- Pheonix ICE 80-HV Firmware help.
- help with mix digital servos / a123 batt.
- Batteries Available
- using old lipo
- Anyone using the combination Futaba MC9100A and Hacker C50-14
- Settings for Hacker Q80 13XS
- Deans vs. bullets for the battery
- New ESC.
- CC80HV
- Jeti Mezon ESCs
- a123 or life batteries rx and tx
- Futaba 9650 servos for pattern
- New pattern ship recomendation
- 2m vanquish
- 21x14 or 20x13???
- 62" Osiris trim problem
- Newbe Guestion Setup Wind S 110
- Bullet Connector Size
- X - UAV B17
- Oxai citrin
- Electric Conversion from glow
- BJ Craft Monolog 400
- Tower/Hobbico 110 servo experience
- How hot is too hot to fly?
- A60-8S V2 28 Pole Outrunner
- Proposed Masters/ Advanced 2013
- burned 2 ESC in few days, help me solve my problem
- Stab or Stab Adjuster fo 2M Vanquish
- SAVOX SERVOS WITH LiFePo4 BATTERY
- YGE 90HV F3A
- where can we buy JETI Spin 99
- Pletty Advance disassembly
- Square/rectangular winding wire?
- What is a good ESC for f3a
- Jeti Advance 90 Pro Opto ESC for pattern?
- Wanted to buy Cell Pro 10s charger
- First electric?
- Power sources
- CATION F3A
- Gaudious landing gear
- New Falcon props and spinners
- New Griffin by Xtreme Composite
- pics of your Pletty Advance install
- Linear vs. switch mode voltage regulator
- SNAP-ROLL ON AIRTRONICS SD-10G
- Andrew Jesky Precision Flight DVD
- Pattern ship winglet.
- MARQUET 82MM CARBON SPINNER WITH COOLING SLOTS... WHERE TO BUY???
- Who has the power?
- field charging lipos
- How to measure PW
- BIPLANE IDENTIFICATION
- Show us your charging system.
- HobbyKing Turnigy Rotomax 1.60
- Wing and fuse cover for Genesis
- ANYONE USING HACKER Q80-13XS MOTOR???
- SAVOX Servos
- HYK New inrunner motor for pattern plane!
- New Mystic
- FAI F3A Asian Oceanic Competition 2012 invitation
- Mercurio
- hyperion 720i with Parallel charging board
- Neu F3A anyone ??
- Wow! Jeti Mezons! Who else has heard?
- New Battery Warmer
- Dave Snow Wings/Stabs
- redudant rx setup problem
- Basic ESC question
- Plettenberg advance esc settings
- Prolog
- ICE 85 ESC
- Tip: Modifying throttle stick for mechanical brake
- MKS servos in a F3A 2M
- 9303 Fixed Endpoints
- Straight leading edge versus tapered.
- Hacker A-60 S7 v2 mount
- Ordered new batteries . . . we'll see . . .
- Question: Best battery for max RPM and ESCs for constant RPM.
- Charging 5s Zippy packs with Cellpro 10s
- P13 Reverse Spins
- Dualsky Xmotor 6355DA-12T
- Plettenberg ….plenty of them for sale
- Trimming Questions
- Evolution 2 Meter Canopy
- Spark Eliminator
- RX Lipo C rating?
- Ray Bird by Oxai and S2 Pro
- what is the best front mounted motor
- Selling my Wind 110
- retrofitting airframe with new motor
- F3P airo
- Pilot Yak conversion
- D5 Pittsburg, KS contest 6/23, 6/24 2012 (Date Changed!!)
- Parallel Charging
- APC V2 electric props.
- Custom motor shaft help
- Wing adjusters - worn off
- Dream 110 Electric Conversion
- Power issue
- X-Treme Composite Hatta Special 19-13
- Soldering Lipos
- Prop for Neptuno?
- HiMax 6330-200 ESC settings
- Suggestions on the HiMax 6330-200 Motor prop adapter
- Hacker A60-7S V2 28 Pole Motor
- Silver Torque Motor Specs
- what is a cheap f3a 5S 5000mah battery
- AXI 5330 fai
- Setup look over?
- Converted Angels Shadow
- Cellpro 10S charger
- Choosing: Vanquish 2m or Axiome 110
- Squeaky Scorpion
- Experience of using high LiPo charge rates
- Centre of gravity location
- Plettenberg 30-10 evo and Jeti 90
- brio 10
- Toxiris
- IITOP 2012
- What to do? 2m Patternship
- hacker q80 20 o 28 poles?
- Outrunner magnetr a 63-62-250 Electrifly
- strange hacker A50 16L V2
- Iota 55 and cell pro charger
- Extreme Composite Pegasus
- Idle up
- Neu motor for sell
- Monolog 70 Build Thread
- Esc and bec for wind s110?
