- Smoked CC HV85 ESC !
- Counter rotating prop
- E. pattern problems
- Futaba R6008HS and Jeti ESCs?
- Wind 110 Upgraded motor
- Delro E-Motion kit
- New GP50" Sequence Electric F3A ARF
- Neu motors in F3a
- Where To Find Sebart Angel S50E?
- new to electric flight need help!!!
- Turnigy Sentilon Question
- Cellpro 10 balancing adapter warning
- Looking for a Pattern Plane
- Which is the best
- Sebart Miss Wind S 50E
- E powered Black Magic VF3
- Jumping Jack Manual
- change Focus Sport to Electric
- Pack wont charge right or
- Drilling Props
- Commercially manufactured arming plug?
- Thunder Power ProPower 30c 10s?
- Measuring the receiver output pulse Width
- Air Outlets
- Dream 110 power setup advise
- New AXI
- Lipo charging schedule
- Schulze Next 10.36-12 Eco Car + FlightPower F3A
- WEB PAGE SPAIN TEAM F3A 2009 WC Portugal
- Firewall for Abbra for Plettenberg Xtra 30-10 EVO
- Hyperion Z5025-22
- Control Throws for Pattern flying
- Cellpro 10 S charger
- Robbe Roxxy Bl Outrunner 6362/10
- Braking
- TrueRC 10C pack compatibility
- RF Filter required?
- MEGA ACn F3A
- QUESTION ABOUT TRIMMING (MIXING)
- Inrunner gear box lube
- Plettenberg Xtra 30-10 EVO
- clever boy
- Xoar Wood PJH-E F3A Electric Propellors
- Hyperion Helios 63a F3a
- Switchmode BEC vs. battery
- Jeti spin 99 or Hacker/Jeti Spin 99?
- Ammo box
- No Spark calculations
- Small pattern plane for winter training
- Oxai Beryll Instruction Manual.
- New batteries from Flight Power
- Castle HV85 manual throttle endpoints
- question on mounting Hacker C50 vs. Plettenberg EVO30-10
- Airfoil to use..
- Neu F3A Motor & Hyde Soft Mount info and pics
- F3A servos
- Determining CG
- Kfactor Electric writeups, I would like
- Turnigy AerodriveXp SK Series 63-64 230Kv / 3150W
- Thunder Power 5200's
- ZN LINE AXIAL
- NEU Engine 1515/2Y F HD6.7:1
- Poly RC batteries from Rclipos.com
- New FlightPower EON F3A 5400 batteries
- Hacker C50-14XL
- Axi 5330/F3A
- Hacker C50-13XL ver. Hacker C50-14XL
- ESC 100 Amp
- DualSky 6360 bearings
- Axi 4130... anyone run one or similar
- Focus Sport electric components
- Contro- Rotating Setup
- Is it LEGAL to fly Commercial with Large Lithium Batteries?
- *Hyperion Katana F3A 90e*
- Need data on airplane
- airframe recommendation for newbie (electric)?
- Compare electric to glow
- Hacker C50-12XL
- Wich Lipo for Hacker A60
- Winter storage of Lipo's
- Deleted
- "Ping" so loud you can hear it inflight
- Power recommendations for an oldie goldie
- True RC 5000's Longevity
- Sebart Angel S50 - Brake or not to Brake!!
- Fliton Element 170 ARF build
- outrunner mount
- Buying Battery Packs
- ESC Timing ?
- Xtra 30 vs Xtra 30 EVO
- motor Hirotex 2500 W/10-R
- Safety question
- Precise Micro Servos Wanted!
- Recommended Setup For a Jeti Spin99 and AxiF3A
- Thinking about electric in my next pattern project
- Sebart Wind 110
- Throttle adjustment problem
- AMA Pattern Max Voltage
- How to fix a AXI F3A in my Cocain
- Jetibox setup
- sebart angel s50
- An electric engine which fails to start properly
- 90-110 Size Electric Power-Setups?
- Jason Shulman-30-10 EVO wins US F3A Nats
- Plettenberg EVO 30-10 rpm confirmation
- Speed Control Fire
- Knoxville TN AMA pattern meet
- Electrical setup
- A123 charger for 11S 2P pack
- sebart angel s50e
- Receivers for electric models
- Hacker C50 mounting
- FAI-F'09 Sequence flown by Jonathan Girabel - SPARK
- Motor struggles to get above idle
- Himax 6332-230 efficiency improvement
- DualSky 11T testing
- E prop options
- masterspin 99 readings in correct ?
- Neu vs. CC 5.5mm bullet connectors
- Oxai Azurit
- Interested in electric pattern
- Does a Metal Spinner make the plane fly better?
- Hacker A60-24S mount recommendation
- New Sebart Wind 110E
- Flightpower pack repair
- Oxai Dymaxion Motor
- Used equipment sites dedicated to Pattern?
