PDA
View Full Version : Electric Pattern Aircraft
Pages : 1 2 [3] 4 5 6 7 8 9
  1. First Look - Mejzlik Contra-Rotating props for Brenner Contra
  2. Pattern practice plane by FMS
  3. New Tech-Aero Throttle Tech
  4. Sebart Mythos 125e
  5. Axiome 70 EP
  6. How to eliminate battery connection spark
  7. Anyone coming to WRAMS Show have an Electric Airframe for sale ?
  8. Help needed to program Jeti Master Spin Pro 99 Opto
  9. Ozone Shuttle Pro
  10. Servo Advice for a e-50 pattern plane
  11. Astrual bipe from CA models
  12. Anyone tried/using Biela 21x14 electro prop in pattern flying
  13. Jeti Advanced 90 Pro with Hacker Q80-14XS F3A
  14. Brake Setup
  15. What size (scale) airframe?
  16. Shulman Aviation Fury F3A and Himax 210 power
  17. Mangonel Biplanes
  18. First Annual Desert Pattern Challenge
  19. LIFE batteries
  20. Any data on PT model or Mejlik 20X13 three bladed props?
  21. Need help to setup my F3A electric power
  22. Look at this : RayBird 70 with conra drive
  23. New YS 175s
  24. Neu F3A Motor
  25. Mejzlik 20x13EL 3 Blade
  26. Rudder TE
  27. what tool do you use to measue you elevator throws
  28. Motor drive batteries in parallel
  29. Fury F3A
  30. speed controller
  31. New F3A belt driver system from Graupner?
  32. DURAFLY HYPERBIPE. Foamy Electric Pattern practice plane.
  33. OS Motor w 6.7 gear reduction
  34. Throttle-Tech - New product from Tech-Aero Designs LLC
  35. Contradrive Drive
  36. BJ Craft Passion
  37. Few Thunderpower G8 pro lite 25C 5000 mah (10S version) packs for sale
  38. Honda generator rebate
  39. Sk3 motor for sebart wind 50E
  40. Decisions Decisions
  41. Vanquish landing gear ripped out
  42. Servos
  43. Vanquish ultracote color
  44. Landing Gear Vendor?
  45. IITOP 2014 The Epilogue.....
  46. Hokusei Primus 90 V2
  47. Sebart Mythos 2M
  48. Falcon spinner w/ Plettenberg Advance
  49. 2 m vanquish spinner
  50. Plettenberg Advance 30-10 or Hacker Q80-14XS running data
  51. New Himax 6330 Pro motor
  52. Plettenberg parts/service
  53. Himax HC 6320-250
  54. Which Honda Generator
  55. Help selecting a charger
  56. Outrunner throttle curve (endpoints question)
  57. Battery packs - Hows your longevity?!
  58. what type of model is this
  59. ESC question
  60. Securing Batteries in Fuse
  61. My new/used electric Shinden
  62. BJ Craft Motor Mount Questions - ALL Airplanes
  63. SeBart Angel S 50 parts
  64. Hacker A50-16S vs EMax BL4030
  65. Monolog 70 Setup/Flying
  66. 2m pattern plane from general hobbies?
  67. Marquet spinner screws
  68. Eye-opener Zippy Compact incident
  69. Turnigy let down
  70. SEcraft Aluminum Servo Arms
  71. ESC problem?
  72. Questions on Hacker MasterSpin Pro 99, JR 12X, SpinBox
  73. Jeti Box Spin 99 programmer
  74. Jetti Spinn 99
  75. Jeti Master Mezon 95 question: Need Help!!!!
  76. Gear set for futaba s9551 low profile
  77. OS Motor OMA-5025-375 .
  78. Light Batteries for sale
  79. Jeti Mezon ESCs
  80. ESC Failure - What went wrong?
  81. Electric contra-rotating motor
  82. soft mounted Q80
  83. Gaudious canopy
  84. Citrin / Hacker C50 13XL
  85. Aileron servo
  86. Pletty Advance & kontronik jive80 HV malfunction
  87. E-flight Power 90 question
  88. Mislabelled packs?
  89. which wheels
  90. Wind S Pro 2m warped/twisted rudder
  91. Jetti Pro Spin 99
  92. -
  93. Referee or judge in pattern??
  94. A metal part came out of my Hacker A60-7XS motor - advice.
  95. Hacker A60-7S V2 Install in Vanquish
  96. Latest info on generators?
  97. Brio - Glow to Electric
  98. 3 blade prop for Electric ?
  99. How to go about setting up a box?
  100. Adjustable motor mount or just shim it?
  101. LiPo sources
  102. Sentilon 100A HV (V4) esc
  103. Sebart 2M Wind SPro
  104. minimizing effects of wind gusts
  105. 3-1/2" electric carbon spinners
  106. Q80 13XS VS 14XS
  107. Charge to 4.1v/cell
  108. LiPo fire mid-flight
  109. Weird noise from my A60
  110. BJ Craft Fantasista
  111. CC Phoenix Ice2 HV80 problems
  112. new battery questions
  113. mix for landing?
