- USA F3A Team Website is UP
- Questions on my 3D hobbyshop Osiris
- Cycling Lipos at Home
- Opium
- which is the best option?
- Dead spot on throttle
- Props for Hacker A50-16L 10S
- Build F3A Zulanair (Plans)
- don lowe Pheinox 8 converted to EP
- Battery Break-in Stand
- 18x18 - 20x20 prop 10,000 rpm
- Servo Current Usage Graph for Intermediates
- Great Planes Sequence
- New Mk electric wheels
- Castle 110HVS ??????????
- Had enough of Glow - need advice on conversion
- Delayed Full Throttle
- Redundant power Part II
- Phoenix 7. IF electric, would you buy?
- What defines the IDEAL E-Motor for you?
- Recommended Firewall for Electric Outrunners
- Mayr's Toxiris
- Lipo's; old soldiers never die, or do they??
- Neu versus Plettenberg.
- CBA II
- Props. What's the best? How do you know?
- Time to fly a Sequence. Do you record it? Intermediate?
- Charging Box
- Texas Republic Pattern Classic June 25-26, Georgetown TX
- Tire Sizes Sebart S 110E
- The Official Pletttenberg Xtra 30-9 Evo II Thread
- questiion about wind s 110
- Xigris C1 CG?
- Lipo batteries in your transmitter
- Receiver packs
- DO YOU KNOW THİS PLANE??
- Transporting Batteries on Airline
- E firewall for Bravo
- Extreme Flight Vanquish 2m Build Thread
- jeti controller
- Dean Connectors
- Koratop 40
- New plane seen....
- plettemberg..... incredible service!
- Hacker Q 80
- A newcomer to the full-size F3A models
- Oxai -Matt Peridot
- Visa´s ready for WC in Muncie
- De Ja Vu #2 Finally
- Source for Rhino and Zippy 4s lipos
- Hacker Motor Question
- 3D Hobby Shop Osiris 2M
- De-Ja-Vu WC
- Jeti Spin 99 Brake and End Point Settings
- F3A (On a Budget)
- CPLR goes to Electric
- New planes on Lindinger site
- Miss Wind 50E - Glow conversion
- Anti-Graviton v2
- Help with Neu F3A motor, CC HV80 in a Passport
- Europa PRO-LT
- Envision kit
- Hacker gearbox grease
- SETTING PLETTEMBERG 30-10 SCHULZE 32.115
- YGE HV90 & Neu F3A
- Secraft Axles
- Canopy cover for a Sickle??
- Pletty Evo 30-10 controller
- Hacker A50 12S
- Battery Balancer suggestions
- battery suggestions: 8S with A50-16L
- Static Thrust and Prop Stall in pattern setups
- My Neu 1512/3.5D - any thoughts/advice?
- any good choise of 110 size f3a(ep)?
- Japan
- Sebart 110 Motors and issues
- Battery Configurations
- Himax 6330-210 F3A Advance motor
- Prop size
- WTB AXI 5330/18
- CAELESTIA NEW F3A 2011
- Throttle curve for Hacker Q80-13S 20P
- How do carbon props compare?
- Cation Sneak Peak
- New Batts TP 4400 and 5000
- 2 Batts or 1?
- Share your transmitter setup
- Hacker A50-16L question
- ZN Twister
- Portable Charging Case
- Comparision
- PPG Paint
- ZN Xigris C1 build
- Spacer Needed With Neu F3A & Budd Mount?
- Jeti now making transmitters....
- Plettenberg 30-9 evo ii ?
- Russian F3A masterpiece “Europa PRO LT” now produced in Europe
- The battery thread
- Plettenberg Advance 30-10 Inrunner Test Data!
- Assist in motor choice
- 2m Pattern Plane Weight Problems
- Replacing OS 140 with Himax 6330
- When is a good time to order next season's batteries from China?
- Thunder Power 820 Charger walkthrough
- Q80 with ICE 80HV
- 110 size wing tube length & diameter recommendations?
- External arming switch
- Hyperion EOS 1210i on sale... $120
- Da-Ja-Vu Build thread
- De-Ja-Vu
- Spring in SoCal
- 3/4 pound foam bulk order... you want in?
- E-Flite or Hangar 9 Pattern or 'faux pattern' plane?
- Cellpro Power lab 8 for pattern use
- Wood Prop?
- Which Battery Charger to buy
- Gearing up
- New F3A motor: XC6325/12 F3A
- Oxai Asyuler EP
- Castle ESC screaching during brake-to-throttle transition
- On the lighter side
- Batteries hot even in Winter!
- 110-120 E-power setup recommendations?