- N/A
- N/A
- What size motor for Monolog 110?
- A Swarm of Nano Quadrotors
- new spinner idea
- CC ICE2 80HV current reading calibration
- Osiris 2m Flight
- Backup/Redundant batteries
- Kontonik JIVE 120 HV Startup trouble: Any help?
- Newbie to Electric Pattern
- Sebart's new pattern ship MYTHOS
- savox motor
- Hacker Q60 anyone useing it ?
- Falcon 20.5 X 14.5 Light Weight Props
- 12fg again
- Plettenberg Advance and CC80HV
- Cellpro 10XP Issue
- Prolog
- YS To Electric conversion
- New 47.5 monolog from nitro planes
- Install stab adjusters for electric pattern
- New TP Battery for F3A
- Dormoy Flying Bathtube plans from Hanke Iltzsch of Seekonk, Massachusetts.
- 2 Meter Pattern Plane Servos ?
- Futaba MC 9100A ESC
- what is a good charger for charging 10s
- CC 80HV vs Jeti 77 (not Spin) performance?
- Builtup stabs for Integral
- Jett spin set up for pletty advance
- Iota DLS-55 questions
- NEW HOKUSEI MODELs!!!!!!
- perfect linkage geometry
- Neu F3A motor and YGE 90 settings
- New OXAI CITRIN by Wolfgang and Roland Matt
- Builder Wanted!
- opinions on which Nano tech 5S lipo packs
- BLS and 123's
- Gens Ace Mars motors for F3a
- Tx motor settings for electric pattern motors?
- How big of a generator do I need ?
- MasterSpin 99Opto Vs Spin 99Opto
- Osiris CG trhows and expos
- Prolog vs Nuance
- 2 plettys for sale
- HACKER Q-60/CASTLE HV 85 ESC SETTING
- Osiris V2 F3P-AP In the Desert VIDEO
- Are Black Magic Plans Still Available??
- Toxiris ARF
- Eflite motors
- Nuance
- Is there a Hacker expert out there ?
- BJCraft Episode
- Jeti Spin 99 - any updates?
- My New plane Toxiris design by Gerhard Mayer
- Spark Dynamic and EVO I
- Neu Motor/Castle ESC settings
- Lipo charge concern / Use recommendations?
- Prop question
- Which batteries?
- Latest Neu motor housing info request
- Monolog 110
- Aeroworks Stingray cooling ?
- Futuba 12FG
- Need help with my motor install
- Special Edition Hacker MasterSpin 99opto By JETI
- Cellpro 10XP
- New Hacker ESC Senstrol
- Still waiting for Castle Creations ESC replacement...
- Hacker for Pattern Hack
- Vanquish MK II - 48" version
- GEnsACE 5300's
- Alternate ESC's
- Partner 4 Sale
- Black Magic with Inrunner?
- The future of LiPo batteries?!!!?
- In-flight battery voltage
- Tech-Aero Regulators
- Weight issue with Axiome+ EP
- Futaba ESC
- full composite Wind S pro -Sebart
- Motor options!
- TP 5300's
- Temperature of Axi 5325/24 F3A
- Plettenberg maintenance?
- 10S Cell Pro charger
- electric practice plane
- Castle Creations Phoenix Ice HV... send them in to CC.
- Spektrum Dx8
- NEW 1.06M Vizion Pattern Plane
- Combining battery packs?
- ZN line Integral classic electric conversion
- Electric motor-battery-prop calculator
- TP 1010C & Balancer
- DUALSKY F3A MOTOR. Video
- Charging Thunderpower 5000mah 65c 8S lipo
- Safe Storage of Many LiPo's
- Speed control recomendations
- nitro powered f3a plane convert to electric
- New Composite F3A. "NUANCE"
- New Falcon 20.5X14.5 V2 Prop - Light just got lighter
- Replacement Canopy and Cowl for Angel-S 50
- Pattern maneuver geometry
- Help - Lipo Pack Won't Balance
- Wind 110S Won't Accept Stock Hacker A50 16L... Suggestions?
- Debris inside Neu F3a motor?
- Puffy LiPo packs
- A closer look at Gerhard Mayr's Toxylen
- Over Heating??? Ugh
- Hacker Q80 or Plentenberg Advance for F3A ??
- Wind S 110E - Carbon Fiber Landing Gear
- Where to find nylon wing-half securing nuts?
- Spoilerons and Flaperons
- Composite Visa Wings
- 6S + 4S =10S ????
- Updated Castle ICE 80HV
- Kontronik JIVE 80 HV
- To BRAKE or NOT to Brake that is the question?