- Downline Speed - Braking
- My hats off to 3-D Hobbies!
- Mounting An Axi or Dualski in a Shinden
- Good suppliers
- Sickle f3a
- AXI 5330 F3A - Loose Magnets
- Another Black Magic Maiden
- RF Filter/Choke failure
- I want to get started in Pattern Flying
- BM V3 Maiden flight- Fantastic!
- Sokol balance
- Safe charging system
- Electric motor weights
- Spin 99 / Jeti Box error message
- Castle phoenix 110HV experience?
- Servo choice for a 2 x 2 Electric?
- Plans for F3A
- Is a choke required between an ESC and receiver?
- How do you mount your batteries?
- Battery Carrier
- Chargers/carrier
- Patterns forever !
- 90 4 stroke,Electric Equivalent?
- Hyperion Helios F3A 63e and 10e build thread!!!
- If you can start over, how would you do it?
- Throttle ESC ?
- Hyperion Lipo experience?
- tiger 400
- Dualsky 6360
- Charging system questions
- AXI 8 MM Adapter - Anyone Want a Steel One?
- Another bad day
- Thunder Power eXtreme V2 5000
- Bad day, Good lesson - everyone read
- OT slightly but please advise re batteries
- which parameters for F3A and Jeti Spinn 99
- What is a good hybrid?
- Battery future ?
- Motor & Battery Selection
- P-09 Video - SPARK F3A Jonathan Girabel . SPAIN
- So will Plett, Hacker. Thunderpower, Flightpower et. al. get involved in Motorsport?
- Lipo capacity estimation
- Tenergey 5S 4450mAh 22C LiPo for pattern
- Dualsky 6360 11T Prop numbers
- Eflite 46 questions???
- Power 160 motor
- OUYA-40
- Dualsky 6360 wots watt ??
- Video link and picture about SPARK F3A ,from Spain
- CA Models Epsilon 90 + electric
- Sebart Angel S Evo 50E
- e superpacer build
- Spark F3A, from Krill Models - SPAIN TEAM
- Outrunner Mounting
- Groovy 50 F3A
- Differences in Oxalys 50 ARF nitro and electric versions
- Measuring battery degradation
- Anyone flying electrics in Santa Maria Ca.?
- E Prop Balancing
- Plettenberg 30-10 EVO
- Prop Life
- Pattern Fylying ???????????
- Data Loggers - E Pattern
- What is Balancing?
- motor mount firewall mark GENESIS
- AXI 5330/F3A for 2x2 pattern plane
- F3P in the Dayton Ohio area
- Dualsky 6360-12T props
- AXI - Jetti - TX Range and Prop Noise
- Lipo battery suppliers
- Small Electric Flight Times?
- Interpreting EagleTree data
- Servos for my new Leviosa
- INFORMATION ele engines batteries chrages and balancers
- Which Jeti/hacker ESC for C50x13XL Acro comp
- Sebart Angel
- I'm thinking...
- TP battery question? 5cellx2 or 10 cell x1
- uBEC requirements for digital servos
- Mini Imac would you play?
- High prices of electric motors and batteries
- F3A GWS Formosa maiden!
- Max amp 14.8v 2100mah lipo. What plane?
- Clik 3D(or pattern 3PX) full fuse foamie project
- Chargeing LiPo Batery packs
- Hacker side thrust
- Electric Genesis for sale
- Vanquish cooling
- Connectors
- Atlanta 60 for sale in Northern Virginia
- Fliton Element 30 Kit Critique
- A New counter-rotating Prop by Sebastiano Silvestri
- Info on new TP batteries V2
- 46-50 size electric set-up, post here
- Rumfal on 4S A123
- Vanquish with 4S A123
- Trimming out a 3D/Pattern Plane
- TP5300 longevity
- Vanquish F3a two questions
- Hacker A60-20S SOLD
- cost per flight hour vs. glow
- Aspera vs. Vanquish
- 2100 ma IMAC pattern bird.
- New Batteries?
- Air Boss 45 Amp ESC Programming?
- Help with Hyde mount/Hacker motor
- OXAI Dymaxion F3A motor
- Axi 5320 problems...
- Extreme Flight Vanquish P07 sequence video
- Jeti Spin 99 Cutting Out
- Battery/Balancer question
- Anyone tried Hyperion in a 2x2 yet?
- rules or guides to follow?
- Planes for sale
- Storing Lithuim Polymer batteries
- Black Magic VF3 E build thread!
- Electric power for newbies: A primer anywhere?
- How low can one go?
- Where to buy Hacker C50 14XL motor in NY
- GP Elictric Cub Motor choice ?
- 12S packs for pattern
- Polyquest repairs?
- 3DHobbyshop Aspera on 4S A123
