PDA
View Full Version : Electric Pattern Aircraft
Pages : 1 2 3 4 5 [6] 7 8 9
  1. South Morovian Czech republic
  2. new Axiome??
  3. Battery Choice
  4. Hacker C50 14XLs for sale
  5. Problem with Scorpion 4025-12
  6. 3S For Jaccio Regulator
  7. power supplies
  8. New Angel's Shadow 2010
  9. Servo Extension Between ESC and Rx
  10. Converting Sbach 342 to electric
  11. Intermediate ?
  12. Castle ICE controller and motor timing - No apparent effect on current draw?
  13. How different are all the F3A models?
  14. Gearbox noise from Neu
  15. Wings set for Oxalys Evolution - TS composite
  16. Argentina Nationals Cordoba
  17. ESC braking. Truth vs. perception. Please help!
  18. NEW!! Delro composite line
  19. EC4 connectors or Deans
  20. Neu F3a and CC 85 hv
  21. Motor question regarding "max continuous current"
  22. EFlight Power 160
  23. The secret unveiled! The new Power Unlimited batteries are out!
  24. Best prop for Axi 5330-18
  25. Aerodynamics of a pattern plane
  26. Changing from glow to electric (tips?)
  27. Transmitter outputs to the ESC: What's the scoop?
  28. Hacker c50 14xl w 20X15 APC
  29. Dist 7, 14th Annual BARCS Pattern by the Bay Contest in Richmond
  30. Dist 7, 1st Annual Arvin Pattern Contest
  31. watts/pound for f3a 2 meter plane
  32. Electric 'crappola' thread
  33. Exciting new test thread. Post your test here!
  34. A quick thank-you to RCU.
  35. Jeti 77 Advance Pro Opto vs Castle ICE 80 HV.
  36. OOPS?
  37. Pheonix HV 85 W/ Hacker A60-20S
  38. CC Phoenix 85HV brake settings for AXI 5325 or 5330?
  39. Castle 160A Ice Lite
  40. Simple redundant pwr. Battery + BEC.
  41. Hyperions new LiFePO4. The future of TX/RX packs?
  42. E. spinner option and CF props
  43. How many packs and how many chargers
  44. To BEC or not to BEC.
  45. JR 12 X charging problem
  46. JR 12X battery charging ???
  47. The Plettenberg nose exists. Anyone in the US tried it?
  48. 12X bulletin. Must read for 12X owners.
  49. Venture 60 Electric setup
  50. Mystery knocking noise?
  51. How to get your Rhino to lose weight!
  52. Setting your E-idle. What's your trick.
  53. New Mark Hunt design Hindsight
  54. HobbyKing Batteries in USA
  55. Is 10c 5000mAh package to much?
  56. Good cheap ESC, are there any?
  57. Storage Charge
  58. Cellpro 10S Battery Charger
  59. What is up with Neu?
  60. 5S 20C 4900s (brand x?)
