PDA
View Full Version : Electric Pattern Aircraft
Pages : 1 [2] 3 4 5 6 7 8 9
  1. New BJ Craft Andrew Jesky Designed 2016 Nats winner Element thread
  2. Futaba Telemetry Cable
  3. New O.S. F3A motor
  4. Convenient Cheap Discharger
  5. Looking for a 2 Meter Air frame
  6. Vortex Generators?
  7. New charger
  8. New CG stand
  9. 2017 Project H F3a plane?
  10. Graphene Batteries
  11. Caressa - new plane from CKAero
  12. Prop for Hacker Q80 11S
  13. Denkado Musette 1.1m F3A Assembly
  14. Batteries for a De Ja Vu
  15. Plastic covering film with no edges?
  16. BJ Craft Contra
  17. Electric Power in Pattern
  18. Charging LiPo packs
  19. Neo stage
  20. Caelus Landing Gear Fix
  21. ESC question - Castle HV85
  22. Mria, new biplan model
  23. From israel - next generation f3a technology
  24. Neu 1512 2Y Vs 1513 2Y
  25. Any thoughts on BJ Craft's Etude?
  26. Deutronic Hacker Senstrol ESC and motors?
  27. Himax, Jeti Spin 99, Motor Timing
  28. Series Plug Short?
  29. New planes from BJCraft
  30. A funny place to asking for glow engine headers....
  31. D-6 Contest
  32. Prop drag
  33. Scorpion backup guard
  34. Plettenberg motor inside spinner?
  35. F3A European Championship 2016, Untermünkheim, Germany
  36. Stabilizer Fences
  37. New 2017 2m planes
  38. Excess
  39. Excess
  40. App for measuring F3A flying sector?
  41. Stribog pattern plane ?
  42. P51 Fuse Shape
  43. Battery C rating question - Masters Pattern
  44. Skyaviation Wolfgang Matt's ARROW ARF
  45. Futaba 14MZ "Backup error" - should I be worried?
  46. Throttle curve starting point?
  47. jeti f3a braking
  48. Caelus Balance & CG Assitance Help
  49. Lipo Fire
  50. BJ Craft Passion build/ New guy
  51. Occasional motor screech.
  52. Xtremecomposites SkyAngel biplane?
  53. Redundant Voltage system
  54. Caelus Firewall Mounting
  55. Powerbox Electronic Switch - Lipo Recommendation
  56. Wixey WR300 Type 1 - one question.
  57. Hacker Mezon Opt 95 ESC commutation error
  58. Falcon 3 blade prop
  59. Receiver mounting positions
  60. Pattern Weight Limit Why?
  61. Oxai Galactika unboxing, assembly, setup, maiden etc.
  62. Hacker C54-2Y L Acro 6,7:1 Competition
  63. P-17.03 Knife-Edge Combination... - "sustained knife-edge fligt"?
  64. Building a Pattern Aircplane
  65. Electra
  66. (Oxai) Citrin 50e size biplane?
  67. Need a little help
  68. New CA plane from F3A Unlimited
  69. New AJ Pattern Plane
  70. OXAI no more ??
  71. BJ Craft Etude
  72. Caelus - build and test flights
  73. 29% g-202
  74. Hysol or Epoxy resin the better option here?
  75. Griffin vs Prolog? six of one, half a dozen of the other?
  76. Allure Electric Build Custom Yellow Scheme
  77. Bat Safe
  78. HK Order Saga Zippy Compact 5S/5000
  79. CA Models Epic ARF
  80. MAC and c/g considerations
  81. futabaa servoes
  82. Galactika datum line?
  83. Castle cc-bec and esc master spin opto 99
  84. Power Unlimited LiPo Reviews?
  85. New DuaSky DA3 6355-XX
  86. Lubing Neu gearbox
  87. Battery tray in Your F3A plane - show us.
  88. Galatik90
  89. New titanium control horns
  90. Dinogy lipos on sale
  91. Les "No Name" (temporary) new plane for 2016
  92. Question : the theory of brake operation
  93. Contra
  94. Arming System for Main Batteries
  95. Exchanging Q80 motor on MYTHOS 2M into Brenner's CRD + RS mount
  96. A123 Batteries
  97. Jeti Spin Pro 66 and Hacker A50 16S
  98. BJ Craft Agenda CD
  99. *New 2m Pattern Plane*
  100. CK Aero Allure- builders kit build
  101. 2 piece fuselage F3A plane?