  114. BJ Craft - Nuance 120
  115. Pletty Advance mystery
  116. Hacker A 60 7S V2
  117. armsafe and ESC wire length
  118. ICE HV firmware for Pletty Advance
  119. How many rounds at a typical pattern contest?
  120. Zippiy Compacts
  121. Options for 4S 5000mAh?
  122. This is what it's all about !!
  123. 24V power supplies
  124. New Li-Ion Technology
  125. Charging 'Field Box" for electrics
  126. My New Ride!!
  127. OS ESC & Hacker 14XS compatibility??
  128. 2M Monolog Build
  129. Hacker Q80-14xs & Castle ICE2 80HV settings
  130. TOLEDO SHOW THUNDERPOWER PROMO CODE
  131. Image Loading......................?
  132. Battery Tray set-up
  133. Reflex set Up or Down?
  134. Throttle Curve?
  135. Field Charging
  136. Got my first Falcon prop
  137. Arming switch - advice.
  138. -
  139. E-flight 160 for a Brio ??
  140. Q80-14XS
  141. Battery Question from a new electric pilot
  142. NEW CASTLE CREATIONS ESC
  143. 2m plane for weekend flying
  144. PLETTY 30-10 Advance
  145. props
  146. RE: Os ESC 1100HV
  147. RE: Os ESC 1100HV
  148. Epic Journey
  149. 1600W from 6S?
  150. Faster way to charge 2X10S packs?
  151. BJ Stab Fences
  152. Inine fuses for chargers
  153. Prop Selection and battery life
  154. 4S Practice Plane
  155. 62 osiris trim ?
  156. For Futaba !!
  157. How long in the fridge??????
  158. jetibox mini
  159. Cut cooling slots in CF Spinner
  160. Bruckman sensation.
  161. Where to put the gators front or back
  162. hooking up 2 5000 lips in series
  163. Osiris
  164. Brand new O.S. OCA-1100HV 100Amp 50V ESC
  165. New model Diaguita Biplano
  166. Watt Meter Recommendations
  167. Realflight Pattern Practice Field - give it a try.
  168. Aero-Model Carbon Spinners
  169. Pletenburg 30-10 setup numbers?
  170. 2S packs Question
  171. Jeti Box / Jeti Box Mini
  172. Two 5s packs or 1- 10s pack
  173. 1992 Modeltech Saphir II-4T designed by Wolfgang Matt
  174. Brand new Jeti 99 Spin pro OPTO
  175. A question for OhD
  176. Marquet spinners
  177. Kaos Konversion...too good to be true??
  178. New LiPo Vendor - DINOGY
  179. E-Flite Splendor 50size BNF basic pattern plane
  180. 24V power supply
  181. HK Mi Coreless HV 320oz
  182. Build thread BJ Craft Prolog V2 F3A Unlimited version
  183. Lancaster, CA AMA/F3A and Classic Pattern Contest - Feb. 9 & 10
  184. Formosa 11
  185. Here's a new one....
  186. Anyone need the BJ Craft less swept gear?
  187. RIGHT THRUST
  188. DW Foamies On Axis
  189. Hobby King
  190. HACKER A 60-7S V2
  191. Sebart Miss Wind 50E motor?
  192. Value Hobby Oasis
  193. zippy compact 5000 25c
  194. ASYULER 70
  195. HK Brushless HV Video
  196. HV Magnetic Induction Brushless HK Servo
  197. High quality BEC's made in Canada
  198. BJCraft BISIDE
  199. What is the best electric pattern plane out there right now?
  200. Sebart Mythos 2mtr
  201. Brainstorming for rear Q80 support
  202. CP Leo V2 F3A 110
  203. Nice incidence adjusters
  204. New composit model CONTRAST
  205. New DUALSKY XM6355DA-13 Limited Edition
  206. Need suggestion where to store batteries
  207. charger
  208. Nitroplanes f3a arf
  209. New F3A motor for cheap?
  210. Cell impedance question
  211. New Extra Light Mejzlik Props
  212. Power Supply
  213. Duplicate post-sorry
  214. Rud-Ail mix and slow roll (roll rates)
  215. Propeller size
  216. Kaos Hush Kit
  217. Soldering
  218. Hobby King
  219. Zippy Compact 5S 5000mAH question
  220. Hacker Q80 14xs + CC HV80 doesn't work
  221. Prop recomendations for Himax f3a 210kv
  222. Plettenberg advance 30-10 for sale
  223. Futaba FASSTest
  224. Futaba 18MZ Extra Voltage connection
  225. Pletti advance and downthrust
  226. Battery Tray Ideas
  227. NEW TO ELEC PATTERN ,INFO NEEDED
  228. Balance Discharge Rates
  229. A nice feature for an ESC would be....
  230. Super light props
  231. 10 AWG vs 14 AWG
  232. Accurate charge setting on Cellpro 10s
  233. HP-ZS40 Back Mount
  234. Question about charger balance connectors
  235. Converting my existing BlackMagic V2.2 to electric
  236. Hacker Q80-14XS F3A in the PHOENIX-E CBmodelisme
  237. Wow! Hooked...
  238. wing incidence
  239. Getting started in electric F3A
  240. Last questions before I fly my vanquish
  241. BJCRAFT - MONOLOG 70 FOR 50E -
  242. Converted Black Magic VF3
  243. Pattern Practice plane - Trunk plane
  244. Batteries running-in and swollen batteries
  245. Questions from first time pattern electric
  246. Splendor OXAI-Quique
  247. futaba 9252
  248. Pattern gear, Futaba servos, Tech Aero 6V reg
  249. Neu F3A motors, CC 80 ESC HV V2, Hyde mount
  250. Neu F3A to C50 conversion