  61. Sebart Wind 50e - MONOPLANE ??
  62. Cheaper batteries, what have we learned?
  63. Is there a good plane for this power combo?
  64. Xtreme Composite Pegasus
  65. Axiome CG
  66. Low C-rate with 1st flights after winter??
  67. Suggest a plane for 3S or 6S 2200mAh LiPo
  68. SebArt Angel S 30e vs Sequence...
  69. e30 size(ish) Pattern plane
  70. Dualsky 6360, anyone using it?
  71. 4 Bladed RASA Folding prop
  72. Convert old Sequel pattern ship to electric?
  73. Vanquish MkII Finished
  74. Otop CG
  75. Temple Tx. contest Canceled
  76. I need help on decision
  77. Batteries - Please Help...
  78. CA Models ENVISION
  79. When to buy batteries?
  80. slowing down for a landing
  81. Post Your Battery Weights
  82. Trial & error matching electric system
  83. Wiring diagram for newbies
  84. For every really pretty plane out there, there is always an ugly one.
  85. New E.F. 48" Vanquish MK II
  86. E flight trimming question, motor thrust
  87. NEU F3A-1 question
  88. Gyroscopic inertia of inrunners vs. outrunners.
  89. Need 8mm collet spinner adapter
  90. New Plettenberg F3A motor
  91. Anyone have an electric Temptation?
  92. Two new F3A outrunners from Hacker
  93. CA Models and F3A Unlimited
  94. SEBART ANGEL 50e
  95. RASA Folding Props advantages???
  96. Paint
  97. Electric Setup for Summit 60
  98. New Jeti Advance 77 Pro Opto. 53g! WOW!
  99. Pass-Port trim
  100. Outrunner versus Inrunner.
  101. Castle Ice ESC's need input
  102. Himax 6330-F3A Pattern Motor
  103. Passport with Power 160
  104. e-Neptuno
  105. Anderson Power Pole Connectors. Have you had a failure or not?
  106. Battery connectors
  107. Cyclon 40??
  108. JETI 99 REG
  109. Focus or Focus Sport video anywhere?
  110. Your experience with Savox servos please.
  111. Hyperion Helios power and expectations
  112. Oxai Amethyst thread
  113. 30C Batteries for F3A
  114. ON SALE CA MODEL PLANES
  115. GWS Motors
  116. Turnigy Aerodrive-Xp SK 63-64 ?
  117. Motors Motors Motors...
  118. lipo minimum temp
  119. Battery Charging for Pattern
  120. Miss Wind Pro, Contra Rotating Prop
  121. schulze and 14mz
  122. another dumb question, how do you know
  123. Delro ADDICTION
  124. Newbery Club Buenos Aires First Class
  125. Carbon gear servos
  126. Turnigy C42-60
  127. Passport 2010
  128. CA Models VISA
  129. Flying with different batteries
  130. APC 20.5x14 electric prop
  131. Scorpion motors for 2x2 model
  132. affect of higher voltage
  133. Electric ZN Line Xigris C2 Build Thread
  134. Gaudius
  135. Power switch for 10s. Any available?
  136. APC-E 21x14 vs. Pt Model 21x14 Carbon
  137. Castle Creations ICE HV ESC
  138. PT Model electric F3A props
  139. CA Models ONAS
  140. Plettenberg 25-12 Evo? Is it enough for most?
  141. Shulze Speed control
  142. Why such a big variation in watts on my Integral?
  143. Neu motor question
  144. Great Planes Sequence F3A gas conversion
  145. Schulze ESCs
  146. Onas by CA Models
  147. Hyperion G3 batteries
  148. Fuse before ESC ?
  149. AXI Motors?
  150. Spektrum A6010 servos
  151. Build Thread-Scratch built for 8s
  152. Hacker outrunner F3A 2m
  153. Graph Tech F3A Landing Gear update
  154. For Sale Neu 1515/3D F HD6.7:1
  155. Bolly Landing Gear Clones
  156. 8s Charge Setup
  157. Thottle Curve on DX-7 for electric
  158. Electric Power Suggestions
  159. Eageltree Elogger and RPM sensor in classified
  160. Delro Emotion
  161. Wind 110 repairs
  162. duplicate
  163. Ordered (well...pre-orderd) my AngelS Evo 50e
  164. RASA Prop Sizing for Neu Motor
  165. winter is coming, what about lipo's?
  166. Lipo Query - Any one help??
  167. Is it Electric really worth the trouble ?
  168. Help me choose some F3A lipo packs
  169. Himax 6330/F3A outer runner test data
  170. Sebart Wind S Pro
  171. TP-ProLite V2-20C 4350 mAh for P11
  172. LiPo Shipping Regs
  173. Venus 40 on a123's
  174. ZN line Axial
  175. New "E" Pattern web site
  176. Hyperion 4020-14
  177. Brio on a123's ?
  178. New Axi 5325/24 test results
  179. Can you help a newbie?!
  180. Zippy Flightmax Batteries
  181. Velcro for battery packs
  182. 2M Electric only planes...?
  183. Plettenberg Xtra 30-10 EVO - Jeti 99 and Brake
  184. Travelling with LIPOS
  185. Great Planes Sequence F3A
  186. Micro Pattern now a reality?
  187. Rhino lipo packs
  188. Chargers
  189. Mini Scalar
  190. Motor calc program
  191. APC E- Props VS Standard APC pattern props
  192. Fast charging
  193. To B(ec) or Not to B(ec)
  194. Castle Creation Phoenix 85HV robustness
  195. 99+ Amps drawn by my Hacker C50-14XL
  196. Batery sparking
  197. again questions about electric pattern
  198. Is 4350 mAh enough for F3A schedules
  199. Himax 6332-230 repair DIY
  200. few questions about an electric pattern
  201. New Hacker Outrunner!!!
  202. ESC Jeti spin opto or CC HV 85
  203. Another Electric site
  204. Hacker A50-16L Question
  205. Hacker C50-14XL cooling fan Problem
  206. Downline Braking : ESC set up query
  207. Dualsky 6360/12 and Jeti OPTO 99
  208. ProLite-V2 5000 10S
  209. Which one?
  210. Hacker XL Maintenance
  211. Turnigy Sentilion 100Amp ESC
  212. Time to convert?
  213. Dave Patric Ultimate conversion to Electric
  214. rhino price reduction!!!!!
  215. Hub for RASA paddles
  216. Set-Up Help
  217. What 30 size pattern plane to choose?
  218. Charger - Battery Protection
  219. 22x13 Electric prop
  220. battery for charging
  221. Thunderpower Packs
  222. Cell IR Meter
  223. Bolly Style undercarts
  224. Crazy question MAYBE !!!!
  225. katana 50e prop?
  226. VenusII Electric Set up
  227. Flightpower EON X LiPo
  228. Fliton
  229. RPM from Hacker 14XL
  230. ZNLine Integral Kit - good for electric setup?
  231. Sickle wing delaminated
  232. Duralite Batteries (Buyers Beware)
  233. New APC 21 x 13.5 E...thanks to Chip H.
  234. Throttle Curve for DX-7
  235. Hacker Prog-Box
  236. YGE 80 HV Speed Controller
  237. Flightmax Packs
  238. Kontronik Jazz63V ESC
  239. Rhino Lipos
  240. Hacker A60 with Jeti Opto Spin 99
  241. 2009 Oxai Amethyst
  242. Laser device
  243. New regulations from DC
  244. c50 13 xl prop
  245. old pattern planes to Electric!
  246. Transmitter choice for electric pattern
  247. Hyperion nano technology batteries
  248. Thunder Power Prolite V2 5300 cycle life comparison
  249. FashionLine conversion?
  250. Optimum Kv for 2 meter motor?