  102. Vanquish 2M motor
  103. Another plane with stepped leading edgrs
  104. Xoar PJH-ET CF props?
  105. Jeti esc
  106. S.Bus for pattern
  107. Plettenberg Advance bearing replacement
  108. Hacker Q80-14XS / CC EDGE HV80 (Bad combo)?
  109. Overhauling Plettenberg 30-10 EVO
  110. Aluminum socket head cap screws for landing gear?
  111. BJ Craft Agenda
  112. Why is it harder to fly F3A with wind blowing towards You?
  113. What sunglasses du You use for F3A flying?
  114. OS OCA-1100HV - can I run a high voltage receiver setup?
  115. need the Plettenberg advance 30-10 and Castle Phoenix Edge 80HV settings
  116. general ESC summertime operating questions
  117. Castle Creations Edge 80HV Lite vs the non-lite version
  118. Brake settings for Contra
  119. CG of Invitation/Essence
  120. Screaming Dualsky
  121. Cygnus
  122. Sebart PrometheuS biplane
  123. New Galactika EP/GP plane from Christophe Paysant-Le Roux
  124. Looking for a 10s motor for a sebart mytho s 125e
  125. Passion V2 Yellow
  126. Amadeus
  127. Katana F3A 120e Electric Pattern plane
  128. Q80-13XS Hacker and Master Mezon 90 ESC for sale
  129. Extreme Flight Vanquish 2M
  130. 2m F3A composite planes under $1000
  131. Esc with bec and backup power
  132. Interesting changes in the FAI 2015 Technical Notice F3 Aerobatics, effective May 1
  133. Shell Stamina RL2 grease
  134. Contra Prop Balancing???
  135. F3A float plane?
  136. How to service your Brenner Contra unit in 2 minutes and 30 seconds
  137. BJ CRAFT INVITATION (Electric)
  138. Incidence help
  139. Futaba Skyleaf biplane?
  140. CPLR Axiome 70 biplane?
  141. Xoar carbon fiber F3A PJH-ET props?
  142. Power loss issue with Neu & Jetti Spin 90 light
  143. Sun-shield (spot) for pilot (and judges) when sun in flying sector.
  144. OXAI Final's Touch EP - Assembly
  145. Location of COG in a very stabile trainer ?
  146. F3P World Championships - Poland
  147. aristo-craft sharp 45 pattern/sport plane.
  148. Jeti Mezon with Plettenberg Advance 30-10
  149. mk aurara 25 for sale.
  150. Musette 1m pattern plane from Japan
  151. New Oxai biplanes - Kunzit and Zebec
  152. New Contra Design: Adverrun
  153. New BJCraft Fantasista 110?
  154. black mgic vf3 pattern plane parts
  155. BJ Craft G2 Essence
  156. WTB second hand carbon prop
  157. Galactik 90 By CPLR and Winners Model
  158. Winds S pro Fuse
  159. Alternative to Plettenberg advanced 30-10
  160. Great Planes Sequence 1.20 Build Thread
  161. 3 Blade props
  162. Hacker
  163. Digital throw meters. Anything new?
  164. RTF EPIC for sale
  165. Service Futaba 14mz
  166. New pattern plane from BJCraft
  167. BJ CRAFT new plane PASSION
  168. Box opening BJ Craft Nuance 70..
  169. Hyde mounts
  170. Hyde mounts
  171. Jeti Telemetry with Futaba
  172. Caelus New F3A design by Top RC Model
  173. Nishioka Rosetta F3A monoplane
  174. New lower cost 1.6m pattern plane -- Smoove
  175. What risk running a 5s max outrunner on a 6s Lipo pack?
  176. Thottle curse setting?
  177. COSTCO Generator
  178. 25% off ThunderPower RC
  179. Very lightweight inverter generator for field charging
  180. C50-13XL vs outrunners ?
  181. SD10G TX charger needed
  182. F3AUnlimited and plane selection Setting the record straight
  183. Chip Hyde Finals Touch biplane
  184. FMS F3A Explorer (scaled down Olympus)
  185. OS 100Amp ESC/ Himax 6330 Pro motor settings question
  186. Fitting PT CF prop in a Falcon CF spinner
  187. Contra Powered BJ Craft Nuance
  188. Bullets,Deans or Anderson Power Pole battery connectors?
  189. Sbus or not?
  190. Hobbyking 1.5m practice pattern plane?
  191. Anybody repaint or paint over a BJCraft fuselage?
  192. Sparkless bullett connectors
  193. BJ Craft planes now available to be shipped to Central and South America
  194. Spin 99 Start Power
  195. YGE fire / Programing
  196. Great Planes Sequence 120?
  197. STATUS Bipe
  198. Wing/Stab Incidence?
  199. capacity estimator for sequences ?
  200. BJCraft BiSide 70ep
  201. Kaos conversion video
  202. "Inspire" - Contra Powered Design - BJ Craft
  203. Mystery Bipe by CA Model
  204. BJ Craft Nuance 70
  205. F3AUnlimited website issues mostly resolved 5% discount
  206. BJ Craft Inspire Contra monoplane
  207. Gaudius
  208. Jetti box hook issue with Spin 99
  209. Hacker A60 motor help
  210. Wanted fuse for an Integral pattern plan
  211. Hacker C50 & OCA-1100HV 100A Brushless ESC
  212. Redundant Reciever Battery system
  213. Allure by Bryan Hebert
  214. Extreme Flight Vanquish (Small) wing tube
  215. Motor Temp - How Hot is Too Hot for an Outrunner?
  216. Broken Arrow, OK Pattern Contest
  217. Help please with motor/esc selection
  218. Castle 80HV Edge alternate
  219. Jetibox
  220. Connector change on Hacker A50 16 ... ??
  221. BJ Craft Fantasista 70
  222. Castle Edge 80HV question
  223. Need some help with a Himax HC6330-210
  224. Neu Motor / OS 1100HV Motor Control
  225. Carbon Props
  226. Spare nylon wing bolts - where? (for Sebart MythoS Pro)
  227. futaba 18MZ and Mezon telemetry
  228. Help Setting Fixed End Points with Jeti
  229. Sebart MythoS Pro unboxing, assembly and maiden
  230. Battery placement in fuselage - vertical center of gravity (MythoS Pro)
  231. Fms f3a olympus !
  232. Is it ok to ..
  233. Castle Speed Controlers and Fury F3A motor
  234. Q60 Owner Question
  235. Power with no AC
  236. Anyone play with a Graupner MZ-24 ?
  237. Himax 6330 motor front mount conversion kit
  238. touch screen for Futaba 14MZ Radio
  239. Superstition pattern classic 2014
  240. what is the best charger
  241. scratchbuilt f3a plane
  242. New Spark EVO II on the market....
  243. RC Supersales
  244. Castle Speed Controlers
  245. Anybody experienced on this?
  246. Sbus Wiring in an F3A Model
  247. Castle Link
  248. Axiome 70EP Build Log
  249. Episode motor mounting
  250. Life source batteries
