tx
- No signal! need help
- Evo Gurus help please!!!!!!!!!!!!!!!!!!!!!
- Hitec programmer
- can i use a plane radio in my boat????
- giant stinger servo choice?
- Recommended servo size for a GP Spectra EP glider?
- Futaba 148DF Micro or Hitec Supreme 8
- Futaba Challenger conversion buddy interface
- Futaba Conquest 4-Ch is narrow band, right? (I hope)
- Spoileron Servo Matching
- Not impressed with Futaba 3010S servo
- Temp range for JR 662
- Flaperons adjustment with JR421EX radio
- futaba 7 manual
- Futaba 9153 or J.R. 8611
- Retract Servos
- Posi or Neg.. .. stupid question
- post homemade transmitter tray pics
- Servo range of movement
- Need Help with Flap Maricle Y Problem??
- Digital Servos -- what's the advantage?
- How do I identify Futaba RX Low vx High
- What a Bummer...8103 Charger Problem
- Futaba 9cap ergonomics compared to JR?
- 8U futaba rec. options
- Large aluminium case??
- Futaba crystal identification
- 72 mgz AM/FM what's the difference?
- Spectra glider - what servos - radio desisons....
- Futaba 7CAF TX only?
- Replacement for Futaba 9ZWCII
- Problem when programming Kontronik Beat 40-6-18 in car-mode 2
- JR 4735 vs 4131
- Iterfernce "i need help"
- Hitec HS-635HB Servos?
- Question about the RANGE on a RADIO???
- Hitec Eclipse 7 problem
- Can I use this Tx and Rx together ? (Futaba)
- JR XP6102 or Futaba 7C?
- Cheapest place to buy Hitec?
- Why Do You Use Like A 9 Channel System When We Really Don't Use That Many??
- Servo binding or broken?
- My apologies to 9C users.
- 7C vs 6102
- Best Source for buying Hitec Rxs
- dual elevator servos servo selection
- Y harness
- QUestion about futaba 6xa and 3003 servos
- FUTABA cap-7 cap-9 rubber grips
- Futaba pcm
- How many channels?
- Motor interference
- Rx Crystal compatibility
- Computer Radio question
- Rquired Airtronics 94102 servo gear set
- Futaba 9CAP
- Dielectric grease
- Skid Steer Control
- Kraft plastic frequency module plug-in dome
- Futaba/Hitec When are they coming out with new radios besides the 9CAF and Ecloipse??????????????
- Are they anygood???
- RD6000 CROW function
- Thought you'd guys would like to know!!!!
- Looking for GOOD 60+ oz and 90+ oz servos....suggestions
- Airtronice RD6000 super/Voyager E
- Whats the Best RX???
- Futaba Receiver working voltage
- FM receiver and digital servos
- Futaba 2PL Question
- Kraft information wanted
- AM and FM
- Servos Futaba or JR
- Receiver Good Or Bad
- servos glitching
- Airplane servo torque requirements.
- Questions about Ham Band, 50Mhz, channels, etc.
- JR or FUTABA
- Kraft plug in frequency modules
- Aero Arms - Interchangable?
- Jr or Hitec
- contact cleaner
- Futaba 9CHP question
- Battery cycler necessary?
- Multiplex 4000 Got My Stick End Buttons
- servo wheel differental
- FCC 'type acceptance' and modules
- Servo Bounces when Centering
- JR FLEXEQUIP ?
- 9CAP is reversed
- Graupner MC-24 "Gold Edition" ! ! !
- Futaba S3305 or Hitec HS605?
- Hitec HB-635 - used one yet
- Single-stick radios all gone?
- DOH!! Antenna cut - HELP!!
- Futaba S3305 servo's
- First Radio!! Need Advice--Please Help!!!!
- Servos for a NONFLYING F-16
- hi all skysport 6vh
- Kraft questions