- Proline Fantasista
- Cheapest radio for F3A
- What power source does everyone use for field charging?
- Pletty 30x10 evo and jeti master spin 99. Help please !
- Builder Wanted!
- Custom charge case
- Neu Gear Box Clean & Lube
- Kontronic Korotop 40
- Hacker Q80 help needed
- Vquick Custom Charge BOX
- A different approach
- What's the latest in batteries?
- What motor/battery for Conquest 7?
- Scorpion F3A Motor?
- Seasons Greetings!
- Hacker A60 Mounting ideas?
- BuddEngineering
- Controller Setup for Hacker Q60
- Battery question
- Wind S Pro problems
- Which motor: Neu F3A-1 or Hacker c50 14xl?
- To give or not to give?
- Ball bearing rod ends and other interesting connectors
- February Contest D3
- New Builds for 2011 Season?
- 2011 Polk Pattern Classic Lakeland, FL
- Hobby king lipoly batteries
- E-Neptuno build thread
- Contra rotating props
- Andrew Jesky Precision Flight DVD
- Neu F3a Motor
- Osmose
- Help for the new guy
- building is great, what about flying?
- Lightning Build
- Comp-arf Valiant..weight
- simulator for pattern practice
- Folding props
- Wing/Stab Tips. Flat or Rounded?
- Visa C/G & Flight Reviews
- A use for those tired old 10s packs
- Plane for Torque 2814 help please
- New Krill Spark Evo I- Build Thread.....
- Delro Composite Jupiter
- Which motor?
- CC Phoenix ICE HV80 Reset??
- Plettenberg 30-10? 30-9? or Advance 30-10?
- Flying time for Pattern competition
- Futaba BLS servos in F3A
- How to paint a fiberglass fuselage?
- New Hacker Q60+Spin99 Setup
- PT Model 20 x 13E Prop
- ESC ARMING SOUND QUESTION
- Turnigy Nano-Tech batts?
- Landing Gear Mounting Plate
- MasterSpin 99 low voltage cut
- Glow or Electric
- Combining the best of I/C and Electric Power
- iCharger just blew up and took out other charger
- prottype new Hacker Q80 20P/13s
- DSC and Charging
- New Delro model - "Opium"
- Spin 99 Airtronics SD-10G
- NEU 1515 2Y/1515 3D
- Osiris Kudos
- Your Best Method for locating canopy pins: How To's
- Rhino 4900
- new axiome ep
- NEU Motor Mounts
- Anyone have an electric Focus 2?
- New Dualsky Pattern Motors! 6360
- Castle Creations ESC Recall
- Sickle (V-2)
- Any thoughts on the Kyosho Osmose 70EP?
- Electric props for sale
- New Charge Box
- F3A of 50 inch wings
- Pentathlon Evo - Electric
- Gulf Coast Pattern Championship- Sulphur Louisiana
- New Himax 6330-210 pattern motor and 20.5x14.5 CF prop
- Arming Switch
- Cheap & cheerful setup for an Angel 50
- YS Electric Motors??
- Passport Firewall Template
- De Ja Vu
- READINGS
- Power 160 settings
- Prop adapters
- 1/3 scale 80cc gas to electric Project
- How strong should the deck plate be for 10s battery pack?
- A llittle help here
- Castle ICE HV 80 data port Q. . .
- Spin 99 Controller Question
- European Cup for F3A on floats
- Rutro, What did I do now? HV85
- Mission Impossible? Or am I nuts?
- Power Set Up Question
- C50 mount
- AXIOME + PICTURES + INFO + TIPS
- HACKER C50-13XL & JETI SPIN99-OPTO
- Phoenix HV85 issue
- Europa S Pro
- Xigris C1 motor/ESC choice
- Carbon E props, what’s your experience?
- Scorpion 5030 220KV F3A Motor
- Who's run Hacker A50-16L on 10S?
- Castle Creation ICE HV 80, Hacker Comp 14xl
- Cutting Spinner
- Hacker C50 14 XL and CC 85 HV
- New Sebart Wind 50E
- Radio problems
- I'm new to F3a 3D Hobbies Osiris?
- Hacker C50-11XL 8s setup.
- Moving to Electric - Which Chrager to Buy?
- e-Power system questions
- Passport Build
- Nats NSRCA Merchandise
- Extreme Flight 70" Extra 300
- When side force generation gets out of hand
- Which 1900 series Neu motor?
- Castle Creations HV80 ESC
- Choice of electric motors for pattern plane
- Contra Rotating Propeller Drive for f3a 2m Pattern Planes
- Charger Box
- How to charger 10S pack with Two 6S balancer???
